Staro 01.01.2020., 20:59   #2971
Postovi: 8,667
Purported internal Intel doc reveals Core i9-10900K tests: Up to 30% gain in threaded work
This document includes SYSmark, SPEC, XPRT, and Cinebench benchmarks, and with the exception of Cinebench, most of these benchmarks are quite kind to Intel and are used quite frequently in Intel's internal benchmarks. That 30% performance bump comes from the SPEC benchmark, and Cinebench R15 results are just behind it with a 26% increase. Given that the 10900K is a ten-core CPU and the 9900K is only an eight core, it isn't surprising that we're seeing this kind of performance. Other benchmarks show a much lower improvement, especially XPRT which averages about 3-4% higher on the 10900K than the 9900K. This benchmark measures single-threaded performance, and since we know the architecture isn't really that different than its predecessor, it's almost certain that Intel has yet again increased clock speeds with this upcoming 10th-Gen chip. It's noteworthy that the test results peg the 10900K at a 125W TDP, but also lists a 250W TDP. The second value should represent the chips' PL2 power state that's required to hit all-core boost clock rates.
Izvor: Tom's Hardware
Staro 01.01.2020., 21:06   #2972
MAHER
Postovi: 1,583
Znaci realno 300W za hladenje? Vruce za proc.
MAHER je offline   Reply With Quote
Staro 01.01.2020., 22:01   #2973
thunderbird
Premijum AMDebil
thunderbird's Avatar
Lokacija: jastrebarsko
Postovi: 1,150
Grijalice za zimske dane
X
Staro 02.01.2020., 10:47   #2974
Chuxonja
Pajcek
Chuxonja's Avatar
Datum registracije: Jun 2012
Postovi: 1,090
Skidaju sve rekorde, ovo bu bolja grijalica od bilokoje AMDove do sada, how the turn tables
CPU: i7-4790K @4.3 GHz + Scythe Ninja 3
MBO: ROG Maximus VII Ranger
ODD: Asus DRW-24B1ST
SSD: Intel 760p 256GB NVME
HDD: WD Purple 1TB
PSU: FSP Hyper 700W
CASE: Antec 1200
OS: Windows 10 Pro
CPU: i5-4690K @4.5 GHz + Raijintek Themis
MBO: ASRock Z87 Pro3
GPU: Intel HD Graphics 4600
ODD: LG GH24NS70
PSU: Corsair TX 650W
CASE: Zalman Z3 Plus
OS: Windows 10 Pro
MBO: Gigabyte GA-X58A-UD7
GPU: Gigabyte HD 5450 1024MB
SSD: Corsair Force GT 120GB
HDD1: Toshiba P300 2TB
HDD2: Hitachi DeskStar 2TB
HDD3: Hitachi DeskStar 2TB
HDD4: WD Green 2TB
HDD5: WD Red 2TB
HDD6: WD Purple 4TB
PSU: Corsair CX 600M
CASE: Chieftec Bravo
OS: Windows 10 Pro
MBO: Asus P5Q SE/R
FDD: Samsung SFD-321B 3.5"
ODD: LITEON iHAS124
CASE: Antec Sonata
LINK
MBO: Abit AB9 Pro
RAM: 6GB DDR2 800MHz
GPU: Asus R7 240 2GB
ODD: LG CH10LS20
SSD: LITE-ON LCS-256L9S 256GB
HDD1: WD Green 1TB
HDD2: Seeagate Baracuda 2TB
CASE: Lian Li PC-7FNB
LINK
MBO: Epox EP-AF550 Pro/G
GPU: Sapphire HD 4850 1024MB
FDD: Alps DF354H 3.5"
ODD: LG GH22LP20
PSU: Levicom VP450B.BL
CASE: Xilence X1
OS: Windows 7 Pro
LINK
MBO: Abit AI7
RAM: 4x1GB Kingston 400MHz
FDD1: TEAC FD-235HF 3.5"
FDD2: TEAC FD-55GFR 5.25"
ODD2: Pioneer DVR-112DBK
PSU: Enlight 400W
CASE: Chieftec Dragon
OS: Windows XP SP3
LINK
CPU: Athlon XP 3200+
MBO: Gigabyte GA-7N400
RAM: 2x1GB Kingston 400MHz
ODD2: Pioneer DVR-107D
HDD: WD 160GB
PSU: MS Platinum 400W
OS: Windows XP SP3
CPU: Pemtium MMX 233
MBO: Vtech VIB804DS
RAM: 2x32MB SDRAM
GPU1: ATi AIW 3D Rage Pro
SND: Sound Blaster 16
FDD1: Mitsumi D359T5 3.5"
FDD2: Mitsumi D509V2 5.25"
ZIP: Iomega Z100ATAPI
ODD: Mitsumi CRMC-FX400
HDD: Seagate U4 6.4GB
PSU: DTK PTP-2008 200W
CASE: ES-COM AT case
OS: Windows 98SE
LINK
Dobar trgovac: 1, 2, 3, 4, 5, 6, 7, 8, 9, 10, 11, 12, 13, 14, 15, 16, 17, 18
Živi bili pa umrli!
