Staro 15.06.2009., 15:25   #1
JuiceBox
Xulos :)
JuiceBox's Avatar
Postovi: 7,544
ATI 4700 serija
AMD is preparing yet another performance-mainstream Radeon HD 4000 series SKU. The Radeon HD 4790 finds lineage from the Radeon HD 4890, currently AMD's fastest GPU. The RV790 GPU will be given a new set of specifications and memory configuration, to yield an SKU that performs better than the Radeon HD 4770, and slightly better than HD 4850. It beats us as to why it is positioned in the HD 4700 series, and not say "Radeon HD 4860", but we are too late to comment on that.
Specifications-wise, the RV790 core runs at 600 MHz, slightly lower than the RV770 in Radeon HD 4850 (625 MHz), but its performance increment over it comes from the use of GDDR5 memory. The GPU makes use of a 256-bit wide GDDR5 memory interface. It handles 512 MB of memory clocked at 800 MHz (3200 MHz effective). Being based on the RV790, it is pin-compatible with any existing HD 4890 PCB. Price-wise, it is expected to sit between the HD 4850 and HD 4870.
Slika : http://www.techpowerup.com/img/09-06-15/20a.jpg
Preuzeto sa : http://www.techpowerup.com/96859/AMD..._on_RV790.html
Staro 15.06.2009., 15:30   #2
Jelc
Super Moderators
Datum registracije: May 2002
Postovi: 17,485
SAPPHIRE HD 4730 lands in Europe
Following the successful launch of the world’s first 40nm Graphics processor, the HD4770, SAPPHIRE Technology, the leading manufacturer and worldwide supplier of AMD/ATI based graphics solutions is now shipping the SAPPHIRE HD 4730 - a powerful midrange graphics card that will appeal to enthusiasts on a budget.
Like SAPPHIRE’s high end graphics cards, the new HD 4730 uses the latest GDDR5 memory and the powerful graphics architectures from the ATI division of AMD, incorporating multi-purpose stream processing units, integrated memory management architecture and on-chip hardware video decoding.
SAPPHIRE HD 4730 has 640 stream processors – twice as many as previous generation mid-range cards - and core clock speed of 750MHz - faster than competing products - together with 512MB of GDDR5 memory with a 128-bit interface clocked at 900MHz (3600MHz effective). The SAPPHIRE HD 4730 delivers excellent performance for gaming or image rendering at a competitive price point.
Like the previous generation, SAPPHIRE HD 4730 supports DirectX10.1 for enhanced rendering performance and special lighting effects now being implemented in the latest games. The SAPPHIRE HD 4730 series uses the PCI-Express Gen2 interface, and features connectors for CrossFireX bridge cables, allowing two cards to be used together on a CrossFireX compatible mainboard for higher graphics performance. The SAPPHIRE HD 4730 uses a conventional two slot fan assisted cooler optimized for low noise and offers dual-link DVI, VGA and HDMI ports on the bracket, allowing a choice of two displays to be used without adaptors.
SAPPHIRE graphics cards in the HD 4000 series incorporate the latest ATI Avivo™ HD Technology for enhanced Video display. They feature a new generation of built in hardware UVD (Unified Video decoder) considerably reducing CPU load and delivering smooth decoding of Blu-ray™ and HD DVD content for both VC-1 and H.264 codecs, as well as Mpeg files. Integrated upscaling technology delivers the best quality DVD video images. With the latest drivers, the SAPPHIRE HD 4730 also offers ATI Stream processing for the acceleration of video transcoding and other supported applications.
SAPPHIRE HD 4000 series graphics cards are Microsoft Windows Vista™ Premium certified and supported by the ATI Catalyst® suite of software, ensuring customers have ongoing access to software updates for performance, stability and added features.
Staro 25.06.2009., 16:30   #3
branuschi
branuschi's Avatar
Lokacija: Sinj
Postovi: 397
ATI Radeon HD4730
dali tko ima iskustva s navedenom karticom dali se iplati uzet za 740kn ili bolje neku polovnu tipa HD3870, 4830, 4850.
link kod nas: http://www.autronic.hr/cms/Detaljno....aProizvod=3386
poz..
