Staro 29.10.2009., 15:28   #1051
trouble
našikan pravim haos
Lokacija: u zabrani
Postovi: 2,707
Autor Razer Pregled postova
LoL, kod nas se takav rast cijena bu prvi "odvijao", ne sumnjam
pa naši su odma počeli s večin cijenama,zašto odgađat nešto za sutra kad možeš danas?
Staro 29.10.2009., 19:18   #1052
Bono
Uptime 99.99%
Bono's Avatar
Postovi: 2,614
Samo 5850 bi trebali poskupiti 15-20$, cijena ostalih serija bi ostala na istoj razini.
Bono je online   Reply With Quote
Staro 30.10.2009., 12:26   #1053
Matth€w
Matth€w's Avatar
Lokacija: NaN
Postovi: 3,438
HD 5970 spotted in the wild
uess what, it's big
AMD's upcoming HD 5970, the mother of all graphics cards, has been spotted in the wild, running in a massive Antec 1200 chassis.
You're probably wondering what the chassis has to do with it, but bear with me. The card is immense, measuring 13.5 inches or 34.3cm, it easily puts Ron Jeremy to shame.
As we said earlier, the TDP should end up around the 300W mark, and it shows. According to the bloke who fiddled with it, the fan runs at 4700RPM, so it's not that quiet. Mind you, this is an early sample, and there's a chance production models will have a somewhat slower fan.
AMD kindly asked the site to remove performance tests and pointed out that the card is an engineering sample, so some bios and driver tweaks are expected. AMD also said that this was not the final version of the card, and the production model could look a bit different.
http://www.fudzilla.com/content/view/16208/34/
Matth€w je offline   Reply With Quote
Staro 30.10.2009., 18:48   #1054
DraŽ
DraŽ's Avatar
Lokacija: Petrinja
Postovi: 904
Zen5 PCIvy bridge Notebook
CPU: AMD Ryzen 7 9700x, CO per Core, CS -20 (Mid, High, Max)
COOLER: Arctic Cooling Liquid Freezer III 420 A-RGB
MBO: MSI Tomahawk X870
RAM: Corsair Vengeance DDR5 32GB, 6000MHz CL28
GPU: MSI SuprimX Nvidia GeForce RTX 3070
NVM1: Samsung Evo 970 2TB
HDD1: WD Red 4TB, WD40EFRX
HDD2: WD Blue 6TB, WD60EZRZ
HDD3: WD Blue 6TB, WD60EZRZ
PSU: Corsair RMx 850W, ATX3.1
CASE: Fractal Meshify 2 XL
VENTS: 4x Arctic Cooling P14 PWM PST A-RGB
OS: Win 11 Pro, 64-bit
MONITOR: AOC Q3279VWFD8 - 32", IPS, 2560x1440
TV: LG 7450
MOUSE: Logitech MX Master 3
KEYBOARD: Logitech MX Keys
GAMEPAD: XBOX One
HEADPHONES: Sennheiser HD560s
DELL Inspiron 15R, 5520
CPU: Intel Core i7 3632QM, 2.20Ghz, turbo 3.20GHz
RAM: DDR3, 6GB (4GB + 2GB), 1600Mhz CL11
GPU: AMD Radeon 7670, Intel HD4000
SSD: Samsung EVO 850, 250GB
SCREEN: 15,6 inch LCD, 1366x768
OS: Ubuntu 24.04, 64-bit
DraŽ je offline   Reply With Quote
Staro 30.10.2009., 18:54   #1055
Omega
Omega's Avatar
Lokacija: Sibenik
Postovi: 1,226
ova bi napokon mogla zadovoljiti one "zelim najduzu crnu k...articu u kompu" kupce
Casemodd logs : Dragon Storm, Kali, Entourage
Complete Case Painting Guide
Omega je offline   Reply With Quote
Staro 30.10.2009., 19:39   #1056
Igor_Zg
Igor_Zg's Avatar
Postovi: 909
fakat je ogromna kartuša
još da vidimo performanse
EDIT: vidim da bi mi taman stala u kučište
Igor_Zg je offline   Reply With Quote
Staro 31.10.2009., 19:11   #1057
Matth€w
Matth€w's Avatar
Lokacija: NaN
Postovi: 3,438
BTJ, kolka je. Takvi će i rezultati bit ^^
Staro 31.10.2009., 19:23   #1058
Doink the Clown
Jack of all, master of none
Doink the Clown's Avatar
Lokacija: Matulji - Rijeka
Postovi: 6,214
35 prokletih cm! Upravo sam išao mjeriti, stala bi u mog Chiefteca, imala bi pol cm lufta Stvarno su pretjerali, a još kad pomislim koliko će to čudo trošiti... Većina ljudi koji kupe tu grafu morati će kupiti novo napajanje i novo kućište da je mogu udomiti i upogoniti kako treba
C L O W N I N G A R O U N D
Staro 31.10.2009., 20:07   #1059
Postovi: 34,003
Pa vidiš da su stavili 1kW napajanje. Valjda joj je to dovoljno?
