Staro 09.12.2014., 11:21   #1
Alph4Dawg
Addicted to music.
Alph4Dawg's Avatar
Postovi: 1,782
Catalyst 14.12 WHQL Omega
Novi 'Catalyst Omega' driveri su dostupni za download!
Nove stvarcice:
Virtual Super Resolution (VSR)
Video playback enhancements
5K LCD Panel Support
Frametime Frame Pacing enhancements
Performance optimizations for APUs
Performance optimizations for Dedicated graphics cards
Performance Optimizations versus AMD Catalyst 14.9 WHQL
Sid Meier's Civilization: Beyond Earth performance optimizations - Mantle API activated for ultimate performance in Sid Meier's Civilization: Beyond Eart
Call of Duty: Advanced Warfare performance optimizations - Up to 30% performance increases with FXAA and lower game resolutions
Optimized AMD CrossFire Profile update for improved performance - Assassin's Creed Unity performance optimizations
Single GPU performance improvements - Optimized AMD CrossFire Profile update for improved performance
Dragon Age: Inquisition performance optimizations - Up to 15% performance increase in single GPU scenarios with Anti-Aliasing enabled.
Far Cry 4 performance optimizations - Up to 50% performance increase in single GPU scenarios with Anti-Aliasing enabled.
Vise o tome:
klikni ovdje
Download:
klikni ovdje
All you have is your fire and the place you need to reach.
Don't you ever tame your demons, always keep them on a leash.
Alph4Dawg je offline   Reply With Quote
Staro 15.12.2014., 13:53   #2
segregator
Propali Amigaš
segregator's Avatar
Lokacija: Nin
Postovi: 7,007
Staro 12.03.2015., 03:20   #3
HCS
Premijum
HCS's Avatar
Postovi: 1,360
Ok, pitat cu ovdje jer mi se trentuno to dogada na ovoj verziji drivera. Naime, prilikom OC-a preko MSI AB-era, kartica prihvati OC i u Gpu-zu se vide zadane vrijednosti, ono sto mene je muci to da nakon nekog izvjesnog vremena frekvencije vracaju na stock, konkretno je to na 7950 sa OC-a 1100/1400 vraca na defaultnih 880/1250, tek nakon restarta mogu dobit ponovo OC vrijednosti, i to opet na ograniceno doba ma koliko god puta u AB-u potvrdivao OC. Vrlo cudan i iritantan problem, probano sa vise Ati kartica, na svima ista stvar se pojavljivala. Sa GTX 760 nikakvih problema nije bilo sto se toga tice.
Imam osjecaj da me neke power saving feature atijev hebe?
Staro 12.03.2015., 06:02   #4
esc
Lynnfield
Datum registracije: Sep 2012
Postovi: 1,023
Autor HCS Pregled postova
klasika,još nisu riješili a zadnja verzija trixx-a ni ne radi u win 8.1,meni samo spusti napon na default 1031 i normalno to me izbaci
esc je offline   Reply With Quote
Staro 12.03.2015., 12:11   #5
HCS
Premijum
HCS's Avatar
Postovi: 1,360
Autor esc Pregled postova
Cek, to je onda do drivera, windowsa ili OC tool-a?
Staro 12.03.2015., 16:08   #6
esc
Lynnfield
Postovi: 1,023
neznam do čega je,trixx zadnja verzija mi se nije htjela pokrenut u win8.1,msi ab me isto zezao...još uvijek nisu ništa riješili(drivere,oc tool,windows,igre) a to se provlači već ohoho vremena
Staro 12.03.2015., 22:23   #7
BoobZ
BoobZ's Avatar
Datum registracije: Feb 2012
Lokacija: VK
Postovi: 174
Meni MSI AB radi savršeno na Win 8.1 sa Omega 14.12
BoobZ je offline   Reply With Quote
Staro 13.03.2015., 15:23   #8
jopis
gadget freak
jopis's Avatar
Lokacija: Jasenovac
Postovi: 2,224
Autor BoobZ Pregled postova
Ma rade i trixxx i ab, samo znaš onu, nije kriv sw i hw, ima nešto i u korisniku
jopis je online   Reply With Quote
Staro 13.03.2015., 16:42   #9
esc
Lynnfield
Postovi: 1,023
Autor jopis Pregled postova
trixx zadnji meni ne radi a za vrijeme hardline bete me je izbacilo iz igre jer je napon bacilo na default a taktovi oc-a su ostali
nvidia je bolja,pogotovo šta se tiče drivera
Staro 13.03.2015., 18:07   #10
HCS
Premijum
HCS's Avatar
Postovi: 1,360
Probat cu s trixxom jos eventualno, ali mi se to vec na par atica dogadalo s ovim driverima, cudno da vec dugo nema novih, mozda nesto.propustam, neznam. Savjeti slobodno. Ali da, nvidia je po pitanju drivera za dva koplja iznad, makar i ona ima svojih musica.
Staro 13.03.2015., 20:51   #11
esc
Lynnfield
Postovi: 1,023
nema dugo amd drivera,kao da su ovi savršeni a nisu....sad će vjerojatno izbacit nove za battlefield hardline
Staro 18.03.2015., 20:10   #12
dinos3
Dino Saur
dinos3's Avatar
Datum registracije: Jan 2012
Postovi: 941
Takoder
dinos3 je offline   Reply With Quote
Staro 25.03.2015., 04:12   #13
Smoki_Gs
Smoki_Gs's Avatar
Datum registracije: Aug 2008
Lokacija: Gospić
Postovi: 452
Samo ukratko da kazem da sam skinuo i probao novu CCC betu 15.3,i obrisao ju nakon 15 min.. Nisam nikakve testove pokusavao,prije instaliranja sam igrao "The Crew",i kad sam stavio te drivere,igra se nije htjela pokrenut 3 puta za redom. Vratio Omegu staru,sve radi iz prve.. Tako da nisam ni pokusavao druge stvari..
EDIT:Nije mi vrag dao mira... Maknuo sam Omegu opet,stavio 15,3 ponovo,i danas sam igrao FC4,The Crew,Dota2,i sve je bilo bez greske... Vrag zna sto mu je bilo prvi put...
Zadnje izmijenjeno od: Smoki_Gs. 28.03.2015. u 06:01.
