Staro 25.01.2021., 14:08   #541
lajchi
Postovi: 506
@thesaint255
Ima neki iritannti zvuk, ali jos nisam siguran da li je pumpa ili vent od ploce.
lajchi je offline   Reply With Quote
Staro 27.01.2021., 09:59   #542
Dottore
Dottore's Avatar
Postovi: 7,701
Small form factor (SFF) buildovi
Autor lajchi Pregled postova
@thesaint255
Misliš orginalni vent od Nzxt?
Edit.
Za fanove mrzitelja šarenih Noctua -Arctic izdao Slim ventiltore 120mm x 15mm
https://www.techpowerup.com/277757/a...0mm-15mm-thick
Отправлено через iPhone
HP 845 G9
CPU: AMD Ryzen 7 PRO 6850U
RAM: 64GB Samsung DDR5 4800
Graphic: AMD Radeon 680M
LCD: 14" IPS @ 1920 x 1200
OS: Windows 11 Pro 25H2
Mice: Logitech MX Master 3S
Lenovo ThinkPad P15v Gen 3
CPU: AMD Ryzen 7 PRO 6850H
RAM: 64GB DDR5
Graphic: AMD Radeon
LCD: 15" IPS @ 3840x2160
Lenovo ThinkPad T14 Gen 3
RAM: 16GB soldered LPDDR4
Mice: Logitech VX Nano
Lenovo X1 Carbon 7th Gen
CPU: Intel Core i7-8665U
RAM: 16GB soldered LPDDR3
Graphic: Intel HD 620
LCD: 14" IPS @ 2560x1440
Lenovo X1 Carbon 10th Gen
CPU: Intel Core i7-1260p
SSD: Sk Hynix 512 GB NVMe M.2
Graphic: Intel Iris Xe
LCD: 14" IPS @ 1920x1200
Zadnje izmijenjeno od: Dottore. 27.01.2021. u 10:07.
Staro 27.01.2021., 14:18   #543
thesaint255
thesaint255's Avatar
Datum registracije: Dec 2009
Lokacija: Graz
Postovi: 539
Original nzxt vent nije izvor zvuka, pumpa je 100%. Ali da, zamijenio sam nzxt vent sa noctuom.
7800X3D @ Scythe Fuma 2
ASRock B650I Lightning WiFi
32 GB Corsair Vengeance DDR5-6000
RTX 4070 ti Gamerock
Corsair SF750
Cooler Master NR200P
thesaint255 je offline   Reply With Quote
Staro 27.01.2021., 18:59   #544
Dottore
Dottore's Avatar
Postovi: 7,701
A mislio sam na drugi vent osim Noctue.
Prije sam bio zainteresiran za H1 dok nisam saznao problem. Sviđa mi što dolazi vodenjača i napajanje. I tako okrenuo interes za Coolermaster NR200P, može napraviti 3D print za kavez ATX napajanje.
Отправлено через SM-G975F
HP 845 G9
RAM: 64GB DDR5
Graphic: AMD Radeon
Staro 27.01.2021., 20:24   #545
Postovi: 8,231
Nikako da naučite. Pumpa se čuje, specifičnim zvukom, svaka.
Ako idete na totalno nečujno, onda neidete na najjači hardver, a pogotovo ne na vodeno hlađenje.
Autor Dottore Pregled postova
Edit.
Inače, ove godine izlaze neki crni kuleri od noctue, al drago mi je da se napokon ima neka alternativa u tom segmentu 15mm ventova.
Staro 27.01.2021., 21:37   #546
Dottore
Dottore's Avatar
Postovi: 7,701
Odlično.
Nisam baš mrzitelj kričave. Ali drago mi je što se otvara veća ponuda za niže cijene. Više naginjem veći MTBF i kvalitetan ležaj. S-Flex, Minebea, Gentle Typhoon i SanAce (Sanyo Denki)
HP 845 G9
RAM: 64GB DDR5
Graphic: AMD Radeon
Staro 27.01.2021., 21:46   #547
thesaint255
Lokacija: Graz
Postovi: 539
Ja sam imao i custom vodena i AIO solucije zadnjih 10-15 godina u koristenju i nisam idiot da neznam sta ocekivati od pumpe, ova u H1 je stvarno minijaturna ( smjestena je u samom radijatoru, nasred radijatora ) i stvarno pika usi ako se rucno ne namjesti na neke skroz niske okretaje, nisam niti u jednom reviewu na youtubeu cuo da se pumpa tako glasa a ekipa je demonstrirala akustiku sa mikrofonom tik do nje. Imam osjecaj da bas mi je uletio li-la primjerak. Ali ostatak je super, napajanje je necujno i temperature sasvim snaznog hardvera je jako impresivna. Ako pumpa ode jos nagore cu kontaktirati H1 i zamoliti ih da mi samo posalju AIO zasebno da ne saljem cijelo kuciste natrag.
Corsair SF750
Staro 28.01.2021., 06:01   #548
lajchi
Postovi: 506
Edit.
Ne, mada i taj sam zamijenio Noctuom.
Mislim na vent od x570 chipseta na maticnoj ploci.
Staro 28.01.2021., 10:50   #549
Dottore
Dottore's Avatar
Postovi: 7,701
Negdje sam vidio kako ekipa montirala malenu Noctu-u na Asus i Gigabyte
Imam Gigabyte X570 I Aorus Pro Wi-Fi i baš ne čuje zujanje sa trenutnim biosom F31. Nabavio sam prije 2 mj i znajući za negativne komentare zbog zujalice kada je bila predstavljena. Možda putem biosa i AGESA smanjili opterečenje chipseta, smanjili okretaje.. Ipak ću nabaviti Noctua vent za rezervu jer sam prilično zadovoljan stabilnošću i bez bugova.
