Staro 28.06.2009., 15:20   #1
Liquid Snake
Liquid Snake's Avatar
Postovi: 166
CCC novi dizajn
Liquid Snake je offline   Reply With Quote
Staro 28.06.2009., 15:25   #2
Razer
Razer's Avatar
Postovi: 11,642
Nadam se da s novim dizajnom dolazi i poboljšanje po pitanju brzine. Jer je sadašnji trom i vuče se ko ništ, još otkad je izašao...
Staro 28.06.2009., 15:28   #3
DraŽ
DraŽ's Avatar
Lokacija: Petrinja
Postovi: 904
Autor Razer Pregled postova
Nebih se s tim složio.
Zen5 PCIvy bridge Notebook
CPU: AMD Ryzen 7 9700x, CO per Core, CS -20 (Mid, High, Max)
COOLER: Arctic Cooling Liquid Freezer III 420 A-RGB
MBO: MSI Tomahawk X870
RAM: Corsair Vengeance DDR5 32GB, 6000MHz CL28
GPU: MSI SuprimX Nvidia GeForce RTX 3070
NVM1: Samsung Evo 970 2TB
HDD1: WD Red 4TB, WD40EFRX
HDD2: WD Blue 6TB, WD60EZRZ
HDD3: WD Blue 6TB, WD60EZRZ
PSU: Corsair RMx 850W, ATX3.1
CASE: Fractal Meshify 2 XL
VENTS: 4x Arctic Cooling P14 PWM PST A-RGB
OS: Win 11 Pro, 64-bit
MONITOR: AOC Q3279VWFD8 - 32", IPS, 2560x1440
TV: LG 7450
MOUSE: Logitech MX Master 3
KEYBOARD: Logitech MX Keys
GAMEPAD: XBOX One
HEADPHONES: Sennheiser HD560s
DELL Inspiron 15R, 5520
CPU: Intel Core i7 3632QM, 2.20Ghz, turbo 3.20GHz
RAM: DDR3, 6GB (4GB + 2GB), 1600Mhz CL11
GPU: AMD Radeon 7670, Intel HD4000
SSD: Samsung EVO 850, 250GB
SCREEN: 15,6 inch LCD, 1366x768
OS: Ubuntu 24.04, 64-bit
DraŽ je offline   Reply With Quote
Staro 28.06.2009., 15:34   #4
Baja 001
Baja 001's Avatar
Postovi: 7,504
Autor DraŽ Pregled postova
Misliš na 9.7 ili na prijašnje, jer se ovi od prije vuku i sporo podižu
Staro 28.06.2009., 15:38   #5
DraŽ
DraŽ's Avatar
Lokacija: Petrinja
Postovi: 904
Ja neznam šta je za vas sporo? Meni se svi otvaraju u roku 0.5s i ono otvaranje u ccc-u kao overdrive, 3d settings, information center... to otvara u istom trenutku.
Mislim na verzije ccc-a koji su dolazili s verzijama drivera od 8.8 -> 9.5.
TV: LG 7450
GAMEPAD: XBOX One
Staro 28.06.2009., 15:38   #6
alengrosevic
alengrosevic's Avatar
Postovi: 3,775
sad sporo je ocito sujektivna ocjena. recimo meni se na 9.6 kad kliknem dolje desno na ati ikonu za sekundu i pola otvori CCC na ekranu. po meni to nije sporo. Istina bog, friski je sistem ali opet i kad je bio nakrkan, mislim da se nikad nije otvarao duze od 3 sec...
alengrosevic je online   Reply With Quote
Staro 28.06.2009., 15:39   #7
Razer
Razer's Avatar
Postovi: 11,642
Pod sporim mislim na samo loadanje CCC-a na početku. Kad se utabori u memoriji sa svojih 50-ak MB-a, normalno da dalje nije problem
P.S. Draž, miči si taj link iz siga
Staro 06.07.2009., 18:33   #8
Sn4k3
Sn4k3's Avatar
Lokacija: Zd
Postovi: 4,746
Upravo to sam primjetia kod frenda sto ima 4830, te kod drugog frenda koji ima 4670... Bas se primjeti neki flicker ekrana dok inicijalizira drivere i komp je "rezerviran" sve dok ne zavrsi (sto u oba slucaja traje ~20sek). S druge strane, ja taj problem nikad nisam ima (ni s xp-om, vistom, pa ni sa sedmicom)
Staro 07.07.2009., 08:49   #9
greg SE
greg SE's Avatar
Datum registracije: Oct 2001
Lokacija: Vinkovci
Postovi: 5,231
ja jos nisam dozivio da to ne vidim. I kad boot kao zavrsi i dalje se nesto desava, skoro minutu se win ponasaju kao da im nesto gusi disk ili proc (a nije niti jedno). Kako sam slab sa zivcima kad ubacim ati grafulju i to vidim vec od starta ju mrzim. Dovoljan je jos jedan bug da ju bacim na trznicu
Staro 07.07.2009., 09:01   #10
thedream
thedream's Avatar
Lokacija: Zagreb ( Šibenik )
Postovi: 5,458
Samo nek maknu debilni VPU recovery,ako će se srušit radije ću restartat komp. Čak i kad je ugašen,čini mi se kao da je integriran i dalje u CCC, pa ga je najbolje ni ne instalirati već samo goli driver + neki tool za settingse.
