Staro 30.10.2014., 17:05   #541
Chuxonja
Pajcek
Chuxonja's Avatar
Datum registracije: Jun 2012
Postovi: 1,085
Trebo si samo zakvačit onaj Install alongside current OS i sve bi prošlo kak treba :P
CPU: i7-4790K @4.3 GHz + Scythe Ninja 3
MBO: ROG Maximus VII Ranger
ODD: Asus DRW-24B1ST
SSD: Intel 760p 256GB NVME
HDD: WD Purple 1TB
PSU: FSP Hyper 700W
CASE: Antec 1200
OS: Windows 10 Pro
CPU: i5-4690K @4.5 GHz + Raijintek Themis
MBO: ASRock Z87 Pro3
GPU: Intel HD Graphics 4600
ODD: LG GH24NS70
PSU: Corsair TX 650W
CASE: Zalman Z3 Plus
OS: Windows 10 Pro
MBO: Gigabyte GA-X58A-UD7
GPU: Gigabyte HD 5450 1024MB
SSD: Corsair Force GT 120GB
HDD1: Toshiba P300 2TB
HDD2: Hitachi DeskStar 2TB
HDD3: Hitachi DeskStar 2TB
HDD4: WD Green 2TB
HDD5: WD Red 2TB
HDD6: WD Purple 4TB
PSU: Corsair CX 600M
CASE: Chieftec Bravo
OS: Windows 10 Pro
MBO: Asus P5Q SE/R
FDD: Samsung SFD-321B 3.5"
ODD: LITEON iHAS124
CASE: Antec Sonata
LINK
MBO: Abit AB9 Pro
RAM: 6GB DDR2 800MHz
GPU: Asus R7 240 2GB
ODD: LG CH10LS20
SSD: LITE-ON LCS-256L9S 256GB
HDD1: WD Green 1TB
HDD2: Seeagate Baracuda 2TB
CASE: Lian Li PC-7FNB
LINK
MBO: Epox EP-AF550 Pro/G
GPU: Sapphire HD 4850 1024MB
FDD: Alps DF354H 3.5"
ODD: LG GH22LP20
PSU: Levicom VP450B.BL
CASE: Xilence X1
OS: Windows 7 Pro
LINK
MBO: Abit AI7
RAM: 4x1GB Kingston 400MHz
FDD1: TEAC FD-235HF 3.5"
FDD2: TEAC FD-55GFR 5.25"
ODD2: Pioneer DVR-112DBK
PSU: Enlight 400W
CASE: Chieftec Dragon
OS: Windows XP SP3
LINK
CPU: Athlon XP 3200+
MBO: Gigabyte GA-7N400
RAM: 2x1GB Kingston 400MHz
ODD2: Pioneer DVR-107D
HDD: WD 160GB
PSU: MS Platinum 400W
OS: Windows XP SP3
CPU: Pemtium MMX 233
MBO: Vtech VIB804DS
RAM: 2x32MB SDRAM
GPU1: ATi AIW 3D Rage Pro
SND: Sound Blaster 16
FDD1: Mitsumi D359T5 3.5"
FDD2: Mitsumi D509V2 5.25"
ZIP: Iomega Z100ATAPI
ODD: Mitsumi CRMC-FX400
HDD: Seagate U4 6.4GB
PSU: DTK PTP-2008 200W
CASE: ES-COM AT case
OS: Windows 98SE
LINK
Dobar trgovac: 1, 2, 3, 4, 5, 6, 7, 8, 9, 10, 11, 12, 13, 14, 15, 16, 17, 18
Živi bili pa umrli!
Staro 31.10.2014., 09:51   #542
WraGG
WraGG's Avatar
Lokacija: Stuttgart
Postovi: 1,602
Trebaju mi dvije licence W8.1 pro x64. Koja mi je trenutno najpovoljnija opcija, a da bude 100% legalno?
