Staro 25.01.2026., 23:12   #5161
tomek@vz
White Rabbit
tomek@vz's Avatar
Postovi: 5,574
An anonymous reader shared this article from the blog Linuxiac
In a blog post, Alan Pope, a longtime Ubuntu community figure and former Canonical employee who remains an active Snap publisher... [warns of] a persistent campaign of malicious snaps impersonating cryptocurrency wallet applications. These fake apps typically mimic well-known projects such as Exodus, Ledger Live, or Trust Wallet, prompting users to enter wallet recovery phrases, which are then transmitted to attackers, resulting in drained funds.
The perpetrators had originally used similar-looking characters from other alphabets to mimic other app listings, then began uploading "revisions" to other innocuous-seeming (approved) apps that would transform their original listing into that of a fake crypto wallet app.
But now they're re-registering expired domains to take over existing Snap Store accounts, which Pope calls "a significant escalation..."
I worked for Canonical between 2011 and 2021 as an Engineering Manager, Community Manager, and Developer Advocate. I was a strong advocate for snap packages and the Snap Store. While I left the company nearly five years ago, I still maintain nearly 50 packages in the Snap Store, with thousands of users... Personally, I want the Snap Store to be successful, and for users to be confident that the packages they install are trustworthy and safe.
Currently, that confidence isn't warranted, which is a problem for desktop Linux users who install snap packages. I report every bad snap I encounter, and I know other security professionals do the same — even though doing so results in no action for days sometimes... To be clear: none of this should be seen as an attack on the Snap Store, Canonical, or the engineers working on these problems. I'm raising awareness of an issue that exists, because I want it fixed... But pretending there isn't a problem helps nobody.
Staro 28.01.2026., 21:04   #5162
Mario92
Omicron Alpha resident
Mario92's Avatar
Lokacija: Bistra
Postovi: 5,136
Razočarenje - Certilia middleware paket ima samo u .deb formatu, nema .rpm. Kaj, nemrem znači na Fedori niš oko toga napraviti nativno?
Ryzen 7 5700G
AsRock B550 Pro4
Kingston A2000 1TB NVMe
Intel 660p 1TB NVMe
Fortron Hexa 400W
Random PC case
Proxmox VE
Fujitsu U7311
Intel i5 1135G7
16GB DDR4 3200MHz
SK Hynix P31 Gold 1TB
13.3" FHD IPS
Staro 28.01.2026., 21:42   #5163
domy_os
domy_os's Avatar
Postovi: 19,023
Alienom ga pretvori, imao sam isti problem dok je još bio eID Middleware tamo negdje prije 5-6 godina.
RAM: 2 x 16 GB DDR4-3200
WLAN: Intel Wi-Fi 6 AX201
LCD monitor: AOC AG493UCX
SB: Mackie Onyx Producer 2x2
Speakers: 2 x JBL LSR305
MFP: Canon Pixma MP240
Staro 28.01.2026., 21:51   #5164
tomek@vz
White Rabbit
tomek@vz's Avatar
Postovi: 5,574
Autor Mario92 Pregled postova
Debian i AUR (Arch). Interesantan izbor. I cini mi se dosta staro jer kao meduovisnost ima prastaru libjpeg biblioteku. Ukratko ima vise nacina kako rijesiti ovaj problem:
1. Alien
Code:
       sudo alien --to-rpm certiliamiddleware_3.9.8-2_amd64.deb --scripts
certiliamiddleware-3.9.8-3.x86_64.rpm generated
sudo rpm -ivh certiliamiddleware-3.9.8-3.x86_64.rpm
error: Failed dependencies:
        libjpeg.so.8()(64bit) is needed by certiliamiddleware-3.9.8-3.x86_64
        libjpeg.so.8(LIBJPEG_8.0)(64bit) is needed by certiliamiddleware-3.9.8-3.x86_64
E sad - verzija koja je u Fedori je dosta novija:
Code:
       ls -l /usr/lib/libjpeg.so.62
lrwxrwxrwx. 1 root root 17 Sep  3 02:00 /usr/lib/libjpeg.so.62 -> libjpeg.so.62.4.0
Od toga nazalost nema vajde ovaj put. Legitimno pitanje je zasto umjesto AUR paketa ne naprave RPM za RedHat bazirane sisteme ili Appimage/Flatpak.