Staro 02.01.2020., 11:46   #2975
thunderbird
Premijum AMDebil
Postovi: 1,150
Ono kad misliš da veća grijalica od FX9590 neće postojati
X
Staro 02.01.2020., 18:39   #2976
Manuel Calavera
Manuel Calavera's Avatar
Postovi: 14,589
Pa i9 9900K je već prekobacio FX 9590 po potrošnji
Staro 03.01.2020., 02:05   #2977
Postovi: 8,667
Lako za potrošnju, jer na kraju šampion je ipak...
How to tarnish Platinum: Sell it as Xeon 9200 (Not so scalable)
In 2019, Intel announced its Cascade Lake family of enterprise processors, and sitting at the top of the stack was the Cascade Lake-AP family: a quartet of parts that changed Intel’s paradigm for high-end processors. This hardware used two of Intel’s large 28-core silicon dies in the same package, providing a weakly linked dual-processor system in a single package, built to look like a single processor up to 56 cores and 12 memory channels with up to a 400W TDP. Despite not providing pricing, Intel is keen to promote the Xeon 9200 as its extreme performance platform up against AMD’s 64-core EPYC "Rome" offering.
One of the large OEMs was very clear that they don’t plan on stocking or reselling the Xeon 9200 system. Instead, the customers for which the Xeon 9200 might be reasonably relevant are requesting quad-socket platforms and blades. A true quad-socket system will offer more total memory than a Xeon 9200 system, can potentially support Optane, and uses socketed processors that can be adjusted and configured easily. Not only that, but the system would be easier to cool. One of Intel’s resellers gave us some insight into their contracts. This particular company deals with a number of university supercomputing contracts – those that work with separate research grants and add to their compute power over time, and perhaps spend $20k-$250k per year to build their systems. These systems might also be held off-site. These customers aren’t interested in Xeon 9200. Even bigger customers, spending $1-2m a year, aren’t looking at Xeon 9200 either.
Izvor: AnandTech
...i nažalost nitko ih neće - kupiti ili staviti u ponudu.
Staro 04.01.2020., 21:10   #2978
suedamA obmaR
Game, PC ,motobikes, bike
suedamA obmaR's Avatar
Datum registracije: Jan 2010
Lokacija: Sibenik
Postovi: 779
Autor thunderbird Pregled postova
Nek tog intela pokuša 120 aio ohladit, mog 9590 nekako i drži oko 62 stupnja a da para ne izlazi na radijator.
suedamA obmaR je offline   Reply With Quote
Staro 06.01.2020., 17:32   #2979
Postovi: 8,667
Intel at CES 2020: 45W 10th Gen Mobile CPUs Soon, Tiger Lake with Xe Graphics Later
For CES 2020, Intel has disclosed a couple of products for consumption: moving its 10th Gen mobile CPU line in to 45 W hardware, but we also had a couple of details about the post-Ice Lake hardware, called Tiger Lake. With the 45 W mobile CPUs, it’s important to note that we are talking about Comet Lake here – Intel’s latest 14++ nm microarchitecture derived from the original Skylake but optimized from the latest Coffee Lake hardware. What this means for users is essentially a small improvement in frequency: Intel isn’t saying that much with what the new CPUs will bring at this point, but they are pointing out that they will be hitting 5.0 GHz with the new 45W Core i7 parts, and more than 5.0 GHz with the Core i9 hardware.
