Staro 22.02.2008., 00:10   #1
Mar
Suit up!
Mar's Avatar
Postovi: 5,968
Lenovo Thinkpad X300
Thinkpad se vraća u stilu (poznavatelji će primjetiti "stare" nove botune za trackpoint).
Preliminarna recenzija:
http://www.notebookreview.com/default.asp?newsID=4270
Jedina mana - cijena
- Barney Stinson
Mar je online   Reply With Quote
Staro 12.04.2008., 12:35   #2
Trillian
Trillian's Avatar
Lokacija: Zagreb grad
Postovi: 195
Samo da se pohvalim...igrao sam se sa njime neko vrijeme i proizvod je vrhunski.
Tako dobre detalje, takve materijalne izrade, crvstocu uz i više nego dobre perfomrmanse na visti (SSD rula)...uf...ako ce tako u buducnosti izgledati thinkpadovi mislim da ce se konkurencija dobrano pomučiti
Trillian je offline   Reply With Quote
Staro 15.04.2008., 11:10   #3
sick_boy
sick_boy's Avatar
Postovi: 680
Ima u Ve-Mila za cca 20k kuna. IMHO - way 2 much. Mislim, vjerujem da je stroj prva liga and all, ali mislim da veliki dio cijene čini sam brand.
Čini mi se otprilike jednako neisplativo kao i MacBook Air
iBase MI980VF-4700EQ Motherboard
Intel Core I7-4700EQ (2.4-3.4Ghz, 4 cores, 8 threads)
16GB DDR3L RAM 1600 MHz
250 GB Samsung 860 Evo mSATA SSD
1TB Seagate Barracuda 7200 2.5" HDD
ATI RX550 4GB
Kolink Satellite mATX Cube Case
Delta Electronics GPS-350EB-200 A ATX 350W PSU
Acer 27" 1440p 75Hz Freesync IPS monitor
Cherry MX Board 1.0 keyboard, brown switches
LOGITECH G305 Lightspeed mouse
Arch Linux/Win 10
Lenovo Idepad 5 pro:
AMD Ryzen 7 6800HS
16GB DDR5 RAM 5600 MHz
1TB Micron nVme HDD
16" 2160x1600 16:10 IPS Display
Windows 11
Fujitsu Esprimo:
Intel(R) Core(TM)2 Duo CPU E7500
4GB DDR2 RAM
WDC WD1600AAJS-0 160GB
Seagate ST4000DM000 4TB
openmediavault 4.1.17
Philips 55PUS7373/12 55" 4K HDR VA Direct LED TV
Toshiba 50" QLED 4K Dolby Vision/Dolby Atmos TV
TCL 40ES560 40" FullHD TV
Pioneer BDP-160 BD player
Maxell SB-3000 soundbar
Onkyo TX-SV444 AV Receiver
Onkyo DX-7333 CD Player
Audio-Technica AT-LP2XGY gramofon
Mirage 290is bookshelf speakers
sick_boy je offline   Reply With Quote
Staro 15.04.2008., 11:20   #4
Old Iggy
Old Iggy's Avatar
Postovi: 4,888
Autor sick_boy Pregled postova
Nije bas vise brand toliki dio cijene, X300 ima neke razloge zasto koliko kosta, imam tu jedan.
S druge strane, ThinkPadi su bitno jeftiniji nego nekad, s tim da treba pricekati da se ustabili na trzistu, tad ce i cijena pasti.
Igor Batinic
Staro 15.04.2008., 12:21   #5
sick_boy
sick_boy's Avatar
Postovi: 680
No, hajd me onda prosvijetli i reci što može koštati 20k kuna? IMHO, to je brand i svrstavanje u određenu kategoriju.
Svi laptopi su bitno jeftiniji nego nekad - danas poslovne laptope u solidno ojačanom kućištu, te sa biranim komponentama možeš kupiti već od 5k kuna (govorim o poznatim brandovima - Lenovo, HP, Dell, Toshiba...), tako da to što je x300 jeftiniji nego bi ekvivalentni model bio prije par godina i nije neki argument.
