#601 |
Postovi: 7,568
MSI 790X-G45 AM2+ ploča
MSI is currently working on bringing to market a new motherboard based on the AMD 790X chipset, the 790X-G45. Seen below, the upcoming board makes use of the 790X/SB710 combo and features the APS (Active Phase Switching) function for PWM control, support for AM2/AM2+ Phenom and Athlon processors, four DDR2-1200 memory slots, and two PCI-Express x16 slots enables CrossFireX setups. The 790X-G45 also includes six SATA 3.0 Gbps ports, Gigabit Ethernet, 7.1 channel VIA VT1828S audio, one PATA connector, an Easy OC switch and a Clear CMOS button. MSI's board is likely to become available in the next few weeks.Izvor: TechConnect Zadnje izmijenjeno od: McG. 30.09.2010. u 18:02. |
#602 |
Postovi: 7,568
Šesterojezgreni AMD Istanbul u desktop formatu
AMD usually builds server processors with the cores similar to desktop ones that differing a little by external interfaces support: they have more HyperTransport busses and the memory controller is designed to support Registered memory DIMMs. Istanbul core stands out of this rule: so far it has no desktop analogue. Although we can’t deny that Istanbul, just like Shanghai, is close to Deneb in microarchitecture. However, in this case the differences go beyond the memory controller and the number of HyperTransport busses. Istanbul has six computational cores on a single processor die, which makes these processors the most expensive solutions in the Opteron lineup: they are priced starting at $450. There is nothing surprising about it: Istanbul die size is 346 mm2, which is about 1/3 larger than Shanghai die. The six-core processor has 904 million transistors. All this fits onto a monolithic semiconductor die, which holds not only six computational cores each with 512 KB L2 cache, but also a shared 6 MB L3 cache.Izvor: X-Bit Labs Zadnje izmijenjeno od: McG. 30.09.2010. u 18:03. |
#603 |
Postovi: 1,816
Ovo je ... jako los preview onoga sto bi mogao six core AMD u desktop okruzenju. MSI ploca je u biti stara neke 2g. a sam chipset je puno stariji. Testna konfiguracija:
Na ovoj drugoj platformi vjerujem da bi rezultazi bili barem 20% bolji i tada bi stvari dosta drugacije izgledale. Vise bih volio da su stavili jedan ovaj Opteron u ovu plocu pa da su onda testirali: ![]() DDR3 ce ocito biti rezerviran za novi C32 socket. BTW, mislim da bi AMD trebao izbaciti Dual socket Enthusiast platformu s 2x 6 core otkljucanim i na defoultu na 3GHz (novi FX?) s 4 PCIe 16x jer mislim da 500$ za plocu te 1000$ za dva procesora s ukupno 12 jezgri je cijena na koju bi mnogi pristali! ![]()
Stupid is as stupid does Zadnje izmijenjeno od: McG. 05.11.2009. u 01:04. |
#604 |
Lokacija: NaN
Postovi: 3,438
Dvije nove AMD desktop platforme u svibnju 2010. godine
AMD may no longer have the high-end power-efficiency crown, but it's nevertheless cooking up a pair of new desktop platforms. So writes DigiTimes, basing its story on tips from insiders at motherboard manufacturers. These platforms will include Leo at the high end and Dorado for the mainstream. Leo should bring together current Phenom IIs, future Thuban six-core desktop CPUs, and new 890-series chipsets with SB850 south bridges. DigiTimes mentions an 890FX and 890GX; if those are anything like the 790FX and 790GX, the latter will have integrated graphics and multi-GPU support.Izvor: The TechReport Zadnje izmijenjeno od: McG. 30.09.2010. u 18:03. |
#605 |
Postovi: 7,568
MSI 770-G45 AM3 ploča
MSI is readying the 770-G45 motherboard, which supports socket AM3 Phenom II and Athlon II series processors from AMD. The motherboard makes use of AMD's SB710 southbridge, and hence supports the ACC feature. The more important feature however, is the provision of two PCI-Express x16 slots, supporting ATI CrossfireX. The second slot however, seems to be wired to the southbridge, and electrical PCI-Express x4. The CPU is powered by a simple 6 phase VRM circuit, supporting the Active Phase Switching feature, it is wired to four DDR3 DIMM slots to support dual-channel memory. All six SATA 3 Gb/s ports are internal. A PCI-E x1 and three PCI slots make for the rest of the expansion. Connectivity includes gigabit Ethernet, a serial port, and a number of USB 2.0 ports. The OC Switch feature aims to simplify overclocking. Ideally, this motherboard should make it around the $100 price point, though the price isn't known at this point.Izvor: TechConnect i tech PowerUp Zadnje izmijenjeno od: McG. 30.09.2010. u 18:03. |