Staro 07.07.2009., 09:07   #11
Mad_Duke
Autor greg SE Pregled postova
A onda očisti smeće sa kompa. Meni tako nije na prastarom Sock.A mobilcu sa samo 512 RAM-a, te X1300. (ili 9600xt)
O E5200 i 4850 da ne pričam.
Staro 07.07.2009., 19:55   #12
greg SE
greg SE's Avatar
Lokacija: Vinkovci
Postovi: 5,231
nema kod mene smeca....al ono, doslovno. Koristim minimum programa, izbjegavam IM i slicne pizdarije, ne koristim torrente niti ista slicno.....ljudi bi se sokirali da vide
i sigurno nema veze s OSom jer sam to vidjao na valjda 4 razlicita, na 5 razlicitih konfiguracija tijekom godina. I tu samo racunam svoju kantu, na tudjima ne bi mogao jamciti za zagusenost smecem. Vecinom je izrazito samo prvih par rebootova ali primjeti se i kasnije ako gledas. A ne mogu si pomoc, gledam
Iako moram priznati da nisam primjetio na starijim karticama s driverima novijim od negdje 8.6, trenutno hounta samo hd4xxx seriju koliko vidim.
To sto ste vi spremni na puno toga zazmirit samo ne daj boze da bi rekli rijec protiv necega za cega ste dali lovu....neka vam. Ali ne diraj moje pravo da mi to smeta
Staro 18.07.2009., 22:33   #13
TROOPER007
Propali User
TROOPER007's Avatar
Postovi: 221
Imam jedno pitanje u vezi CCC-a.Da li je potrebno da on bude upaljen tjekom neke radnje npr. igranje jer probao sam ga ugasiti i tada nisam imao gubitke fspa nego je bio stalan.Hoce li vent je na defaultu i bez CCC-a dici se s povecanjem temp graficke ili je potreban da bi to sve kontrolirao.Pitam ovo jer se dosad nisam susretao s CCC.
TROOPER007 je offline   Reply With Quote
Staro 19.07.2009., 00:10   #14
SRV
SRV's Avatar
Lokacija: n/a
Postovi: 6,128
CCC uopce nije potreban da bude pokrenut. Dakle ugasis ga da se ne pokrece automatski, ako ti sta treba da promijenis - upalis ga, podesis i ponovno ugasis. A sve i da ne ugasis, to ne utice na 3D performanse, koliko "guta" ram.
Staro 19.07.2009., 00:28   #15
TROOPER007
Propali User
TROOPER007's Avatar
Postovi: 221
a hoce li se fan raditi kao i prije tj hoce li se pojacavati kad se poveca temp graficke?Ima mozda di na forumu kako najbolje podesiti 3D?
Staro 19.07.2009., 00:52   #16
blava
blava's Avatar
Lokacija: スラボニア
Postovi: 3,059
riva tuner
ja mislim da mozes praviti 3D profile i 2D profile,te brzinu fana na odredjenoj temperaturi
Staro 19.07.2009., 00:57   #17
TROOPER007
Propali User
TROOPER007's Avatar
Postovi: 221
ma nebi ja to nista diral nego me samo zanima kak ga najbolje posloziti taj ccc i jel automatski se fan brze vrti i bez njega
Staro 19.07.2009., 01:39   #18
Sn4k3
Sn4k3's Avatar
Lokacija: Zd
Postovi: 4,746
kako Blava kaze, najbolje ti je u riva tuneru sloziti profil za 2D i 3D taktove, tj. podesiti automatsku regulaciju... Osim ako ne zelis imati ugrijanu grafu u 2D modu i prebucnu u 3D-u...
Staro 19.07.2009., 02:11   #19
TROOPER007
Propali User
TROOPER007's Avatar
Postovi: 221
moral sam sam u test i radio je fan i bez ccc-a automatski.Svejedno hvala na pomoci a za ostalo se cujemo
Staro 23.07.2009., 23:53   #20
vedran031
vedran031's Avatar
Postovi: 544
upravo prije par minuta sam instalirao ccc 9.7 za xp32bitni i uopce mi tak neizgleda katalist, izgleda mi ko i 9.6 9.5 itd... jel to ok?
vedran031 je offline   Reply With Quote
Staro 25.07.2009., 01:54   #21
TROOPER007
Propali User
TROOPER007's Avatar
Postovi: 221
da meni isto ali pise da je verzija 9.7 ali skin je isti ako i u prijasnjim verzijama nema nikakve slicnosti sa slikama iz prvog posta
Staro 25.07.2009., 04:51   #22
Sn4k3
Sn4k3's Avatar
Lokacija: Zd
Postovi: 4,746
Pise u change-logu da je promjena izgleda CCC-a napravljena samo za Vistu i Win7...