ATI RX550 4GB
Arch Linux/Win 10
AMD Ryzen 7 6800HS
1TB Micron nVme HDD
Windows 11
Fujitsu Esprimo:
4GB DDR2 RAM
Staro 15.04.2008., 12:33   #6
Renesis
Ex-Gastarbajter
Renesis's Avatar
Lokacija: Zagreb / Rijeka
Postovi: 5,463
ovi od 5kkn su maaalo veći, i maaalo lošije napravljeni daleko od toga da x300 nije skup, ali mislim da velikim dijelom moze i pokrit svoju cijenu... čisto kada uzmem u ruke novi acer koji je stari ubo za 6500kn, ili stari IBM R30, mislim da je jasno da su to dva svijeta...
Abit IS7-E + TR NB-1
Homemade vodeno part1
Homemade vodeno part2
Staro 15.04.2008., 12:50   #7
Mar
Suit up!
Mar's Avatar
Postovi: 5,968
Kako je dolar pao značajno, ako kome treba može se ovdje nabavit poprilično povoljno u usporedbi s cijenom kod nas.
Link
- Barney Stinson
Staro 15.04.2008., 14:13   #8
Old Iggy
Old Iggy's Avatar
Postovi: 4,888
To su me isto pitali i kad su kostali 40 - 60 kkn.
Samo disk mu realno bitno povecava cijenu. Kad uzmes kompletnu kalkulaciju proizvoda (koja nema nikakve veze s onim sto ljudi misle da ista sadrzi) dobijes OK kalkulaciju.
BTW, ne vidim koji konkurent ima slican proizvod, posebno za 5 kkn.
Igor Batinic
Staro 15.04.2008., 14:14   #9
Old Iggy
Old Iggy's Avatar
Postovi: 4,888
Autor Mar Pregled postova
Link
Vec je na preko 13,5 kkn. Na to nadodas transport, pa na sve zajedno carinu i jos PDV, bas me zanima gdje vidis racunicu.
Igor Batinic
Staro 15.04.2008., 14:24   #10
Mar
Suit up!
Mar's Avatar
Postovi: 5,968
Autor Old Iggy Pregled postova
cca. 12,500kn + 500kn za transport = 13000kn + 22% PDV = 15860kn + 10% carina = 17500kn.
To je najviši mogući iznos, s tim da se dobije 4 gige rama (2x2GB) za razliku od ovdašnjeg 2x1GB (+ bar 500ak kn razlike).
Znači razlika u najskupljoj soluciji je min. 3000kn, a da ne govorim kako je vrlo lako moguće navesti nižu vrijednost, a možda te u carini i ne opale za to (recimo šalje se u nekoj staroj kutiji, otvoren i "zamazan").
A tu je uvijek i opcija "tete" iza Amerike
- Barney Stinson
Staro 15.04.2008., 14:33   #11
Old Iggy
Old Iggy's Avatar
Postovi: 4,888
Trosak transporta za takvo sto je bitno veci (ne bi bas da idem bilo cim, posebno kao kvazi polovan), uz rabat na neku firmu skoro pa dobijes tu cifru.
Inace sam svako malo preko bare, zadnjih par puta nisam uzeo nista od tehnicke opreme jer se - ne isplati. Cifre koje se vide preko weba nisu one u trgovinama, obicno ima "malih" caka, a kad se uzme u obzir problematicno jamstvo i ostalo - ne hvala.
Igor Batinic
Staro 15.04.2008., 17:18   #12
sick_boy
sick_boy's Avatar
Postovi: 680
Don't take me wrong, ne tvrdim da netko ima proizvod koji uopće može konkurirati ovom, ali i dalje mislim da je cijena prenabrijana.
