Staro 01.10.2015., 10:44   #991
Chuxonja
Pajcek
Chuxonja's Avatar
Datum registracije: Jun 2012
Postovi: 1,091
Tak sam testiro stabilnost i nisam nikad mrdo nakon toga Trebo bi i adaptive u nekom trenu isprobat, samo nikak se commitat prčkanju opet. Voltaža stoji, al se proc normalno downclocka do 800Hz kad se niš ne dešava. Vjerojatno i volti dropaju kad ode u C state, sa nisam provjeravo.
CPU: i7-4790K @4.3 GHz + Scythe Ninja 3
MBO: ROG Maximus VII Ranger
ODD: Asus DRW-24B1ST
SSD: Intel 760p 256GB NVME
HDD: WD Purple 1TB
PSU: FSP Hyper 700W
CASE: Antec 1200
OS: Windows 10 Pro
CPU: i5-4690K @4.5 GHz + Raijintek Themis
MBO: ASRock Z87 Pro3
GPU: Intel HD Graphics 4600
ODD: LG GH24NS70
PSU: Corsair TX 650W
CASE: Zalman Z3 Plus
OS: Windows 10 Pro
MBO: Gigabyte GA-X58A-UD7
GPU: Gigabyte HD 5450 1024MB
SSD: Corsair Force GT 120GB
HDD1: Toshiba P300 2TB
HDD2: Hitachi DeskStar 2TB
HDD3: Hitachi DeskStar 2TB
HDD4: WD Green 2TB
HDD5: WD Red 2TB
HDD6: WD Purple 4TB
PSU: Corsair CX 600M
CASE: Chieftec Bravo
OS: Windows 10 Pro
MBO: Asus P5Q SE/R
FDD: Samsung SFD-321B 3.5"
ODD: LITEON iHAS124
CASE: Antec Sonata
LINK
MBO: Abit AB9 Pro
RAM: 6GB DDR2 800MHz
GPU: Asus R7 240 2GB
ODD: LG CH10LS20
SSD: LITE-ON LCS-256L9S 256GB
HDD1: WD Green 1TB
HDD2: Seeagate Baracuda 2TB
CASE: Lian Li PC-7FNB
LINK
MBO: Epox EP-AF550 Pro/G
GPU: Sapphire HD 4850 1024MB
FDD: Alps DF354H 3.5"
ODD: LG GH22LP20
PSU: Levicom VP450B.BL
CASE: Xilence X1
OS: Windows 7 Pro
LINK
MBO: Abit AI7
RAM: 4x1GB Kingston 400MHz
FDD1: TEAC FD-235HF 3.5"
FDD2: TEAC FD-55GFR 5.25"
ODD2: Pioneer DVR-112DBK
PSU: Enlight 400W
CASE: Chieftec Dragon
OS: Windows XP SP3
LINK
CPU: Athlon XP 3200+
MBO: Gigabyte GA-7N400
RAM: 2x1GB Kingston 400MHz
ODD2: Pioneer DVR-107D
HDD: WD 160GB
PSU: MS Platinum 400W
OS: Windows XP SP3
CPU: Pemtium MMX 233
MBO: Vtech VIB804DS
RAM: 2x32MB SDRAM
GPU1: ATi AIW 3D Rage Pro
SND: Sound Blaster 16
FDD1: Mitsumi D359T5 3.5"
FDD2: Mitsumi D509V2 5.25"
ZIP: Iomega Z100ATAPI
ODD: Mitsumi CRMC-FX400
HDD: Seagate U4 6.4GB
PSU: DTK PTP-2008 200W
CASE: ES-COM AT case
OS: Windows 98SE
LINK
Dobar trgovac: 1, 2, 3, 4, 5, 6, 7, 8, 9, 10, 11, 12, 13, 14, 15, 16, 17, 18
Živi bili pa umrli!
Staro 26.12.2015., 19:30   #992
narc
Datum registracije: Mar 2009
Postovi: 84
Pozdrav, digo sam i5 3570k sa mugen2 coolerom na 4.0 sa default opcijama (bez diranja voltaze i ostalog). Da li moze ici i vise sa mugen dvojkom ?
https://www.youtube.com/watch?v=IAnjq6W-UCk
Ovaj je na 4.6 uspio stable doc.
Zadnje izmijenjeno od: narc. 26.12.2015. u 19:45.
narc je offline   Reply With Quote
Staro 27.12.2015., 16:03   #993
Chuxonja
Pajcek
Chuxonja's Avatar
Postovi: 1,091
Prati temperature pa vidi. Digni za malo pa prži prime95 ili neš slično uz mmonitoring da se uvjeriš da ti neće zakuhat. Ak si zadovoljan, rokaj dalje dokle ide
HDD: WD Purple 1TB
PSU: FSP Hyper 700W
CASE: Antec 1200
OS: Windows 10 Pro
ODD: LG GH24NS70
OS: Windows 10 Pro
HDD4: WD Green 2TB
HDD5: WD Red 2TB
HDD6: WD Purple 4TB
OS: Windows 10 Pro
MBO: Asus P5Q SE/R
ODD: LITEON iHAS124
CASE: Antec Sonata
LINK
MBO: Abit AB9 Pro
ODD: LG CH10LS20
HDD1: WD Green 1TB
LINK
ODD: LG GH22LP20
CASE: Xilence X1
OS: Windows 7 Pro
LINK
MBO: Abit AI7
PSU: Enlight 400W
OS: Windows XP SP3
LINK
HDD: WD 160GB
OS: Windows XP SP3
MBO: Vtech VIB804DS
RAM: 2x32MB SDRAM
OS: Windows 98SE
LINK
Živi bili pa umrli!
