Staro 29.03.2026., 12:06   #5341
telefunken
telefunken's Avatar
Datum registracije: Apr 2015
Postovi: 732
njub sam za linux i molim pomoc ko da objasnjavate djetetu:
Instalirao sam Armbian na android STB
zelim instalirati pihole
slijedim tutorial odavde: https://i12bretro.github.io/tutorials/0433.html
kad upisem curl -sSL https://install.pi-hole.net | bash dobijem error: Unable to update package cache. Please try "sudo apt update"
Kad upisem sudo apt update dobijem:
Ign:1 http://security.debian.org buster/updates InRelease
Ign:2 http://httpredir.debian.org/debian buster InRelease
Err:3 http://security.debian.org buster/updates Release
404 Not Found [IP: 199.232.18.132 80]
Ign:4 http://httpredir.debian.org/debian buster-updates InRelease
Ign:5 http://httpredir.debian.org/debian buster-backports InRelease
Err:6 http://httpredir.debian.org/debian buster Release
Err:7 http://httpredir.debian.org/debian buster-updates Release
Err:8 http://httpredir.debian.org/debian buster-backports Release
Hit:9 http://armbian.lv.auroradev.org/apt buster InRelease
Reading package lists... Done
E: The repository 'http://security.debian.org buster/updates Release' does not have a Release file.
N: Updating from such a repository can't be done securely, and is therefore disabled by default.
N: See apt-secure(8) manpage for repository creation and user configuration details.
E: The repository 'http://httpredir.debian.org/debian buster Release' does not have a Release file.
E: The repository 'http://httpredir.debian.org/debian buster-updates Release' does not have a Release file.
E: The repository 'http://httpredir.debian.org/debian buster-backports Release' does not have a Release file.
u repository listi koja se nalayi u /etc/apt/sources.list.d/armbian.list stoji:
deb http://apt.armbian.com/ buster main buster-utils buster-desktop
deb http://security.debian.org buster/updates Releas
zasto ne mogu instalirati pihole i kako da ga instliram
Pošten trgovac
Trgovine: 1, 2, 3, 4, 5, 6, 7
telefunken je offline   Reply With Quote
Staro 29.03.2026., 13:17   #5342
Mihael
Mihael's Avatar
Lokacija: Home
Postovi: 2,190
To je nekakva prastara verzija bazirana na debian 10 buster. Trenutna verzija je 13 (trixe). Zato ti ne radi.
Nadogradi ili instaliraj podrzanu verziju armbiana pa onda dalje
Autor telefunken Pregled postova
Staro 29.03.2026., 14:08   #5343
telefunken
telefunken's Avatar
Postovi: 732
Autor Mihael Pregled postova
Da li je moguće, i kako, tu trenutnu verziju nadograditi na 13 truxie drito iz armbiana? Ili moram opet naći image ali s v13 i s balena-om ga zapisat na sd?
Skinuo sam svoju verziju odavde: https://i12bretro.github.io/tutorials/0185.html
koliko vidim, image s armbianom su rađeni za razne verzije STB uređaja, od onih s Rockchip cipovima do amlogic-a. E sad, dal miram naći baš verziju prilagođenu za svoj chipset ili postiji neki univerzalni koji će raditi?
I bonus pitanje: obzirom kako će mi STB biti samo za pokretanje pihole-a, ne trebam aplikacije na linuxu a ova verzija koju imam je puna svega, dakle trebam neku ful light verziju s kojom smo pokrećem pihole
Pošten trgovac
Staro 29.03.2026., 17:15   #5344
Mihael
Mihael's Avatar
Lokacija: Home
Postovi: 2,190
Kad bi napisao kao ji je uređaj sa kojim cipsetom pa da mogu potražiti?