2. Wine
Skines .exe in lupis
Code:
wine Certilia_Middleware_v3.9.9.exe
E sad posto nit imam citac kartica nit kaj u tom smjeru nebrem vise od toga testirat.
Staro 28.01.2026., 22:19   #5165
Dule
Dule's Avatar
Postovi: 738
DEB i RPM nisu ništa drugo nego arhive, mogu se raspakirati sa 7z. Raspakiraj ih i vidi što je unutra, pa probaj dodati librarye koji fale (folder sa libraryima se može podesiti sa LD_LIBRARY_PATH env varijablom).
Dule je offline   Reply With Quote
Staro 28.01.2026., 23:23   #5166
tomek@vz
White Rabbit
tomek@vz's Avatar
Postovi: 5,574
Autor Dule Pregled postova
Tocno (ili ar -x na Linuxu na primjer). No znas onu staru Dependency Hell...takve operacije su moguce al treba pazit da se ne skrse sistemske biblioteke nativne za distru. Pocetnicima takva kemijanja nebih preporucio. Da vidis onda belaja . Kad bi imao src negdje mogao bih kreirat RPM za Fedoru kroz OBS al nisam nista nasao.
Code:
       /Downloads$ tree
├── certiliamiddleware_3.9.8-2_amd64.deb
├── control
│   ├── control
│   ├── md5sums
│   ├── postinst
│   ├── postrm
│   ├── preinst
│   └── prerm
├── control.tar.zst
├── data
│   ├── etc
│   │   ├── apt
│   │   │   └── sources.list.d
│   │   │       └── certilia.sources
│   │   └── xdg
│   │       └── autostart
│   │           └── certiliasigner.desktop
│   ├── opt
│   │   └── certiliamiddleware
│   │       ├── certificates
│   │       │   ├── AKDCARoot.pem
│   │       │   ├── CERTILIA.pem
│   │       │   ├── HRIDCA2025.pem
│   │       │   ├── HRIDCA.pem
│   │       │   ├── KIDCA.pem
│   │       │   ├── TESTAKDCARoot.pem
│   │       │   ├── TESTCERTILIA.pem
│   │       │   ├── TESTHRIDCA2025.pem
│   │       │   ├── TESTHRIDCA.pem
│   │       │   └── TESTKIDCA.pem
│   │       ├── CertiliaClient
│   │       ├── CertiliaSigner
│   │       ├── lib
│   │       │   ├── libQt6Core.so.6
│   │       │   ├── libQt6DBus.so.6
│   │       │   ├── libQt6Gui.so.6
│   │       │   ├── libQt6Network.so.6
│   │       │   ├── libQt6PrintSupport.so.6
│   │       │   ├── libQt6Widgets.so.6
│   │       │   └── libQt6XcbQpa.so.6
│   │       ├── licenses
│   │       │   ├── BoostLicense.txt
│   │       │   ├── gSOAPLicense.pdf
│   │       │   ├── JasPerLicense.txt
│   │       │   ├── libxml2License.txt
│   │       │   ├── MiddlewareLicense
│   │       │   ├── OpenSSLLicense.txt
│   │       │   ├── PantheiosLicense.txt
│   │       │   └── QTLicense.TXT
│   │       ├── pkcs11
│   │       │   └── libCertiliaPkcs11.so
│   │       └── plugins
│   │           ├── imageformats
│   │           │   ├── libqjp2.so
│   │           │   └── libqjpeg.so
│   │           ├── platforms
│   │           │   └── libqxcb.so
│   │           ├── printsupport
│   │           │   └── libcupsprintersupport.so
│   │           ├── tls
│   │           │   ├── libqcertonlybackend.so
│   │           │   └── libqopensslbackend.so
│   │           └── xcbglintegrations
│   │               ├── libqxcb-egl-integration.so
│   │               └── libqxcb-glx-integration.so
