Staro 23.06.2008., 10:05   #1
d^_^b
d^_^b's Avatar
Lokacija: Sarajevo
Postovi: 474
RAM problem... Trgovac me prevario ili je do Winowsa?
Dakle prije koji dan sam konacno dobio computer kojega sam vec davno platio i narucio.... Trgovac me razvlacio ko placu... To je sad nebitno...
Kada sam ga kupovao dogovor je bio da ide 2 x 2GB Apacer 800MHz DDR2...
Sinoc gledam malo sa PC Wizard 2008 sta mi je to sve stavio u stroj...
Kad vidim ovo: "Physical Memory : 4096 MB (2 x 2048 DDR2-SDRAM )"
Sad, sta to znaci?
Evo vam jos neki detalji:
> General Information :
A0 : Empty
A1 : Empty
A2 : Empty
A3 : Empty
A0 (Bank0/1 ) : 2048 MB - DIMM
A2 (Bank4/5 ) : 2048 MB - DIMM
> Information SPD EEPROM (A0) :
Manufacturer : Kingston
Part Number : 2G-UDIMM
Serial Number : 0C08ADAD
Type : DDR2-SDRAM PC2-5300 (333 MHz) - [DDR2-666]
Format : Regular UDIMM (133,35 x 3)
Size : 2048 MB (2 ranks, 8 banks)
Module Buffered : No
Module Registered : No
Module SLi Ready (EPP) : No
Width : 64-bit
Error Correction Capability : No
Max. Burst Length : 8
Refresh : Reduced (.5x)7.8 µs, Self Refresh
Voltage : SSTL 1.8v
Prefetch Buffer : 4-bit
Manufacture : Week 13 of 2008
Supported Frequencies : 200 MHz, 266 MHz, 333 MHz
CAS Latency (tCL) : 3 clocks @200 MHz, 4 clocks @266 MHz, 5 clocks @333 MHz
RAS to CAS (tRCD) : 3 clocks @200 MHz, 4 clocks @266 MHz, 5 clocks @333 MHz
RAS Precharge (tRP) : 3 clocks @200 MHz, 4 clocks @266 MHz, 5 clocks @333 MHz
Cycle Time (tRAS) : 9 clocks @200 MHz, 12 clocks @266 MHz, 15 clocks @333 MHz
Min TRC : 12 clocks @200 MHz, 16 clocks @266 MHz, 20 clocks @333 MHz
> Information SPD EEPROM (A2) :
Manufacturer : Apacer Technology
Part Number : 78.A1GA0.9K4
Serial Number : 02008194
Type : DDR2-SDRAM PC2-6400 (399 MHz) - [DDR2-800]
Width : 64-bit
Voltage : SSTL 1.8v
Manufacture : Week 19 of 2008
Supported Frequencies : 200 MHz, 266 MHz, 400 MHz
CAS Latency (tCL) : 3 clocks @200 MHz, 4 clocks @266 MHz, 5 clocks @400 MHz
RAS to CAS (tRCD) : 3 clocks @200 MHz, 4 clocks @266 MHz, 5 clocks @400 MHz
RAS Precharge (tRP) : 3 clocks @200 MHz, 4 clocks @266 MHz, 5 clocks @400 MHz
Cycle Time (tRAS) : 9 clocks @200 MHz, 12 clocks @266 MHz, 18 clocks @400 MHz
Min TRC : 12 clocks @200 MHz, 16 clocks @266 MHz, 23 clocks @400 MHz
> Memory Controller Information :
Memory Controller : System Memory
Number of connectors : 4
Max. Module Size : 4096 KB
Izvinjavam se sto vas opterecujem sa ovim, ali ne mogu nikako da uploadam slike na imagesack... Sredit cu to kasnije...
Sada da pitam: Sta sve ovo znaci?
Je li to znaci da me trgovac prevario i stavio mi staru memoriju koja je OC-ana jedno 1000000 puta ili da je nesto drugo?
Molim za pomoc jer se u ovo i ne razumijem bas mnogo...
Zadnje izmijenjeno od: d^_^b. 23.06.2008. u 10:44.
d^_^b je offline   Reply With Quote
Staro 23.06.2008., 10:14   #2
dejanbinladen
konjpjukter
Postovi: 934
pa kolko vidim jedan keks ti je kingston a ne apacer !?!?!? i to 667mhz
dejanbinladen je offline   Reply With Quote
Staro 23.06.2008., 10:32   #3
Renesis
Ex-Gastarbajter
Renesis's Avatar
Lokacija: Zagreb / Rijeka
Postovi: 5,474
imaš dva različita keksa memorije. jedan je ovaj koji si tražio, a drugi nije
jeli novo ili ne, ne znam, valjda je novo (ipak su svježe, 13. i 18.tjedan 08.). čovjek vidio da se valjda ne razumiješ toliko, pa stavio što se našlo u trgovini...