HP 845 G9
RAM: 64GB DDR5
Graphic: AMD Radeon
Staro 28.01.2021., 13:29   #550
lajchi
Postovi: 506
Gledao sam sad malo oko ventova. Na zalost, Asus ima 30mm vent, dok je najmanja Noctua 40mm. Citao sam da su na mom modelu maticne znali zaboraviti thermal pad, tako da je i to moguci problem.
Staro 31.01.2021., 16:23   #551
rendula
Lokacija: Zagreb, Trešnjevka
Postovi: 5,777
https://youtu.be/AZWRcTqBqjQ
Optimum tech opet testira glupa-ideja build sa milijun undervolta.
Staro 31.01.2021., 20:47   #552
riba2233
riba2233's Avatar
Datum registracije: Nov 2020
Postovi: 26
Moj novi build ako nekoga zanima:
https://www.reddit.com/r/sffpc/comme..._3700x_vega64/
Sve je apsolutno nečujno
riba2233 je offline   Reply With Quote
Staro 31.01.2021., 21:38   #553
Postovi: 8,231
Gledao sam konfigurator čim si izbacio. Fakat je versatilno.
Nažalost, neke stvari sam rješavao pa kućište nikako da dođe na red, ali jednog dana bude.
Staro 01.02.2021., 12:27   #554
Dottore
Dottore's Avatar
Postovi: 7,701
Autor rendula Pregled postova
Dobar bilder.
Ja ne bi odrekao 120mm venta.
HP 845 G9
RAM: 64GB DDR5
Graphic: AMD Radeon
Staro 02.02.2021., 16:16   #555
Dottore
Dottore's Avatar
Postovi: 7,701
Opet zgodni Stevo o NXZT H1
HP 845 G9
RAM: 64GB DDR5
Graphic: AMD Radeon
Staro 07.02.2021., 01:03   #556
MegaSkot
Modder
MegaSkot's Avatar
Lokacija: Waterford
Postovi: 919
Stigao NR200P, sad jedan Minecraft mod, full custom water cooling.
Staro 07.02.2021., 03:02   #557
Postovi: 8,231
Taj Masterbox NR200 je rjeđi od cjepiva za covid
Baci neke slike kada budeš radio u svakom slučaju.
Staro 07.02.2021., 03:33   #558
MegaSkot
Modder
MegaSkot's Avatar
Lokacija: Waterford
Postovi: 919
Caseking ih ima.
Staro 07.02.2021., 11:03   #559
Postovi: 10,254
Gledao sam prosli mj. NR200 (bez stakla) i nema pa nema. Ovih sa staklom uvijek ima, cak i kod nas ih se nadje.
Staro 07.02.2021., 11:06   #560
rendula
Postovi: 5,777
Autor xlr Pregled postova
NR200 non-P afaik nece ni biti dostupan u Europi. Kupis P, prodas riser i bacis tempered glass ako ti smeta.
Staro 07.02.2021., 11:24   #561
Dottore
Dottore's Avatar
Postovi: 7,701
Autor Pupo Pregled postova
Tako je, jako rijedak i teže dobavljiv u posljednje vrijeme (Links pogotovo)
Više bi volio imati bez stakla radi protoka zraka
P.S.
treba dobro paziti na visinu tower hladnjaka
Edit.
Znam da kolega @xulos ima bijelog i fino složio.
Staro 07.02.2021., 11:30   #562
rendula
Postovi: 5,777
Cek sta nema on Ghosta? Nije se pohvalio Coolermasterom.
Staro 07.02.2021., 11:41   #563
Postovi: 10,254
A tako znaci, P verzija dolazi kao 2u1 varijanta, pa kako to nisam znao? U tom slucaju sve jasno!
Ima ili je imao. Jer ni u zadnjem oglasu vise nije spominjao Ghosta za prodaju #babetracare
Mislim da sam taj stari oglas otvorio jedno pet puta... Svrbilo me
Staro 07.02.2021., 11:54   #564
gibo
gibo's Avatar
Datum registracije: Feb 2010
Postovi: 187
Da, P verzija dolazi sa obje bočne stranice. Na kućištu je metalna perforirana stranica i u zasebnoj kutiji dolazi tempered glass stranica. Ja sam ga lani uzeo u Linksu.
gibo je offline   Reply With Quote
Staro 08.02.2021., 14:54   #565
JuiceBox
Xulos :)
JuiceBox's Avatar
Postovi: 7,579
Haha vidi baba sto prate Da, otisao louqe u dalmaciju, ugrabio u linksu za 660 kn nr200p. Zamjenio sam 2080ti sa 3070 i to je to.
IMG-3446 IMG-3447
B59-D85-C4-3-F23-4-C37-B7-C1-505-F6-AE5820-B
Staro 08.02.2021., 16:06   #566
Dottore
Dottore's Avatar
Postovi: 7,701
Napokon si živ!!!! #Babeeee, živ je.
HP 845 G9
RAM: 64GB DDR5
Graphic: AMD Radeon
Staro 09.02.2021., 19:30   #567
dukee
dukee's Avatar
Lokacija: vz
Postovi: 466
Doslo je hebeno dobro kuciste na EU lager, njega sam gledao dok sam jos bio u nabavci Loque/T1
https://www.caseking.de/jonsbo-v10-m...-gejb-073.html Jonsbo v10
dukee je offline   Reply With Quote
Staro 10.02.2021., 16:26   #568
Postovi: 8,231
I onda si od sve muke i odabira izdao i boga i rvacku i uzeo matx kuciste
Staro 13.02.2021., 12:38   #569
the_ghost
lar~
the_ghost's Avatar
Postovi: 1,557
Staro 13.02.2021., 15:49   #570
Dottore
Dottore's Avatar
Postovi: 7,701
Bilder