#606 |
Postovi: 7,568
AMD-ove buduće desktop, mobilne i serverske platforme
It’s got roughly one billion 32nm transistors, fabbed at Globalfoundries. Four CPU cores and a single graphics core. It’s what AMD calls an Accelerated Processing Unit (APU). And we’ll see it in 2011. The APU, codenamed Llano, was originally scheduled for 2010 but got pushed back. In 2009/2010 Intel will be the first to deliver on-chip graphics with Clarkdale/Arrandale, and in late 2010 Sandy Bridge will have on-die graphics. The first APU will use the existing Phenom II architecture on the same die as DX11 graphics, but at 32nm. Sandy Bridge will use a brand new microprocessor architecture on 32nm but with updated Intel integrated graphics. It looks like Sandy Bridge will have the CPU advantage while Llano might have the GPU advantage, assuming Intel can't get their GPU act together by then. Llano is on schedule to debut in 2011 with OEM sampling happening before the end of the year. Based on the die shot displayed by Rick Bergman, senior vice president and general manager of AMD’s products group, the first Fusion processor from AMD will feature 4 x86 cores that resemble those of Propus processor (AMD Athlon II X4) as well as 6 SIMD engines (with 80 stream processors per engine) that resemble those of Evergreen graphics chip (ATI Radeon HD 5800), PC3-12800 (DDR3 1600MHz) memory controller, possibly, with some tweaks to better serve x86 and graphics engines. The processor lacks unified L3 in order to reduce manufacturing cost, but will have 2MB of L2 cache (512KB per core), which contradicts to previously available information that the chip has 4MB of L3. AMD’s Llano will feature around 1 billion of transistors, which is logical since AMD’s Propus processor has around 300 million of transistors, whereas 480 stream processors and additional special purpose logic includes around 600 million of transistors. The chip will be made using 32nm silicon-on-insulator fabrication process. Desktop Next year the high end platform will be called Leo. It’s made up of a Thuban CPU, which is an updated Phenom II rev sporting as many as six cores. It’s still 45nm so don’t expect much in the way of new architectural features. Graphics comes courtesy of the Radeon HD 5000 series, which we all know and love. The chipset is going to be AMD’s new 8-series, complete with a new SB850 south bridge. In 2011 we get Bulldozer and it comes in the form of the Zambezi CPU (AMD’s codenames are such fun). You’ll see four and eight core versions of Zambezi. Both will support DDR3 and both will work in Socket-AM3. Obviously guaranteeing motherboard support this early in the game is difficult, but AMD is usually good about maintaining socket compatibility. You may be able to slip a Zambezi into your current day Socket-AM3 motherboards. The 2011 mainstream desktop platform is called Lynx, purr. It comes with the Llano APU, which as I mentioned before, doesn’t use Bulldozer. Instead Llano is made up of as many as four 32nm Phenom II-like cores. Llano also features an integrated DX11 GPU. Llano will require a new socket as the pinout will have to support video out just like Intel’s Clarkdale. AMD’s first APUs drop in 2011, but what happens in 2012? Intel is committed to new microprocessor architectures every 2 years as a part of its tick-tock strategy. AMD’s GPU-inspired equivalent is called Velocity. Velocity also means that even if it’s difficult getting more performance out of a CPU architecture, AMD can always rely on a beefed up GPU core to give users a reason to upgrade.Mobile For mainstream notebooks today AMD doesn’t really offer anything sexy. We have the Tigris platform based on the Caspian CPU (45nm Athlon II X2 derivative) and RS880M chipset with integrated Radeon HD 4300 series graphics (DX10.1). Next year we get the