WraGG je online   Reply With Quote
Staro 31.10.2014., 15:19   #543
Juice
Fresh Juice
Juice's Avatar
Postovi: 4,585
Autor WraGG Pregled postova
Jel trebaju za kućnu upotrebu ili poslovno?
Staro 31.10.2014., 15:28   #544
WraGG
WraGG's Avatar
Lokacija: Stuttgart
Postovi: 1,602
Autor Juice Pregled postova
Hajmo reci da je za kucnu upotrebu. Poslovno je, ali ne uzimaju se radi inspekcije, nego sto programer ne zeli staviti svoj software na nelicencirani win.
Staro 31.10.2014., 15:36   #545
Juice
Fresh Juice
Juice's Avatar
Postovi: 4,585
Najjeftinije rješenje je nać studenta, registrirat se preko njega na Dreamspark.com i uzet ključeve
Što se dućana tiče, ne znam, pogledat na nabavi di ima najjeftinije ili preko nekog sitea uzet ključeve samo.
Staro 31.10.2014., 18:47   #546
Shamanix
Shamanix's Avatar
Postovi: 870
Imam problem s Win8.1... nekad mi se hard disk upali na 100% a nista na kompu ne radim... pokusavao sam gasit servise koje preporucuju na netu ali opet isto mi se desava... Ne mogu skontat u cemu je problem i to me pati uzasno.. ak netko zna rjesenje neka pomogne molim vas
EDIT: zanemarite, instalacija je bila pokidana, sad napravio novu instalaciju i cini mi se da sve radi kako treba... cudno..
Zadnje izmijenjeno od: Shamanix. 01.11.2014. u 18:51.
Shamanix je offline   Reply With Quote
Staro 04.11.2014., 17:28   #547
Ako se ponovi, lijepo napravi sljedeće. Odi u services i disejblaj BITS. I sigurno ti se C disk neće zakucavati na 100%.
Staro 05.11.2014., 13:27   #548
Željac
sto da napisem ?!
Željac's Avatar
Postovi: 880
GRRRRR !!!
problemi po shutdownu !
dakle, izvrtio sam sve moguće, disejblao fast startup, disejblao hibernaciju...
prvi put kad je bio fast startup omogućen, usb power je bio tu itd. rekao bi- hibernacija. Ali se iz nje nikako i ničime nije moglo "probuditi".
Disejblao sam fast startup, kao ugasi se... (nema više blinkanja usb-a i šitova), ali mi se cpu fan još vrti i brijem da disk rošta. i to tako stoji. Do tog stanja dođe za klasično vrijeme gašenja, ali u tom stanju može stajati doživotno. Dok je tako, ne može se upaliti na ikoju tipku (pojedinačna- kratka na kućištu ili išta od input uređaja) i ne reagira dok ga prisilno ne ugasim na kućištu i opet upalim. Nema šta nisam probao, izluđuje me i proklinjem sve osim ubuntu-a. Tu sam u temi pročitao da je netko prešaltao diskove na druge portove na ploči ali mi nema smisla (trenutno su dva spojena na sataIII konektore, eventualno da ih probam na sata II zbaciti... ali nema mi smisla)
pomoć, jer ga odmjeravam (a to ni dobro)
Staro 06.11.2014., 16:16   #549
Vegetto
Lokacija: Zagreb, Trešnjefka
Postovi: 102
Autor Shamanix Pregled postova
my computer-> desni klik na c disk->properties
quota->quota settings/management
enable quota management
limit disk space na isto kolko RAM-a imas, i warning isto...
i to je to....
meni se sve stabiliziralo nakon toga
ja sam isto mislio da je radi instalacije, ali nije bilo!
Vegetto je offline   Reply With Quote
Staro 06.11.2014., 23:58   #550
HCS
Premijum
HCS's Avatar
Postovi: 1,360
Jel itko imao ovakvih problema? Ima li rjesenja bez da moram kompletan hard formatirat?
Staro 07.11.2014., 00:43   #551
Željac
sto da napisem ?!