Staro 31.10.2009., 20:33   #1060
Halos
muimerP
Halos's Avatar
Lokacija: VG
Postovi: 3,334
Našao sam i neke SS bencheva, pa sad mozda da okacim?
Ugl., grafa je stvarno zvijer, ali mene jos uvijek nekako češe zakaj nisu stavili barem 320bitnu sabirnicu, da se pređe preko 256-ne, unatoč ddr5ici
Ugl., ogromno dugačka zvijer, jos nekidan buraz kad je vidio 3870x2 veli wtf , pa šta je to?Mislim si ja...nisi ti vidio
Staro 31.10.2009., 20:38   #1061
Postovi: 34,003
Na 57x0 i 4770, 128bitna sabirnica u kombinaciji sa GDDR5 sasvim zadovoljavajuće obavlja svoju funkciju. U 48xx i 58xx 256bitna je također dovoljna za GDDR5. Zašto mijenjati nešto što dobro radi? Osim toga, jeftinije je staviti nešto što imaš otprije nego razvijati sasvim novo od početka.
Staro 31.10.2009., 20:47   #1062
Matth€w
Matth€w's Avatar
Lokacija: NaN
Postovi: 3,438
Zato kae veći broj bolji, a to ovi u marketingu ATi-a još nisu skontali.
Staro 31.10.2009., 20:56   #1063
nino
nino's Avatar
Postovi: 12,613
Pa zar nije serija 2900 imala 512bitnu sabirnicu?
Staro 31.10.2009., 21:04   #1064
JuiceBox
Xulos :)
JuiceBox's Avatar
Postovi: 7,567
Je ali je na njoj GDDR3 ,i mislili su da ce s tom 512 sabirnicom nes dobit a 8800 GTX ju je oprala ( tek na visokima rezama su tu negdje ) : http://www.tweaktown.com/articles/11...s/index12.html
E sad zasto ju ne stave na ovu zvjerinu neznam.
Staro 31.10.2009., 21:11   #1065
Momir
Momir's Avatar
Postovi: 1,011
A i nvidija se, prema nekim glasinama, vraca na 256bita u kombinaciji s GDDR5, vjerojatno je to dovoljno za nahranit GPU.
Momir je offline   Reply With Quote
Staro 31.10.2009., 23:21   #1066
Halos
muimerP
Halos's Avatar
Lokacija: VG
Postovi: 3,334
1.http://www.imagesforme.com/show.php/...eonHD59704.jpg
2.http://www.imagesforme.com/show.php/...eonHD59704.jpg
3.http://www.imagesforme.com/show.php/...eonHD59703.jpg
Evo ga, to sam našao negdje, neznam niti sam...slucajno
meni konkretno nista od ovoga neznači, ali mozda nekima ovdje da(ako imaju viska oko 4k kn)
@xulos - ja fkt. nisma znao da je 2900xt na visokim rezama tako blizu 8800GTX?Mislim sam da je puno slabija...
Staro 01.11.2009., 01:23   #1067
dh41400
Señor Audiophile
dh41400's Avatar
Lokacija: Zabreg
Postovi: 3,280
Neki bi rekli cak i brza od GTX-ice, pod malim gasom
Sve u svemu opasna kartulja ... kada bi ove nove bile barem upola dobri OC-eri kao ta stara garda :/
The Secret ...
Staro 01.11.2009., 02:18   #1068
zkljaja
Brat od Đon Vejna
zkljaja's Avatar
Lokacija: zg-vg
Postovi: 1,204
512mb ddr3 sa 512bit sabirnicom cak 130gb propusnosti...ako ddr5 sa tom nebi isao prek 250...
Staro 01.11.2009., 03:10   #1069
Razer
Razer's Avatar
Postovi: 11,642
Autor dh41400 Pregled postova
Brzina i ne čudi, s obzirom da je za takve sulude brzine potrebno napraviti 13-ak modova, od poboljšanja regulacije napona, do voltmodova čipa i memorije
Staro 01.11.2009., 03:21   #1070
dh41400
Señor Audiophile
dh41400's Avatar
Lokacija: Zabreg
Postovi: 3,280
... i sto je najbolje to sve kartulja moze preziviti
U svakom slucaju vrlo zanimljiva kartica za male igre s otpornicima/kondicima i lemilicom.
Sada bi se nasle za kojih 300-injak kn i onda na posao
BTW imao sam jednu 2900Pro koja je uz minimalne promjene u njenom biosu (bez lemilice) uspijevala podignuti oko 30-40% svoje taktove ... to su bili dani
Jedina zamjerka je izuzetna potrosnja, koja bi sezala i do 350-400W sa C2D-om i jednom kartuljom (extreme load).