Danube platform, complete with Champlain CPU (Athlon II X2 or X4 derivative) and relatively similar graphics to what we have now. Like the desktop roadmap, things don’t get interesting until 2011; that’s when we meet Sabine. Sabine comes with a Llano APU, just like the desktop, and four 32nm Phenom II-like cores.Server The Maranello platform is AMD’s high end server platform, due out in 2010. It supports the 8 and 12 core Magny Cours processors. These are multi-chip-modules with two quad or hexa core die on a single package. With twice the die, you get twice the memory controllers. Magny Cours has four DDR3 memory channels. With more memory channels, Magny Cours needs a new, higher pincount socket which AMD is calling Socket G34. The chips will be branded as Opteron 6000 series. San Marino is the second major server platform of 2010 and it’s for more normal servers. Four and six core Lisbon processors find their homes in San Marino. There’s also a low power Adelaide platform that’ll be available. These Lisbon processors will be branded as Opteron 4000 series chips and will work in Socket C32. In 2011 we get Interlagos and Valencia platforms, both based on AMD’s next-generation Bulldozer cores. Interlagos is a Socket-G34 platform supporting 12 and 16 core processors, while Valencia is Socket-C32 and can accommodate 6/8 core chips.Izvor: AnandTech i Xbit-Labs Zadnje izmijenjeno od: McG. 12.11.2009. u 02:39. |
#607 |
Postovi: 7,568
Službeno predstavljanje Bulldozer arhitekture i Bobcat procesora
Bulldozer In 2011 AMD will introduce two next-generation microarchitectures: Bulldozer for the high end desktop and server space and Bobcat for the price/power efficient ultra mobile market. First up, Bulldozer. This is a single Bulldozer core, but notice that it has two independent integer clusters, each with its own L1 data cache. The single FP cluster shares the L1 cache of the two integer clusters. Within each integer “core” are four pipelines, presumably half for ALUs and half for memory ops. That’s a narrower width than a single Phenom II core, but there are two integer clusters on a single Bulldozer core. Bobcat AMD says that a single Bobcat is capable of scaling down to less than one watt of power. Typically a single microarchitecture is capable of efficiently scaling to an order of magnitude of TDP. If Bobcat can go low as 0.5W, the high end would be around 5W. If it’s closer to 1W at the low end then 10W would be the upper portion. Either way, it’s too low to compete in current mainstream notebooks, meaning that Bobcat is strictly a netbook/ultraportable core as AMD indicated in its slides. Eventually Bulldozer will probably scale down to take care of the mainstream mobile market. AMD provided very little detail here other than it delivers 90% of today’s mainstream performance in less than half of the silicon area. If AMD views mainstream as an Athlon II X2, then Bobcat would deliver 90% of that performance in a die area of less than 60mm^2. Clearly this is bigger than Atom, but that’s just a guess. Either way, the performance targets sound impressive. SSE1-3 are supported as well as hardware virtualization.Izvor: AnandTech |
#608 |
Postovi: 7,568
Gigabyte GA-790FXTA-UD5P AM3 ploča
Gigabyte is readying the industry's first socket AM3 motherboard that offers the new connectivity features combo that is turning out to be quite a selling point in itself: USB 3.0 and SATA 6 Gbps. Enter GA-790FXTA-UD5P, a high-end socket AM3 motherboard based on the AMD 790FX + SB750 chipset, that isn't just a revised GA-MA790FXT-UD5P. Apart from the star attractions of USB 3.0 and SATA 6 Gbps, the board features a redesigned expansion slot layout, among other new features. The socket AM3 motherboard supports AMD Phenom II AM3 and Athlon II series processors with support for dual-channel DDR3 memory.Izvor: techPowerUp i The Tech Report Zadnje izmijenjeno od: McG. 30.09.2010. u 18:03. |
#609 |
Postovi: 34,129
Lijepo od njih da su stavili najnovije komunikacijske standarde, ali ja još uvijek nisam vidio uređaj koji bi ih mogao iskoristiti. SSD-ovi bi mogli imati vrlo zanimljive performanse na SATA3 kontroleru.