│   └── usr
│       ├── bin
│       │   ├── certiliaclient -> /opt/certiliamiddleware/CertiliaClient
│       │   └── certiliasigner -> /opt/certiliamiddleware/CertiliaSigner
│       ├── lib
│       │   └── akd
│       │           └── pkcs11
│       │               └── libEidPkcs11.so -> /opt/certiliamiddleware/pkcs11/libCertiliaPkcs11.so
│       └── share
│           ├── applications
│           │   ├── certiliaclient.desktop
│           ├── ca-certificates
│           │   └── akd
│           │       ├── AKDCARoot.crt -> /opt/certiliamiddleware/certificates/AKDCARoot.pem
│           │       ├── CERTILIA.crt -> /opt/certiliamiddleware/certificates/CERTILIA.pem
│           │       ├── HRIDCA2025.crt -> /opt/certiliamiddleware/certificates/HRIDCA2025.pem
│           │       ├── HRIDCA.crt -> /opt/certiliamiddleware/certificates/HRIDCA.pem
│           │       ├── KIDCA.crt -> /opt/certiliamiddleware/certificates/KIDCA.pem
│           │       ├── TESTAKDCARoot.crt -> /opt/certiliamiddleware/certificates/TESTAKDCARoot.pem
│           │       ├── TESTCERTILIA.crt -> /opt/certiliamiddleware/certificates/TESTCERTILIA.pem
│           │       ├── TESTHRIDCA2025.crt -> /opt/certiliamiddleware/certificates/TESTHRIDCA2025.pem
│           │       ├── TESTHRIDCA.crt -> /opt/certiliamiddleware/certificates/TESTHRIDCA.pem
│           │       └── TESTKIDCA.crt -> /opt/certiliamiddleware/certificates/TESTKIDCA.pem
│           ├── doc
│           │       ├── BoostLicense.txt -> /opt/certiliamiddleware/licenses/BoostLicense.txt
│           │       ├── changelog.Debian.gz
│           │       ├── copyright -> /opt/certiliamiddleware/licenses/MiddlewareLicense
│           │       ├── gSOAPLicense.pdf -> /opt/certiliamiddleware/licenses/gSOAPLicense.pdf
│           │       ├── JasPerLicense.txt -> /opt/certiliamiddleware/licenses/JasPerLicense.txt
│           │       ├── libxml2License.txt -> /opt/certiliamiddleware/licenses/libxml2License.txt
│           │       ├── OpenSSLLicense.txt -> /opt/certiliamiddleware/licenses/OpenSSLLicense.txt
│           │       ├── PantheiosLicense.txt -> /opt/certiliamiddleware/licenses/PantheiosLicense.txt
│           │       └── QTLicense.TXT -> /opt/certiliamiddleware/licenses/QTLicense.TXT
│           ├── keyrings
│           │   └── certilia-2025.gpg
│           └── pixmaps
├── data.tar.zst
└── debian-binary
34 directories, 74 files
Dakle raspakiras data.tar.zst i nakon ovih koraka stvar sljaka nativno:
Code:
sudo cp -rv data/opt/certiliamiddleware/ /opt/
sudo cp -rv data/usr/bin/* /usr/bin/
sudo cp -rv data/usr/lib/akd/ /usr/lib/
sudo cp -rv data/usr/share/applications/certilia* /usr/share/applications/
sudo cp -rv data/usr/share/ca-certificates/ /usr/share/
sudo cp -rv data/usr/share/keyrings/ /usr/share/
sudo cp -rv data/usr/share/pixmaps/certiliaicon.png /usr/share/pixmaps/
       /usr/bin/certiliaclient
Dali ce autentifikacija i ostalo radit...testiraj.
Zadnje izmijenjeno od: tomek@vz. 28.01.2026. u 23:46.