Moje trgovine: 1 ,2 , 3 , 4 , 5 , 6 , 7 , 8 , 9 , 10 , 11 , 12 , 13 , 14 , 15 , 16 , 17 , 18 , 19 , 20 , 21 , 22 , 23 , 24
branuschi je offline   Reply With Quote
Staro 25.06.2009., 17:36   #4
Nybelung
Autor branuschi Pregled postova
poz..
NE isplati se, toliko bi trebala koštati HD4770! Pa za manje od 800kn imaš HD4850 u Protisu npr.
Cijene HD4770 su još više napuhane, u Linksa je najjeftinja 900kn, a za te novce se nađe i pokoja HD4870 koja će ju pojesti za doručak.
A za rabljene SA GARANCIJOM gledaj HD4850 ~600kn, HD4830 ~500kn..
Mislim da na tržnici sad imaš HD4850 baš za 600kn!
Staro 25.06.2009., 20:20   #5
branuschi
branuschi's Avatar
Lokacija: Sinj
Postovi: 397
Autor Nybelung Pregled postova
a HD3870 za 500 ili HD 4850 za 600kn gar. cca. 1god.
Staro 26.06.2009., 01:40   #6
Nybelung
Za 500kn već imaš 8800GT, bolja je od HD3870..
Staro 26.06.2009., 11:21   #7
McT.
McT.'s Avatar
Lokacija: tam negde :)
Postovi: 290
Neznam dal se spominjalo prije, no neki novi brand je došao na naše tržište, ako se to tak može nazvat. VTX, od strane TUL Corporationa, ovih što drže Powercolor.
http://www.techpowerup.com/95993/TUL...brand_VTX.html
Ima već kod nas HD 4770 za 680 kn, a i serija 48xx je dosta nižih cijena.
EDIT: http://www.vtx3d.com/
McT. je offline   Reply With Quote
Staro 08.08.2009., 02:37   #8
Omega
Omega's Avatar
Lokacija: Sibenik
Postovi: 1,226
evo jos jedne.... ati se udomacio na testovima
Sapphire HD4730 @ sobitza
Casemodd logs : Dragon Storm, Kali, Entourage
Complete Case Painting Guide
Omega je offline   Reply With Quote
Staro 08.08.2009., 18:42   #9
blava
blava's Avatar
Lokacija: スラボニア
Postovi: 3,059
hehe dobar uvod
inace dobra kartica,ali jbg potrosnja je yebena,a i ATI ju je osakatio
Staro 08.08.2009., 22:10   #10
fran123456
Premija
fran123456's Avatar
Datum registracije: Mar 2009
Postovi: 1,634
fran123456 je offline   Reply With Quote
Staro 15.08.2009., 14:03   #11
McT.
McT.'s Avatar
Postovi: 290
Asus i Powercolor počeli stavljat nove coolere na svoje HD4770. Za ostale nisam našao. VTX će vjerojatno također izaći s novim coolerima (pošto su im kartice identične Powercolorkama). Ako netko nabavi HD4770 s ovim novim rješenjem, nek napiše dojmove
Staro 15.08.2009., 14:41   #12
Nybelung
Uff, Asus je ružan.
Jel izašao koji review? Kako hladi ta formula?
Staro 15.08.2009., 14:58   #13
fran123456
Premija
fran123456's Avatar
Postovi: 1,634
Stvarno je formula 4750 nema 6 pinski, right?
Staro 15.08.2009., 18:51   #14
McT.
McT.'s Avatar
Postovi: 290
http://www.bjorn3d.com/read.php?cID=1608
Autor fran123456 Pregled postova
Fudzilla
Priča se da će se prodavat u China i okolica only...prema testu HD4750 je 27% brža od HD4670, a 32% sporija od HD4770 i HD4850.
Zadnje izmijenjeno od: McT.. 15.08.2009. u 19:02.