The Secret ...
Staro 01.11.2009., 03:46   #1071
maX
maX's Avatar
Postovi: 7,326
Ja imam doma jednu Sapphire HD2900XT sa namontiranim Accelero Xtreme 2900
Staro 01.11.2009., 03:53   #1072
dh41400
Señor Audiophile
dh41400's Avatar
Lokacija: Zabreg
Postovi: 3,280
Vidio sam sto si napravio s dvije .... najs
Na listi sve neke 3870x2, 5870, 4870 , 4890 i onda ko sakom u oko 2900Pro
The Secret ...
Staro 01.11.2009., 10:22   #1073
maX
maX's Avatar
Postovi: 7,326
Thnx.
To je bilo sa 2xHD2900Pro. Sad imam baš 2900XT
Eh da mi je nabavit još jednu...
P.S. Sorry na OT
Staro 02.11.2009., 23:43   #1074
sinisa1989
Bazinga
sinisa1989's Avatar
Lokacija: Križevci
Postovi: 3,933
Radeon HD 5970 - Prvi pogled
Prve novosti o kartici.
Više o tome.
EDIT:
Vidim da ima već nekoliko riječi u ovoj temi.
Pa može spajanje ili brisanje. Krivo sam vidio pa sam otvorio novu temu.
Isprike.
Staro 03.11.2009., 00:02   #1075
mislav_os
freak
Postovi: 2,688
Vec?!? pretjerano,jos se nisu ni uhodale 5850 i 5870 :S
Staro 03.11.2009., 00:22   #1076
sinisa1989
Bazinga
sinisa1989's Avatar
Lokacija: Križevci
Postovi: 3,933
Vjerojatno s tom serijom misle konkurirat nvdijinom GT300 čipu, jer trenutna 5xxx serija nije dovoljna.
Staro 03.11.2009., 00:29   #1077
pinkskin
pinkskin's Avatar
Lokacija: Daruvar
Postovi: 1,744
Autor sinisa1989 Pregled postova
Kak znaš, imaš GT300
Staro 03.11.2009., 11:09   #1078
antrax
antrax's Avatar
Lokacija: Vz - Zg
Postovi: 2,930
nema, al da u nvidii nisu nista dirali po optimizacijama nego samo bubnuli dupli broj SPova i gddr5 memoriju na 384 bitni memorijski kontrolac vec su solidno premasili 5870. Nedostatak kartice ce bit da ce cip opet kostat ko svetog petra kajgana, al sta je tu je.
izdavanje kartice sa 2 chipa ima prilicno smisla prije gt300 (cak i ako ne bude brzi od 5870, dapace) jer odredeni dio ljudi bas ceka tu karticu ili nvidijino dual rjesenje i ne zele nista sto nije naj iz neke generacije, a gt300 dual ce vjerojatno jos malo vise kasniti. Malo je takvih, al zasto ne pobrati lovu od svih ako se moze bez vecih naprezanja!? Jedino me zanima posto ce to cudo bit, 5000, 6000, vise? uzas
Msi x79a GD65
Intel i7 3930k @ 4.7 1.4V
4x 4GB Kingston 1866 9-11-9
Gigabyte gtx 460 1gb
Samsung 830 128GB
640GB WD AAKS
WD green 1.5TB
LG drzac za kavu
Seasonic S12 500W
Coolermaster Stacker 831
HP LP2065 / LG IPS231P
Windows 7 Enterprise
Trenutno nepostojeci
Staro 03.11.2009., 11:26   #1079
Jelc
Super Moderators
Datum registracije: May 2002
Postovi: 17,485
Trla baba lan
Za sada je ta grafa samo "Paper Dragon", koliko će imati tranzistora više od 5870?
50% više?
Tak jasno da i perfomanse budu išle gore...
Naravno, to sve budemo vidjeli kad se pojavi jednog lijepog dana
Staro 03.11.2009., 11:35   #1080
antrax
antrax's Avatar
Lokacija: Vz - Zg
Postovi: 2,930
upravo tako, bas zato sto se nvidia busa o prsa i najavljuje tko zna sta, a mogao bi bit potencijalni relativni fijasko u odnosu na najave jednog ljepog dana kad i ako izade, atiu je vrlo dobra ideja imat u tom trenutku trziste preplavljeno svojim karticama svih razina. Pa kupci birajte, hocete li jednu vrlo skupu i relativno jaku zelenu karticu ili birat iz cjele game crvenih koja vam najvise odgovara, cjenovno ili performansama koje ce bit i ispod i iznad zelene, samo pitanje kojim redosljedom. 5970 je zato tu da osigura vrh kako god ispalo
Msi x79a GD65
Samsung 830 128GB
640GB WD AAKS
WD green 1.5TB
LG drzac za kavu
Seasonic S12 500W