Kad sam rekao 5k kn, nisam mislio na sličan proizvod, nego jednostavno da mi se čini suludo davati 15k kuna više za nešto manji i možebitno robusniji laptop sličnih perfomansi. Ali opet, svaka roba nađe svog kupca, samo što mi se čini da ovo baš neće biti bestseller.
ATI RX550 4GB
Arch Linux/Win 10
AMD Ryzen 7 6800HS
1TB Micron nVme HDD
Windows 11
Fujitsu Esprimo:
4GB DDR2 RAM
Staro 15.04.2008., 17:50   #13
Trillian
Trillian's Avatar
Postovi: 195
Kako to mislis bestseller? Zar je ikada x300 i zamišljen kao bestseller? Omanuo si celi fudbal...
X300 je Tecnological showcase da se pokaze sto se moze uz malo truda. Ja nisam siguran da li si ti uzeo u obzir konkurenciju i cijenu te konkurencije. Kada to bolje pogledas shvatiti ces da je X300 prejeftin.
Uzmimo npr mac book air - appleov poluproizvod koji sa SSD diskom košta 25k kn. Što je najbolje koristi prespori Samsungov N880X ssd koji koristi paralelno-serijsku konverziju i iskreno zakurac je. Lenovo je jedini proizvodjac na svijetu koji isporučuje nove Samsungove NBX diskove koji su više nego 2x brži od N880X, uz naravno i manju potrosnju energije. Naravno MBA nema ni optical drive.
Druga stvar...koliko znaš laptopa da su kompletno napravljeni od magnezija i carbon fibera? Da su debljine jedva ethernet porta (zato i nije moguće napraviti tanji funkcionionalan laptop od x300) a čvrsti da možeš proliti vodu po njima, stati na njih i ispustiti sa više od metra visine da budu neoštečeni?
uz to sve ima odličan audio sustav, superbright ekran sa LED osvijetljenjem, HSDPA pripremu (antene i utor za sim koji postaju funkcionalni čim u europu će se mogu uvesti wwan adapter), ambient light senzor, osvijetljenje tipkovnice, 6cell bateriju, optical drive,kameru itd itd itd.
X300 vjeruj mi onog trena kada ga primis u ruku i vidis kako preglomazna vista radi brzo (iskreno još nisam vidio laptop da brze radi s vistom, a moj posao je vezan usko uz laptope)svaka kuna ce ti biti jasna.
Kada sam ga ja gledao kupio ga je frajer koji je ušao u ducan iza mene. Za cijenu nije pitao...shvatio je sto je to...kasnije je uzeo uz jega i L200x u bundlu...
2 mar: cijena X300 sa SSD diskom i 6cell i ODD je 3197$ sa popustom, redovna cijena 3539$. Isto tako uzmi da kada platis shipment, osiguranje posiljke, špeditera, pdv i zamislih nekih minimalnih par % marže doci ces tocno na hrvatsku cijenu. Bez brige već je meni palo na pamet da bi si ga tamo mogao kupiti, ali ne isplati se...
Zadnje izmijenjeno od: Trillian. 15.04.2008. u 18:05.
Staro 15.04.2008., 18:10   #14
Trillian
Trillian's Avatar
Postovi: 195
BTW izašao je ifull review na nrw:
zaključak -The ThinkPad X300 is a premium product that's worth the price if you need the features it offers. The X300's excellent portability, abundance of wireless options, built-in optical drive, SSD advantage, great screen, fantastic keyboard, and second-to-none build quality all add up to a notebook that's easy to recommend to business users who consider a notebook to be an important part of their success with work. It's certainly not the right notebook for everyone, the 64GB storage limit
http://www.notebookreview.com/default.asp?newsID=4281
Staro 15.04.2008., 20:42   #15
sick_boy
sick_boy's Avatar
Postovi: 680
Ma, dobro, vidim da si se zaljubio u taj "piece of equipment". Taj "business wanna be" laptop ustvari kupovati će entuzijasti i tatini sinovi više nego pravi poslovni ljudi, jer, kao što već rekoh, za puno manje novaca može se kupiti pristojan business laptop sa svim tim featurima, samo nešto veći i manje robustan.