Staro 15.08.2009., 19:03   #15
Nybelung
Stvarno je formula
Malo sam guglao, kažu da je i brza ko formula.
Šteta što je tako ružan hladnjak.,..
Staro 16.08.2009., 23:52   #16
maX
maX's Avatar
Postovi: 7,326
Autor x64 Pregled postova
Da je 29% brža od HD4670 i 30% sporija od HD4770 i HD4850 onda bi ju možda kupio, ali ovako ne.
Otkud samo potežu te postotke...
Staro 29.09.2009., 17:43   #17
amd_guru
amd_guru's Avatar
Postovi: 23
e ovako imam hd4730 (sapphire) kupljenu jučer i skužio sam da mi u driverima piše radeon 4810 (što je nelogično jer 4730 je jača i od 4830). driveri su zadnja verzija 9.9 pa ak neko zna jer stvara tak krivi naziv kakve probleme ili je to normalno ili je to neki poznati bug i dal će biti ispravljeno kad dođu nekim novijim driverima?
amd_guru je offline   Reply With Quote
Staro 29.09.2009., 18:34   #18
klem
Postovi: 591
4730 nažalost nije jača od 4830
klem je offline   Reply With Quote
Staro 30.09.2009., 09:47   #19
Router
Hejter
Postovi: 6,521
Autor klem Pregled postova
Ali postizu vrlo slicne rezultate
Druzio sam se bas s Sapphire 4730 , i kartica je prerastrosna , bar za moje napajanje a i velika za moje kuciste Ali cijenom od 600kn predstavlja jako dobar izbor za one kojima to ne igra ulogu .
Staro 03.10.2009., 13:02   #20
amd_guru
amd_guru's Avatar
Postovi: 23
Al mene samo zanima jel je normalno da piše 4810 umjesto 4730 (ili 4700 series)
Staro 03.10.2009., 13:07   #21
Router
Hejter
Postovi: 6,521
Naziv je nebitan ako grafa funkcionira kak treba , ocito je do drivera , vidio sam jos negdje na netu u nekom reviewu da im je za grafu pisalo da je 4810 . Pogledaj kaj gpu-z kaze da se uvjeris da je ili nije sve normalno .
Staro 03.10.2009., 13:55   #22
BeroVK
Lokacija: Vinkovci
Postovi: 780
Kupio maloprije Sapphire HD4730 zasad sam zadovoljan, samo sto je kartica povelika , ali hladnjak je dobar dok nepredje 60% brzine venta onda postaje bucan.
BeroVK je offline   Reply With Quote
Staro 05.10.2009., 22:18   #23
nexteen
nexteen's Avatar
Lokacija: Zrenjanin
Postovi: 18
Ok ajd nek mi neko kaze da li je isplativije uzeti HD4770 ili 4850 jer je to za mene nedoumica...jedni kazu uzmi ovo , drugi ono ili bolje receno jedni kazu uzmi 4850 jer ima bolje performance ali se greje kao lud i ima veliku potrosnju struje , dok za 4770 kazu uzmi jer se malo greje i ima malu potrsonju struje te se lako klokne do skoro istih vrednosti kao i 4850 pa si kao dobio graf. koja manje trosi sa istim performansama...inace pored toga meni je bitno da kasnije kad spadnu cene povezem to u Crossfire pa opet neki kazu da je 4770 jedna od najboljih opcija te sam video ovo sto podrzava tu teoriju a opet neki drugi kazu da to nije tacno i da se ne postizu tako dobri rezultati...ko je ovde lud LOL ... ajmo ljudi prosvetlite me na koju karticu se bazirati ?
nexteen je offline   Reply With Quote
Staro 05.10.2009., 22:26   #24
Jackson
Postovi: 648
Dobre performanse 4770 u crossu su potvrđene i na sobitzi.
Baš zato što su sve te kartice SKORO istih perfomansi, nema točnog odgovora.
Uzmi onu koja ti je najdostupnija i najjeftinija. Ja bi uzeo 4770 zbog buke, ali sad će se netko javiti s drugim mišljenjem.