Željac's Avatar
Postovi: 880
samo obriši taj disk na koji želiš instalirati, pa će ti dati.
to sam se i ja iscimao. prvo sam klikao po formatu, sve prođe oke, ali mi nije htio dalje (uz tu poruku).
samo na erase
ja i dalje nisam riješio ono svoje pitanje gore, pa ako ima itko kakvu ideju... slobodno !
Staro 07.11.2014., 01:01   #552
HCS
Premijum
HCS's Avatar
Postovi: 1,360
Autor Željac Pregled postova
samo na erase
Ma jok, ne zeli ni izbrisat, tj format napravit, isto baca neki error, uspio sam jedino deletat skroz particiju, ali onda ne zeli vise napravit novu Show samo tako, Windows 7 sve pici najnormalnije
Staro 07.11.2014., 01:21   #553
dinos3
Dino Saur
dinos3's Avatar
Datum registracije: Jan 2012
Postovi: 941
Autor HCS Pregled postova
Mozda problem u CDu?
dinos3 je offline   Reply With Quote
Staro 07.11.2014., 14:19   #554
HCS
Premijum
HCS's Avatar
Postovi: 1,360
Autor dinos3 Pregled postova
Sumnjam, napravio sam bootabilni USB za UEFI biose preko Rufusa, ista stvar.
Staro 07.11.2014., 14:49   #555
tor
Administrator
tor's Avatar
Lokacija: Sesvete
Postovi: 15,964
sve ti piše, disk ti mora biti u gpt-u, da bi to išlo. Ili se oduefaj ili prebaci disk u gpt
Kako - ovako, ali to sve briše jel...
Malo o gpt-u:
http://msdn.microsoft.com/en-us/libr...(v=vs.85).aspx
Staro 07.11.2014., 15:15   #556
HCS
Premijum
HCS's Avatar
Postovi: 1,360
Autor tor Pregled postova
Malo o gpt-u:
Komplikacije nepotrebno Nista, izgleda da ce bit sedmica jos ok neko vrijeme
Staro 07.11.2014., 17:14   #557
Chuxonja
Pajcek
Chuxonja's Avatar
Postovi: 1,085
Nemoj UEFI bootat i trebalo bi šljakat, ili ga napravi opet ali bez UEFIranja.
HDD: WD Purple 1TB
PSU: FSP Hyper 700W
CASE: Antec 1200
OS: Windows 10 Pro
ODD: LG GH24NS70
OS: Windows 10 Pro
HDD4: WD Green 2TB
HDD5: WD Red 2TB
HDD6: WD Purple 4TB
OS: Windows 10 Pro
MBO: Asus P5Q SE/R
ODD: LITEON iHAS124
CASE: Antec Sonata
LINK
MBO: Abit AB9 Pro
ODD: LG CH10LS20
HDD1: WD Green 1TB
LINK
ODD: LG GH22LP20
CASE: Xilence X1
OS: Windows 7 Pro
LINK
MBO: Abit AI7
PSU: Enlight 400W
OS: Windows XP SP3
LINK
HDD: WD 160GB
OS: Windows XP SP3
MBO: Vtech VIB804DS
RAM: 2x32MB SDRAM
OS: Windows 98SE
LINK
Živi bili pa umrli!
Staro 07.11.2014., 22:29   #558
HCS
Premijum
HCS's Avatar
Postovi: 1,360
Autor Chuxonja Pregled postova
Yep, tnx, tak sam napravio, disejblao uefi dvdv boot i proslo je bez problema.
Staro 27.11.2014., 17:19   #559
syss
syss's Avatar
Postovi: 10,805
osim što nemam riječi mržnje za opisati win 8.1 skupa sa uefi kombinacijom, upravo sam naletio na pravi biser - http://www.mobileworxs.com/2014/08/2...-professional/
ne znam ni da počnem koliko nam je to sada problema napravilo... pričamo (za krajnjeg korisnika) o jako skupom tabletu.
