Imam problem koji se ne javlja cesto al me zeza i hocu to riješiti, pa trebam vašu pomoc.
Otprilike jednom tjedno iz cista mira mi se pojavi blue screen, nemogu povezati s nicim...kad radim u bilo kom programu il je u mirovanju... temperature su ok i u pcwizardu i na dodir. kad se pojavi blue screen ne stignem ništa procitati, jer se odmah restarta. I napocetku ispiše da je bila greška...al ja tu nemogu ništa iscitati... E sad pitanje, postoji li negdje zabisano što ga ruši i kako to riješiti?
Konfa..pod moj komp. Instalirani su win7, prije bila vista i isti problem.
Hvala, pozdrav!
Pronašao sam dump fajl, al nemogu ga otvoriti (.dmp)
a error - u event viweru (The previous system shutdown at 0:36:41 on 28.1.2010. was unexpected.)
Microsoft (R) Windows Debugger Version 6.11.0001.404 AMD64
Copyright (c) Microsoft Corporation. All rights reserved.
Loading Dump File [D:\MEMORY.DMP]
Kernel Summary Dump File: Only kernel address space is available
Symbol search path is: *** Invalid ***
* Symbol loading may be unreliable without a symbol search path. *
* Use .symfix to have the debugger choose a symbol path. *
* After setting your symbol path, use .reload to refresh symbol locations. *
Executable search path is:
* Symbols can not be loaded because symbol path is not initialized. *
* The Symbol Path can be set by: *
* using the _NT_SYMBOL_PATH environment variable. *
* using the -y <symbol_path> argument when starting the debugger. *
* using .sympath and .sympath+ *
*** ERROR: Symbol file could not be found. Defaulted to export symbols for ntkrnlmp.exe -
Windows 7 Kernel Version 7600 MP (4 procs) Free x64
Product: WinNt, suite: TerminalServer SingleUserTS
Built by: 7600.16385.amd64fre.win7_rtm.090713-1255
Machine Name:
Kernel base = 0xfffff800`02a5f000 PsLoadedModuleList = 0xfffff800`02c9ce50
Debug session time: Thu Jan 28 00:37:22.568 2010 (GMT+1)
System Uptime: 0 days 2:19:00.472
Loading Kernel Symbols
Loading User Symbols
PEB is paged out (Peb.Ldr = 00000000`7efdf018). Type ".hh dbgerr001" for details
Loading unloaded module list
* Bugcheck Analysis *
Use !analyze -v to get detailed debugging information.
*** ERROR: Module load completed but symbols could not be loaded for Ntfs.sys
*** ERROR: Symbol file could not be found. Defaulted to export symbols for fltmgr.sys -
*** ERROR: Module load completed but symbols could not be loaded for eamon.sys
***** Kernel symbols are WRONG. Please fix symbols to do analysis.
*** Your debugger is not using the correct symbols ***
*** In order for this command to work properly, your symbol path ***
*** must point to .pdb files that have full type information. ***
*** Certain .pdb files (such as the public OS symbols) do not ***
*** contain the required information. Contact the group that ***
*** provided you with these symbols if you need this command to ***
*** work. ***
*** Type referenced: nt!_KPRCB ***
*** work. ***
*** Type referenced: nt!KPRCB ***
*** work. ***
*** work. ***
*** work. ***
*** work. ***
*** work. ***
*** work. ***
Probably caused by : eamon.sys ( eamon+6c33 )
Followup: MachineOwner
ide jedino "open crash dump"
Machine Name:
*** work. ***
*** work. ***
*** work. ***
*** work. ***
*** work. ***
*** work. ***
*** work. ***
*** work. ***
Zadnje izmijenjeno od: domy_os. 31.01.2010. u 00:06.
Machine Name:
Kernel base = 0xfffff800`02a19000 PsLoadedModuleList = 0xfffff800`02c56e50
Debug session time: Sat Jan 30 21:26:11.892 2010 (GMT+1)
System Uptime: 0 days 9:27:25.796
PEB is paged out (Peb.Ldr = 000007ff`fffdb018). Type ".hh dbgerr001" for details
*** work. ***
*** work. ***
*** work. ***
*** work. ***
*** work. ***
*** work. ***
*** work. ***
*** work. ***
Probably caused by : ntkrnlmp.exe ( nt!FsRtlQueryMaximumVirtualDiskNestingLevel+66d )
prevrtio sam memtest, sve ok
maknuo nod, počistio registry i instalirao BitDefender
za sad je ok, sad čekam dal će se opet pojaviti...
EDIT:
ali, pojavio se opet...proguglat cu ntkrnlmp.exe možda nađem rješenje
Machine Name:
*** work. ***
*** work. ***
*** work. ***
*** work. ***
*** work. ***
*** work. ***
*** work. ***
*** work. ***
Zadnje izmijenjeno od: domy_os. 31.01.2010. u 00:07.
Razlog: spajanje postova
I dalje ne mogu naci rješenje.
i dalje se javlja, al svaki put druga greška...
(zadnje) Probably caused by : Ntfs.sys
Ako netko ima ideju, što uciniti.....?
Zahvaljujem.
Zahvaljujem.
Kolko sam vidio po netu, dosta ljudi ima takvih problema, posebice na Win x64, ali i u Visti 64. Većinom se radi o nekim softverskim problemima, odnosno driverima (pogotovo za grafičku). Neznam koje verzije drivera imaš, pa probaj neku drugu verziju staviti, al imaj na umu da ponekad i najnovija verzija drivera i nije najbolja.
Ako ovo neda nikakve rezultate, probaj defragmentirati registry sa tuneup utilities programom i ostale korisne sistemske programe koji su tamo, a možda da probaš staviti i novi bios na matičnu.
Zahvaljujem.
Nadam se da si memtest pustio da skenira bar 2 passa, možeš i HD Tuneom provrtiti error scan sistemskog diska, može biti da imaš bad sector.
Memtest86+ je toliko nepouzdan da to nije normalno. Ako zelite iole sigurne rezultate s tim testicem trebate ga ostaviti da radi bar 6-8h.
Kod mene ni to nije pomagalo (testiroa sma danima) , sve je bilo "OK" a komp se srusi iz cista mira dva-tri puta dnevno ili jednom u 3 dana , totalno random. Kao sto napisah tamo Goldmemory mi je nasao greshe i sa tim screen grabovima sam dobio drugi RAM i od ond anema problema.
Dal to mogu i s neregistriranim goldmemory?
probat cu i fizicki testirat...prvo jedna plocica tjedan dana pa druga... pa da vidim.
Hvala na odgovorima.
Nemam pojma, ja sam imao neki stariji Hirens Boot CD i na njemu je bio GM.
Autor Dizel
Meni je tek nakon 7-8h pokazao greske na prvim krepanim Ballistix Tracerima.
Ja sam vrtio i po 15-16 sati - stavim navecer prije spavanja i prekinem kad se vratim s posla i nista, nema gresaka na Memtestu .
Problem riješen, problem je bio u memoriji.
Testirao sam fizički samo s jednom pločicom i nakon 10 dana komp je radio bez greške, a s drugom pločicom, blue screen svaki drugi dan. Na kraju je i memtest pokazao greške, al tek nakon 10 sati...
Zamjenu sam riješio bez problema...poštom poslao u Esys (s Protisovim računom i opisom kvara) i nakon tjedan dana na adresu mi je stigla nova memorija :-)
Hvala svima na savjetima