Da bi nadogradio zamijeni u /etc/apt/sources.list, svugdje gdje pise buster sa trixie i onda
sudo apt update
sudo apt full-upgrade
Staro 30.03.2026., 06:42   #5345
telefunken
telefunken's Avatar
Postovi: 732
sudo apt update
Tanix TX9 Pro (s912 3gb)
Probao sam zamijeniti buster s trixie i updejtat no izbacilo mi je errore nešto kako lib64 dir nije dir već fajl pa sam odlučio potpuno iz početka flashat SD s novom zadnjom verzijom, no sad mi se nije bootao u armbian već u android os pa moram vidjet gdje sam fulao. U međuvremenu sam našao ovaj tutorijal pa ću probat s njime pa javim ako zašteka
Pošten trgovac
Staro 30.03.2026., 07:50   #5346
tomek@vz
White Rabbit
tomek@vz's Avatar
Lokacija: München/Varaždin
Postovi: 5,789
Long story short > pregazi sa novijom verzijom. Sve ostalo ce ti sa tom razinom znanja biti muka (bez uvrede).
Staro 30.03.2026., 09:35   #5347
Mihael
Mihael's Avatar
Lokacija: Home
Postovi: 2,190
https://www.armbian.com/amlogic-s9xx-tv-box/
Dolje imaš minimal verziju i link na sd writing tool sa tutorialom
Staro 31.03.2026., 06:32   #5348
telefunken
telefunken's Avatar
Postovi: 732
Hvala svima na pomoći! Long story short: nanovo sam flashao s najnovijom lite verzijom s armbian.com i ono gdje je sam fulao prvi put je što nisam rename file u-boot-s905x-s912 u u-boot.ext
Uspio sam se normalno bootat u armbian i instalirat pihole
Pošten trgovac
Staro 31.03.2026., 06:37   #5349
tomek@vz
White Rabbit
tomek@vz's Avatar
Postovi: 5,789
Despite being FOSS, Linux distros will often add support for proprietary apps within the operating system. Not only does it make it easier for people to migrate from closed-source operating systems to Linux, but it's also really handy for people who may not want to pick from the open-source options available.
Unfortunately, it turns out that GNOME 50 will scrap a part of its GNOME Online Accounts (GOA) tool that allows people to add Google Drive to Nautilus. However, before you reach for your pitchforks, it's worth noting that it got scrapped because, seemingly, nobody really cares for it.
> GNOME 50 killed Google Drive integration because nobody wanted to maintain it
Archinstall 4.0 is out today and just in time for the April 1 monthly refresh to the Arch Linux installer. With Archinstall 4.0, this Arch Linux OS installer is now using the Textual TUI library rather than the Curses library.
Archinstall 4.0 is now using Textual rather than Curses to provide a more modern text-based user interface. THe developers feel this provides a better looking terminal-based installer for Arch Linux rather than the mature curses library.
> Archinstall 4.0 Released For Improved Arch Linux Installer Using Textual UI
The Arch Linux-based SystemRescue (formerly known as SystemRescueCd) live Linux toolkit for system rescue and recovery tasks has been updated today to version 13, a release that ships with a brand-new kernel, new tools, and various improvements.
Powered by the long-term supported Linux 6.18 LTS kernel series, SystemRescue 13 ships with updated Bcachefs tools and kernel module, and new tools including the FATSort utility for sorting FAT12, FAT16, FAT32, and exFAT partitions, and nss-mdns, a NSS plugin providing host name resolution via Multicast DNS.
> SystemRescue 13 Released with Linux Kernel 6.18 LTS, GParted 1.8.1, and More
Staro 31.03.2026., 06:47   #5350
tomek@vz
White Rabbit
tomek@vz's Avatar
Postovi: 5,789
The framework is published by Germany's Federal Ministry for Digital Transformation and Government Modernisation, and it covers every level of public administration in the country, from federal government bodies down to states and municipalities.
Also keep in mind that the rollout of key infrastructure components is targeted for 2028.
ODF, or OpenDocument Format, is an XML-based file format for office documents. It covers text files, spreadsheets, charts, and graphical documents. The standard is maintained by OASIS and is also an ISO standard (ISO/IEC 26300), which means it is vendor-neutral and not controlled by any single company.
PDF/UA, short for PDF/Universal Accessibility, is the ISO accessibility standard for PDF files (ISO 14289). It lays out specs that make PDF documents readable by assistive technologies like screen readers, making it a sensible choice for a government that has to serve a diverse population.