Radim u velikoj firmi u kojoj imamo na stotine službenih business laptopa i niti jedan nije tako skup (premda si, naravno, možemo to priuštiti, ali nikom ne pada na pamet da zatraži komad hardware-a koji košta 20k kuna, a biće zastario za godinu-dvije). I da, i naši su laptopi otporni na vodu, mogu pasti sa stola, može se na njima stajati, imaju ambient sensor (feature koji svi odreda isključuju jer je bespotrebno sranje). Također, imaju brži procesor, neki i neusporedivo bolje grafičke perfomanse te višestruko veći kapacitet diska.
Na kažem da to nije izvrstan proizvod. Preskupi i precjenjeni izvrstan proizvod (kao i npr. Honda Civic hatchback, Pioneer plasma televizori, 8800GTX grafika kad je izišla i sl.).
ATI RX550 4GB
Arch Linux/Win 10
AMD Ryzen 7 6800HS
1TB Micron nVme HDD
Windows 11
Fujitsu Esprimo:
4GB DDR2 RAM
Staro 15.04.2008., 21:08   #16
Mar
Suit up!
Mar's Avatar
Postovi: 5,968
To je ultrakompaktno premium poslovno računalo.
Trenutno je daleko ispred bilo kakve konkurencije što se tiče karakteristika, tehnologije i izrade.
Uspoređivati ovaj laptop s nekom HP "štracom" od 5000kn je kao uspoređivanje krušaka i jabuka, kao uspoređivanje Dacie Logan i Lexusa LS600h/S klase/A8-ice itd...
- Barney Stinson
Staro 15.04.2008., 22:39   #17
Old Iggy
Old Iggy's Avatar
Postovi: 4,888
Mislim da brkas kruske i jabuke. Usporediti, recimo, R i X seriju u samom Lenovo portfoliu je apsolutno smijesno, a naci pravu konkurenciju sa strane jos je nemoguce. K tome je X300 prethodnik cijele serije takvih, jamcim da ce za 6 mjeseci cijena i ovome pasti, ali i da ce biti modela i za 30 kkn.
Bas smo imali rasprave i usporedbu s onim malim Macom, neki kazu da je mozda odgovor na Mac, meni su usporedbe nemoguce jer je ovo pravi radni stroj, a Mac ipak vise igracka.
Igor Batinic
Staro 16.04.2008., 08:53   #18
sick_boy
sick_boy's Avatar
Postovi: 680
Uvijek će biti prijenosnika sa (pre)visokom cijenom, no i dalje tvrdim da veliki dio te cijene nosi brand, image, svrha svrstavanja u određenu kategoriju itd.
Nije. Prije će biti usporedba Citroena C5 ili Peugeota 407 sa navedenim - A8 i Lexus su puno bolji proizvodi iz neke druge kategorije, ali neopravdano skupi. :P
ATI RX550 4GB
Arch Linux/Win 10
AMD Ryzen 7 6800HS
1TB Micron nVme HDD
Windows 11
Fujitsu Esprimo:
4GB DDR2 RAM
Staro 16.04.2008., 12:11   #19
Trillian
Trillian's Avatar
Postovi: 195
Ako cemo vec u aute molio bih te da thinkpad ne uspoređuješ sa francuskim poluproizvodima...
...imas daciu logan (aka ono što ti smatraš pod laptop) i bmw.
A šo se tiče onoga gore, apsolutno si smiješan i uopće nisi shvatio bit X300. X300 nije company standard, X300 je executive tool.
Staro 16.04.2008., 12:14   #20
Trillian
Trillian's Avatar
Postovi: 195
naravno...imaš i R seriju koja ima magnezijsku šasisju, uno puno jače procesore, ekrane puno više rezolucije, značajno bolje grafike, višestruko bolje diskove, moze pasti, ima active protection system, ima i security chip i osvijetljene tipkovnice i sve što bi poslovno računalo trebalo imati. I najjači sa svime košta jedva malo preko 8k kn u maloprodaji.