Staro 29.01.2026., 01:05   #5167
Mario92
Mario92's Avatar
Lokacija: Bistra
Postovi: 5,136
Thanks svima, Certilia je up and running
E sad, jel koristitie nekaj OS-native za elektronički potpis?
Tipa znam da Papers od GNOME-a podržava digitalni potpis, pa i LibreOffice, ali natjerati da skuži certifikat sa smart carda jednostavno ne kužim.
Kod Winsa mi je to lagano, middleware importa cert u personal store i to "just works", ovde baš i ne.
U Firefoxu sam otišel pod Privacy & Security -> Security -> Security Devices i tam sam loadao Certiliu, i tak sam npr uspel se prijaviti na egrađani i na Certilia portal prek FF-a. Sad bi još nekak htel skužiti kak iskoristiti cert s kartice.
(inače, već sam riješil potpisivanje prek e-Signa i mobile app-a jer mi je bilo hitno, ovo sad mi je više vježba i prilika za učenje pa se pravimo da mi još uvek to treba )
Ryzen 7 5700G
AsRock B550 Pro4
Intel 660p 1TB NVMe
Fortron Hexa 400W
Random PC case
Proxmox VE
Fujitsu U7311
Intel i5 1135G7
16GB DDR4 3200MHz
13.3" FHD IPS
Staro 29.01.2026., 07:15   #5168
domy_os
domy_os's Avatar
Postovi: 19,023
Misliš na potpisivanje kao u Adobe Readeru?
Staro 29.01.2026., 07:57   #5169
strikoo
strikoo's Avatar
Postovi: 1,056
strikoo je offline   Reply With Quote
Staro 29.01.2026., 12:23   #5170
BlackDwarf
BlackDwarf's Avatar
Lokacija: Novska
Postovi: 2,452
Da li je onda ispravan samo iz njihovog alata ili je ispravan i kroz Adobe ili neki drugi alat?
BlackDwarf je online   Reply With Quote
Staro 29.01.2026., 12:27   #5171
Postovi: 8,655
Malo po malo i ne bude dugo trebalo da se Linux dodatno nametne kao bolji izbor za gaming dio priče.
Open Gaming Collective forms to enhance Linux gaming + GOG calls Linux its “next major frontier”
The OGC aims to establish a unified set of software components that will become the standard across various Linux distributions within the gaming community. Founded by ASUS's Linux division, Universal Blue / Bazzite, ChimeraOS, Nobara, Playtron, Fyra Labs, PikaOS, and ShadowBlip, the OGC team is focused on a universal goal of bringing Linux gamers a better experience. The basic concept involves all members contributing software updates across the stack and standardizing certain areas to improve game and device compatibility. The newest collective aims to make gaming on Linux much smoother, similar to what Valve did with its SteamOS and Proton compatibility layer.
Last month, GOG came under new ownership. The company became independent from CD Project and now falls under the leadership of its new owner, Michał Kiciński. While GOG’s mission remains unchanged, to make games live forever, the company can now pursue this goal with greater vigour. GOG sells DRM-free on its storefront and ensures that all of its games run on modern versions of Windows. With its GOG Preservation Program, the company has even updated and improved legacy titles to make them playable on modern hardware.
This approach is unlike Steam, which currently sells many games that aren’t compatible with modern OS’s without fan-made updates or mods. GOG fans have been asking for a dedicated Linux client for some time. Now, it is clear that a Linux version of GOG Galaxy is part of the company’s 2026 strategy. However, it remains unclear when GOG Galaxy’s Linux version will be released.