The reasons behind this are not hard to understand. Vendor lock-in is the obvious one.
> Big Win for Open Source as Germany Backs Open Document Format
Manjaro has long been one of the more popular Arch-based Linux distributions, known for making Arch Linux more accessible to everyday users. But it has been losing ground for years, both in terms of user trust and active contributors, and the complaints about its direction have only gotten louder.
Now, things have hit a breaking point, with calls for a fork if the current leadership does not budge.
A Manjaro team member going by the handle "Aragorn" has published the "Manjaro 2.0 Manifesto" on the official Manjaro forum. The post lays out a detailed restructuring plan for the project that has been signed by 19 team members, including developers, community managers, moderators, and the company's technical lead.
> Manjaro Linux Team Goes on Strike, Threatens to Fork the Project
Staro 31.03.2026., 07:05   #5351
Libertus
Libertus's Avatar
Datum registracije: Jul 2017
Lokacija: Ramura
Postovi: 2,895
Ovo je korak u dobrom smjeru. Treba na razini EU donijeti isto.
Staro 01.04.2026., 17:30   #5352
radi.neradi
Datum registracije: May 2023
Lokacija: Mrkopalj
Postovi: 98
"The future is now old man". Nažalost moramo se prilagoditi ili pravac vlastita distra za specifičnu namjenu koju imaš, nema druge. Ako si na ti sa Cruxom i možeš ovo sve izvesti uz manje muke odaberi tu opciju, nema druge nažalost. Ili...Debian?
1. Inicijativa je urodila plodom na Alma Linuxu.
2026-02-05
18:10.0.0-14.5.alma.1
- Enable QXL device build
- Enable building for ppc64le
- Re-added Spice support
- Don't remove slof.bin for ppc64le
Autor radi.neradi Pregled postova
Prije par godina napravljen je flash Coreboot-a na Thinkpad W530 (Ivy Bridge). Linux je radio kako treba, ali se NetBSD zamrzavao kod povratka iz nekog deep statea, jer kernel ne podržava C6/C7 uopće IIRC (https://man.netbsd.org/acpicpu.4), uz to smo zaključili da se dešava kada CPU počne dizati clockove / voltažu. Vratili smo originalni BIOS jer stvari nisu funkcionirale.
2. Coreboot je sada funkcionalan na Ivy Bridge-u sa *BSD.
radi.neradi je offline   Reply With Quote
Staro 01.04.2026., 18:35   #5353
tomek@vz
White Rabbit
tomek@vz's Avatar
Postovi: 5,789
2026-02-05
Nice
Staro 03.04.2026., 19:20   #5354
tomek@vz
White Rabbit
tomek@vz's Avatar
Postovi: 5,789
Valve's March 2026 Steam Survey shows Linux gaming usage jumping to a record 5.33% share -- more than double macOS's 2.35%. Phoronix reports:
Steam on Linux was never above 5% and easily an all-time high for the Linux gaming marketshare, especially in absolute numbers. It was a massive 3.1% spike in March while macOS also jumped surprisingly by 1.19% to 2.35%. The Steam Survey numbers show Windows losing 4.28%, down to 92.33%.
Part of the jump at least appears to be explained by Valve correcting again the Steam China numbers. Month over month they report a 31.85% drop to the Simplified Chinese language use and English use increasing by 16.82% to 39.09%. Other languages also showed gains amid the massive decline in Simplified Chinese use.
The latest numbers for March show around a quarter of the Linux gamers are running Steam OS. Due in part to the Steam Deck APU being a custom AMD product and the popularity of AMD hardware on Linux for its open-source nature, AMD CPU use by Steam on Linux gamers remains just under 70%.
Staro 03.04.2026., 19:55   #5355
spiderhr
spiderhr's Avatar
Datum registracije: Jul 2021
Lokacija: Sesvete
Postovi: 1,344
Evo usporedbe desktop environmenta...
