Staro 03.05.2016., 15:39   #1
Glavas_ZG
Datum registracije: Feb 2015
Postovi: 218
Intel "Kaby Lake" LGA-1151 Info Thread
Kaby Lake will add native USB 3.1 support, whereas Skylake motherboards require a 3rd-party add-on chip in order to provide USB 3.1 ports. It will also feature a new graphics architecture to improve performance in 3D graphics and 4K video playback. Kaby Lake will add native HDCP 2.2 support. Kaby Lake will add full fixed function HEVC Main10/10bit and VP9 10bit hardware decoding. Kaby Lake will have an integrated memory controller that supports both DDR4 (2400 MHz) and DDR3 (1600 MHz) memory. It looks like Kaby Lake will be more of the same, slightly better in energy efficiency, though it has to be stated - the processor listed would be an engineering sample. Intel will release Kaby lake in the 2nd half of 2016.
http://www.guru3d.com/news-story/int...ppearance.html
Zadnje izmijenjeno od: Glavas_ZG. 16.06.2016. u 11:02.
Glavas_ZG je offline   Reply With Quote
Staro 03.05.2016., 16:01   #2
JuiceBox
Xulos :)
JuiceBox's Avatar
Postovi: 7,581
Klasicno prodavanje muda pod bubrege. Nije govno nego se pas posro. Nerazumjem potez intela izbacit ISTI cpu s drugim imenom, sreca pa nisu socket mjenjali. Prvi put se nadam da ce amd ubost s ovim zenom da malo spuste ove na zemlju.
Staro 03.05.2016., 16:29   #3
Glavas_ZG
Postovi: 218
Autor xulos Pregled postova
Mene je iznenadilo da je boost ''samo'' 4.2Ghz obzirom na i7 4790k koji je sad već star 2 generacije a i dalje ima najveći turbo boost.
Staro 03.05.2016., 18:11   #4
animATrIx
animATrIx's Avatar
Lokacija: Vukovar-Osijek
Postovi: 491
Autor Glavas_ZG Pregled postova
vjerojatno nisu promijenili kvalitetu paste ispod heat spreadera
animATrIx je offline   Reply With Quote
Staro 03.05.2016., 18:23   #5
kurc
kurc's Avatar
Datum registracije: Aug 2008
Postovi: 237
Treba malo zdrave konkurencije, ali ako Zen uspije, onda će intel izmislit nešto novo nakon 5 godina, to će postati norma za AAA gaming - pola foruma će morati upokojiti sandy, a 3 mjeseca kasnije i ja svoj haswell.
kurc je offline   Reply With Quote
Staro 03.05.2016., 18:56   #6
Chuxonja
Pajcek
Chuxonja's Avatar
Datum registracije: Jun 2012
Postovi: 1,090
nemože, fujto. ja oću svoj devils canyon do penzije gurat
CPU: i7-4790K @4.3 GHz + Scythe Ninja 3
MBO: ROG Maximus VII Ranger
ODD: Asus DRW-24B1ST
SSD: Intel 760p 256GB NVME
HDD: WD Purple 1TB
PSU: FSP Hyper 700W
CASE: Antec 1200
OS: Windows 10 Pro
CPU: i5-4690K @4.5 GHz + Raijintek Themis
MBO: ASRock Z87 Pro3
GPU: Intel HD Graphics 4600
ODD: LG GH24NS70
PSU: Corsair TX 650W
CASE: Zalman Z3 Plus
OS: Windows 10 Pro
MBO: Gigabyte GA-X58A-UD7
GPU: Gigabyte HD 5450 1024MB
SSD: Corsair Force GT 120GB
HDD1: Toshiba P300 2TB
HDD2: Hitachi DeskStar 2TB
HDD3: Hitachi DeskStar 2TB
HDD4: WD Green 2TB
HDD5: WD Red 2TB
HDD6: WD Purple 4TB
PSU: Corsair CX 600M
CASE: Chieftec Bravo
OS: Windows 10 Pro
MBO: Asus P5Q SE/R
FDD: Samsung SFD-321B 3.5"
ODD: LITEON iHAS124
CASE: Antec Sonata
LINK
MBO: Abit AB9 Pro
RAM: 6GB DDR2 800MHz