I odličan je i konkurencija se moze sakriti i iza njega....no...onog trena kada primiš X300 u ruku sve postaje jasno...svaka kuna
Staro 16.04.2008., 12:43   #21
Mar
Suit up!
Mar's Avatar
Postovi: 5,968
- Barney Stinson
Staro 16.04.2008., 15:33   #22
sick_boy
sick_boy's Avatar
Postovi: 680
Slika dočarava sve.
@Trillian: glede automobila - s Daciom bih usporedio Forcebook. Toshibu i HP (business lines) s Francuzima (isplativi i pouzdani), IBM sa Nijemcima - robustan, kvalitetan i preskup
Executive tool - misliš nešto čime se direktori i meneđeri kurče okolo vrteći na njemu PP slide-ove? Da, to je upravo to.
ATI RX550 4GB
Arch Linux/Win 10
AMD Ryzen 7 6800HS
1TB Micron nVme HDD
Windows 11
Fujitsu Esprimo:
4GB DDR2 RAM
Staro 16.04.2008., 17:17   #23
Trillian
Trillian's Avatar
Postovi: 195
sick boy: jep...ali taj ppt vrte vjerojatno brze nego ti na tvom 8510p i za svoj rad dobijau značajno više neovaca nego pol IT staff-a skupa.
Računalo je ekstremno kvalitetno, iznimno brzo za ultraportable i ima wow faktor.
Uostalom, izažao je pcekspert review:
http://www.pcekspert.com/articles/572.html
Očito se i uredništvo pceksperta slaže sa mojim dojmom
Staro 17.04.2008., 08:13   #24
sick_boy
sick_boy's Avatar
Postovi: 680
Autor Trillian Pregled postova
I sa mojim (negativno - cijena)
ATI RX550 4GB
Arch Linux/Win 10
AMD Ryzen 7 6800HS
1TB Micron nVme HDD
Windows 11
Fujitsu Esprimo:
4GB DDR2 RAM
Zadnje izmijenjeno od: sick_boy. 17.04.2008. u 08:25.
Staro 17.04.2008., 12:34   #25
Old Iggy
Old Iggy's Avatar
Postovi: 4,888
Prvo i osnovno kod takvih sustava jest - oni koji ga trebaju ne brinu previse za cijenu.
Igor Batinic
Staro 17.04.2008., 12:57   #26
nino_z
nino_z's Avatar
Lokacija: Valpovo/Osijek
Postovi: 267
i uglavno ga ne placaju ga sami
nino_z je offline   Reply With Quote
Staro 17.04.2008., 13:14   #27
sick_boy
sick_boy's Avatar
Postovi: 680
Upravo to - ne plaćaju ga sami i zato ne brinu za cijenu. S druge strane, oni koji ga sami plaćaju, razmislit će o stvarnim potrebama i izabrati nešto isplativije.
ATI RX550 4GB
Arch Linux/Win 10
AMD Ryzen 7 6800HS
1TB Micron nVme HDD
Windows 11
Fujitsu Esprimo:
4GB DDR2 RAM
Staro 17.04.2008., 13:17   #28
Old Iggy
Old Iggy's Avatar
Postovi: 4,888
Autor nino_z Pregled postova
Zato ja imam Della, a ne ThinkPada.
Igor Batinic
Staro 17.04.2008., 13:24   #29
nino_z
nino_z's Avatar
Postovi: 267
Mislim da bi i Salma Hayek u onom koznom badicu tesko uvjerila sefa da joj treba bas X300, tako da si dobro i prosao, poslodavci vjerojatno misle da su oni prijenosnici iz Konzuma za 3599 kn svima dovoljni.
Staro 17.04.2008., 13:31   #30
Old Iggy
Old Iggy's Avatar
Postovi: 4,888
Pa nisu bas svi takvi.
Igor Batinic
