Addicted to music.
Postovi: 1,782
Catalyst 14.12 WHQL Omega
Novi 'Catalyst Omega' driveri su dostupni za download! Nove stvarcice: Virtual Super Resolution (VSR) Video playback enhancements 5K LCD Panel Support Frametime Frame Pacing enhancements Performance optimizations for APUs Performance optimizations for Dedicated graphics cards Performance Optimizations versus AMD Catalyst 14.9 WHQL Sid Meier's Civilization: Beyond Earth performance optimizations - Mantle API activated for ultimate performance in Sid Meier's Civilization: Beyond Eart Call of Duty: Advanced Warfare performance optimizations - Up to 30% performance increases with FXAA and lower game resolutions Optimized AMD CrossFire Profile update for improved performance - Assassin's Creed Unity performance optimizations Single GPU performance improvements - Optimized AMD CrossFire Profile update for improved performance Dragon Age: Inquisition performance optimizations - Up to 15% performance increase in single GPU scenarios with Anti-Aliasing enabled. Optimized AMD CrossFire Profile update for improved performance Far Cry 4 performance optimizations - Up to 50% performance increase in single GPU scenarios with Anti-Aliasing enabled. Vise o tome: klikni ovdje Download: klikni ovdje
All you have is your fire and the place you need to reach. Don't you ever tame your demons, always keep them on a leash. |
Propali Amigaš
Lokacija: Nin
Postovi: 7,005
Premijum
Postovi: 1,360
Ok, pitat cu ovdje jer mi se trentuno to dogada na ovoj verziji drivera. Naime, prilikom OC-a preko MSI AB-era, kartica prihvati OC i u Gpu-zu se vide zadane vrijednosti, ono sto mene je muci to da nakon nekog izvjesnog vremena frekvencije vracaju na stock, konkretno je to na 7950 sa OC-a 1100/1400 vraca na defaultnih 880/1250, tek nakon restarta mogu dobit ponovo OC vrijednosti, i to opet na ograniceno doba ma koliko god puta u AB-u potvrdivao OC. Vrlo cudan i iritantan problem, probano sa vise Ati kartica, na svima ista stvar se pojavljivala. Sa GTX 760 nikakvih problema nije bilo sto se toga tice. Imam osjecaj da me neke power saving feature atijev hebe? |
#4 | |
Lynnfield
Datum registracije: Sep 2012
Postovi: 1,023
Premijum
Postovi: 1,360
Lynnfield
Postovi: 1,023
gadget freak
Lokacija: Jasenovac
Postovi: 2,224
Lynnfield
Postovi: 1,023
Premijum
Postovi: 1,360
Probat cu s trixxom jos eventualno, ali mi se to vec na par atica dogadalo s ovim driverima, cudno da vec dugo nema novih, mozda nesto.propustam, neznam. Savjeti slobodno. Ali da, nvidia je po pitanju drivera za dva koplja iznad, makar i ona ima svojih musica. |
Lynnfield
Postovi: 1,023
nema dugo amd drivera,kao da su ovi savršeni a nisu....sad će vjerojatno izbacit nove za battlefield hardline |
Dino Saur
Datum registracije: Jan 2012
Postovi: 940
Datum registracije: Aug 2008
Lokacija: Gospić
Postovi: 452
Samo ukratko da kazem da sam skinuo i probao novu CCC betu 15.3,i obrisao ju nakon 15 min.. Nisam nikakve testove pokusavao,prije instaliranja sam igrao "The Crew",i kad sam stavio te drivere,igra se nije htjela pokrenut 3 puta za redom. Vratio Omegu staru,sve radi iz prve.. Tako da nisam ni pokusavao druge stvari.. ![]() EDIT:Nije mi vrag dao mira... Maknuo sam Omegu opet,stavio 15,3 ponovo,i danas sam igrao FC4,The Crew,Dota2,i sve je bilo bez greske... Vrag zna sto mu je bilo prvi put...
http://forum.pcekspert.com/faq.php Zadnje izmijenjeno od: Smoki_Gs. 28.03.2015. u 05:01. |
