Staro 16.05.2006., 00:37   #1
Panzer
Panzer's Avatar
Lokacija: Sv. Nedjelja
Postovi: 1,814
Wink Pomoc u OC mog nortija!!!
Dakle, imam problem... Norti ide samo do 3.0GHz na ovoj ploci... Ja neznam jel stvar u ploci ili procu, te bi htio isprobati a nemam kak...
Znaci trebao bi vasu pomoc, netko tko ima ABIT IC-7 (G,MAX3), ASUS P4C800 - E-DLX, P4P800 - E-DLX ili slicnu plocu koja ide preko 270FSB, da ga testira : sweating. Bilo bi dobro da je u okolici zagreba, samobora...
Hvala
UPGRADED...
MBO: Gigabyte M59SLI-S4 cooled by HR-05 SLI & Zalman ZM-NBF47
CPU: AMD Athlon64 X2 3600+ cooled by Scythe Infinity @ 2.7GHz / 1.25V
RAM:2x 1GB Kingmax DDR2 800
VGA: Sapphire HD3850, 256MB Accelero S1 & 120mm AC @750/1900MHz
HDD:Western Digital 160GB (S-ATA, 8MB)
HDD 2: Western Digital 640GB AAKS
CD/DVD : DVD RW Pioneer DVR-112D Silver (Color match with case)
Powered by OCZ GameXtream 600W
Everything in Chieftec LCX-04SL-SL-A (HDD cooling – 3x92mm Sharkoon, ispuh 1x120mm CoolerMaster)
Coolers controled by Zalman ZM-MFC1
Visual expirience by Samsung 940BW
Notebook: Fujitsu Siemens Amilo Pro V3205 (12", CoreDuo 1.6, 1536MB RAM, 80GB) & Ubuntu 8.04
Audio sistem: Monitor Audio Silver RS1, Monitor Audio PureFlow Speaker Cable, Marantz PM310 pojacalo, Pioneer PD-S501 player, van den Hul M.C. THE BAY C5 Hybrid interkonekt.
Panzer je offline   Reply With Quote
Staro 16.05.2006., 11:48   #2
Renesis
Ex-Gastarbajter
Renesis's Avatar
Lokacija: Zagreb / Rijeka
Postovi: 5,463
si stavio divider meme na 3:2 ili 5:4? meni recimo 3:2 zna raditi probleme.
isto tako, moj neće na 3.6 da ga prikoljem, a na 3.55 radi sa skoro niš struje...
Abit IS7-E + TR NB-1
Homemade vodeno part1
Homemade vodeno part2
Staro 16.05.2006., 22:23   #3
Panzer
Panzer's Avatar
Postovi: 1,814
Autor Renesis
Probao sam oboje...
Na 3.0 ide sa stock voltazom, dalje nece ni da ga ubijes, eventualno kojih 50MHz... Sad neznam jel to ploca sere ili proc, a htio bi znat...
Ajde, pa kaj se nece nitko izivljavat na mom procu?
UPGRADED...
Staro 16.05.2006., 22:30   #4
Pomo
Laughing Man
Pomo's Avatar
Postovi: 3,041
Si probao isključiti PAT? Navodno poboljša overklok, tj isti ne ide preko određenog fsb (250 čini mi se) ako je PAT uključen. Pingaj HR_Swarm_Dude čini mi se da je on o tome nešto više znao.
Staro 16.05.2006., 22:35   #5
Panzer
Panzer's Avatar
Postovi: 1,814
Jesam, i PAT, i mreznu i sve te intergrirana cuda sam iskljucivao ukljucivao, uspio sam ga dobit do 255 FSB, jedva je digo windoze... Naravno, povecavao sam voltazu i na AGP (chipset) i memoriji i procu... Proc sam stavljao do 1.65V, i 1.7...
UPGRADED...
