Staro 20.03.2021., 20:35   #3331
Chuxonja
Pajcek
Chuxonja's Avatar
Datum registracije: Jun 2012
Postovi: 1,082
Okie dokie. Samo da provjerim, govorimo dakle o Zalmanu "Fanmate 2"
Yup, that's the one.
MBO: ROG Maximus VII Ranger
ODD: Asus DRW-24B1ST
SSD: Intel 760p 256GB NVME
HDD: WD Purple 1TB
PSU: FSP Hyper 700W
CASE: Antec 1200
OS: Windows 10 Pro
MBO: ASRock Z87 Pro3
GPU: Intel HD Graphics 4600
ODD: LG GH24NS70
PSU: Corsair TX 650W
CASE: Zalman Z3 Plus
OS: Windows 10 Pro
MBO: Gigabyte GA-X58A-UD7
GPU: Gigabyte HD 5450 1024MB
SSD: Corsair Force GT 120GB
HDD1: Toshiba P300 2TB
HDD2: Hitachi DeskStar 2TB
HDD3: Hitachi DeskStar 2TB
HDD4: WD Green 2TB
HDD5: WD Red 2TB
HDD6: WD Purple 4TB
PSU: Corsair CX 600M
CASE: Chieftec Bravo
OS: Windows 10 Pro
MBO: Asus P5Q SE/R
FDD: Samsung SFD-321B 3.5"
ODD: LITEON iHAS124
CASE: Antec Sonata
LINK
MBO: Abit AB9 Pro
RAM: 6GB DDR2 800MHz
GPU: Asus R7 240 2GB
ODD: LG CH10LS20
SSD: LITE-ON LCS-256L9S 256GB
HDD1: WD Green 1TB
HDD2: Seeagate Baracuda 2TB
CASE: Lian Li PC-7FNB
LINK
MBO: Epox EP-AF550 Pro/G
GPU: Sapphire HD 4850 1024MB
FDD: Alps DF354H 3.5"
ODD: LG GH22LP20
PSU: Levicom VP450B.BL
CASE: Xilence X1
OS: Windows 7 Pro
LINK
MBO: Abit AI7
RAM: 4x1GB Kingston 400MHz
FDD1: TEAC FD-235HF 3.5"
FDD2: TEAC FD-55GFR 5.25"
ODD2: Pioneer DVR-112DBK
PSU: Enlight 400W
CASE: Chieftec Dragon
OS: Windows XP SP3
LINK
CPU: Athlon XP 3200+
MBO: Gigabyte GA-7N400
RAM: 2x1GB Kingston 400MHz
ODD2: Pioneer DVR-107D
HDD: WD 160GB
PSU: MS Platinum 400W
OS: Windows XP SP3
CPU: Pemtium MMX 233
MBO: Vtech VIB804DS
RAM: 2x32MB SDRAM
GPU1: ATi AIW 3D Rage Pro
SND: Sound Blaster 16
FDD1: Mitsumi D359T5 3.5"
FDD2: Mitsumi D509V2 5.25"
ZIP: Iomega Z100ATAPI
ODD: Mitsumi CRMC-FX400
HDD: Seagate U4 6.4GB
PSU: DTK PTP-2008 200W
CASE: ES-COM AT case
OS: Windows 98SE
LINK
Živi bili pa umrli!
Staro 20.03.2021., 20:39   #3332
Trekkie4
Autor Chuxonja Pregled postova
Dogovoreno, tvoj je
Staro 20.03.2021., 21:03   #3333
Alien_200581
Alien_200581's Avatar
Postovi: 1,181
Volim kad mi Chuck potvrdi da sam stavio post, danas je bas urnebes sa forumom hahaha
Hm da, citam malo po Vogonsima sad i da citiram jedan post vezano za slicno pitanje i 1024x768... "They will stutter. 12MB cards stutter as well, but 8MB cards will stutter a lot more.". Dakle upitno isplativo. Teoretski bi onda bilo bolje uzeti Voodoo 3 za taj scenarij (koji je cak malo i jeftiniji od V1 i V2... Svašta ).