The other part to Intel’s disclosure at CES is Tiger Lake. What is Tiger Lake, you may ask – it’s the next mobile platform beyond Ice Lake. Bearing in mind that Intel has been speaking about Ice Lake a while, and we now finally have top tier partners with 1065G7 designs, we’re still waiting for Intel’s mid-tier and lower-tier partners to come out with the platform. So we’re still a long way away from Tiger Lake, unless Intel wants to move beyond Ice Lake quickly. However, regarding Tiger Lake specifically, Intel did confirm that it has Xe graphics. Whether this is related to the DG1 silicon that the company has spoken about recently isn’t clear, but Tiger Lake is monolithic and the Xe graphics inside will provide full INT8 support for AI workloads (which will be supported through Intel DL Boost)
Izvor: AnandTech
Staro 06.01.2020., 18:14   #2980
Mladenxy
Mladenxy's Avatar
Postovi: 4,511
Kak je rekel Škot, godišnje ide 160 miliona laptopa i tu je glavna lova.
Staro 06.01.2020., 18:19   #2981
Postovi: 8,667
To sigurno, Intel drži itekak čvrsti stisak na tom dijelu tržišta, možda AMD uspije oteti koji postotak s novom mobilnom 4000 serijom, ali Intel bude i dalje alfa i omega. Vijesti o novom LGA socketu također zvuče zanimljivo.
EDIT:
Zadnje izmijenjeno od: The Exiled. 07.01.2020. u 02:01.
Staro 07.01.2020., 13:07   #2982
Manuel Calavera
Postovi: 14,589
Unhappy
Znači chiplet dizajn na 1700 socketu krajem 2021 god. Naravno nije official, ali tako sam i očekivao
Staro 07.01.2020., 13:57   #2983
Postovi: 8,667
Je, nemaju drugi put, jer 14nm im sad već opasno udara u zid. Jedino kaj taj novi pravokutni socket izgleda dosta veliko za dosadašnje desktop modele.
Staro 07.01.2020., 14:13   #2984
Manuel Calavera
Postovi: 14,589
To je možda za dugoročno, jer će se ići na sve veći broj jezgri. Moraju biti spremni na 16+ jezgri, možda i do 32 jezgre, da ih AMD opet nebi zaskočio
Staro 07.01.2020., 15:17   #2985
Postovi: 8,667
Jedino kaj se sad nadolazeći LGA-1200 skoro, pa može odmah umiroviti, jer ne bude trajal dulje od godinu dana i evo opet smjena generacija na LGA-1700.
Staro 07.01.2020., 15:31   #2986
Manuel Calavera
Postovi: 14,589
Neće ni taj 1700 možda više od 2 generacije držati, ali sam mislio dugoročno kao format tj. dimenzije. Radi buduće kompatibilnosti coolera od 10+ godina. A koliko će jezgri biti na mainstream socketima sljedećih cca 10 godina pitaj boga, ali sigurno neće biti malo i trebat će više prostora u svakom slučaju
Staro 07.01.2020., 15:39   #2987
Postovi: 8,667
Samo se bojim da od svega toga ne ispadne čušpajz, jer AMD je već sad počel s cijenama u stilu Intela u najboljim danima. Do 2021./2022. stignu itekakav zamah uzeti, a ovi još uvijek izmišljaju toplu vodu s 10nm.
Staro 08.01.2020., 18:24   #2988
Mladenxy
Mladenxy's Avatar
Postovi: 4,511
Malo o Intelovom prljavom marketingu.
https://www.youtube.com/watch?v=ahEmrGQvebQ
Staro 09.01.2020., 14:14   #2989
Postovi: 8,667
Autor MAHER Pregled postova
Ne da si znal, nego Ryan Shrout već šalje nagradu na tvoju adresu.
Intel Comet Lake-S: The finished mainboards have to wait for the CPUs
Not a single word from Intel about Comet Lake at the CES 2020 press conference. There is a reason for this and motherboard manufacturers are not very happy because their products are all ready. But ten cores still cause some problems - and the power consumption is said to have washed. Complete motherboard series, led by the Z490 chipset, are just waiting for the go from Intel - but that won't come for a few months. Several motherboard manufacturers revealed that the ten-core break the 300-watt mark at maximum load. The high power consumption in the desktop could be one reason why no ten-core CPU has been seen for notebooks.
Izvor: ComputerBase
Staro 09.01.2020., 16:45   #2990
Manuel Calavera
Postovi: 14,589
Logičan slijed kad i9 9900K na 5ghz povuče 250w u torture loopu (prime95 avx on), stock 205w. I još sko efikasnot još opada...
Zadnje izmijenjeno od: Manuel Calavera. 09.01.2020. u 16:53.