GPU: Asus R7 240 2GB
ODD: LG CH10LS20
SSD: LITE-ON LCS-256L9S 256GB
HDD1: WD Green 1TB
HDD2: Seeagate Baracuda 2TB
CASE: Lian Li PC-7FNB
LINK
MBO: Epox EP-AF550 Pro/G
GPU: Sapphire HD 4850 1024MB
FDD: Alps DF354H 3.5"
ODD: LG GH22LP20
PSU: Levicom VP450B.BL
CASE: Xilence X1
OS: Windows 7 Pro
LINK
MBO: Abit AI7
RAM: 4x1GB Kingston 400MHz
FDD1: TEAC FD-235HF 3.5"
FDD2: TEAC FD-55GFR 5.25"
ODD2: Pioneer DVR-112DBK
PSU: Enlight 400W
CASE: Chieftec Dragon
OS: Windows XP SP3
LINK
CPU: Athlon XP 3200+
MBO: Gigabyte GA-7N400
RAM: 2x1GB Kingston 400MHz
ODD2: Pioneer DVR-107D
HDD: WD 160GB
PSU: MS Platinum 400W
OS: Windows XP SP3
CPU: Pemtium MMX 233
MBO: Vtech VIB804DS
RAM: 2x32MB SDRAM
GPU1: ATi AIW 3D Rage Pro
SND: Sound Blaster 16
FDD1: Mitsumi D359T5 3.5"
FDD2: Mitsumi D509V2 5.25"
ZIP: Iomega Z100ATAPI
ODD: Mitsumi CRMC-FX400
HDD: Seagate U4 6.4GB
PSU: DTK PTP-2008 200W
CASE: ES-COM AT case
OS: Windows 98SE
LINK
Dobar trgovac: 1, 2, 3, 4, 5, 6, 7, 8, 9, 10, 11, 12, 13, 14, 15, 16, 17, 18
Živi bili pa umrli!
Staro 03.05.2016., 19:13   #7
kurc
kurc's Avatar
Postovi: 237
Has/sky/kaby mora još bar 2-3 godine biti top. Ni 10nm neće biti nešto posebno brži, osim ako ne počnu radit čipove 0.5m^2.
Staro 03.05.2016., 19:18   #8
Nick7
Lokacija: Velika Gorica
Postovi: 1,541
Ni 7nm nece pomoci.
Stovise, procesori su presli vec poodavno granicu kad smanjivanje tehnoloskog procesa donosi ubrzanje.
Sad smanjenje tehnoloskog procesa donosi usporenje.
A to se kompenzira s drugim tehnoloskim napretcima (vise kanala za bandwidth, cache, itd, itd...), a jedan od najlaksih je dodati vise core-a na istu povrsinu.
Ukratko, postaje problem povecati single thread performanse sa trenutnim tehnologijama.
Staro 03.05.2016., 19:26   #9
JuiceBox
Xulos :)
JuiceBox's Avatar
Postovi: 7,581
A i to, 2016 godina , mi i dalje tapkamo sa 4 jezgre. Jel toliko tesko ubaciti 6+6 ? I sad ce netko rec al imas x99 , ovo je mid range. Pa nije midrange ako cpu kosta 3000 kn, to je daleko od midrangea.
Staro 03.05.2016., 21:59   #10
Manuel Calavera
Manuel Calavera's Avatar
Postovi: 14,589
Navodno će i cannonlake biti baziran na skylake uz određene optimizacije. Dakle die shrink i eventualno manja potrošnja
Staro 03.05.2016., 22:02   #11
Manuel Calavera
Postovi: 14,589
Ima na yt jedan zanimljiv intervju sa onim debelim wendelom iz tek syndicate (možda i najpametniji lik od tih silnih youtubera) koji kaže da intel kreće entuzijaste gurati prema enthusiast platformi (x99, xeone i to), a ovo ostaju mainstream socketi za raju. Ima smisla, jer budući da su pomaci mali, neće jedan entuzijast recimo haswell i7 mjenjati za quad i7 cannonlake i sl. Jednostavno nije isplativo
I saw what you did there intel, cpu od 3 soma postaje "mainstream" da ne kažem midrange... Quad + HT su još uvijek impresivni cpu, ali pitanje je dali će to biti i za nekoliko godina
Staro 03.05.2016., 22:51   #12
JuiceBox
Xulos :)
JuiceBox's Avatar
Postovi: 7,581
Pa bas to, drzim fige da AMD ubije sa zenom pa ce odjednom mainstream ili bit 1000 kn jeftiniji ili bar 50% jaci.
