#9631 | ||||
Postovi: 8,656
Potencijalni Zen 4 na AM4 može biti godinu ili dvije nakon kaj bude AM5 službeno u opticaju i opet bude dobro, taman da se MBO ekipa pobuni i ograniči Zen 4 samo na B550 i X570. ![]() Nakon pet godina, AM4 je ispunil i više od očekivanog, tak da se bilo kaj dodatno, novi Zen 3 ili Zen 4 + 3D cache modeli, mogu dočekati kao dodatan bonus na koji nitko ionak nije računal. EDIT:
AMD Ryzen 9 9950X | Noctua NH-U12A chromax.black | MSI MAG B650 Tomahawk Wi-Fi | 128GB Kingston FURY Beast DDR5-5200 | 256GB AData SX8200 Pro NVMe | 22TB WD Red Plus | Fractal Define 7 Compact | Seasonic GX-750 AMD Ryzen 5 7600 | Noctua NH-U12A chromax.black | MSI MAG B650 Tomahawk Wi-Fi | 128GB Kingston FURY Beast DDR5-5200 | 256GB AData SX8200 Pro NVMe | 2x12TB WD Red Plus | Fractal Define 7 Compact | eVGA 650 B5 AMD Ryzen 5 7600 | Scythe Kotetsu SCKTT-1000 | MSI MAG B650 Tomahawk Wi-Fi | 64GB Kingston FURY Beast DDR5-5200 | 256GB AData SX8200 Pro NVMe | 2x8TB WD Red Plus | Fractal Define 7 Compact | Seasonic SSR-550PX Zadnje izmijenjeno od: The Exiled. 26.07.2022. u 18:59. |
#9632 | |
Postovi: 8,656
AMD beats Q2 earnings with revenue of $6.55B, up 70% ![]() Citiraj:
AMD Ryzen 9 9950X | Noctua NH-U12A chromax.black | MSI MAG B650 Tomahawk Wi-Fi | 128GB Kingston FURY Beast DDR5-5200 | 256GB AData SX8200 Pro NVMe | 22TB WD Red Plus | Fractal Define 7 Compact | Seasonic GX-750 AMD Ryzen 5 7600 | Noctua NH-U12A chromax.black | MSI MAG B650 Tomahawk Wi-Fi | 128GB Kingston FURY Beast DDR5-5200 | 256GB AData SX8200 Pro NVMe | 2x12TB WD Red Plus | Fractal Define 7 Compact | eVGA 650 B5 AMD Ryzen 5 7600 | Scythe Kotetsu SCKTT-1000 | MSI MAG B650 Tomahawk Wi-Fi | 64GB Kingston FURY Beast DDR5-5200 | 256GB AData SX8200 Pro NVMe | 2x8TB WD Red Plus | Fractal Define 7 Compact | Seasonic SSR-550PX Zadnje izmijenjeno od: The Exiled. 03.08.2022. u 01:08. |
#9633 | |
Datum registracije: Aug 2020
Postovi: 900
#9634 |
Prvoklasni Krkan
Postovi: 5,477
A moglo bi uskoro svima biti veselo. Na Tajvanu je situacija poprilično usijana. Nadam se da svi skupa imaju nekakav backup plan za proizvodnju.Samsung trlja ruke... tj jesu li uopće njihove tvornice u Koreji? |
#9635 | ||||
Postovi: 8,656
Ma ima svega na sve moguće strane, ciganluk je jak naročito kad država daje pare. TSMC je nedavno završil svoj 5nm FAB u Arizoni, dok je Intel istovremeno odgodil radove na svojim fabrikama, dokle god im država nije osigurala sreCtva. Samsung većinu toga bitnog (mikroprocesori) drži na domaćem terenu, ali imaju i par DDR tvornica u Kini, tak da kak god se okrene svi vodeći proizvođači se taktički raspoređuju diljem svijeta. Citiraj:
Intel je pak izgubljen u vlastitoj magli propagandnih poruka, dok voCtvo uz marketing lupa ko Maks po diviziji. Citiraj:
AMD Ryzen 9 9950X | Noctua NH-U12A chromax.black | MSI MAG B650 Tomahawk Wi-Fi | 128GB Kingston FURY Beast DDR5-5200 | 256GB AData SX8200 Pro NVMe | 22TB WD Red Plus | Fractal Define 7 Compact | Seasonic GX-750 AMD Ryzen 5 7600 | Noctua NH-U12A chromax.black | MSI MAG B650 Tomahawk Wi-Fi | 128GB Kingston FURY Beast DDR5-5200 | 256GB AData SX8200 Pro NVMe | 2x12TB WD Red Plus | Fractal Define 7 Compact | eVGA 650 B5 AMD Ryzen 5 7600 | Scythe Kotetsu SCKTT-1000 | MSI MAG B650 Tomahawk Wi-Fi | 64GB Kingston FURY Beast DDR5-5200 | 256GB AData SX8200 Pro NVMe | 2x8TB WD Red Plus | Fractal Define 7 Compact | Seasonic SSR-550PX Zadnje izmijenjeno od: The Exiled. 03.08.2022. u 11:58. |
#9636 |
Lokacija: Zd
Postovi: 4,770
Mislim da nije bilo... Neki detalji vezani uz taktove i cache nadolazeće Ryzen 7000 serije procesora by WCCF tech... Ryzen 9 7950X, Ryzen 9 7900X, Ryzen 7 7700X, Ryzen 5 7600X CPU Specs Leaked: Up To 16 Zen 4 Cores, 5.7 GHz Boost, 170W TDP |
#9637 | |
Postovi: 8,656
AMD Ryzen 7000X3D CPUs to Feature Improved Thermals/Heat Dissipation, Higher Boost Clocks of up to 5GHz ![]() Citiraj:
AMD Ryzen 9 9950X | Noctua NH-U12A chromax.black | MSI MAG B650 Tomahawk Wi-Fi | 128GB Kingston FURY Beast DDR5-5200 | 256GB AData SX8200 Pro NVMe | 22TB WD Red Plus | Fractal Define 7 Compact | Seasonic GX-750 AMD Ryzen 5 7600 | Noctua NH-U12A chromax.black | MSI MAG B650 Tomahawk Wi-Fi | 128GB Kingston FURY Beast DDR5-5200 | 256GB AData SX8200 Pro NVMe | 2x12TB WD Red Plus | Fractal Define 7 Compact | eVGA 650 B5 AMD Ryzen 5 7600 | Scythe Kotetsu SCKTT-1000 | MSI MAG B650 Tomahawk Wi-Fi | 64GB Kingston FURY Beast DDR5-5200 | 256GB AData SX8200 Pro NVMe | 2x8TB WD Red Plus | Fractal Define 7 Compact | Seasonic SSR-550PX |
#9639 |
Datum registracije: Feb 2021
Lokacija: TRPI
Postovi: 456
@Ag008 Govorilo se da ce mozda neki Zen 4 modeli izaci za AM4, znat ce se pri kraju godine. |
#9640 |
Postovi: 8,656
Desktop CPU sales lowest in 30 Years, AMD gains market share anyway ![]() Citiraj:
#9641 |
Lokacija: TRPI
Postovi: 456
@The Exiled U segmentu gaminga, zadnjih 2-3 godine cpu postaje sve manje bitan faktor u usporedbi sa gpu, pogotovo u 1080p gamingu koji je najzastupljeniji. Za vrijeme krize ljudi su "zadovoljni" sa kvalitetnim 1080p gamingom i potreba za nadogradnjom ima smisla tek kad se ekonomija oporavi, jer nadogradnja PC-a cesto zahtjeva i prelazak na noviji monitor (1440p ili 4k). |
#9642 |
Postovi: 8,656
Kak god bilo, AMD uz ostalu konkurenciju i Intelove nedaće da izda išta od najavljenog, polako, ali sigurno stišće na svim tržišnim segmentima. Tak da bude veselo, ako se Intel u neko dogledno vrijeme ne trzne iz ove zone sumraka u koju su upali.