Staro 09.01.2020., 19:36   #2991
Mladenxy
Mladenxy's Avatar
Postovi: 4,511
U gamingu je na 70 w i nije nikakav problem osim cijene. Brijem da se nitko od nas ne bi bunio da nam ga netko pokloni
https://www.tomshardware.com/reviews...u,5847-11.html
Staro 09.01.2020., 20:01   #2992
Manuel Calavera
Postovi: 14,589
Nije gaming problem, ali ploča mora moći izdržati maximalne scenarije, da izbace 10 core pa da se ploča otopi svakome ko odvrti stress ili render. Ploče su kaže tekst gotove, a ovaj probija neke standarde
Staro 09.01.2020., 21:39   #2993
Postovi: 8,667
Pripremaju se nove revizije, jer ovo kaj sad imaju na čekanju bude u rukama korisnika završilo ko prve X299 ploče. Proizvođači su na temelju Intelovih specifikacija pripremili VRM i popratnu skalameriju koja nažalost ne može držati deseterojezgrene modele pod kontrolom. Intel s jedne strane forsira 5.0GHz+ na svemu kaj imaju u ponudi, ali jebiga - dodatne dvije jezgre i još malo viši takt - uzimaju svoj danak. Ostaje za vidjeti koliko dugo bude se predviđenih nekoliko mjeseci stvarno odužilo da se pripreme nove revizije Z490 ploča.
Staro 09.01.2020., 22:02   #2994
Manuel Calavera
Postovi: 14,589
Inače više glasina tvrdi da je all core na 10 coreu 4.8ghz, potencijalno 4.9ghz uz neki feature i brutalno hlađenje tipa chilleri
Staro 09.01.2020., 22:04   #2995
Postovi: 8,667
Ti mater (Intel), znači propisno crni scenarij i ajde da je to HEDT platforma - ovak za mainstream desktop dodatno grdo izgleda.
Staro 09.01.2020., 22:21   #2996
Manuel Calavera
Postovi: 14,589
The chip has a base frequency of 3.7 GHz and a boost frequency of 5.1 GHz. However, using Intel's Turbo Boost Max 3.0 technology, the chip can boost up to 5.2 GHz on a single-core and what's even better is the 4.9 GHz all-core boost. Some of the features of this particular chip, as detailed by Videocardz, include:
Up to 4.8 GHz All-Core Turbo
Up to 5.3 / 4.9 GHz Thermal Velocity Boost Singe / All-core Turbo
Up to 5.2 GHz Intel Turbo Boost Max 3.0
Up to 10C and 20T
Up to DDR4-2933 MHz dual-channel
Enhanced Core & Memory Overclocking
Active Core Group Tuning
Here's the interesting part, the chip would also get Thermal Velocity Boost, similar to the current flagship parts. CPUs that support this algorithm, like the Core i9-10900K, would feature even faster boost frequencies of 5.3 GHz (single-core) and 4.9 GHz (all-core). However, as the name suggests, only top-tier cooling solutions would be able to allow full utilization of the Thermal Velocity Boost feature. So unless you rock a high-end AIO liquid cooler or a closed-loop setup, don't expect a sustained velocity boost but rather short bursts until the threshold is hit. It will be interesting to know the full extent of the features that this function has to offer and what kind of cooling would the Core i9-10900K requires in general.
https://videocardz.com/newz/intel-co...-lake-s-leaked
Staro 09.01.2020., 22:33   #2997
Vrlo bitno pitanje: ide li na Z370 i Z390 ploče? Ako ne ide, onda su stvarno gamad veća nego što jesu...
Staro 09.01.2020., 22:42   #2998
Postovi: 8,667
Tak jasno da ne ide. Znaš kakva firma je u pitanju. I onda za godinu dana nakon toga izlazi novi LGA-1700 socket.
Staro 09.01.2020., 22:49   #2999
Znači uz 4500 kn za proc, trebati će još 2500 kn za ploču i 1500 kn za hlađenje tako da proc može postići ono kako je deklariran?
Vjerujem da bude imao svoju publiku. Kod nas teško ali vani kupaca sigurno bude.
Staro 09.01.2020., 22:53   #3000
Postovi: 8,667
Zasad kruže glasine da bi to čudo koštalo u rangu 650/700$, znači kod nas skoro hladnih 1.000€ kad se svi lijepo namire. I onda kad pogledaš da HEDT Core i9-10900X ima slične taktove i iste muke u odnosu na Zen 2.
Ne bude taj mainstream model ni toliko daleko od HEDT brata. Samo da bi ga unutar godinu dana pokopali sa 10nm++ chiplet-design modelom ili kaj već budu izmislili. Nema računice za LGA-1200 kak god se okrene.