#610 |
Datum registracije: Oct 2001
Lokacija: Vinkovci
Postovi: 5,231
samo raid polja istih, ostalo bas i nije limitirano suceljem. Jedan manji dio ponude ali taj bi ionako bio i sa sata 3. A s obzirom da ima cijela dva konektora (ima li taj kontroler uopce raid mogucnosti?)....blah, marketing prodaje sve pa ce i ovo ![]() |
#611 | ||
The Last Akkadian
Datum registracije: Apr 2008
Postovi: 194
1st EDIT: cini mi se da su TPU i TTR u krivu; chip nije Marvell 88SE9123 vec Marvell 88SE9128 (bar prema AMDZone). Marvell je cini se povukao jos ovog ljeta 88SE9123 chip, tj. isto su ucinili i Asus (sa X58 i P55 based MBO) i GB (sa P55 MBO). A prema specifikaciji 88SE9128 podrzava SATAIII i RAID 0 (sto sam vidio). Postoji li non-RAID verzija, ne znam. Mozda se na ovaj nacin, nudeci samo RAID verziju sa onboard procom, Marvell zeli iskupiti za nestabilnosti uzrokovane 88SE9123 chipom...
![]() Zadnje izmijenjeno od: McG. 26.11.2009. u 14:53. Razlog: 88SE9128 |
#612 | |
Señor Audiophile
Lokacija: Zabreg
Postovi: 3,280
Bojim se da je to opet vrlo slicna implementacija :/ Ovako to izgleda kod Asrocka (Marvell 88SE9128): ![]() Obratite pozornost na tip utora (njegovu propusnost - PCIe x1) na koji se doticni kontroler spaja ... to je teoretskih 500MB/s (u stvarnosti DALEKO manje). Nesto slicno je bilo u planu i kod ploca predvidjenih za AMD-ovog rivala, kod kojih su koristeni nekakvi bridgevi (upitne kvalitete i performansi): Citiraj:
The Secret ... Zadnje izmijenjeno od: McG. 26.11.2009. u 14:54. |
#613 |
Lokacija: Vinkovci
Postovi: 5,231
@naram-sin koliko se sjecam cijela zbrka oko prve verzije chipa je bio neki bug s pata dijelom istoga, dakle SATA nikada nije ni bio problematican. A cak sam i ja koji uvijek cekam da tehnologija preboli dječje bolesti odavno odustao od pata uredjaja tako da to zapravo i nije bio neki problem. Tako da se ja ne bi fokusirao na to, veci je problem sto su ovi podaci koje si naveo teoretski, nikako praksa i sto nemamo uredjaja koji bi to mogli iskoristi cak i kad ne bi bila samo teorija. Tako da ostajem kod svoje izjave da je sve samo marketing. Pa sad, tko misli da mu treba.... ![]() btw, ajd necemo vise McGu kvariti thread ![]() |
#614 |
The Last Akkadian
Postovi: 194
Heh, pitam se do kuda mu seze strpljenje. ![]() Priznajem da nisam nigdje uocio da je problematika rezervirana za PATA dio kontrolera, ali vjerujem da je tako, ak kazes, samo sto to (taj) problem ne cini nista manjim. Ako je implementacija bila losha, a objektivno jest, povlacenje iz produkcije je bilo jedini logican kraj prethodnog chipa, a nova i "naprednija" revizija/verzija jedini logican (prije svega) komercijalni korak. Inace bi zfixali taj PATA kontroler... Btw, naravno da je sve samo teorija, ploce i tak nisu jos dostupne. I naravno da je trend napichavanja USB3.0 i SATAIII kontrolera 99,9% marketinski motiviran. Valjda slicno kao i (nekada) Draft-N wless. Kako veli dh41400, sve ce to biti znacajno i tehnoloski tek kada bude dio AMDovih SBxxx (i rivalovih ICHxxR). Ovi JMicroni, Marvelli i slicni i tak ne sluze nicem (dobro), osim za eSATA konektore... ![]() Cekamo McG-a... ![]()