Znaci ukratko mogu ostati na 800x600 (ovak kako je jer nisam primjetio neke probleme) ili ici na Voodoo 3. Hmmm...
Staro 20.03.2021., 21:32   #3334
stereotyp
1,2,3... fall over!
stereotyp's Avatar
Postovi: 206
Cijela poanta v2 @ sli je sto je to cool, nista vise, nista manje . Isto tak, sav taj retro aspekt se meni osobno ne bazira na performansama, nego bas na tom nekom nostagicnom osjecaju koji ce te vratit u to doba. Meni cak pase kad vidim da konfa stuca sa nekim zahtjevnijim igrama iz tog doba, jer tak je bilo tad. Velika vecina si nismo mogli priustit uber konfu na zakucanih 60fps. Isto mi je kul vidjet mali ghosting na starijim, sporijim 4/3 lcdima..
Al opet, svako na to gleda drugacijim ocima
vintage hi-tec
stereotyp je offline   Reply With Quote
Staro 20.03.2021., 22:14   #3335
Trekkie4
Više-manje ono što sam ti rekao, nadam se da si vidio post na prijašnjoj stranici?
Ali da, ako ciljaš na "best bang for the buck", onda ti je to svakako Voodoo3. Model 2000 ako želiš osnovno, 3000 ako želiš više, i 3500 ako želiš izvući maksimum
Fun fact, baš sam danas slušao Star Wars, Yodinu temu
Autor stereotyp Pregled postova
Ima jedna stvar o kojoj se ne govori, a to je kompatibilnost... Naime, Voodoo2 je backwards kompatibilna sa igrama koje su rađene za 3dfx Voodoo (jedinicu), dok Voodoo3 ima problema sa nekima od njih i zahtjeva posebne drivere ili prilagodbe da bi radile.
Ali, u pravilu se slažem. Dođeš na isto, jedino što ti V2 nudi tu mogućnost da "šlepaš" još jednu grafičku u tandemu (Ti4200, u mojem slučaju) i imaš "Best of both worlds"
Isto tako, probao sam svojevremeno jednu opciju kombiniranja Voodoo2 i Voodoo3. Netko bi rekao suludo i nepotrebno, ali eto - i to sam prošao. Takav setup zahtjeva posebni pristup, sa aplikacijom koja omogućuje prebacivanje sa jednog Glide sustava na drugi, i samim time odabir koji Glide (odnosno koju karticu) želiš - V2 ili V3.
Iskreno, kako mi je ostala jedna Voodoo2 čak razmišljam da je stavim u onu P3B-F konfu i uparim je sa V3 3000
Staro 20.03.2021., 23:33   #3336
Alien_200581
Postovi: 1,181
Zapravo u međuvremenu sam se domislio i trece opcije, i to vjerovatno hardverski najbogohulnije A to je da testiram kako ce se ponašati wrapper sa w98 i ti4200, actually sam procitao dosta dobrih stvari za takve ideje i geforce 4/5. Teoretski nemam nista protiv Voodoo3 ideje, ali me najvise smeta to kaj bi morao hititi van iz kompa ti4200, ili dati astronomsku cifru za PCI verziju V3 što je isto teški no-no.
Ali to sve kada stignem, prvo cu se uloviti MMX-a da ga skompletiram, mami me previse onaj 5.25 floppy...
I definitivno kužim vašu logiku da stroj bude iz vremena kojeg je i da se vrti na njemu prikladne stvari u prikladnoj rezi, i ta prica bi mi bila zakon da imam neki podrum od 80 kvadrata i da ga slozim u retro den u kojem bi bili kompovi i crti sa svih strana kao u starim igraonama Ali za sad nista od toga, maybe some day...
