#5341 |
Datum registracije: Apr 2015
Postovi: 732
njub sam za linux i molim pomoc ko da objasnjavate djetetu: Instalirao sam Armbian na android STB zelim instalirati pihole slijedim tutorial odavde: https://i12bretro.github.io/tutorials/0433.html kad upisem curl -sSL https://install.pi-hole.net | bash dobijem error: Unable to update package cache. Please try "sudo apt update" Kad upisem sudo apt update dobijem: Ign:1 http://security.debian.org buster/updates InRelease Ign:2 http://httpredir.debian.org/debian buster InRelease Err:3 http://security.debian.org buster/updates Release 404 Not Found [IP: 199.232.18.132 80] Ign:4 http://httpredir.debian.org/debian buster-updates InRelease Ign:5 http://httpredir.debian.org/debian buster-backports InRelease Err:6 http://httpredir.debian.org/debian buster Release 404 Not Found [IP: 199.232.18.132 80] Err:7 http://httpredir.debian.org/debian buster-updates Release 404 Not Found [IP: 199.232.18.132 80] Err:8 http://httpredir.debian.org/debian buster-backports Release 404 Not Found [IP: 199.232.18.132 80] Hit:9 http://armbian.lv.auroradev.org/apt buster InRelease Reading package lists... Done E: The repository 'http://security.debian.org buster/updates Release' does not have a Release file. N: Updating from such a repository can't be done securely, and is therefore disabled by default. N: See apt-secure(8) manpage for repository creation and user configuration details. E: The repository 'http://httpredir.debian.org/debian buster Release' does not have a Release file. N: Updating from such a repository can't be done securely, and is therefore disabled by default. N: See apt-secure(8) manpage for repository creation and user configuration details. E: The repository 'http://httpredir.debian.org/debian buster-updates Release' does not have a Release file. N: Updating from such a repository can't be done securely, and is therefore disabled by default. N: See apt-secure(8) manpage for repository creation and user configuration details. E: The repository 'http://httpredir.debian.org/debian buster-backports Release' does not have a Release file. N: Updating from such a repository can't be done securely, and is therefore disabled by default. N: See apt-secure(8) manpage for repository creation and user configuration details. u repository listi koja se nalayi u /etc/apt/sources.list.d/armbian.list stoji: deb http://apt.armbian.com/ buster main buster-utils buster-desktop deb http://security.debian.org buster/updates Releas zasto ne mogu instalirati pihole i kako da ga instliram |
#5342 | |
Lokacija: Home
Postovi: 2,190
To je nekakva prastara verzija bazirana na debian 10 buster. Trenutna verzija je 13 (trixe). Zato ti ne radi. Nadogradi ili instaliraj podrzanu verziju armbiana pa onda dalje Citiraj:
#5343 | |
Postovi: 732
Skinuo sam svoju verziju odavde: https://i12bretro.github.io/tutorials/0185.html koliko vidim, image s armbianom su rađeni za razne verzije STB uređaja, od onih s Rockchip cipovima do amlogic-a. E sad, dal miram naći baš verziju prilagođenu za svoj chipset ili postiji neki univerzalni koji će raditi? I bonus pitanje: obzirom kako će mi STB biti samo za pokretanje pihole-a, ne trebam aplikacije na linuxu a ova verzija koju imam je puna svega, dakle trebam neku ful light verziju s kojom smo pokrećem pihole |
#5344 |
Lokacija: Home
Postovi: 2,190
Kad bi napisao kao ji je uređaj sa kojim cipsetom pa da mogu potražiti? Da bi nadogradio zamijeni u /etc/apt/sources.list, svugdje gdje pise buster sa trixie i onda sudo apt update sudo apt full-upgrade |
#5345 | |
Postovi: 732
Probao sam zamijeniti buster s trixie i updejtat no izbacilo mi je errore nešto kako lib64 dir nije dir već fajl pa sam odlučio potpuno iz početka flashat SD s novom zadnjom verzijom, no sad mi se nije bootao u armbian već u android os pa moram vidjet gdje sam fulao. U međuvremenu sam našao ovaj tutorijal pa ću probat s njime pa javim ako zašteka |
#5346 | |
White Rabbit
Lokacija: München/Varaždin
Postovi: 5,789
#5347 | |
Lokacija: Home
Postovi: 2,190
Dolje imaš minimal verziju i link na sd writing tool sa tutorialom |
#5348 |
Postovi: 732
Hvala svima na pomoći! Long story short: nanovo sam flashao s najnovijom lite verzijom s armbian.com i ono gdje je sam fulao prvi put je što nisam rename file u-boot-s905x-s912 u u-boot.ext Uspio sam se normalno bootat u armbian i instalirat pihole |
#5349 | |||
White Rabbit
Postovi: 5,789
> SystemRescue 13 Released with Linux Kernel 6.18 LTS, GParted 1.8.1, and More |
#5350 | ||
White Rabbit
Postovi: 5,789
> Big Win for Open Source as Germany Backs Open Document Format Citiraj:
> Manjaro Linux Team Goes on Strike, Threatens to Fork the Project |
#5351 | |
Datum registracije: Jul 2017
Lokacija: Ramura
Postovi: 2,895
#5352 | ||
Datum registracije: May 2023
Lokacija: Mrkopalj
Postovi: 98
1. Inicijativa je urodila plodom na Alma Linuxu. 2026-02-05 18:10.0.0-14.5.alma.1 - Enable QXL device build - Enable building for ppc64le - Re-added Spice support - Don't remove slof.bin for ppc64le Citiraj:
#5353 |
White Rabbit
Postovi: 5,789
#5354 | ||
White Rabbit
Postovi: 5,789
#5355 |
Datum registracije: Jul 2021
Lokacija: Sesvete
Postovi: 1,345
Evo usporedbe desktop environmenta...