Staro 29.01.2016., 13:28   #994
šokre
Postovi: 324
Može pomoć?
Overclockao sam jučer 4670K prvi put i stavio sam sve u Biosu na auto, disable turbo eist i c1, ram na 1600 i 1.65V, i uspio sam odvrtiti geekbench2 na 4.2 i 1.187V (drugo nisam jer sam mislio da može više)
Ostale postavke oko voltaže nisam dirao (a ima ih mali milion).
4.3 na 1.23 bsod neće ni u windowse
4.5 na 1.3 isto
S obzirom da je kod asusa drugačiji naziv nekih postavki, jel mi može netko pomoći?
Ili mi je jednostavno proc nula bodova?
ploča je Asus Gene VI Z87 ako nije jasno iz potpisa
PS
Nakon malo igranja s postavkama uspio sam
4.2 - 1,187V
4.4 - 1.265V
4.5 - 1.35V
4.6 - 1.38125V
temp nisu iznad 70
AIDA 64 extreme prolazi (kratko testiram doduše), ali Prime95 v28.7 ruši sistem odmah
Iz nekog razloga ne mogu isključiti turbo - sam mi stavlja core multi na auto?
Probati ću uncore multi promijeniti...
Zadnje izmijenjeno od: šokre. 30.01.2016. u 15:35. Razlog: izmjena
šokre je offline   Reply With Quote
Staro 31.01.2016., 00:23   #995
Bariarnil
Autor šokre Pregled postova
Može pomoć?
4.5 na 1.3 isto
PS
4.2 - 1,187V
4.4 - 1.265V
4.5 - 1.35V
4.6 - 1.38125V
temp nisu iznad 70
1.65v je pun K.... za DDR3 RAM @1600 mhz.Ukljuci XMP profil za ram.Prime95 nemoj za intela,previše ih prži po nekim izvorima pa se nebih igrao s tim.Posto imas asusovu plocu vjerojatno imas Digi+ pa se tamo poigraj s postavkama.Neznam koje hladenje imas al ispod 1.42v za Haswell bi bilo ok ako su temp uredu.
Staro 04.02.2016., 15:39   #996
šokre
Postovi: 324
Autor Bariarnil Pregled postova
Ma ram je 2400 pa sam samo manualno stavio na 1600 i ostavio 1.65.
Hlađenje imam dobro - usis je 180mm veliki silverstone koji ide ravno na 1x120mm vent na hladnjaku i na ispuh 120mm na caseu.
Temperature nisu problem, preko 70C ne ide.
Međutim OCCT i Prime95 - 26.6V mislim (ona koja je OK uglavnom) mi ruše komp. Geekbench od 1min test prolazi i AIDA64 extreme 5 min prolazi (nisam dugo testirao).
Gledam da imam neki stabilan OC 24/7.
Vidim da ne preporučaju preko 1.3V dugoročno.
Jel trebam isključiti eist, c1 itd?
S čime je najbolje testirati i koliko dugo - ne radim ništa prebitno na kompu ali htio bih da je stabilan?
Staro 10.10.2018., 09:59   #997
cendol
Datum registracije: Oct 2018
Lokacija: Surabaya
Postovi: 10
imam pitanje....na kolko bi isao intel core i5 750 2,66 sa thermaltake bigwater 735 vodenim?
cendol je offline   Reply With Quote
Staro 18.06.2019., 23:29   #998
pavlov1982
pavlov1982's Avatar
Datum registracije: Jun 2019
Postovi: 1
pitanje. Da li tko probao ovreclokirati intel M7-6Y75 na laptopu? Tnx
pavlov1982 je offline   Reply With Quote
Staro 14.01.2020., 12:38   #999
Wiz3m4n
Wiz3m4n's Avatar
Datum registracije: Apr 2009
Lokacija: Bjelovar
Postovi: 244
Autor cendol Pregled postova
ovisno o više faktora, no ako su uvjeti zadovoljeni 3.5-4ghz bi morao iči, no bez da probaš nečeš znati
Wiz3m4n je offline   Reply With Quote
Staro 14.01.2020., 12:42   #1000
mamutarka
ODUZIMAM VAM RIJEČ
mamutarka's Avatar
Postovi: 13,616
moj je na zraku išao do 4, al sam radi stabilnosti držao 3.8
CM 212 zračno
valjda dobar primjerak
edit: nisam pratio, a ni kolega, da je ovo staro
Staro 14.01.2020., 13:01   #1001
Autor Wiz3m4n Pregled postova
Kaj trošiš danas ?
Em odgovaraš botu, em odgovaraš botu na post star godinu i kusur.