Izvor: TechPowerUp i OC3D
AMD Ryzen 9 9950X | Noctua NH-U12A chromax.black | MSI MAG B650 Tomahawk Wi-Fi | 128GB Kingston FURY Beast DDR5-5200 | 256GB AData SX8200 Pro NVMe | 22TB WD Red Plus | Fractal Define 7 Compact | Seasonic GX-750
Staro 29.01.2026., 14:27   #5172
radi.neradi
Datum registracije: May 2023
Lokacija: Mrkopalj
Postovi: 93
LibreOffice.
libreoffice za signing moze koristit pki db u koji rucno importas certifikat uz pomoc pkcs11-tool u ~/.pki/nssdb/cert9.db (procitaj pkcs11.txt u direktoriju ff profila) ili mozes koristit firefox profil sa vlastitom db (iirc key4.db) koja se popuni nakon prve uspjesne autorizacije. metodu koristenja db i lokaciju ff profila definiras u libreoffice postavkama. oba nacina rade, ali je drugi jednostavniji. moze se desiti da libreoffice povremeno zablokira pin jer ima neadekvatan retry mehanizam ili neku logicku gresku kod upisa pina, pa uradi unlock sa pukom kroz CertiliaClient jer pkcs11-tool iako podrzava --unlock-pin - kod mene ne radi. iz nekog razloga potpisivanje dokumenata koji se salju na nias se prihvacaju samo sa non-repudiation certifikatom. ako se dobro sjecam potpis sa pkcs11-tool prolazi.
skine se .deb, ar -x, u security devices ide libEidPkcs11.so, u certifikate AKDCARoot.pem i HRIDCA2025.pem, na sistem pcscd za komunikaciju - uradis pcsc_scan da vidis prepoznaje li pcscd smart card reader. firejail radi sa 'noblacklist /run/pcscd' i 'whitelist /run/pcscd/pcscd.comm'
Zadnje izmijenjeno od: radi.neradi. 29.01.2026. u 18:04.
radi.neradi je offline   Reply With Quote
Staro 29.01.2026., 15:09   #5173
yossariane
yossariane's Avatar
Datum registracije: Oct 2021
Lokacija: Grobinština
Postovi: 78
https://joeyh.name/code/alien/
disleksija i disgrafija su mi vrline.
yossariane je offline   Reply With Quote
Staro 29.01.2026., 15:30   #5174
tomek@vz
White Rabbit
tomek@vz's Avatar
Postovi: 5,574
Autor yossariane Pregled postova
Katkad se pitam jel cita uopce tko sve postove ovdje....
Staro 29.01.2026., 19:05   #5175
yossariane
yossariane's Avatar
Postovi: 78
Nije moja krivnja, kad sam otvorio forum njegov post je bio zadnji. Kad sam poslao svoj post bio je ispod njegovog. Tko je kriv nemam pojma.
Staro 02.02.2026., 08:05   #5176
tomek@vz
White Rabbit
tomek@vz's Avatar
Postovi: 5,574
Windows has long been the default choice for PC gamers, but that grip is beginning to loosen. Linux gaming is surging, not only because of growing frustration with Windows 11, but also due to Valve's major inroads in making Linux a more viable gaming platform, driven by optimizations developed for the Steam Deck. To cater to this expanding community, Nvidia is doing its part and has now launched a GeForce Now Linux client in beta.
Nvidia announced plans to bring GeForce Now to Linux at CES 2026 a few weeks ago. The service was already available on Linux-powered handhelds like the Steam Deck, but it is now also supported on general Linux distributions for desktops and laptops.
> Nvidia launches official GeForce Now client for Linux in beta
Staro 02.02.2026., 10:21   #5177
Cuky
jedan i jedini :D
Cuky's Avatar
Lokacija: novi zagreb
Postovi: 5,310
Very nice. Tko bi rekao da ce se u tako malom vremenskom razdoblju pocet desavat tako velike stvari za linux desktop 🙂
Staro 02.02.2026., 10:26   #5178
d0X
Kostolomac
d0X's Avatar
Postovi: 1,576
Sviđa mi se ova OGC inicijativa. Riječju velikog mislioca Wanderleia Silve: "Swoon...".
PSN Steam
Staro 02.02.2026., 10:30   #5179
Piksa
Piksa's Avatar
Lokacija: Chakovec
Postovi: 501
Da, sve to ide u dobrom smjeru. Samo ovi veliki igrači poput Autodeska i sličnih budu jako tvrd orah.
