Staro 18.10.2008., 10:29   #1
Jelc
Super Moderators
Datum registracije: May 2002
Postovi: 17,485
Far Cry 2 HotFix
The information in this article applies to the following configuration(s):
Far Cry 2
Radeon™ HD 4800 series
Radeon™ HD 4600 series
Radeon™ HD 3800 series
Radeon™ HD 3600 series
Radeon™ HD 3400 series
Radeon™ HD 2900 series
Radeon™ HD 2600 series
Radeon™ HD 2400 series
Radeon™ X1950 series
Radeon™ X1900 series
Radeon™ X1800 series
Radeon™ X1650 series
Radeon™ X1600 series
Windows Vista 32-bit Edition
Windows Vista 64-bit Edition
Windows XP Professional
Windows XP Home Edition
Windows XP Media Center Edition
Windows XP Professional x64 Edition
This hotfix
Improves performance for the DirectX 9 version of Far Cry 2 on CrossFire™ compatible systems
Improves performance for the DirectX 10 version of Far Cry 2 on both single and CrossFire™ compatible systems
http://support.ati.com/ics/support/d...estionID=38664
Staro 18.10.2008., 13:51   #2
Sonic1984
Sonic1984's Avatar
Postovi: 542
Aj bar su izbacili hotfix prije igre a ne nakon par mjeseci kad vecina ljudi vec zavrse sa igranjem......
Sonic1984 je offline   Reply With Quote
Staro 18.10.2008., 15:44   #3
Jelc
Super Moderators
Postovi: 17,485
Je, sad nam samo fali igra pa da isprobamo
Staro 18.10.2008., 16:57   #4
Sonic1984
Sonic1984's Avatar
Postovi: 542
Jos samo malo.......jos samo par dana.......
Staro 18.10.2008., 17:05   #5
edoo
1337
Lokacija: Slav. Brod
Postovi: 95
imam pitanje jel to sam za Amd procesore jel tak ili ?
edoo je offline   Reply With Quote
Staro 18.10.2008., 17:08   #6
Postovi: 7,568
To je za grafičke kartice i totalno je svejedno koji procesor imaš.
Staro 20.10.2008., 19:45   #7
DraŽ
DraŽ's Avatar
Lokacija: Petrinja
Postovi: 904
Znaci sa hotfixom dolazi ccc i display driveri 8.10???
DraŽ je offline   Reply With Quote
Staro 20.10.2008., 22:12   #8
jurbAs
jurbAs's Avatar
Postovi: 2,582
evo razlike najocitija je sa 4870x2 pri manjim rezama
LINK
jurbAs je online   Reply With Quote
Staro 21.10.2008., 09:59   #9
Enter Sandman
dark paradise
Enter Sandman's Avatar
Postovi: 551
Kveščn: dal se taj fiks bubne prek drivera ili ne pošto ima ccc?
Piše: Note: This driver is provided as is and is not supported by AMD. It has not completed full AMD testing, and is only recommended for users experiencing the particular issue described above.
Enter Sandman je offline   Reply With Quote
Staro 21.10.2008., 10:16   #10
Big Guy
RPG player
Postovi: 1,574
hmmm
nema mobility verzija grafa, valjda će mi raditi
I hate to see you leave, but I love to watch you go
Big Guy je offline   Reply With Quote
Staro 21.10.2008., 20:16   #11
DraŽ
DraŽ's Avatar
Lokacija: Petrinja
Postovi: 904
Taj hotfix dolazi sa modificiranim driverima 8.10 (CCC+Display driveri) znaci unninstal starih,driver sweeper ili driver cleaner i stavis ove i onda pokrenes farcry 2 i dobijes 20% vise fps-a
Zadnje izmijenjeno od: DraŽ. 21.10.2008. u 21:17.
Staro 22.10.2008., 22:07   #12
Valg
Lokacija: City
Postovi: 1,404
Imam jedan mali problemčić. Naime, kada istalim hotfix i restartam računalo, jednostavno mi se ne prepoznaju driveri, tj grafa je nepoznati! ???