Za moj naum (pokriti sav gaming preko svih perioda sa cim manje konfi) ovekill hw je po mojoj logici najbolja opcija. Ove ideje sa SLI-em su samo završne finese za tu w98 konfu, jer taj rig je vec bio gotov sa ti4200 unutra. Ona vrti 99% stvari a dodatni V2 je fino uletio da izvrti jos ovih 1% koje su iskljucivo Glide naslovi. Iz moje perspektive smatram da su stvari koje rade u glideu a istovremeno i drugim API-evima cisti extra feature, u stilu "super je imati opciju izbora koji ces API" ali to nikako nije must. Tako da sad je samo pitanje koliko se još mogu ti extra feature-i "nabrijati" i za koju lovu, i ofc da si ja "odmeditiram" kolko mi je to napeto ili ne.
Staro 21.03.2021., 12:51   #3337
ICT Avatar
ICT Avatar's Avatar
Datum registracije: Dec 2014
Lokacija: Area 51
Postovi: 256
Kolekcionarski primjerak
ICT Avatar je offline   Reply With Quote
Staro 21.03.2021., 12:57   #3338
Thermaltake
1
Thermaltake's Avatar
Postovi: 3,613
Pronašao sam u šupi ovo čudo no bez kartice nje očito nemam, ne znam kolko je staro ko mi je dao ni ništa, jel netko imao takvo što ?
Staro 21.03.2021., 13:16   #3339
Trekkie4
Konektor izgleda kao obična EGA CGA grafička, možda griješim? Ako ti treba, sigurno bi se jedna našla u "čarobnoj" kutiji sa dijelovima za 386/486 mašine
Edit
Forum se i dalje raspada... Žalosno je da za toliko vremena nisu mogli riješiti problem
Edit2
Autor Alien_200581
Samo testiram da vidim dali ce se opet na tebi prelomiti sve
Testing testing
Vidim poruku, ali ne mogu odgovoriti... Čim odgovorim, baca Chuck Borisa Ali šalu na stranu, ovo postaje frustrirajuće, imam više dolazećih poruka, dealova, dogovora, a na pola toga nisam mogao odgovoriti. Jučer sam baš razgovarao sa @Riceburnerom telefonom, jer se nismo drugačije mogli dogovoriti što i kako.
Edit3
Autor Alien_200581
Haha da, ti brejkaš i dalje internetz sa svojim Voodoo magijama... Drugom kolegi je osla poruke bez ikakvih problema. Presmješno
Ista stvar, Roy i još nekoliko korisnika rade OK, i njih mogu kontaktirati bez problema. Ali tebe (i nekoliko drugih) ništa!
Zadnje izmijenjeno od: Trekkie4. 21.03.2021. u 13:34.
Staro 21.03.2021., 17:17   #3340
Roy
15/JG52
Roy's Avatar
Postovi: 771
Ja tebe baš i ne, Dobijem Chucka ali kasnije dobijem tvoj odgovor tako da poruke nekako ipak prolaze.
Anyway...traži se...BIOS
E sad, priča je ovakva. Već neko vrijeme imam Sapphire ATI 1950GT AGP verziju, kad sam je isprobao ne baca sliku ali se uredno grije pa sam odmah razmišljao o varijanti da dignem sistem sa PCI kartice dok je AGP također u utoru ali nisam...do danas. I što, kad se digne XP kartica se vidi u pronađenim uređajima pa mi je teorija da treba flešnuti BIOS da opet proradi. Problem, nema BIOS fajla. Techpowerup nema AGP BIOS (ima za PCI-E) Sapphire nema arhivu (poslao mail) pa pitam (koliko god mala šansa bila) ima li tko karticu da dumpa BIOS i pošalje.
Staro 21.03.2021., 18:03   #3341
Trekkie4
Autor Roy Pregled postova
Meni je drugačije... Kad želim odgovoriti Alienu na primjer, dobijem Chuck-a, i veli "Error 500", ali poruke NE prolazi. Barem mislim, neka Alien potvrdi. Ali kad kontaktiram tebe, Stefa, i još nekoliko drugih kolega poruke odmah prođu, bez ikakvih problema i grešaka.
E, sad je samo pitanje da li oni mogu odgovoriti meni, ili je one-way komunikacija?