Staro 03.05.2016., 22:59   #13
Manuel Calavera
Postovi: 14,589
Neće ih sigurno ubiti sa ipc, ali recimo bilo bi dobro kad bi do 3 soma ponudili 6 ili 8 čru core (+ SMT) procesore sa "haswell like ipc", quadove za siću itd. Onda bi intel morao (ili trebao) bumpati sve za jedan razred gore (da i3 bude quad itd.) što se i spominjalo da će možda napraviti sa cannonlake, ali to su zasad samo glasine
Staro 04.05.2016., 01:05   #14
Glavas_ZG
Postovi: 218
Ja se isto nadam da ce AMD ZEN biti barem ekvivalent HSW / SKY po povoljnijoj cijeni, da se stvar malo zagrije, obzirom da je Intel stavio karte na stol sad ostaje jako zanimljivo za vidjeti sto ce AMD ponudit.
Staro 04.05.2016., 08:48   #15
Pa i trebali bi. Za desktop korisnike bi bilo lijepo da to bude ovako te uz postojeću paletu cijena:
Celeron - dual core
Pentium - dual core + HT
i3 - quad core
i5 - six core ili quad + HT
i7 - octa core
Staro 04.05.2016., 11:04   #16
scarzz
scarzz's Avatar
Lokacija: Stuttgart/Rijeka
Postovi: 414
Po meni je Zen bitan zbog takoreci "prisilnog" snizvanja cijena highend intel cpu-ova jer su cijene stvarno visoke a i dati 3000kn za jedan cpu je stvarno puno...
scarzz je offline   Reply With Quote
Staro 04.05.2016., 15:19   #17
Manuel Calavera
Postovi: 14,589
Celeron - dual core
i3 - quad core
i7 - octa core
To je neki prirodni slijed događaja. Samo je pitanje kada. Neće vječno 3 od 5 serija na mainstream platformi biti dual core. Kad sam ja to spomenio prije godinu-dvije svi su se čudili ko pura dreku. Nekad je i pentium bio single core, i5 dual core + ht itd...
Alternativa tome još može biti da sve ostane kako je, ali sve drastično pojeftini. Quad i7 da košta kao danas i5, a recimo hexa + HT sa enthusiast platforme da košta recimo 2500kn +/-, a celeron ili pentium da se izbace, jer neće biti potrebe za 2 serije čistih dualaca (čini mi se da su se jedva za skylake celerone odlučili).
Zadnje izmijenjeno od: Manuel Calavera. 04.05.2016. u 15:31.
Staro 04.05.2016., 16:07   #18
kurc
kurc's Avatar
Postovi: 237
Neznam zašto vi mislite da će intel spustit cijenu i5 i i7, i da će AMD prodavat hexa i octa core za "siću". Onaj zen koji će biti u rangu i7 će biti 10-20% jeftiniji od i7. Intel će eventualno spustit cijenu sa 3000 na 2800. Ovo s quad i3, quad+HT i5, to će biti za 3 godine bar, ali naravno, i5 će tada biti 2-2500.
Staro 04.05.2016., 16:20   #19
Vrlo vjerojatno bude AMD digao cijene do Intela prije nego bude lntel spustio do AMDa, ali lijepo se nadati.
Ja ipak više volim svoj novčanik i novce u njemu nego plave, crvene ili zelene zastave a naša nadanja se sa tom ljubavlju slažu.
Intel je daleko odgurao već, a Kaby Lake će se prodavati kao i Skylake tako da oni nikakav problem ne budu imali. Osim ako AMD ne izbaci Zen prije toga...
Staro 04.05.2016., 17:06   #20
kurc
kurc's Avatar
Postovi: 237
Normalno, zašto bi AMD tjerao Intel da zarađuje manje spuštanjem cijene, ako tako i sebi smanjuju zaradu. AMD-u ide na ruku to što je intel digao cijene u nebesa jer nisu imali konkurenciju zadnjih par godina. Ako će imat konkurentan cpu moći će i oni nabit cijenu skoro ko intel i zarađivati masno.