Pa gdje je problem? Uđem u safe mod, i sve normalno, vratim se u klasičan mod, opet nema grafe, i ne mogu je instalirati! ???
OS je XP SP3 X86. Ako netko može pomoći, hvala!
Valg je offline   Reply With Quote
Staro 23.10.2008., 20:55   #13
Atrax
Atrax's Avatar
Postovi: 553
Autor Valg Pregled postova
hm...što više čitam po forumu, sve više mi se čini koda jedini nemam problema sa instaliranjem drivera....Čak mi i bete prolaze ko po loju (osim 8.10, rušio mi je CoD4 MP).
uglavnom, jesi probao možda ponovno reinstall? al prije toga počistit sa drivelcleaner ili driver sweeper? to probaj počistit dok si u safe modu, možda pomogne. i nekima je znao antivirusni zezat kod instalacije drivera, probaj ga ubit skroz pa pokrenut instalaciju.
kako ti je sa prijašnjim driverima bilo, jesi imo tih problema?
mislim, to je šta bih ja napravio......
Atrax je offline   Reply With Quote
Staro 23.10.2008., 21:04   #14
atha
atha's Avatar
Postovi: 9,067
3870 - nikakve primjetne razlike nema.
___________
Just atha
x
Staro 23.10.2008., 21:25   #15
DraŽ
DraŽ's Avatar
Lokacija: Petrinja
Postovi: 904
Hotfix je sam za hd4**0 seriju to jeste tamo je jedina primjetna razlika iako pise da je za sve crossfire sisteme(xp i vista) i za single gpu sisteme na visti.
Ja sam imao problem sa installom drivera na visti- pukno sam unninstal 8.9 drivera, restart,driver sweeper i idem ja instalirat hotfix kad ono error nakon "installa" pise da se dogodio error tijekom instalacije display drivera. Onda sam resetiorao i pisalo je da je grafa nepoznata i onda sam ponovno isao installirat (bez koristenja driver sweepera) i ovaj put sam stisnuo na "express install" (prosli put je bio "custom") i sve je dobro proslo.
Inace ovo su mi najbolji driveri do sad kriza je puno stabilnija na dx10 pa tako i assassins creed ,a za farcry cu vidit sljedeci tjedan vjerovatno ako ne i kasnije...
Staro 23.10.2008., 21:29   #16
Valg
Lokacija: City
Postovi: 1,404
Autor Atrax Pregled postova
Probao sam sa driver cleanerom, u safe modu, micanje starih pa CC cleanerom brisanje ostalog smeća, itd itd...
Jednostavno nejde!
Ako hoću nove drivere, onda moram svježe windwse instalirati
A neda mi se, jer imam image sa acronisom, pa uvjek vratim na poziciju koju sam napravio, ali to je već sa driverima!
Prije nisam imao takvih problema, prije sam imao 6600GT...
Eh da, dok sam imao 9200pro, mogao sam upgradeati driver sa driverom kako sam želio, ali tada AMD nije imao ništa sa kanađanima...
Staro 23.10.2008., 22:24   #17
the-rider
ha?
the-rider's Avatar
Lokacija: Poreč
Postovi: 540
ja sad probao hotfix, na hd3870, puno bolje je, igra vise ne steka, prije mi je znalo bas zablokirati, sad nista
the-rider je offline   Reply With Quote
Staro 23.10.2008., 22:28   #18
Atrax
Atrax's Avatar
Postovi: 553
a gle, moš ti to i sad radit, samo uvijek postoji mogućnost da ti novi driveri neće u potpunosti pregazit stare, i onda može isto doć do problema. neki tak oduvjek instaliraju drivere i sve im radi kak treba. ja eto imam naviku uvijek sve staro počistit i onda stavit novo.
neznam, probaj onda system restore na datum kad si imo drivere koji su ti radili, pa samo pregazit to novim driverima. možda ti driver cleaner obriše neke datoteke koje novi driver ne stavi ponovo, pa ti se ne instalira kak treba...
makar, shebano je to da moraš svaki put praktički win reinstalirat kad oćeš nove drivere, mora bit neka caka, možda greška u postupku negdje. pogotovo reinstalirat xp nanovo svaki put...pain in the ass. vista se za manje od pol sata instalira skup sa sp1. dobro ti imas image, tak da ne znam kolko ti to olakšava postupak.