#9643 |
Lokacija: Zd
Postovi: 4,770
All the Juicy Details on AMD's Quirky Chipset Solutions for AM5! - by Angstronomics |
#9644 |
Lokacija: Zd
Postovi: 4,770
Ryzen 7950X, 7900X, 7700X and 7600X Zen4 processors listed by Canadian retailer ...paprene cijene, bar tako trenutno izgledaju ![]() |
#9645 |
Postovi: 8,656
Da, najveće odstupanje ima 7950X model koji je ~100$ skuplji od 5950X u vrijeme izlaska. Ostali su kakvih 30$ do 50$ skuplji u odnosu na Zen 3 varijante. Jedino fali 7800X koji bi prema glasinama trebal biti 10C/20T, pa ako mu slože cijenu od npr. 550$, taman bude se uklopil s ostatkom Zen 4 ponude. ![]() Posebice, ako inicijalnu Zen 4 ponudu izbace prema planu sredinom rujna i onda u studenom nastave s predstavljanjem Zen 4 3D cache modela.
#9646 | |
Lokacija: Zd
Postovi: 4,770
![]() Što se tiče 7800X, lako moguće da ponude 10-core s kojim bi popunili ponudu, a s druge strane moguće da ga čuvaju kao neku ekskluzivu s 3d cache-om. U tom slučaju 7700x bi bio ono što je za 5th gen bio 5800x... U svakom slučaju zanimljivo vrijeme ![]() |
#9647 |
Prvoklasni Krkan
Postovi: 5,477
Ma po svemu će imati konkurenciju. Vruću i rastrošnu, ali realno em Intel ima baš jako dobro pokriven srednji i niži segment (i5 i i3) koji se u praksi nije pokazao rastrošnim, em ne znamo kakav će biti zen4 sa potrošnjom. Netko je dobro rekao (ne sjećam se gdje sam čuo ili pročitao), AMD navodno želi što ranije izbaciti zen4 kako bi oteo potencijalne kupce Intelu. U slučaju bržih raptora (EDIT:LOL, omašio muški prije ), ide vj jako brzo 3DC model/i.Zadnje izmijenjeno od: Disco. 16.08.2022. u 06:15. |
#9648 |
Postovi: 8,656
IMHO obzirom da bude Zen 4 i pripadajuća AM5 platforma kakvih mjesec do mjesec i pol dana u rukama recenzenata (koji zapravo već sad imaju sve potrebno), prije službenog predstavljanja, AMD je ovo itekak dobro isplaniral. Zen 4 svakak stiže prije Raptor Lakea, odnosno Alder Lake refresha, dok potencijalni Zen 4 3D cache modeli, onda dodatno stišću Intel, koji će se naći između dvije vatre. Kaj se potrošnje tiče, sumnjam da bude Zen 4 u rangu Raptor Lakeovih 300W+ ili 400W+. U sljedeća tri mjeseca AMD planira izbaciti Ryzen 7000 (+ 3D cache varijante), EYPC 7000 (+ 3D cache varijante) i Radeon RX 7000 modele, dok Intel ima zagarantirani jedino Raptor Lake u listopadu i možda ARC GPU do kraja godine, a Sapphire Rapids je opet i po ko zna koji put ponovno odgođen, dok će Meteor Lake biti još jedna varijacija na Alder/Raptor Lake temu, ali ovaj put u chiplet/tiles izdanju. Mada ko zna kaj sve Intel u međuvremenu još stigne najaviti i usput odgoditi. ![]()
#9649 |
Lokacija: Zd
Postovi: 4,770