Staro 27.11.2014., 18:54   #560
GoGzS
GoGzS's Avatar
Lokacija: Novi Zagreb
Postovi: 979
Autor syss Pregled postova
Ne kužim u čemu je točno problem? OS je bukvalno $0 od cijene tableta. Šta nedostaje, Hyper-V? Windows domena, company policy? Pa toga nikad nije bilo na ičemu ispod professional, a tad su verzije ispod professional koštale... instaliraj Windows 8.1 Pro/Enterprise i gotovo...
Pretpostavljam da se nebi ljutio da je tablet došao sa FreeDOS i da si otpočetka morao instalirat svoje Windowse?
Staro 27.11.2014., 23:59   #561
spawn
spawn's Avatar
Postovi: 8,512
Ne kuzim ovo u vezi Win 8.1 with bing. Imao tu verziju na kingsing tabletu i radio je normalno. I browseri i aplikacije nisu morale ici preko appstorea sve je sljakao kao na normalnom 8.1
Staro 28.11.2014., 09:31   #562
nathan.fake
Lokacija: n/a
Postovi: 1,258
Taj Win8.1 with Bing se ne razlikuje po nicemu bitnom od obicnih "core" Win8.1...
jedina je razlika sto IE i Bing moraju tvornicki bit podeseni kao default (tj OEM ih ne smije mjenjat)... korisnik naravno smije/moze mjenjat i instalirat sto hoce
obicno dolaze s predinstaliranim Office 365 trial (neki dodju s Office 365 licencom na god dana)...
Ovo za nadogradnju sa Win8.1 with Bing na Win8.1 Pro nisam siguran jel moze ili ne, provjerim sljedeci put kad budem imo neki laptop sa Win8.1 with Bing u rukama
Win8.1 with Bing se ne moze kupit u trgovini, dostupan je samo OEM-u... za tablete diagonale ekrana ispod 9" licenca je besplatna, za ove iznad i laptope je neka simbolicna cifra (nigdje se ne navodi tocna cijena)...
Zadnje izmijenjeno od: nathan.fake. 28.11.2014. u 12:01.
nathan.fake je offline   Reply With Quote
Staro 28.11.2014., 13:28   #563
syss
syss's Avatar
Postovi: 10,805
problem je što to nije 8.1 koji se može apgrejdati na pro/ent nego with bing koji se ne može na ništa apgrejdati.
naravno da nam treba minimalno domena pa onda nadalje jer ne pričam o jednom tabletu.
isto tako x86 image se ne može koristiti na x64 stroju jer je uefi drugačiji... maestralno.
Staro 28.11.2014., 14:01   #564
The Man
The Man's Avatar
Datum registracije: May 2012
Lokacija: Agram
Postovi: 1,096
Napravio sam image sistemske particije laptopa na kojoj je bio predinstaliran Windows 8.1 da bi instalirao Windows 7 i sada su particije druge veličine, odnosno ova da Windows 7 je puno veća. Ako vratim image hoće li on sjesti u tu veću particiju od Windows 7 koju bi zbrisao ili formatirao, a ako ne što će se desiti s ostalim particijama.
Također, image sam stavio na Storage particiju od 700GB jer mi ga nije htio snimiti na USB 3.0 flash drive od 64GB (NTFS) pa me zanima, ako je sada manualno prekopiram na flash drive, da li ću je moći "povući" s njega ili ću je morat stavit na eksterni disk?
Help a brother out. Ne želim izgubiti cijeli dan na drndanje oko laptopa ako baš nije nužno.
I LIKE TO WALK ALONG THE BEACH WITH A RAGING HARD ON. IT'S FUNNY TO SEE THE REACTIONS.
The Man je offline   Reply With Quote
Staro 29.11.2014., 12:20   #565
catroot
catroot's Avatar
Datum registracije: Apr 2009
Lokacija: I live in 43 05'04.11"N 17 57'36.71"E
Postovi: 881
Jel zna tko kako zamijeniti dll file na windows 8 u system32 mapi. Trebao bi zamijeniti samo jednu dll datoteku, al neide, stalno izbacuje you need permission to perform this action, pokušavao sam promijeniti postavke u security tabu i opet neće. http://tinypic.com/view.php?pic=2nh0qc7&s=8
edit: riješenje, kopirati d3d11.dll and dxgi.dll iz system32 u mapu igre.