Staro 25.07.2009., 19:38   #23
TROOPER007
Propali User
TROOPER007's Avatar
Postovi: 221
aha ja to ne gledam
Staro 26.07.2009., 22:32   #24
Wizzard
Wizzard's Avatar
Postovi: 493
Autor Sn4k3 Pregled postova
da ccc je promjenjen ali samo na sedmici i visti...
Wizzard je offline   Reply With Quote
Staro 27.07.2009., 01:44   #25
Mad_Duke
ovaj novi dizajn je cisto njesra. Do svega sada dolazim sa jednim ili nekad 2 klika vise nego prije.
Kaj se tiće same brzine, isto kao i prije, ali funkcionalnost, blah...
Staro 27.07.2009., 19:02   #26
Tola
Lokacija: SGE
Postovi: 92
Meni je novi dizajn puno bolji i sam CCC je brži i ugodnij za rad u odnosu na prošle verzije. Ovo je definitivno veliki skok prema naprjed, samo im još ostaje da srede perfomanse u nekim igrama, naročito u igrama "IT's a meant to be played".
Bravo ATi.
Tola je offline   Reply With Quote
Staro 27.07.2009., 20:38   #27
DraŽ
DraŽ's Avatar
Lokacija: Petrinja
Postovi: 904
Autor Tola Pregled postova
Bravo ATi.
Nemogu u tim igrama poboljšat performanse kada se nvidia pošalje svog čovjeka dok se radi igra i on tu igricu optimizira za GeForce-ice ili nešto ubaci da radeonkama padnu performanse, ili oboje?
Treba ATI počet stavljat svoj LOGO u igricama, ako nepočnu neće dobro proći. Ozbiljno razmišljam o prelasku na GeForce, a i na Intel no vidjet ćemo šta vrijeme donosi.
TV: LG 7450
GAMEPAD: XBOX One
Staro 28.07.2009., 12:55   #28
Lihto
The Dark Side of Moon
Lihto's Avatar
Postovi: 3,945
Jel zna netko di je u novom CCC ono oversize,što rastegne sliku da se popuni crno?
Macbook M1+ LG32UQ85R
iPad 5 White 32gb Wifi
iPhone XR 128gb
Lihto je offline   Reply With Quote
Staro 28.07.2009., 13:45   #29
Atrax
Atrax's Avatar
Postovi: 553
Iskreno, vidjevši da Far Cry 2 i dalje ima micro lag "feature" na mojoj grafi, i da se u ATI-jevom stožeru o tom problemu ništa ne spominje, palo je i meni to napamet, jer imho, to je jedan jedini razlog zzašto sam odustao od igre, završio nekih 20% i više nemam živaca, lock na 30 FPS-a je jednostavno no-go za mene u ovoj igri, pre malo.
Vidit ćemo, uskoro planiram uzet novu grafu (ATI narafno), ali bude li i s njom takvih ozbiljnih problema u nekoj igri...
To je kolko sam pročitao problem sa memory leakom kod nekih modela grafe, i zato se javlja taj micro stutter, a nakon nekih pola sata igranja framerate drastično počne padat, i igra se jednostavno ugasi, izbaci me u Win bez ikakvog error reporta.
Šteta, jer igra mi je zabavna, i u principu dobro radi, sve na max, lijepo se vrti, al šta mi to znači kad na 30 FPS-a osjećam lag, a ciljanje i napravit headshot su pain in the ass.
To sve bi se dalo sa kvalitetnim driverom riješit, al eto...
Igra stoji instalirana, i čeka neka bolja vremena.
A ATI-ju držim palčeve, novi dizajn mi se jako sviđa, brže se CCC podiže, primjetio sam i lagani porast performansi u nekim igrama, tako da, nadam se da će im krenut s tim driverima, imho mislim da su ATI-ju jedino ti driveri neka "minus" strana tako reć. Ima tu još dosta lufta za poboljšanja.
Atrax je offline   Reply With Quote
Staro 29.07.2009., 12:33   #30
Mad_Duke
Autor Lihto Pregled postova
To mi je bio prvi put da sam upalio help u tak nečem i tražio di se nalaze scaling opcije. Otidjes na onu opciju di ti je prikazan monitor i ne klikneš desnim klikom na veliku sliku monitora i properties, nego na onu manjeg dolje i configuration. tamo ti se nalaze. definitivno tlaka jer čim mijenjam rezoluciju, odnosno refresh rate moram opet ići sa jednog mjesta na drugo to mjenjati.
@Atrax
Osječaš lag na 30fps-a Pa, lol. Stavi si refresh rate ako imaš telku ili nešto na 30 Hz-a pa onda nemoj niti ulaziti u igru, nego samo mišom idi po ekranu pa buš vidio lijepo laganje. a zašto. Ne zbog ATi-a, niti NVidije, nego jer je 30 fpsa prokleto malo. Čitaj katastrofa!