Da, slažem se. Čisto sumnjam da će potrošnja zen4 biti usporediva s RL-om, iako povećana u odnosu na zen3. Mislim, kao i kolega Disco, da će samo low i mid range RL biti donekle usporediv sa Ryzen3 i Ryzen5 - kao što je i dosad bilo... Valjda neće i od njih napraviti pećnice ![]() Dobra stvar je ta što će AMD imati na raspolaganju više waffera nego prošle generacije kad su morali dobar dio odvojiti za konzole. Stoga možda ponuda pa i cijena reflektira to, iako osobno mislim da će cijene biti generalno nešto skuplje, pogotovo u startu. Kasnije ako Intel zapapri s nižim cijenama moguće je svašta... |
#9650 |
Postovi: 4,510
#9651 |
Postovi: 8,656
Ono kaj valja, to i košta, a i cijena nije problem, ako se ima novaca. ![]() Tak je bar bilo od 2006. do 2017., makar DDR5 cijene su se koliko-toliko unormalile, pa nije sve tak crno.![]()
#9652 |
Lokacija: Zd
Postovi: 4,770
AMD Moves Ryzen 7000 “Zen 4” CPU Launch To 27th September, Same Day As Intel’s 13th Gen Raptor Lake Unveil Pomiču launch iz razloga što ciljaju na količinu umjesto da samo budu prvi. Očito su samouvjereni dovoljno da im ne smeta neki tamo Intel i njihove basnoslovne najave ![]() |
#9653 |
Postovi: 8,656
Ukoliko je istina, onda to rade namjerno (ko nekad Intel i nVidia) da sjebu Raptor Lake najavu, jer Zen 4 recenzije budu u to vrijeme već dva tjedna u opticaju. ![]() Intel će onda taj dan samo najaviti Raptor Lake, dok se Ryzen 7000 pušta u prodaju diljem svijeta. Prokleti marketing. ![]() ![]()
#9654 |
Modder
Lokacija: Waterford
Postovi: 936
#9656 |
Postovi: 4,510
#9657 |
Postovi: 375
Đizs, i ovo MSI-evo je jebeno skupo. Kad sam uzimao odmah na početku AM4 socketa, praktički prve tjedne high-endish ploču, bilo je jeftinije od najjeftinijih modela ovdje. A jeftinijih a odličnih ploča je isto bilo dosta. Rijetko slažem nove kompove - uglavnom cijedim ono što ispočetka nastojim uzeti kao pametnu dugoročnu kupnju, ali ne sjećam se da su ikada ovako ridikulozno skupe ploče bile. Stavi ti neku pimpin ploču za malu djecu sa svim điđama miđama i vodenim hlađenjem za 1k evra, ali daj i nešto normalne cijene, a kvalitetno...ovdje ne vidim ništa normalne cijene. |
#9658 |
mag.math.
Datum registracije: Dec 2021
Lokacija: Daruvar/Zagreb, Republika Hrvatska
Postovi: 366
pohlepna govna tj proizvodaci maticnih ploca su se odlucili na ovakav potez kako se nebi ponovno nasli zateceni sa dugovjecnosti socketa kao sa am4 pa idu na kartu eto fino kupite plocu u 2022 i na njoj izmjenite hrpu generacija am5 procesora do 2027 bez da mjenjate plocu ali zato u startu pljunite €1000 i vise pa je imajte pet godina. |
#9659 |
smeghead
Postovi: 3,194
ja vise ne dajem previse love na precjenjene ploce nakon zajeba s asus x370 CH6 da nece podrzavati 5600 i slicne, odlucio radije uzimati osrednju plocu i ostatak stavit za sljedecu nadogradnju (jest da je dobio podrsku kasnije samo radi amd-a) |
#9660 |
Freelancer
Lokacija: Bilje (Osijek)
Postovi: 5,369
Kad se sjetim da sam do prije par godina DualXoen ploce placao 4000kn i kad vidim sad ovo mrak mi padne na oci. Cak i ova zadnja TR Pro WRX80 ploca koju sma kupio prosle godine je kostala "svega" 1050 EUR a kudikamo je veca i opremljenija nego ovo sto najavljuje Asus za 1500 EUR.