#615 |
Postovi: 7,568
Detalji oko budućih 32nm procesora
Advanced Micro Devices plans to describe some of the features of its next-generation mobile microprocessor at the International Solid-State Circuits Conference (ISSCC) in early February, 2010. The company will not disclose all the details, which is logical, considering that its 32nm central processing units (CPUs) are only due in 2011, but some of the capabilities may be rather interesting. The 32nm implementation of an AMD x86-64 core occupying 9.69mm2 and containing more than 35 million transistors (excluding L2 cache), operates at frequencies >3.0GHz. The core incorporates numerous design and power improvements to enable an operating range of 2.5W to 25W and a zero-power gated state that make the core well-suited to a broad range of mobile and desktop products.Izvor: X-Bit Labs Zadnje izmijenjeno od: McG. 30.09.2010. u 17:57. |
#616 |
Postovi: 7,568
MSI 890FX-GD70 AM3 ploča
AMD will be announcing a new chipset for AM3. This new chipset is AMD 890FX. It was planned for launch in Q2 2010.Izvor: OCWorkbench i EXPreview Zadnje izmijenjeno od: McG. 30.09.2010. u 17:57. |
#617 |
Postovi: 34,129
6 PCI-E slotova? Strava. Čime ih popunit? Hladnjak za faznu regulaciju bi mogao smetati većim cpu coolerima.
#619 | |
freak
Postovi: 2,688
Trebali su staviti 4 PCI-e slota (svaki razmaknut da stane dual-slot grafa), ovako je ovih 6 ajmo rec beskorisno.
#620 |
Lokacija: Sibenik
Postovi: 1,226
Inace... bilo koja PCI-e kartica ide u te slotove ako se ne varam. Ne mora biti grafa |
#621 |
Lokacija: Vinkovci
Postovi: 5,231
ne varas se. Mislim da je ovo jednostavno bas zato da ljudi mogu grafu staviti gdje im vec odgovara ovisno o hladjenjima itd + da imaju mjesto gdje pozele za ostale PCIe kartice (valjda cemo ih u buducnosti vidjeti vise, vise me zivciraju s PCI s obzirom da ih nove ploce bas i nemaju previse i cesto su slabo iskoristivi zbog layouta). Ne vjerujem da ce ici na neki 6x CF. Sad jedino da elektronika ploce omoguci pravilnu raspodjelu, cisto sumljam da ce svi slotovi moci biti s punim bandwithom cak i na FX chipsetu a ako bi opet bili prisiljeni grafe gurati samo u odredjene slotove cijela ideja vise nema smisla previse. @coconut a to i kazem, vise je vrijeme da se rjesimo tih PCI kartica. Bemti poceli su sve vise govana gurati preko USBa samo zato sto su i sami svjesni da PCI slobodnih ljudi nemaju ili su im ih pokrile grafe a PCIe im valjda smrdi ![]() Zadnje izmijenjeno od: greg SE. 11.12.2009. u 19:11. |
#622 |
Postovi: 34,129
Još uvijek dosta dodatnih karticama dolazi sa PCI sučeljem (zvuk, wireless,...), pa mi je malo glupo da su stavili toliko PCI-E slotova.
#623 |
Adrenaline junkie
Lokacija: Doboj - Banja Luka
Postovi: 3,593
Tačno je da se ovi PCI-E slotovi mogu iskoristiti i za neke druge kartice, ne samo grafičke, ali koliko su nama dostupne takve kartice? Meni i dan danas trebaju minimalno 2 PCI slota za TV karticu i još jednu zvučnu karticu.