Staro 16.05.2006., 22:37   #6
Renesis
Ex-Gastarbajter
Renesis's Avatar
Postovi: 5,463
evo i ja sam naletio na iste probleme, dođem do 252. stabilno ko kamen, do 255 radi nestabilno ( dual prime puca nakon 30min), preko neće skoro nikako....
ajmo ljudi, dajte savjete, da ne bi ploča na***************ala, jer bi mogao počet lemit po njoj
PAT je isključen/uključen, nema razlika
Staro 16.05.2006., 22:38   #7
Swarm dude
Premium moderator
Swarm dude's Avatar
Postovi: 4,600
Ja bih se htio iživljavati
Kolje me samo što imam 1.6V
Možda je fora do maksimalnog clocka proca,uopće ne može više ma koliko ga god forsao.
Lord clockan je imao 1.8A koji nije htio preko 2.2 Ghz (ako se ne varam) čak niti sa v-modom
MBO: MSI 760GM-E51 FX
VGA: Nvidia Quadro K600
SSD: Crucial BX500 1TB
Staro 16.05.2006., 22:47   #8
Panzer
Panzer's Avatar
Postovi: 1,814
Moguce da je to max clock proca, ali nemogu znat dok kod nekog ne provjerim... A to me grize kaj neznam u cemu je stvar, ploci il procu...
UPGRADED...
Staro 16.05.2006., 23:00   #9
Smartguy
Spiderpig
Smartguy's Avatar
Postovi: 2,043
ja bi ti rado dao ali stvar je nisam iz ZG.
Nego moja otakad sam je uništio neradi DC ali sve ostalo je normalno.
(ne obaziri se na pokoj joj duši u sigu)
Smartguy je offline   Reply With Quote
Staro 16.05.2006., 23:25   #10
Renesis
Ex-Gastarbajter
Renesis's Avatar
Postovi: 5,463
ma nije do proca ,jer je drugima išao preko... ploča mi jako smrdi tu...
vidjet ću još šta se da napravit...
Staro 16.05.2006., 23:37   #11
vga killer
Treba kaj skurit??
vga killer's Avatar
Lokacija: Zgb
Postovi: 4,025
drzali smo masni i ja ploče (P4P800 i P4C800) oko 280 bez beda s prescotom, dok moje đubre od proca nejde preko 3.4 ni s 1.975V.
Panzer - tesko da je do ploče, morala bi ic puno vise
Staro 17.05.2006., 00:03   #12
Panzer
Panzer's Avatar
Postovi: 1,814
Autor vga killer
Vidim, ti imas P4P800 E-DLX, hoces probat moj proc na njoj? Ili cu ga furat k Swarm dude, kad polozim vozacki...
Inace kad stavim na 260FSB, dobijem crni ekran... Sve se normalno vrti u kompu, osim kaj nema slike...
Moram ugasit - upalit komp, i onda se normalno upali i kaze Overclocking failed...
UPGRADED...
Staro 17.05.2006., 00:16   #13
vga killer
Treba kaj skurit??
vga killer's Avatar
Lokacija: Zgb
Postovi: 4,025
probal bi, al sam jos bar 2 tjedna totalno out, jednostavno nemam vremena
Overclocking failed - limit proca, mala voltaza na procu, memorija zeza itd. moze bit svasta
Staro 17.05.2006., 00:19   #14
Panzer
Panzer's Avatar
Postovi: 1,814
Autor vga killer
Ok, nema problema... Idem probat jos nest kemijat po postavkama ploce i tak...
UPGRADED...
Staro 17.05.2006., 17:53   #15
Jerry
Jerry's Avatar
Postovi: 1,816
Ekipa OSTAVITE se dizanja voltaze na D1 Northyu!!! Samo ce te ga s**bat!
Kod rev C1 i B0 bilo je skaliranja s voltazom ali s D1 imate kontra efekt. Recimo probao sam 1.8A B0 i na 1.525V ide 2GHz, na 1.6V ide 2.2GHz, na 1.7V ide na 2.5GHz i preko toga mu nista ne pomaze. Slicno je i s C1.
Prije mjesec dana sam se igrao s bratovim 2.4B D1 jer se poceo rusiti kako je zatoplilo! Pri podizanju voltaze na 1.62V proc je postao stabilan tek na 3.1GHz uz temp 39C load! Na def od 1.5V proc je stabilno radio na 3.2GHz uz 37C load.