Piksa je offline   Reply With Quote
Staro 02.02.2026., 10:34   #5180
Bono
Uptime 99.99%
Bono's Avatar
Postovi: 2,780
Vide i veliki kakav je kaos napravljen na win 11, a i korisnicima je dosta. Linux desktop je po prvi puta presao 4% market share. A unknown od kojeg bi isto dobad dio mogao biti linux je od pocetka prosle godine skocio sa 6% na 15%.
Sent from my SM-S931B using Tapatalk
Bono je online   Reply With Quote
Staro 02.02.2026., 11:05   #5181
Cuky
jedan i jedini :D
Cuky's Avatar
Postovi: 5,310
Autor Piksa Pregled postova
Mogli bi oni lagano se pocet otvarat prema linuxu kad vide da svi dizu sidro.
Staro 02.02.2026., 11:41   #5182
Disco
Prvoklasni Krkan
Disco's Avatar
Postovi: 5,475
F5 je kriv
Slobodno me dodajte na PSN
Staro 02.02.2026., 12:04   #5183
Postovi: 8,655
Autor Cuky Pregled postova
Da, jer kak je krenulo što dalje tim gore, obzirom da se zakrpane zakrpe dodatno trebaju pokrpati, a i nakon toga još uvijek ništa nije riješeno.
Microsoft confirms more Windows PCs cannot shut down after recent updates
Staro 02.02.2026., 12:09   #5184
mamutarka
ODUZIMAM VAM RIJEČ
mamutarka's Avatar
Postovi: 13,583
kako ne
Staro 02.02.2026., 12:13   #5185
Postovi: 8,655
Ček, još stignu izbaciti zakrpu koja i to onemogućava, pa se mora zvati HEP da dođu provjeriti trafostanicu.
Staro 02.02.2026., 12:53   #5186
Bono
Uptime 99.99%
Bono's Avatar
Postovi: 2,780
Moras traziti dopustenje kako bi izgasio kompjuter, jer vise nije my computer nego this pc.
Staro 02.02.2026., 13:06   #5187
tomek@vz
White Rabbit
tomek@vz's Avatar
Postovi: 5,574
Upravo to mi se na sluzbenom Elitebooku dogada. Dodem na lokaciju, vadim lap - prazni. Kak u pi-pi-pi kad znam da sam ga preko noci napunio. Ok punjac i deri. Dodem doma - updejti, odradim sta trebam - ugasim - poklopim lap i spremim u ladicu. Poslije prckam po routeru nesto vidim lap je online - WTF??? Pogledam u ladicu govno radi...e reko bem ti znas koga.
Staro 02.02.2026., 13:09   #5188
Postovi: 8,655
Nema tu više nikakvog pravila s tim kaj izvode i makar imam podešeno Windows Update pauziranje na 5 tjedni, koliko najviše ide zapravo, na kraju dana to ionak ništ ne znači, jer ovi u međuvremenu naprave još veću štetu s tim pokrpanim zakrpama za koje kasnije trebaju tzv. hotfix za interim-fix.
Staro 02.02.2026., 13:25   #5189
Dule
Dule's Avatar
Postovi: 738
Sad bi vi još htjeli odlučivali kad bi gasili vlastita računala
Staro 04.02.2026., 21:56   #5190
Dule
Dule's Avatar
Postovi: 738
mkey, da se prebacimo u pravu temu
Zanimljiv post ono sa zswap, evo kod mene, 64 GiB memorije, 8 GiB zswap.