Jer argumente za i protiv si već naveo u svom postu.
Eh da, da izvučeš maksimum iz kartice, upgreadaj ostatak kompa, jer je ovako nećeš nego 60-tak posto koristiti, overkill je.
Jackson je offline   Reply With Quote
Staro 05.10.2009., 22:43   #25
nexteen
nexteen's Avatar
Lokacija: Zrenjanin
Postovi: 18
Ma znam da ima poprecnih misljenja...vidi ovako 4770 je cak i skuplja nesto ili minimum ista kao kao 4850 sto znaci da cena ne igra nikakvu ulogu pa gledano tako mogu uzeti i 4850 ali nevolim buku kao sto kazes a s druge strane ako 4770 moze dati slicne rezultate kao 4850 kad se klokne onda bi to bilo sasvim OK...sto se tice kompa ne brigaj uzimam uskoro nov pa se zato raspitujem da se ne zeznem pri kupovini...inace ako bi uzeo 4770 isao bi na klok a tek kasnije kad padnu cene uzeo bi jos jednu pa u Crossfire itd...ono sto mene interesuje je da li kad se povezu te dve grafe u CF moze na njima da se radi klok ili ostaju na fabricka podesavanja...ali opet ako mislite da 4770 nije bolje resenje za Crossfire od 4850 onda cu uleteti u 4850 ... inace makina koja bi trebala to da tera je
CPU E6300 2.8ghz
P45 ploca
2x2gb DDR2 na 1066
OCZ napajanje 500W Stealth Extream itd...
Staro 05.10.2009., 22:52   #26
dh41400
Señor Audiophile
dh41400's Avatar
Lokacija: Zabreg
Postovi: 3,280
Par testova naseg kolege Omege ...
Overclocking HD4770 - RV740 u punom sjaju
CrossFire HD4770 - U drustvu je najbolje
BTW nitko nije rekao da je bilo koja kartica apsolutno najbolja ... sve ovisi sto trazis od kartulje.
Recimo realna razlika izmedju HD4770 i HD4850 je 5-10%, a razlika u potrosnji samih kartica je dvostruka.
P.S. naravno da OC-ane kartice mogu najnormalnije raditi u CF-u.
The Secret ...
Staro 05.10.2009., 23:22   #27
nexteen
nexteen's Avatar
Lokacija: Zrenjanin
Postovi: 18
Ovo je vec koji clanak koji pobija neverne tome oko toga da li treba uzeti 4770...tnx i sto je jos vec ironija oboje imate 4850 a ipak imate ovakvo razmisljanje...
Staro 06.10.2009., 08:18   #28
dh41400
Señor Audiophile
dh41400's Avatar
Lokacija: Zabreg
Postovi: 3,280
A tek ovo ...
Odrezalo mi slicicu ...
No ukratko, radi se o CrossFire-u 3x HD4770 ... taman za 1. mjesto na top listi
The Secret ...
Staro 06.10.2009., 09:46   #29
cane
Amiga fanboy
cane's Avatar
Postovi: 182
Isto slažem novi komp pa sam bio u nedoumici da li da uzmem 4770 ili 4850 sada i onda kasnije uzet još jednu i složiti crossfire. Nisam još složio komp ali sam već uzeo 4770, ponajprije zbog buke i manje potrošnje.
Postoji jedna sitna prednost 48x0 kartica, koja mi ipak nije presudila. Kad se počnu kupovati 5xxx kartice sigurno će biti za kupiti jeftinih 4850, 4870 kartica.
cane je offline   Reply With Quote
Staro 23.10.2009., 23:27   #30
ivand123
otišo po cigare i nesto
ivand123's Avatar
Lokacija: Zagreb (Maksimir)
Postovi: 373
E ovako imam jedno pitanje u vezi Sapphire 4730. Kada pokrenem komp na njoj mi zasvjetli crvena ledica. Kartica radi normalno al ipak pitam da nebi bilo poslje nismo znali.
ivand123 je offline   Reply With Quote