Lenovo ThinkPad W530 - Core i7 3840QM, 32 GB RAM, SSD Samsung 512 GB, nVidia Quadro K1000M 2 GB, 15.6" 1920x1080 IPS, baterija 9 ćelija |
#624 |
Postovi: 7,568
ECS A890GXM-A AM3 ploča
The board model name is ECS A890GXM-A. As the name implies, it is a new board based on AMD 890 chipset that replaces the aging 790GX. This board comes with a PCI slot, 3 PCIe full lenght slots for CrossFire X. There are 4 DIMM slots supporting DDR3-1800 (OC), 5 SATA II ports with the 6th as eSATA at the back panel. The board also deatures Hybrid CrossFire, so we assume the chipset on board is a AMD 890GX with integrated graphics. The board also supports eJiffy which works very similary to Asus’s ExpressGate, allowing you to access the net, instant messaging, browse pictures on your HDD/USB without botting into Windows.Izvor: OCWorkbench Zadnje izmijenjeno od: McG. 30.09.2010. u 17:57. |
#626 |
Postovi: 7,568
Asus M4A89GTOD Pro AM3 ploča
At the ongoing CES event, Asus displayed some of its upcoming motherboards which included the M4A89GTOD Pro, an ATX form-factor model based on the AMD 890G chipset. The AMD 890G seems to be a successor to the AMD 790GX, in being a performance integrated graphics part. It integrates a DirectX 10.1 compliant IGP while supporting discrete graphics with 2-way ATI CrossFireX. The M4A89GTOD Pro comes with an expansive feature-set thanks to the AMD 890G. The more interesting component being the AMD SB800 southbridge chip, which is on its way to being one of the first PC motherboard chipsets to natively support SATA 6 Gb/s. The chip doles out six SATA 6 Gb/s ports, while doing away with its on-die IDE controller. An external JMicron-made storage controller compensates with an IDE connector, a SATA 3 Gb/s port (colored black) and perhaps an eSATA port (at 3 Gb/s speeds), too.Izvor: techPowerUp Zadnje izmijenjeno od: McG. 30.09.2010. u 17:58. |
#627 |
Postovi: 7,568
ECS IC890GXM-A AM3 ploča
The IC890GXM-A is a simpler model aimed at home PC and media users. It has a simpler CPU VRM, the motherboard doesn't have a problem handling DDR3 memory at speeds of 1600 MHz. It claims support for six-core AMD desktop processors as well. The changes become more apparent with the expansion slots, where you will find one PCI-Express 2.0 x16, a PCI-Express x16 (electrical x4), and two each of PCI-Express x1 and PCI. There's just the one gigabit Ethernet controller, alongside the usual 8-channel audio, USB 2.0, eSATA 6 Gb/s, and display connectivity which includes DVI, and D-Sub. It is indicated that AMD's 890GX chipset will be released in April.Izvor: techPowerUp Zadnje izmijenjeno od: McG. 30.09.2010. u 17:58. |
#628 |
Postovi: 7,568
Gigabyte 890GX AM3 ploča
Gigabyte reveals its AMD 890GX mainboard GA-890GPA-UD3H with USB3 and SATA3 (6Gbps) support based on the upcoming AMD 890GX chipset. The 890GX is to replace the aging 790GX chipset and it is built around the AM3 socket with DDR3 support. This chipset will also support the upcoming Thuban 6 core processor. The board South bridge will include SATA3 (6Gbps) no USB 3.0 support yet. The boards have CrossFireX support, and include onboard DX10.1 capable video at 700MHz utilizing UVD2 (Unified Video Decoder) with support for Hybrid CrossFire. From the pictures, we can see that this board comes with NEC USB 3.0 controller chip. So there is USB 3 support on this board. It also has 6 SATA3 (6Gbps) ports in blue. There are 4 DIMM slots, 1394, GbE, 8 ch audio support on this board too. At the back panel, we see 6 USB ports (2 in blue), PS2/Keyboard/Mouse, D-SUB, DVI-D, HDMI, SP/DIF, 1394 and GbE ports.Izvor: OCWorkbench Zadnje izmijenjeno od: McG. 30.09.2010. u 17:58. |
#630 | |
Postovi: 7,568
![]() Zadnje izmijenjeno od: McG. 27.01.2010. u 18:40. |