Staro 04.05.2016., 17:29   #21
John Creasy
Vocna iglica u mudante
John Creasy's Avatar
Lokacija: Beograd
Postovi: 2,838
Autor kurc Pregled postova
u kakvom mi to seljačkom svijetu živimo ako stvarno bude tako.... ..
John Creasy je online   Reply With Quote
Staro 04.05.2016., 18:11   #22
kurc
kurc's Avatar
Postovi: 237
Kapitalističkom?
Staro 04.05.2016., 18:13   #23
John Creasy
Lokacija: Beograd
Postovi: 2,838
Kapitalističkom?
nažalost, da.. i sve to spada pod normalno
Staro 04.05.2016., 18:15   #24
Glavas_ZG
Postovi: 218
AMD Intelu jedino može konkurirati cijenom uz uvijet da su performanse približne, ljudi su jako skeptični prema AMD-u nakon svega, treba vidjeti također kako će se kretati cijene matičnih ploča i što će točno nudit High End ZEN CPU-i i kojim će procesorima u intelovoj ergeli uopce konkurirati.
Staro 04.05.2016., 18:47   #25
Manuel Calavera
Postovi: 14,589
Naravno.
Ja pričam o spuštanju cijena (ili povećanju threadova) zbog najobičnijeg proteka vremena, odnosno tehnološkog razvoja i u određenoj mjeri zbog veće konkurentnosti amd-a. Mislim, takav bi barem bio red, sad kako će na kraju biti pitanje je... Kad se ništa nebi mjenjalo ispada da bi za 5 god. imali intelove procesore sa istim brojem threadova, sa istom cijenom i max 20-25% bolji IPC. Pa to je truba
Tako ispada zadnjih 5 god. od sandy do sada. Čak je prije entry level i5 bio 1200kn, a sad je 1500kn. Pitanje je dali će i tih 25% boljih ipc moći postići, jer prelasci na novi proizvodni proces idu sve teže, 7nm high perfomance chipove će navodno biti jebeno teško proizvest, mnogi predviđaju kašnjenje, znači i tick tock tock je ugrožen. 5nm chipovi će morati ići na neke nove materijale, silikon više ne može. Mislim da je i to jedan od razloga, uz smanjene prodaje zašto intel lagano zapostavlja desktop x86. Nema tu više zarade kao prije
Zadnje izmijenjeno od: Manuel Calavera. 04.05.2016. u 18:53.
Staro 04.05.2016., 19:21   #26
syss
syss's Avatar
Postovi: 10,805
ono kad ti je prva rečenica za novu arhitekturu - Kaby Lake will add native USB 3.1 support...
da, i? ja imam renesas 3rd party usb 3.0 kontroler i šta? koji je točno fičr toga da je integriran u čipset vs. još jedan čip na mbo.
Staro 04.05.2016., 20:15   #27
Manuel Calavera
Postovi: 14,589
pa moraju nešto napisat
Odavno se zna da je svrha kaby donijeti još jaču igpu od broadwella.
Staro 05.05.2016., 09:12   #28
Nick7
Postovi: 1,541
Bolji IPC se ne postize daljnjim smanjivanjem - stovise, daljnje smanjivanje ima negativni utjecaj na performanse, tak' da je tesko odrzati i postojece IPC performanse bez podosta trikova.
Jedini nacin je drukanje vise core-a.
S druge strane... za vecinu korisnika trenutno nema ni potrebe za vise od dva core-a.
Tako da imamo situaciju kakvi imamo sada - a to je da realno tko god ima jos i Sandy-a nema neke realne potrebe za upgrade. Dakle u 4 nove generacije nista revolucionarno se nije desilo, barem sto se IPC-a tice.
Staro 05.05.2016., 12:54   #29
MikaHR
Postovi: 1,264
Koja je uopće poanta kupovati Kaby (pod pretpostavkom da se Intel neće opet za...ti) pored Skylakea i SkyOCa?
MikaHR je offline   Reply With Quote
Staro 05.05.2016., 13:11   #30
Manuel Calavera
Postovi: 14,589
KabyOC?