Abit IS7-E + TR NB-1
Homemade vodeno part1
Homemade vodeno part2
Staro 23.06.2008., 10:33   #4
tech
Postovi: 1,687
Kolko kužim jedan keks je kingston 667mhz a drugi Apacer 800mhz..
EDIT: Renesis me pretekao..
Staro 23.06.2008., 10:36   #5
thedream
thedream's Avatar
Lokacija: Zagreb ( Šibenik )
Postovi: 5,458
Šta ti kaže cpuz? Na koliko radi RAM? Ako se spustio na 667,zeznuo te..ako radi na 800,onda pc wizard laže ko pas..i sve radi na 800...
makar ova dva različita naziva..hmmm..weird..apacer i king..
Staro 23.06.2008., 10:48   #6
d^_^b
d^_^b's Avatar
Lokacija: Sarajevo
Postovi: 474
Autor Renesis Pregled postova
Primjetio sam da su razliciti sada kada sam otvorio...
A gle, razumijem se ja... Samo sto nisam bas neki strucnjak za memorije... Znam sta valja, uzmem to i gotovo...
BTW: Sta znaci ovo boldirano?
Je li to znaci da je to vec neko ranije clockao ili je to tvornicki?
Da li da ja to malo OC-am?
Staro 23.06.2008., 10:54   #7
Wolverine
Wolverine's Avatar
Postovi: 12,433
Ono boldano su SPD postavke deklarirane za pojedini radni takt
ne kužim odakle ti idea da to znači da je netko klokirao ram
Mark Twain
Intel Core i7 2760QM
2x 8GB DDR3
Intel HD3000
NEC USB 3.0 ExpressCard
14" 1366x768
Windows 10 Pro x64
Gigabyte GTX 560Ti
DVD-RW LiteOn SATA
Corsair HX520
TT Chaser MK-1
Logitech MX3200
Windows 10 Pro x64
Intel DP67BG
Intel G1610
Hitachi 250GB
VTX3D HD6670
DVD-RW Asus SATA
FSP 350 PNF
CoolerMaster Cavalier
ViewSonic VX922
Win7 x64 SP1
Staro 23.06.2008., 10:57   #8
TomRi
Can You Hear Me? 142.8 dB
TomRi's Avatar
Lokacija: Zagreb, Kvatrić
Postovi: 2,073
pa odi tam odi si kupio i traži dva ista APACER sticka.
u čemu je problem?
reci da si to već napisao u opciju 'moj komp' i to si platio, to piše vjerojatno na računu i da njih želiš
Danas je teško biti budala, prevelika je konkurencija...
Water cooled PC
Moj najveci MOD
Novi hobby: RC model + HD kamera
TomRi je offline   Reply With Quote
Staro 23.06.2008., 11:30   #9
d^_^b
d^_^b's Avatar
Lokacija: Sarajevo
Postovi: 474
Autor TomRi Pregled postova
u čemu je problem?
Sad sam na vikendici pa cu otici krajem mjeseca...
Inace zvao sam ih i rekli su kako nisu imali 2 ista keksa pa su mi uvalili razlicite... I prodali mi ih po istoj cijeni kao i ona 2 sto sam narucio...
Vidjet cemo sta bude, rekli su da ce zamjeniti... Samo dok nabave robu- to ce se optegnuti...
Hvala na pomoci...
I jos jedno pitanjce... Posto je jedna 800MHz, a druga 667 MHz to znaci da mi obje rade na 667 MHz???
To pitam zato sto znam da je tako dok me trgovac uvjerava da se ova druga automatski dize na visi radni takt i da obje rade na 800MHz...
Trebam to snimiti Gdje sam ja kupio comp :|
Staro 23.06.2008., 11:32   #10
thedream
thedream's Avatar
Postovi: 5,458
Lijepo sam ti napisao..trebali bi se spustiti na 667..a ne da se ovaj sam od sebe clockne na 800...
Staro 23.06.2008., 11:49   #11
TomRi
TomRi's Avatar
Postovi: 2,073
ma negdje je (čini mi se Razer) napisao da većina mema radi na manjem taktu, 667,
a da moraš podignuti sam na 800 ili 1066(iako kupiš tu bržu memu)
kao i latencije, mahom su 5-5-5-15, iako mogu biti 4-4-4-12 na istom naponu
ionako se u svakodnevnom radu u winsima ne kuže neke drastične razlike.
edit: našao:
Autor Razer Pregled postova
A ja mislio da smo to utvrdili za vjeke vjekova...