Staro 23.10.2008., 23:40   #19
Valg
Lokacija: City
Postovi: 1,404
Pa na image-u imam sve: office, drivere, programe koje koristim. Dakle riješena svar, za 5-10 minuta sve vratim na staro (kao PRAVI system restore), no jednostavno nejde instalacija drivera...
Možda je zbog nForce ploče, ne voli ATi možda?
Trenutno nemam od koga posuditi AM2(+) ploču sa AMD ili VIA chipsetom, pa ne znam...
Staro 24.10.2008., 10:08   #20
Jelc
Super Moderators
Postovi: 17,485
Kakve veze ima sad Nvidia ili ATI chipset...ista stvar...
Staro 24.10.2008., 10:42   #21
Melani
Lokacija: doma
Postovi: 964
jednostavno instaliraš drivere jedne prek drugih.stvarno ne kužim ko da je situacija s updateom drivera neki problem setup next next i restart.bez ikakvih cleanera jer oni samo donose probleme ak neznaš kak i kad i zašto ih koristiti.
Melani je offline   Reply With Quote
Staro 24.10.2008., 18:30   #22
Valg
Lokacija: City
Postovi: 1,404
Autor Melani Pregled postova
Bravo, čitaj ponovno što sam napisao...
Staro 26.10.2008., 11:29   #23
Smile07
Smile07's Avatar
Lokacija: Cro
Postovi: 54
oce li bit bolje perfomanse na x1650?
Smile07 je offline   Reply With Quote
Staro 26.10.2008., 11:38   #24
Problem
Pijem samo KAJ
Problem's Avatar
Lokacija: Vž
Postovi: 2,682
pa ako pise da je zahvacena i x1650 serija, onda valjda hoce
Staro 26.10.2008., 11:46   #25
Valg
Lokacija: City
Postovi: 1,404
Damn, moram nove viruse dić da bi instalirao fix... :/
A ovako mi samo prijavi da imam stare drivere, i ide normalno...
Samo od sebe podesi skoro sve na high, osim fizike, a ja dignem rezu na 1680X1050, i imam u prosjeku od 30-40 FPS-a, što je ok...
Nadam se da ću na novim virusima sa hotfixom imati bar 40-50 frejmova...
Staro 26.10.2008., 12:43   #26
pipe
Bill Gates
pipe's Avatar
Lokacija: Vukovar
Postovi: 1,983
Ja dobio max. 20 Fps-a. Ja zadovoljan.
I ja imam na ploci.
Staro 26.10.2008., 20:15   #27
Smile07
Smile07's Avatar
Lokacija: Cro
Postovi: 54
Instalirao i vise nece da ude u igru vratio obicne 8.10
Staro 26.10.2008., 20:25   #28
Valg
Lokacija: City
Postovi: 1,404
Autor Smile07 Pregled postova
Znači ATi (AMD) stvarno ima problema sa driverima...
Očito nije problem samo u karticama, već i kompaktibilnosti drivera pod određenim pločama...
Prvo su sjebali svoje AGP drivere, jer sve nove AGP grafe imaju užasno puno problema, evovećina ih ne radi na SIS baziranim pločama...
Evo sada mene jebe na nForce ploči, probao kod frenda na gigabyteovoj ploči sa intelovim chipsetom, i radi ko beba update drivera...
Čak sam i svoje nLite-ane windowse kod njega na kratno instalirao, stavio starije drivere, probao preko njih instalirati fix, radi normalno...
God job AMD, good job...
Staro 26.10.2008., 22:14   #29
BladeRunner
Type R
BladeRunner's Avatar
Postovi: 1,485
http://forum.pcekspert.com/search.php?searchid=1344328
Jel vidiš poantu?
David linčujem Davida Finčera
BladeRunner je offline   Reply With Quote
Staro 27.10.2008., 03:02   #30
Valg
Lokacija: City
Postovi: 1,404
Autor BladeRunner Pregled postova
"Sorry - no matches. Please try some different terms."