Code:
~ >> ./zswapinfo.sh
Physical memory:      66,814,242,816 bytes
Buffers and cache:    65,308,741,632 bytes / 97.7% of physical memory
Unallocated:          65,275,002,880 bytes / 97.7% of physical memory
Compressed:                   12,288 bytes /  0.0% of physical memory
Decompressed size:             4,096 bytes /  0.0% of decompressed memory
Compression ratio: 0.333
Code:
~ >> cat /proc/meminfo
MemTotal:       65248284 kB
MemFree:        63913312 kB
MemAvailable:   63890352 kB
Buffers:           65500 kB
Cached:           563964 kB
SwapCached:            0 kB
Active:           367048 kB
Inactive:         295580 kB
Active(anon):     104480 kB
Inactive(anon):        0 kB
Active(file):     262568 kB
Inactive(file):   295580 kB
Unevictable:       67112 kB
Mlocked:               0 kB
SwapTotal:       8388604 kB
SwapFree:        8388604 kB
Zswap:                 0 kB
Zswapped:              0 kB
Dirty:                56 kB
Writeback:             0 kB
AnonPages:        100144 kB
Mapped:           154180 kB
Shmem:             71356 kB
KReclaimable:      28168 kB
Slab:             110112 kB
SReclaimable:      28168 kB
SUnreclaim:        81944 kB
KernelStack:        6448 kB
PageTables:         4728 kB
SecPageTables:      2380 kB
NFS_Unstable:          0 kB
Bounce:                0 kB
WritebackTmp:          0 kB
CommitLimit:    41012744 kB
Committed_AS:     461544 kB
VmallocTotal:   34359738367 kB
VmallocUsed:      178844 kB
VmallocChunk:          0 kB
Percpu:             7200 kB
HardwareCorrupted:     0 kB
AnonHugePages:      4096 kB
ShmemHugePages:        0 kB
ShmemPmdMapped:        0 kB
FileHugePages:     45056 kB
FilePmdMapped:     32768 kB
CmaTotal:              0 kB
CmaFree:               0 kB
Unaccepted:            0 kB
Balloon:               0 kB
HugePages_Total:       0
HugePages_Free:        0
HugePages_Rsvd:        0
HugePages_Surp:        0
Hugepagesize:       2048 kB
Hugetlb:               0 kB
DirectMap4k:      302848 kB
DirectMap2M:     5396480 kB
DirectMap1G:    62914560 kB
Code:
~ >> sudo ps_mem
 Private  +   Shared  =  RAM used    Program
 24.0 KiB + 252.5 KiB = 276.5 KiB    init
152.0 KiB + 211.5 KiB = 363.5 KiB    sx
168.0 KiB + 217.5 KiB = 385.5 KiB    clip.sh
148.0 KiB + 252.5 KiB = 400.5 KiB    busybox
444.0 KiB + 358.5 KiB = 802.5 KiB    xsettingsd
576.0 KiB + 271.5 KiB = 847.5 KiB    xclip
748.0 KiB + 766.5 KiB =   1.5 MiB    agetty (3)
872.0 KiB + 701.5 KiB =   1.5 MiB    doas
  2.4 MiB + 202.5 KiB =   2.6 MiB    bash
  2.7 MiB + 821.5 KiB =   3.5 MiB    login
  7.4 MiB + 186.5 KiB =   7.5 MiB    systemd-udevd
  5.9 MiB +   4.1 MiB =   9.9 MiB    openbox
  7.8 MiB +   7.8 MiB =  15.6 MiB    tint2 (2)
 15.5 MiB +   5.4 MiB =  20.9 MiB    conky (3)
 23.9 MiB +   4.4 MiB =  28.3 MiB    termite
 72.1 MiB + 763.5 KiB =  72.9 MiB    Xorg
 63.1 MiB +  13.1 MiB =  76.2 MiB    node-MainThread (2)
                        243.5 MiB
Na što točno ode 1.2 GiB kad se komp boota, nemam pojma. u ps_mem se vidi aplikacije koje se pokreću. Isti setup na 12GiB rama je na bootu trošio oko 400 MiB, a davno dok sam imao 512 MiB RAM-a sličan setup je trošio ispod 80 MiB (doduše na 32-bitnom OS-u)
Valjda što više rama kernel je "slobodniji" što se tiče cachiranja, iako nemam pojma što točno stavlja u memoriju.