Staro 21.03.2021., 20:24   #3342
Alien_200581
Postovi: 1,181
Prolazi prolazi, ali ja ne mogu poslati tebi. Isto tako i za ostale, baci 550tku ali kad odem u sent poruka je tamo. Ali ti... ti si uklet Iako ako si dobio ono testing onda znaci da ti je proslo. Ali za razliku od ostalih tvoju (tj moju poruku tebi) nemam u sentu... Svasta Tako da izgleda da poruka ipak prođe (valjda) ali bar meni za neke usere (sve osim tebe) mi ostane trag u sentu, a za neke nema nikakvih tragova da je ista otislo. Slicno je i sa forumom i postovima, kad refresham stranicu nakon 550tke post je uredno zakeljen u temi.
Edit: E da, i notifikacije mailom su no-go za išta
No imam jedno strucno pitanje... Prtljao sam malo sa MMX-om i 5.25 drajvom (zasad neuspjesno). Predpostavljam da ovakvi zvukovi bas i nisu dobar znak Pa samo da pitam ako netko moze po zvucu diagnosticirati, dali nekaj treba podmazati ili je nekaj krepalo nepovratno unutra... Jesu bili bucni ti drajvovi ali ne ovako. A i cini mi se da nikaj ne radi bogec nego samo rokce
https://streamable.com/ekhvvn
Zadnje izmijenjeno od: Alien_200581. 21.03.2021. u 20:50.
Staro 21.03.2021., 20:51   #3343
riceburner
SCSI Freak, deda :P
riceburner's Avatar
Lokacija: ZEGEIZABREGE
Postovi: 876
da, pukel je ili nekaj iskocilo oko zupcanika, provjeri prijenos...
use SCSI/SAS and live longer!
Staro 21.03.2021., 21:17   #3344
Alien_200581
Postovi: 1,181
Mhm tak sam nekak i mislio, glava se pomice u poziciju normalno ali kad bi trebao krenuti citati disketu krene pilana Tnx !
Staro 21.03.2021., 21:40   #3345
Postovi: 23,626
Mislim da može raditi kad skineš oklop, tako ćeš lakše čuti / vidjeti gdje "zapinje,
samo stavi neku plastiku ispod da ne bude kakvog kratkog spoja.
Edit: Al ga štuca, post prošao na guranje 😀
Staro 21.03.2021., 22:04   #3346
Trekkie4
Hmm, možda ne bi bilo na odmet rastaviti taj 5.25 FDD & detaljno ga počistiti, ali i podmazati "puža" silikonskim mazivom za plastiku.
Napravio sam sličnu generalku 5.25" pogona prije nekoliko godina, bilo je dosta problema ali sam ga uspio dobiti da radi
Staro 21.03.2021., 22:05   #3347
Trekkie4
@Stef
Jok, nisam pronašao modem. To sam pitao onak' usput, zato što ionako još nisam završio projekt, slažem sve malo po malo pa kad već ionako čekam one BTCove (koje si možda vidio u temi) ali i IDE/ATA kabel, mislio sam si da onda riješim i pitanje modema.
E sad, funkcija modema u Win98 konfi... Nema je Sigurno se pitaš "pa čemu onda sve to?!". I odgovor je zato što je originalno IMAO modem kad je došao iz Adisona. Rockwell 56k, V90 interni modem
U stvari, dobra većina mojih konfi koje sam podijelio i prodao ima(la) je dial-up modeme, i svi su bili potpuno funkcionalni, podešeni da zovu HiNet, sa pozivom "0 77 1 00000", i sa Home Page-om na http://www.HiNet.hr koji naravno više ne postoji. Mislim da sam na starijim konfama čak eksperimentirao sa "HPT" opcijom, korištenje "HPT/Gost" metode, koja je ujedno bila i najskuplja koliko me pamćenje služi.
Znači, modemi su potpuno funkcionalni i RADE, ali naravno da ih ne spajam na telefonski priključak. Svojevremeno sam razmišljao o nabavci nekog emulatora, generatora telefonskog signala da pospajam retro konfe na njega (tako da mogu čuti kako modem "zove" izlaznu liniju, ali odustao sam uglavnom zbog materijalnih razloga ... uostalom, već je sam modem dovoljno "retro" za ono što želim
Zadnje izmijenjeno od: Trekkie4. 21.03.2021. u 22:21.
