Staro 11.09.2004., 01:09   #1
Veky
Veky's Avatar
Datum registracije: Nov 2002
Postovi: 1,950
BSPlayer 1.01 i BSPlayer Pro 1.01
http://www.bsplayer.org
Eto, poceli su naplacivat ali samo za pro verziju:
BSplayer Pro version is released!
BSplayer Pro has all great features of BSplayer, plus:
customizable Equalizer
support for capture/tuner devices and capture to file
integrated subtitle editor
network file buffering
Izasla 1.01 verzija:
BSplayer version 1.01 (10 Sep 2004)
BSplayer version 1.01 Build 811 is released.
Here are the changes:
- EQ preamp value is now remembered
- fixed bug with playlist when realative paths were used
- fixed problem with smooth scroll (BSplayer enabled it at start)
- fixed some problems with mpeg2 files
- fixed problem with aspect ratio when window was moved to other monitor
- fixed strange bug with playlist in Win 9x (explorer or any other program crashed when playlist was open)
- if subtitles were disabled, embeded subtitles were still loaded, fixed
- some workarounds for problem with Norton antivirus
- some other bug fixes
- autoplay option is now acting as in previous versions
- full screen skin can now be on top and bottom, also base skin have now full screen skin
- added font smoothing option for subtitles
- added 'boss' button function
- added VMR9 renderless mode and subtitle support, subtitles are now supported with VMR 9
- it's now possible to define every shortcut as global
- added 'movie mode' function (M), it will put movie at top, subtitles at bottom and enable pan-scan as needed
svidja mi se ova "sef" tipka
Veky je offline   Reply With Quote
Staro 11.09.2004., 01:19   #2
Freek
Freek's Avatar
Lokacija: Zagreb/Dubrava
Postovi: 2,869
a, napokon stigla nova verzija najboljeg playera
Staro 14.09.2004., 00:20   #3
ßellerophon
Sannin
ßellerophon's Avatar
Datum registracije: Jun 2003
Postovi: 1,568
YES - BUT /
Staro 14.09.2004., 14:54   #4
Costa
Costa's Avatar
Datum registracije: Aug 2003
Postovi: 3,193
Danas sam frendu slozio Media Player Classic, inace prije je koristio BS, pa je samo gledao kaj radim i cudio se.
Uglavnom vise nema BS-a (Ovo je kratica ) kod njega.
Staro 14.09.2004., 16:24   #5
Freek
Freek's Avatar
Postovi: 2,869
Bez brige to si govorio i za Mv2 pa si se sad preobratio, samo je pitanje vremena kad će Costa promovirat "BS"
Staro 14.09.2004., 16:26   #6
Costa
Costa's Avatar
Postovi: 3,193
Mrzima Mv2. Dobro je jedino kaj mozes titlove micati povlacenjem misa
Staro 14.09.2004., 16:53   #7
MadBoY
MadModerator
MadBoY's Avatar
Datum registracije: Sep 2002
Lokacija: N/A
Postovi: 5,195
Costa - zasto mi trza slika u WMPCL?
Pogotovo kod anime-a (a i ostalih "normalnih" filmovia) pogotovo kod onih koji su kodirani u xvidu?
U BS-u se to ne dogadja. :confused:
Staro 14.09.2004., 17:35   #8
BELIAL
BELIAL's Avatar
Datum registracije: Jul 2004
Postovi: 152
Izasla je ver 1.02 koja je uglavnom popravljal buove
BELIAL je offline   Reply With Quote
Staro 14.09.2004., 17:43   #9
Costa
Costa's Avatar
Postovi: 3,193
WMPCL? Sto je to :confused:
Staro 14.09.2004., 18:20   #10
Freek
Freek's Avatar
Postovi: 2,869
a znaš da je mislio na tvoj "voljeni" Media player classic
Staro 14.09.2004., 19:59   #11
tor
Administrator
tor's Avatar
Lokacija: Sesvete
Postovi: 15,964
MadBoY, koristiš ff ili Xvid kao filter?
tor je online   Reply With Quote
Staro 14.09.2004., 20:50   #12
Costa
Costa's Avatar
Postovi: 3,193
Ne znam jer kratica nimalo ne lici na njegovo ime.
@tor: nema veze s codecom jer svi playeri koriste iste osim ak se MadBoy igrao u Classicu
@MadBoy: Ako koristis MPC pogledaj sto koristi kao output u View > Options > Playback > "Output" - Verzija MPC-a je zadnja
Isprobaj VMR7 i 9 renderless jer preko njih mozes koristiti i titlove. Meni sedmica daje mozaicnu sliku dok devetka normalnu. Kod drugih zna biti obratno.
