Staro 14.05.2009., 11:51   #1
martan100
Lokacija: nedelisce
Postovi: 18
Local Area Connection
neznam dal sam stavio u dobro podrucje, ako nisam se ispricavam... dakle
imam problem
pod network conections mi nema local area conection, pokusao sam i instalirat nove windowse, al je isto i dalje...
mislio sam da bi na maticnoj mozda izgorjela mrezna, pa sam kupio lan karticu, stavio je u komp, al ni tamo ne zeli
kad idem inst. pod add device, dolazi mi do nekog errora., pokusao sam i u devices uninstal, pa ponovo instal al mi dolazi do istog..
jel mozda zna neko u cem bi bio problem ?
martan100 je offline   Reply With Quote
Staro 14.05.2009., 13:27   #2
Mortal
Rambus 3xtr1m
Mortal's Avatar
Postovi: 2,694
a jesi možda sa prčkao po servisima?
run/services.msc
Ryzen 7 2700X
Sonic Tower rev.1 (polirani) + 12cm Chieftec
2x 8gb Crucial
B450 Aurus Elite
Segate 500GB Server edition
Silwerstone Strider 560W +12@11.97-11.94V
GTX 1060
Samsung p2770, Hanns G 22' landscape
Samsung pleomax& Microsoft Sidewinder
Kensington Duo Wawe Pad
1. 2xP3 933, Intel OR840 Server, PCI MX440, 4x128Mb Rambus, 80gb segate, SmartBox 400W
2. P4 2.0 wille, Intel i850, 4x128 Rambus, GF2 GTS PRO, 80gb segate, MS 480w
3. P4 1.6 willie@2.0 - Abit th7 II, 4x128Mb Rambus@ 1078mhz, 9000pro, 80gb segate, silwerstone 400w
3 x Prestigio 710, 3 x Microsoft Optical desktop v2.0
i5 530
640gb
1x4gb, 1x2gb ddr3
GT330M
16' wide - white body
Harman Kardon
MX revolution
Online with nokia E70
Battery grip
Beercan: 35-70, 28-85, 35-105, 70-210
Minolta: 28-80, 35-70, 28-100, 35-80, 28-105xi, 75-300
Sigma: 35-70, 28-135, 18-200, 70-300
Sony: 18-70, 55-200
m42: Zenit 135mm, Crestar 135mm, Helios 44m
Mortal je offline   Reply With Quote
Staro 14.05.2009., 14:02   #3
greenfly
Od nonine sestre kunjado
greenfly's Avatar
Lokacija: (Vinjro)
Postovi: 1,130
Jesi instalirao drivere, koji ti točno error baci??
greenfly je offline   Reply With Quote
Staro 14.05.2009., 20:51   #4
martan100
Lokacija: nedelisce
Postovi: 18
Autor Mortal Pregled postova
run/services.msc
nisam nista prckao.... al.. kod nas je bilo nevrijeme, i udario grom u blizini... i rekao brat da se komp malo kao izgubio... i onda ga je ugasio...
i sad sve radi normalno, samo local area connection nema :S
Staro 14.05.2009., 21:06   #5
domis
Lokacija: Hrvatistan
Postovi: 4,164
mozda je na drugoj strani kabla problem ili čak u kablu...probaj stavit neki linux LiveCD pa vidi
domis je online   Reply With Quote
Staro 14.05.2009., 21:40   #6
martan100
Lokacija: nedelisce
Postovi: 18
Autor d'beast Pregled postova
nije... imam vise kablova, ... al unatoc tome... isto kabel koji na mom kompu ne radi, ovdje radi
Staro 15.05.2009., 11:57   #7
Mortal
Rambus 3xtr1m
Mortal's Avatar
Postovi: 2,694
Pa el ti blicaju lampice kad uštekaš kabal?
Ryzen 7 2700X
2x 8gb Crucial
B450 Aurus Elite
GTX 1060
i5 530
640gb
1x4gb, 1x2gb ddr3
GT330M
Harman Kardon
MX revolution
Battery grip
Sony: 18-70, 55-200
Staro 15.05.2009., 12:22   #8
martan100
Lokacija: nedelisce
Postovi: 18
samo zeleno svjetli, ne bipka
Staro 15.05.2009., 13:20   #9
rams
80286
rams's Avatar
Datum registracije: Jul 2004
Lokacija: Dingolfing, DE
Postovi: 1,724
Autor greenfly Pregled postova
Samo cu citirat.
rams je offline   Reply With Quote
Staro 15.05.2009., 15:59   #10
martan100
Lokacija: nedelisce
Postovi: 18
Autor rams Pregled postova
Samo cu citirat.
kad instaliram network adapter, pise ovako
this device cannot fin enough free resourses that it can use ( code 12 )
if you want to use this device , you will need to disable one of the other devices on this sistem...
btw, nasnimao sam nove windowse
Staro 15.05.2009., 16:56   #11
thopok
Lokacija: Splity
Postovi: 3,003
To mi zvuči nevjerojatno…Ali kad pročitam
The Local Area Connection icon in the Network and Dial-up Connections folder can be in any of the following four states:
  • The icon is not present. There is no Local Area Connection icon when there is no network adapter present, or when the adapter is not configured properly.
…tako da nema veze s kabelom.