Staro 21.03.2021., 22:23   #3348
Alien_200581
Postovi: 1,181
Yup, mislim da budem ga skroz raskopal (ak nis drugo da vidim kako i sta ima unutra) a usput i ocistim i namažem po potrebi. Idem tražit edukativne materijale
Edit: @Trekkie : Zaboravio ti napisati, imam samo jedan moderniji modem (nema iza nikakvih konektora samo za liniju). Ali reci mi dali sam dobro vidio ili je onaj Slot1 rig imao i modem u sebi ? Ako da i ako se sjecas da bi ti pasao taj modem drage volje ti ga izvadim Mrežnu bi još možda u nekoj konstelaciji i koristio jednog dana, ali modem def nema sanse. 99% da bum ga tak i tak izvadio i strpao u neku kutiju kad se ulovim tog riga, tako da ako hoces dam ti ih obadva prvom prilikom kad se vidimo.
Zadnje izmijenjeno od: Alien_200581. 21.03.2021. u 22:34.
Staro 21.03.2021., 22:30   #3349
Trekkie4
Pronašao sam slike...
Nažalost, ne vidi se puno (a i moj problem je bio drugačiji od tvojeg), ali u svakom slučaju - ako budeš rastavljao FDD, pazi na glave. Ako ih budeš skidao iz vodilice, metni komadić vate ili mekanog papira između, jer ako tresneš jednu o drugu mogu puknuti (i uništititi pogon)
Staro 21.03.2021., 23:27   #3350
Alien_200581
Postovi: 1,181
Prvo budem bacio fokus na to skvicanje/roktanje i pogledao motor. Imam filing da se ili nekaj pomaknulo ili da nesto treba podmazati, drive je skroz cist tako da sumnjam da je do prašine. Ali budem i glave malo "podragao" sa stapicima i izopropilom just in case... U svakom slucaju tnx za fotke
Staro 21.03.2021., 23:45   #3351
Trekkie4
Krenuo sam ti odgovarati na ovo, kad je forum "roknuo". Uglavnom, ne treba ali hvala na ponudi
I da, dobro si vidio. Onaj jedan Adison (ako si na njega mislio) ima modem, zapravo SVI ih imaju ali taj jedan o kojem pričam ima neki prastari ISA modem, kojeg sam stavio reda-radi. Drugi ima Motorolu, a treći nisam siguran ... možda čak i Rockwell!
Uglavnom, trebao bi promijeniti onog sa ISA modemom, pa sam se raspitao da li eto netko možda ima stariji tip modema, viška. Napominjem stariji tip jer nema smisla stavljati one nove, bolje onda da mu ostane taj prastari ISA koji se predstavlja kao "Generic Modem", nisam siguran čak ni o kojem je čipu riječ. Uglavnom, nešto prastaro što zahtjeva ručnu konfiguraciju IRQa i adrese, starije čak i od samog Adisona
Staro 21.03.2021., 23:51   #3352
stef
stef's Avatar
Lokacija: Zabok
Postovi: 3,419
Autor ICT Avatar Pregled postova
Fino . Imao sam to čudo cca 2005. na DFI LP UT s754.
Staro 22.03.2021., 00:23   #3353
Postovi: 23,626
Nisam siguran da imam negdje "deponiran" koji modem,
ako nađem prijavim ovdje i doniram zainteresiranima 😀
Staro 22.03.2021., 00:49   #3354
Trekkie4
Autor Nikky Pregled postova
Hvala
Znači, da evo ponovim kriterije po kojima sam tražio modem (zbog svih ovih forumskih problema se zagubilo)
- Da je barem 56k v90
- Da je po mogućnosti Rockwell (iako nije obavezno, može biti PCI ili ISA, također nije bitno)
- Da ima 3.5mm konektore za slušalice & mikrofon (kao sa slike ispod)
- Da je old school, bez ikakvih softverskih emulacija.