Mali Čile SAD Češka Peru |
#5356 |
White Rabbit
Postovi: 5,789
Evo jedan interesantan benchmark: > NVMe Performance Compared: Windows Server 2025 vs. Ubuntu Server 24.04.4 LTS E sad...dosta je nepoznanica kod setupa sa Linux strane (pretpostavka je da je sustav instaliran na LVM+EXT4 setup al se ne spominje nigdje) ali bilo bi interesantno iste testove ponoviti sa optimiranim EXT4 i optimizacijama u I/O Scheduleru te čak i CPU Scheduleru i usporedno sa BTRFS/XFS/ZFS (koji bi bili sporiji). Unatoč tome rezultati su...interesantni . |
#5357 |
Prvoklasni Krkan
Postovi: 5,544
E da zab sam dodati za remminu, da to čudo malo radi, malo ne (jedan dan se spoji bez probelma i koliko god puta probam, drugi dan se neće spojiti nikako, probam RDP sa win i odmah prođe). Def nije dobra zamijena za RDP. Šteta da za linux nema pouzdan RDP klijent pošto mi je to neka osnova. Jedino već spomenuti KVM, pa RDP iz win. Zadnje izmijenjeno od: Disco. 05.04.2026. u 09:22. |
#5358 | |
Uptime 99.99%
Postovi: 2,843
Sent from my SM-S931B using Tapatalk
#5359 | ||
White Rabbit
Postovi: 5,789
#5360 | |
White Rabbit
Postovi: 5,789
#5361 |
Postovi: 782
Ili probaj xfreerdp i probaj se igrati sa parametrima? Remmina je samo UI za xfreerdp koji ima puno parametara s kojima se možeš igrati, npr. ovo je moja naredba za work: Code:
xfreerdp3 /cert:ignore /bpp:32 /network:lan /audio-mode:0 /sound:sys:pulse /scale:180 /monitors:0 /floatbar:sticky:off /gfx:RFX /log-level:FATAL /timeout:30000 +f -themes -wallpaper -grab-keyboard \ /d:"DOMAIN" \ /v:"10.0.0.20" \ /u:"pero" \ /p:"perinpassword" |
#5362 |
Postovi: 8,618
Linux OS - info, how-to, pitanja, novosti, savjeti, problemi...
Pitanje za znalce. Imam uefi dualboot na 2 diska zorin18 +win 10. Postoji li nacin da maknem zorin18 i stavim mint/ubuntu ili mozda nesto drugo da malo isprobam sta mi odgovara od distri a da ne zeznem dualboot ? Na linuxu sam noob, pa nisam siguran da necu nesto zeznut, mozda ima neki tool da napravim backup prije cackanja ako se to uopce moze ![]() Zadnje izmijenjeno od: spawn. 09.04.2026. u 02:03. |
#5363 | |
White Rabbit
Postovi: 5,789
#5368 |
White Rabbit
Postovi: 5,789
#5369 | |
Postovi: 8,618
Jasno hvala, ali svakako radim backup. Tko jednom izgubi podatke radi backup i bez potrebe ![]() Edit: malo za noobse kao ja ili za one koji bi voljeli probat ali ne da im se cackati pa vracat winse. www.distrosea.com nudi online probu da ljudi vise manje vide zele li uopce isprobati linux. Zadnje izmijenjeno od: spawn. 10.04.2026. u 00:08. |
#5370 |
Lokacija: Sesvete
Postovi: 1,345
Sad stavio na komp lxqt ![]() Da vidimo kako se on ponaša.