Mali Čile SAD Češka Peru
Staro 04.04.2026., 07:06   #5356
tomek@vz
White Rabbit
tomek@vz's Avatar
Postovi: 5,789
Evo jedan interesantan benchmark:
> NVMe Performance Compared: Windows Server 2025 vs. Ubuntu Server 24.04.4 LTS
E sad...dosta je nepoznanica kod setupa sa Linux strane (pretpostavka je da je sustav instaliran na LVM+EXT4 setup al se ne spominje nigdje) ali bilo bi interesantno iste testove ponoviti sa optimiranim EXT4 i optimizacijama u I/O Scheduleru te čak i CPU Scheduleru i usporedno sa BTRFS/XFS/ZFS (koji bi bili sporiji). Unatoč tome rezultati su...interesantni .
Staro 05.04.2026., 07:27   #5357
Disco
Prvoklasni Krkan
Disco's Avatar
Postovi: 5,543
E da zab sam dodati za remminu, da to čudo malo radi, malo ne (jedan dan se spoji bez probelma i koliko god puta probam, drugi dan se neće spojiti nikako, probam RDP sa win i odmah prođe). Def nije dobra zamijena za RDP. Šteta da za linux nema pouzdan RDP klijent pošto mi je to neka osnova. Jedino već spomenuti KVM, pa RDP iz win.
Slobodno me dodajte na PSN
Zadnje izmijenjeno od: Disco. 05.04.2026. u 09:22.
Staro 05.04.2026., 08:25   #5358
Bono
Uptime 99.99%
Bono's Avatar
Postovi: 2,843
Autor Disco Pregled postova
E da zab sam dodati za remminu, da to čudo malo radi, malo ne (jedan se spoji bez probelma i koliko god puta probam, drugi dan se neće spojiti nikako, probam RDP sa win i odmah prođe). Def nije dobra zamijena za RDP. Šteta da za linux nema pouzdan RDP klijent pošto mi je to neka osnova. Jedino već spomenuti KVM, pa RDP iz win.
Meni radi odlicno, spajam se na tridesetak masina i sve radi kako treba. Jedino me scaling mucio, ali to drzim na 100% kao neki kompromis.
Sent from my SM-S931B using Tapatalk
Bono je online   Reply With Quote
Staro 06.04.2026., 08:27   #5359
tomek@vz
White Rabbit
tomek@vz's Avatar
Postovi: 5,789
It's finally time: a patch queued into one of the development branches ahead of the upcoming Linux 7.1 merge window is set to finally begin the process of phasing out and ultimately removing Intel 486 CPU support from the Linux kernel. Anyone still using an i486 CPU with an upstream Linux kernel would be incredibly rare and no known Linux distribution vendors are still shipping with i486 CPU support, but in case you are, you can continue to be running one of the existing Linux LTS kernel versions.
> Linux 7.1 Expected To Begin Removing i486 CPU Support
Timed for Easter this year is the seventh weekly release candidate for the Linux 7.0 kernel. If all goes well, Linux 7.0 stable will be out next week.
The Linux 7.0 cycle has been rather heavy with fixes but Linus Torvalds has expressed optimism over releasing on time that would put the stable release out next week on 12 April. But if things don't go well over the next week. there is the always the possibility of an extra release candidate and then releasing instead on 19 April.
As for what's new in Linux 7.0-rc7, there is improved security documentation focused on helping AI agents produce better security/bug reports. Linux 7.0-rc7 also has more graphics driver fixes, Razer Wolverine V3 Pro and Betop KP50 controller support due to just needing new device IDs added to the XPad driver, and a performance fix for the Atheros/Qualcomm Ath11k and Ath12k drivers for an issue that has existed since the drivers were introduced, and various other fixes.
> Linux 7.0-rc7 Released With Improved Docs For AI Agents, WiFi Driver Performance Fix
Staro 06.04.2026., 08:28   #5360
tomek@vz
White Rabbit
tomek@vz's Avatar
Postovi: 5,789
Jesi gledao što logovi kažu? Nikad nisam osobno takvih problema imao.