Osim toga moze biti problem u zvuku jer MPC koristi svoje filtere pa ti preporucujem da pod View > Options > Filters iskljucis MPEG Audio decoder i AC3 Decoder.
Mozes i pricekati do navecer pa cu sloziti postavke i uploadati ih kratkim uputstvom kako sloziti MPC.
BTW taj program niema u imenu "Windows" niti ima kakve veze s njihovim playerom osim sto je pobrao idizajn od WMP6.
Staro 14.09.2004., 23:16   #13
MadBoY
MadModerator
MadBoY's Avatar
Lokacija: N/A
Postovi: 5,195
Hehe...ma...nista .. ok od sad MPC .
Nista. Probao sve al DragonBallZ jos uvijek trza .
EDIT: @tor - koristim xvid.
Zadnje izmijenjeno od: MadBoY. 15.09.2004. u 01:24.
Staro 14.09.2004., 23:52   #14
Freek
Freek's Avatar
Postovi: 2,869
reako si da s BS to sve radi normalno,što je i za očekivat.
Staro 15.09.2004., 02:58   #15
Max_
Max_'s Avatar
Datum registracije: Sep 2004
Lokacija: Sarajevo
Postovi: 147
MPC je zakon! Ili je bio :confused:
Vec nekoliko mjeseci na sajtu stoji 6.4.8.2 kao zadnja verzija... steta ako ga prestanu "doradjivati"
Meni se svidja jer je brz kad je u pitanju video playback, muzika manje-vise
bhtech.org/forum
Max_ je offline   Reply With Quote
Staro 15.09.2004., 11:23   #16
Costa
Costa's Avatar
Postovi: 3,193
Ajd stavi moju konfiguraciju u MPC-ov dir pa probaj ponvono.
On inace postavke sprema u registry no ako mu se u View > Options > Player naredi "Store settings to .ini file" onda ce ih spremati u mplayerc.ini (Isti dir).
Sad da bi ti kopirao moje postavke u njegov dir, on ti mora biti izgasen.
Pa probaj tako.
Nadam se da si kod mijenjanja output postavki svaki put gasio player jer inace ne promjeni?
Ako ni to ne upali onda mi reci koje sve filtere koristi dok gledas film (Play > Filters)?
Ove moje postavke ti zahtjevaju instalirane ove stvari: FFDSHOW, Cyberlink Video/SP Decoder (Dodje s PowerDVDom), AC3Filter i Elecard MPEG2 Demultiplexer (pitaj na PM).
Ukoliko slucajno imas VobSub on ce biti blokiran u radu.
Elecard se koristi kod gledanja MPEG 1 i 2 materijala s tim da se za kompatibilniji rad (Bar koliko sam skuzio) s MPEG1 treba u njemu pod Startup Properties > Init mode > ukljuciti "Simple".
Takodjer Cyberlink zna zezati s opcijom "Use Hardware Accelerator" pa i nju iskljucis ako bude stogod cudno kod gledanja MPEG2 (DVD, SVCD, stvari sa satelitske...).
Postavke filtera se mijenjaju odlaskom u Play > Filters pa klik na pojedini.
@Max: Pa i nema se sto doradjivati.
Staro 15.09.2004., 19:28   #17
Max_
Max_'s Avatar
Lokacija: Sarajevo
Postovi: 147
Pa nema doduse sad... mislio sam, bilo bi njesra kad bi se prekinuo development.
bhtech.org/forum
Staro 15.09.2004., 23:45   #18
MadBoY
MadModerator
MadBoY's Avatar
Lokacija: N/A
Postovi: 5,195
Tnx Costa. Budem probao.
Staro 20.09.2004., 16:33   #19
LuX.23
LuX.23's Avatar
Lokacija: ZaGReB
Postovi: 406
BSplayer Pro version 1.02 (14 Sep 2004)
http://www.bsplayer.org/
Intel P4 1.8 Mhz
ASUS P4S533-E SiS 645DX
2 x 256MB DDR333 Samsung
HERCULES ATI Radeon 9800SE AIW 128 MB
HDD Seagate Barracuda 60 & 80 GB
NEC DVD RW+/-ND-2500
PSU Aopen 300W
Monitor EIZO 19" Flexscan
Microsoft IntelliMouse Optical
CoolerMaster Aerogate II
CoolerMaster Cool Drive 3
CoolerMaster 2 x 80mm vent LED Blue
Papst 120mm vent
SkyStar 2
Case InWin X710 Black
LuX.23 je offline   Reply With Quote
