Staro 13.04.2009., 21:03   #1
LuxZg
Postovi: 512
ATI Radeon HD 4890 X2
Ipak će krenuti u proizvodnju!
I to ne samo X2, nego će chipovi raditi na 1GHz
http://www.tomshardware.com/news/amd...hics,7531.html
AMD clarified with press late last week about the immediate future of its line of Radeon HD graphics products, particularly the HD 4870 X2. According to AMD, its partners are now being selected and prepped for validation of its next major part, the HD 4890 X2.
According to reports, the new card will have both GPUs running at least at 1 GHz core clock speed. Depending on the SKU, customers should be seeing 2 GB and 4 GB cards. The specs are not fully confirmed yet, but we'll let you know when we hear anything different.
Da vidimo.. HD4890 X2 = 2x HD4890
GTX295 = 2x GTX275
HD4890 @ 1GHz > GTX275
HD4890 X2 > GTX295
HD4890 X2 = king of the hill
Intel Core 2 Duo E4400 @ 320x10 (3200MHz) w/ Scythe Ninja rev.B + 120mm fan | Gigabyte GA-P35-DS3R (Intel P35 + ICH9R) | 4x 1GB Kingmax MARS DDR2 800 CL5 | Sapphire ATi Radeon HD4890 | Seagate 7200.11 250GB+2x WD Black 640GB+Samsung F3 1TB; svi SATA/7200rpm | LG GH20NS15 SuperMulti, SATA | LG W2361V-PF 23", 1920x1080, DVI+HDMI | Aplus CS-188AF case w/ 250mm side fan | onboard 7.1, with Logitech X-540 5.1 speakers | Chieftec 450W /w 120mm fan | Windows 7 64bit Enterprise
LuxZg je offline   Reply With Quote
Staro 13.04.2009., 21:08   #2
Neo-ST
Buying Bitcoin
Neo-ST's Avatar
Postovi: 8,266
Lijepo, samo šteta što toj priči nikad nema kraja...
Staro 13.04.2009., 21:24   #3
DraŽ
DraŽ's Avatar
Lokacija: Petrinja
Postovi: 904
Autor LuxZg Pregled postova
GTX295 = 2x GTX275
HD4890 X2 > GTX295
Jedino će biti jedan problem?
HLADNJAK iliti COOLER! Ak stave referentni kao na hd4870x2 opet onda se stvarno svi u amd-u mogu lijepo upucat.
Neka potpišu neki ugovor sa arctic coolingom i da na sve hd4890x2 ide accelero extreme ili nešto slično..
Zen5 PCIvy bridge Notebook
CPU: AMD Ryzen 7 9700x, CO per Core, CS -20 (Mid, High, Max)
COOLER: Arctic Cooling Liquid Freezer III 420 A-RGB
MBO: MSI Tomahawk X870
RAM: Corsair Vengeance DDR5 32GB, 6000MHz CL28
GPU: MSI SuprimX Nvidia GeForce RTX 3070
NVM1: Samsung Evo 970 2TB
HDD1: WD Red 4TB, WD40EFRX
HDD2: WD Blue 6TB, WD60EZRZ
HDD3: WD Blue 6TB, WD60EZRZ
PSU: Corsair RMx 850W, ATX3.1
CASE: Fractal Meshify 2 XL
VENTS: 4x Arctic Cooling P14 PWM PST A-RGB
OS: Win 11 Pro, 64-bit
MONITOR: AOC Q3279VWFD8 - 32", IPS, 2560x1440
TV: LG 7450
MOUSE: Logitech MX Master 3
KEYBOARD: Logitech MX Keys
GAMEPAD: XBOX One
HEADPHONES: Sennheiser HD560s
DELL Inspiron 15R, 5520
CPU: Intel Core i7 3632QM, 2.20Ghz, turbo 3.20GHz
RAM: DDR3, 6GB (4GB + 2GB), 1600Mhz CL11
GPU: AMD Radeon 7670, Intel HD4000
SSD: Samsung EVO 850, 250GB
SCREEN: 15,6 inch LCD, 1366x768
OS: Ubuntu 24.04, 64-bit
DraŽ je offline   Reply With Quote
Staro 13.04.2009., 21:27   #4
Neo-ST
Buying Bitcoin
Neo-ST's Avatar
Postovi: 8,266
Autor DraŽ Pregled postova
Da, i tko će je onda kupiti kada bude dosta skuplja radi toga?
Staro 13.04.2009., 21:32   #5
alengrosevic
alengrosevic's Avatar
Postovi: 3,775
Autor Neo-ST Pregled postova
tak svejedno jel ce biti 3700 ili 4000. onaj tko zeli takvu grafu i ima toliko novaca kupit ce je bez obzia na tih 300 kn razlike
Staro 13.04.2009., 21:35   #6
DraŽ
DraŽ's Avatar
Lokacija: Petrinja
Postovi: 904
Nvidia je skuplja(bila...) pa je ipak kupuju ne? 68$ košta jedan accelero xtreme, što je oko 350-380kn, a ako se makne jedan vent ili stave 3x 80mm ,a ne 92 mm i maknu par listića mogu smanjit cijenu, a i ako naruče preko 1000 komada cijena je još manja ne?
Moglo bi se doći do 200kn porasta cijene, što i nije puno. Ako već imaš para za ultra high end karticu onda imaš još 200kn.
TV: LG 7450
GAMEPAD: XBOX One
Staro 13.04.2009., 21:37   #7
Metamphetamine
Flaccitra
Metamphetamine's Avatar
Lokacija: Vinkovci
Postovi: 276
I ja tako mislim, svakako je primamljivija kartica ako neradi na 100C, po meni bi i pomoglo prodaji, jer kartuša ogromnih gabarita koja gori u kućištu, jednom i nikad više .
Metamphetamine je offline   Reply With Quote
Staro 13.04.2009., 22:18   #8
Halos
muimerP
Halos's Avatar
Lokacija: VG
Postovi: 3,334
Autor Metamphetamine Pregled postova
Ako ništa nebojimo se zime sa x2icama
p.s. 128bit-a rula
Staro 13.04.2009., 22:36   #9
Func
Func's Avatar
Postovi: 483
I opet neće raditi kak spada jel će driveri biti katastrofa i meant to be f...... by nvidia politike.
Some say that he's Mac compatible, and that he once punched a horse to the floor. All we know is, he's called The ...
Func je offline   Reply With Quote
Staro 20.04.2009., 18:37   #10
maX
maX's Avatar
Postovi: 7,326
ajde reci kad driveri od ATI-a nisu bili katastrofa?
to je vec stara cinjenica koja se vise niti netreba spominjat...
Staro 20.04.2009., 22:48   #11
LuxZg
Postovi: 512
Kaj te muči Njofra? Meni ATI nije zadavao nikakve probleme, osim kaj mi je u STALKER:CD falila kamuflaža i povremeno bodljikava žica