Kada sam spustio voltazu na 1.42V proc je stabilno radio na 3.33GHz uz temp od 36C load!
Bilo gdje cete vidjeti na netu da D1 Northy najbolju rezu ima na def voltazi!
Stupid is as stupid does
Jerry je offline   Reply With Quote
Staro 17.05.2006., 20:20   #16
Swarm dude
Premium moderator
Swarm dude's Avatar
Postovi: 4,600
Otišao sam to isprobati,ali mi moje D1 Northie voli veće napone.
Njegov plafon je 3612 MHz na 1.6V, radi stabilno na toj frekvenciji kao kamen, preživio je 7h Primea. Problemi se javljaju kod njega na 3633 MHz i 1.6V, Prime se ruši nakon 20 minuta. Namjestio sam opet 3633 i 1.525V, ali u Primeu se srušio nakon minute i par sekundi.
Staro 17.05.2006., 21:03   #17
vga killer
Treba kaj skurit??
vga killer's Avatar
Lokacija: Zgb
Postovi: 4,025
Ja uvijek prvo frljim proc na visokoj voltazi da se malo privikne i onda polagano spustam...bolje radi nakon toga jer ima nes mozga u njemu, pa si nakon razmisljanja veli...moram radit na nizoj voltazi inace ce me moj glupi gazda opet kurit.
@ swamp dude - fini je to clock. Koja je stepping proca??
Staro 17.05.2006., 21:07   #18
Jerry
Jerry's Avatar
Postovi: 1,816
Kod frenda je radio na 3.4GHz na 1.6V pa onda je morao spustiti na 3.25GHz i sada na 3.13GHz! Ja to ne bih nazvao napretkom i privikavanjem!
Mislim da Burn-In pali samo kod Winbonda
Staro 17.05.2006., 21:10   #19
Swarm dude
Premium moderator
Swarm dude's Avatar
Postovi: 4,600
@vga killer hehe sviđa mi se tvoj način razmišljanja, možda moj shvati da nakon silnog moddanja hoću 3.8 GHz
Moj Northie je SL6PF D1,dakle stock 2.8 GHz i 533 MHz BUS
Evo valiadatora na njegovom "boot maksimumu" http://valid.x86-secret.com/show_oc.php?id=88125
Staro 17.05.2006., 21:15   #20
vga killer
Treba kaj skurit??
vga killer's Avatar
Lokacija: Zgb
Postovi: 4,025
@ Jerry - to se tak ne radi. 1.6V nije nis, treba bar 1.75V.
U isprobavanju max-a kod masnog na vodenom smo ga metnuli na 1.975V pa nek se przi kak spada, al to ne raditi doma
@ Swarm - stvarno si dobro dobio, ovaj moj mulac od 2.4C nece preko 3.4 makar je najbolja serija koja ide bez problema preko 3.6, al ovaj nece.
Staro 17.05.2006., 21:28   #21
Swarm dude
Premium moderator
Swarm dude's Avatar
Postovi: 4,600
Slično sam se i ja poveselio kad sam na netu tražio maksimalan clock svog Northija (samo sam se ja poveselio puno većem clocku ).Na eBayu je neki lik prodavao proc kao i moj i da ide na 4.2 GHz...Bio sam zbilja jako naivan.
Nije ni tvoj clock loš, 3.4 GHz je fenomenalno za 2.4C, BUS ti je sigurno ogroman
Staro 17.05.2006., 21:45   #22
vga killer
Treba kaj skurit??
vga killer's Avatar
Lokacija: Zgb
Postovi: 4,025
je 3.4 super, al ne za ovu moju seriju. Mitzek, RAK, masni i Lord Clockan su imali istog ko moj i njima je iso puno vise tak da sam razočaran, al tak mi svejedno, vise mi se ne da OC-at. Čak mi i memorija radi na 320, a ne na 400
Staro 17.05.2006., 21:50   #23
Swarm dude
Premium moderator
Swarm dude's Avatar
Postovi: 4,600
I meni je isto dosta...Kad se samo sjetim koliko sam vremena uzalud potrošio na testiranje različitih postavki