800Mhz memorija neće raditi na 800MHz ''out-of-box'', već ćeš za dotične postavke morati dizati djelitelj, tj clockati. A isto tako možeš clockati i 667Mhz.
usporedbe radi,
čini mi se da je bilo govora da crucial 667 bolje ide od istih 1066 modula,
pošto gotovo svi 667 idu na 1200MHz (neki i više), a čini mi se da to nije bio slučaj sa svim 1066 modulima...
uz to, 2gb stickovi se clockaju lošije koliko sam vidio po forumu
samo jedan od topica: http://forum.pcekspert.com/showthread.php?t=107975
a i 4GB je upitan odabir, no vjerojatno znas to iskoristiti na XP32?
(zaključio po sp3 koji imaš, a nije izašao za 64bit xp)
Water cooled PC
Moj najveci MOD
Zadnje izmijenjeno od: TomRi. 23.06.2008. u 12:03.
Staro 23.06.2008., 16:25   #12
Dizel
3.14zda ®
Dizel's Avatar
Lokacija: Orahovica
Postovi: 8,320
Noviji chipseti, pa i P35 sami podese DDR2 na 800MHz ako je tako deklariran po SPD-u. Na starijim chipsetima je trebalo naklokavati PC2-6400 da bi radio na tom taktu, sto je danas slicna situacija sa PC2-8500 memorijama koje se mora nagruvati OC-om da rade na toj frekvenciji.
Staro 23.06.2008., 16:31   #13
thedream
thedream's Avatar
Postovi: 5,458
Autor Vin EuroDizel Pregled postova
Govoriš da će keks od 667 i keks od 800 raditi na 800? Da će se auto-OC prvi keks na brzinu drugog..
A dobro..
Staro 23.06.2008., 16:39   #14
Michel
Michel's Avatar
Lokacija: Dubrovnik
Postovi: 1,288
Dakle kao što su priznali jedan modul su ti uvalili ali ok.
Drugo kad se nađu dvije različite memorije pod pretpostavkom da se kako
tako podnose konfa bi trebala radit s time da će se automatski namjestit i radit po onoj slabijoj. (I latencije i frekvencije) To je naravno u globalu a ima ti milijun caka kad će bit ovako kad onako.
Michel je offline   Reply With Quote
Staro 23.06.2008., 16:51   #15
yedwy
Beskorisna bitanga...
yedwy's Avatar
Lokacija: Sesvete (Zg)
Postovi: 6,956
Ako rade u DCu na 800 ja se recimo uopće nebi zamarao sa vraćanjem, ionako je IMHO kingston bolja marka od Apacera...
Ako ne rade u DCu e onda je to već nešto drugo...
Have a nice day...
Staro 23.06.2008., 16:55   #16
Dizel
3.14zda ®
Dizel's Avatar
Lokacija: Orahovica
Postovi: 8,320
A dobro..
Koji si lik, heheh....aj sad mi objasni sto ti nije jasno u pojmu SPD? Ako je SPD 800 ram ce po DEFAULTU raditi na 800, ako je 667 onda ce raditi na doticnom. Ako su razlicite onda radi na nizoj, kao i oldskul DDR, to je bar jaaasno
Staro 24.06.2008., 12:04   #17
Michel
Michel's Avatar
Lokacija: Dubrovnik
Postovi: 1,288
Točno kao što si rekao , uvjek će raditi na nižoj ako postoje dvije različite.
Btw doznat ćeš da li su ti u dual channelu po tome kolika ti piše da je bitna
tj. ako s nekim programčićem vidiš 64 bit single je ako je 128 bit rade kao dual.
Staro 24.06.2008., 12:35   #18
thedream
thedream's Avatar
Postovi: 5,458
nismo se skužili kao obično...mislimo isto
ne znam ponekad kao da turski pričam..lijepo mu kažem upali si cpuz,program ima valjda 500kb..pogledaj ako rade na 667,onda su te preveslali i uvalili ti jedan 667+ jedan 800...ako ti cpuz izbaci fsb meme 400..odnosno 800...to je to..no big deal..
a kao da taj vražji turski pričam..pa 5x treba reći istu stvar na različiti način..
Staro 24.06.2008., 13:19   #19
Dizel
3.14zda ®
Dizel's Avatar
Lokacija: Orahovica
Postovi: 8,320
Previse tockica picis u interpunkciji pa postaje zamorno citati i ekipa preskace bitne dijelove
Pocni BOLDAT ono sto mislis da je bitno u tvom replyu, hehe.
Staro 24.06.2008., 13:31   #20
thedream
thedream's Avatar
Postovi: 5,458
Samo za tvoje oke,boldane točkice..............................,lakše mi njih kresnut nego space..jbg.Glavno da se skužiamo..