Staro 06.04.2026., 11:20   #5361
Dule
Dule's Avatar
Postovi: 782
Ili probaj xfreerdp i probaj se igrati sa parametrima? Remmina je samo UI za xfreerdp koji ima puno parametara s kojima se možeš igrati, npr. ovo je moja naredba za work:
Code:
xfreerdp3 /cert:ignore /bpp:32 /network:lan /audio-mode:0 /sound:sys:pulse /scale:180 /monitors:0 /floatbar:sticky:off /gfx:RFX /log-level:FATAL /timeout:30000 +f -themes -wallpaper -grab-keyboard \
/d:"DOMAIN" \
/v:"10.0.0.20" \
/u:"pero" \
/p:"perinpassword"
Dule je offline   Reply With Quote
Staro 09.04.2026., 01:50   #5362
spawn
spawn's Avatar
Postovi: 8,618
Linux OS - info, how-to, pitanja, novosti, savjeti, problemi...
Pitanje za znalce. Imam uefi dualboot na 2 diska zorin18 +win 10. Postoji li nacin da maknem zorin18 i stavim mint/ubuntu ili mozda nesto drugo da malo isprobam sta mi odgovara od distri a da ne zeznem dualboot ? Na linuxu sam noob, pa nisam siguran da necu nesto zeznut, mozda ima neki tool da napravim backup prije cackanja ako se to uopce moze
Zadnje izmijenjeno od: spawn. 09.04.2026. u 02:03.
Staro 09.04.2026., 13:21   #5363
tomek@vz
White Rabbit
tomek@vz's Avatar
Postovi: 5,789
Autor spawn Pregled postova
Ak je Uefi Boot samo pregazi postojece particije i NE FORMATIRAJ /boot/efi (koristi bez formatiranja). U tom folderu imas EFI/zorin (valjda) folder kojeg naknadno mozes izbrisat i to je to. Ja sam tak imal UEFI boot za svo moguće UEFI kompatibilno govno, Linux, Windows, BSD, nikad problema.
Staro 09.04.2026., 13:38   #5364
Cuky
jedan i jedini :D
Cuky's Avatar
Lokacija: novi zagreb
Postovi: 5,348
Al cak i da pogazi postojeci uefi nova instalacija bootloadera bi trebala pokupiti sve postojece instalacije gore.
Staro 09.04.2026., 14:30   #5365
Ivo_Strojnica
PRO
Ivo_Strojnica's Avatar
Postovi: 5,008
tako je, mogu potvrditi, kad sam nakon Zorin + Win, dodao još i Fedoru, pa onda još i obrisa nakon toga Zorin.
Sve hvata i updatea.
Staro 09.04.2026., 15:58   #5366
spawn
spawn's Avatar
Postovi: 8,618
Napravit cu backup fajlova koji su mi bitni pa cu malo kemijati. Hvala
Staro 09.04.2026., 18:43   #5367
Cuky
jedan i jedini :D
Cuky's Avatar
Postovi: 5,348
Nemas sta kemijati. Pokrenes klasicnu instalaciju minta/ubuntua/cegavec i kad te pita na koji disk/particiju zelis instalirati samo odaberi ovaj gdje ti je vec ZorinOS.
Staro 09.04.2026., 20:16   #5368
tomek@vz
White Rabbit
tomek@vz's Avatar
Postovi: 5,789
Autor Cuky Pregled postova
Osim ak je Windows bootloader na istoj particiji.
Staro 09.04.2026., 20:47   #5369
spawn
spawn's Avatar
Postovi: 8,618
Jasno hvala, ali svakako radim backup. Tko jednom izgubi podatke radi backup i bez potrebe
Edit: malo za noobse kao ja ili za one koji bi voljeli probat ali ne da im se cackati pa vracat winse. www.distrosea.com nudi online probu da ljudi vise manje vide zele li uopce isprobati linux.
Zadnje izmijenjeno od: spawn. 10.04.2026. u 00:08.
Staro 10.04.2026., 08:47   #5370
spiderhr
spiderhr's Avatar
Lokacija: Sesvete
Postovi: 1,344
Sad stavio na komp lxqt
Da vidimo kako se on ponaša.