Zadnje izmijenjeno od: catroot. 29.11.2014. u 12:50.
catroot je offline   Reply With Quote
Staro 01.12.2014., 13:34   #566
sharavanja
Lokacija: Mostar
Postovi: 45
Imam problem s Win 8.1 pro. Instalirao sam ga i sve okej radi, osim što mi prostor na disku misteriozno nestaje. Imam jednu C particiju i na nju sam instalirao Winse i nakon instalacije, bez ikakvih dodatnih aplikacija ili nekih datoteka, mi je bilo zauzeto nekih 70 i kusur GB prostora? Ajde ok, mislim si, imam dovoljno, ako i uzima toliko instalacija nije problem, ali mi sad svako malo misteriozno nestaje prostor, a ništa nemam na disku!?! Tipa jučer sam imao 610 GB slobodno, jutros uključim laptop imam 609 GB slobodno?? Jel nešto zblesavilo totalno, ima li kakvo objašnjenje za ovo? Unaprijed hvala
sharavanja je offline   Reply With Quote
Staro 01.12.2014., 17:15   #567
dinos3
Dino Saur
dinos3's Avatar
Postovi: 941
Autor sharavanja Pregled postova
Skini WinDirStat i analiziraj si disk, da vidis sta ti ga to pretrpava...
Staro 01.12.2014., 17:23   #568
webstartm
Sandy!!!
webstartm's Avatar
Postovi: 1,695
Vidi jel automatski backup ukljucen,negdi u control panelu,nezz sad napamet
Staro 02.12.2014., 12:39   #569
sharavanja
Lokacija: Mostar
Postovi: 45
Hvala :-) Skinuo sam i Windows.old folder bio skoro 60 giga haha. To sam pobrisao, ali čini mi se da još nešto guši disk, što kaže kolega iznad možda neki back up ili nešto, moram to provjeriti :-) Hvala ;-)
Staro 14.12.2014., 23:00   #570
Poggiali
Rocker
Poggiali's Avatar
Lokacija: Zagorje
Postovi: 2,032
Problem sa WIFI na 8.1
Dakle, laptop je noviji , lenovo g710, windows 8.1 64bit.
Prvo sam mislio da je problem u routeru, pa sam mjenjao one kanale rucno, ali koji god da stavim problem je isti, takodjer, probao se spajat na drugi router, isti problem.
Radi se o tome da kod paljenja laptopa automatski se spoji na wifi, ali uskoro pocne trzati prekidati, skype se se svakih 2-3 sec odspaja, otvorim browser, otvori sajt na sekundu, a onda dalje nece, i tako zasteka sve dok ne odem da ugasim wifi, ponovo upalim, povezem se i onda radi, nekad taj proces ponovim i 2 -3 puta, ali svaki put kod prvog spajanja, kad se jednom spoji onda radi bez greske sve do gasenja laptopa. Nemam nikakav firewall ni antivirus. Povremeno skeniram samo malwarebytesom. Koristim Ccleaner i wise registry.
Da li ima netko sa slicnim problemom, kak da to rijesim ? :/
TNX
Konfa: Intel Core 2 Duo E 6400, 2.72GHz || Asus P5B Deluxe || 8800 EVGA GTS 320 mb || Super Talent 2x1 gb 800MHz CL5 || Seagate Barracuda 7200.10 320 GB 16 mb || Samsung Spinpoint F1 750 GB 32mb || Seasonic S 12 430W || A+ X-Blade || Logitech Z 5500 || CL X-Fi Xtreme Game || Logitech G500 || Logitech UltraX Flat Desktop || Canon Pixma iP4300 || Samsung ML-2510 || Toshiba Regza 32XV733G
Poggiali je offline   Reply With Quote