Staro 22.03.2021., 13:26   #3355
Roy
15/JG52
Roy's Avatar
Postovi: 771
Sapphire 1950GT part deux
Iako mi se na prvi pogled činilo da je kartica neoštećena sad sam utvrdio da ipak nije
Nedostaju 4 ova mala kondenzatora za koje pretpostavljam da je identičan postojećem pod oznakom C1937. Pitanje glasi, kako utvrditi ili možda netko prepoznaje koji su u pitanju?
Inače kad dignem XP sa primarnom PCI karticom AIDA uredno vidi koja je kartica, memorija, BIOS etc...
@Trekkie: imam nešto slično ovom Conexant RS56/SP-PCI
Zadnje izmijenjeno od: Roy. 22.03.2021. u 13:34.
Staro 22.03.2021., 14:11   #3356
Overclock
Overclock's Avatar
Datum registracije: Mar 2009
Lokacija: Zagorje
Postovi: 1,001
@Roy
Ne isplati se zamarati sa shemom i trazenjem identicnog kondica, stavi se drugi slicnog ili malo veceg volumena i to je to. Pošto nema oznacen polaritet, onda ga vrlo vjerojatno niti nema i nije bitan. Tamo di je bitno, oznaceni su i PCB i kondenzator.
Staro 22.03.2021., 14:18   #3357
Trekkie4
Odlično, iako mi se više kolega već javilo za modem. Ali od viška glava ne boli, bolje da mogu birati nego da imam jednog manje
Staro 22.03.2021., 14:57   #3358
Postovi: 23,626
Evo pogledao sam, ipak nije završilo u smetju
Radi se o USR263095-OEM > specs & drv > https://www.usr-emea.com/support/s-p...unkg&prod=3095
Da se ne zezam sa slikavanjem izgleda isto kao sa ovog linka > https://www.ebay.com/itm/U-S-Robotic...-/372945320273
- Da je barem 56k v90 > Da
- Da je po mogućnosti Rockwell (iako nije obavezno, može biti PCI ili ISA, također nije bitno) > drugi "klan" - USRobotics
- Da ima 3.5mm konektore za slušalice & mikrofon (kao sa slike ispod) > Ne, ali uredno koristi pc mic i slušalice
- Da je old school, bez ikakvih softverskih emulacija. > Da/Ne, vidi prethodno, stabilno radi (nikad problema)
- i nešto šta nisi naveo, prava verzija sa Line In i Tel. out + relej, u ono vrijeme važan detalj jer relej odspoji tel. i nema smetnji / pucanja veze
Usput ima jedna M-CME8738-4Ch Sound Card > izdleda ovako samo je crveni pcb > http://tse3.mm.bing.net/th/id/OIP.mH...id=ImgDet&rs=1
ATI Radeon 9600 PRO 256MB 128bit DDR AGP > https://www.classicvga.com/product-p...128bit-ddr-agp
samo tvornički sa drugačijim hladnjakom kao ova > https://www.njuskalo.hr/graficke-kar...-oglas-5625711
još ima GV-R9000 PRO II AGP > https://www.gigabyte.com/hr/Graphics...9000-PRO-II#ov
zlatni ventilator je prdeknio pa je netko stavio neki crni
EDIT: Zaboravio staviti:
ASRock P4i65G > https://www.asrock.com/mb/intel/p4i65g/
neki P4 cpu isod hladnjaka (neda mi se sad rastavljati koji je)
1 GB ram (2x 512 MB)
to bi bilo dobro u kompletu ako ima zainteresiranih
Sve je radilo / bilo ispravno u momentu vađenja iz kompa.
That's it
Zadnje izmijenjeno od: Nikky. 22.03.2021. u 16:04.
Staro 22.03.2021., 15:04   #3359
Postovi: 8,238
Posto 9600pro?
Staro 22.03.2021., 15:49   #3360
Postovi: 23,626
Ljudi smo, dogovorit ćemo se
