Lokacija: ZaGReB
Postovi: 406
CoolerMaster
CM Stacker is a new computer chassis from Cooler Master with extremely powerful functions. The innovative design supports Extend ATX, BTX and dual power supply, making for easy upgrading. Besides its unique cross-flow fan, the CM Stacker supports up to eight regular fans, giving it unmatched cooling performance. Built from 1.0 mm thick steel plate, the CM Stacker is immensely strong, with a high-quality anti-vibration stand providing extra protection for the system. Designed for maximum extensibility and allowing the user the utmost flexibility in the utilization of space, the CM Stacker makes upgrading incredibly easy, and can be configured to meet your own personal needs with minimum hassle. -Specification - -- Supports up to 11 5.25” drives -- Moveable front control panel with 6 USB 2.0 connections -- Maximum upgradeability; supports E-ATX and the upcoming BTX -- Dual power positioning design - -Cooling -CM Stacker supports up to 8 fans -- Front – Full mesh screen provides superior air flow; support up to three 12 cm fans -- Top - Ultra silent 8cm Fan * 1 (exhaust) -- Side – Mesh screen on side panels provides the maximum air ventilation -- Rear – Ultra Silent 12cm Fan * 1 + 8 cm Fan * 2 (intake) -- Motherboard – 300mm cross flow fan; provides superior air flow for key PC components (CPU, VGA etc.) - -Assembly -- Tool-free installation; Supports the use of screws for permanent installation -- Maximum flexibility in space utilization for self-assembly - -Structural -- Aluminum alloy motherboard tray frame -- Strengthened with 1.00mm steel plates -- Superior mechanical design for greater stability __ Dimension 584 mm x 227 mm x 536 mm (D x W x H) Material Aluminum Bezel , SECC Chassis M/B Type EXTEND ATX (12" x 13") ; BTX Power Supply Form Factor Standard ATX PS2 5.25 7 (Exposed) 3.5 1 (Exposed), 3 (Hidden) Ventilation One 120 x 120 x 25 mm Front Fan (intake) One 120 x 120 x 25 mm Rear Fan (exhaust) One 80 x 80 x 25 mm Top Fan (intake) Optional Component Aerogate II x 1 Additional USB 2.0 x 6; MIC x 1; Earphone jack x 1; IEEE 1394 (FireWire) x 1 Hmm...
Intel P4 1.8 Mhz ASUS P4S533-E SiS 645DX 2 x 256MB DDR333 Samsung HERCULES ATI Radeon 9800SE AIW 128 MB HDD Seagate Barracuda 60 & 80 GB NEC DVD RW+/-ND-2500 PSU Aopen 300W Monitor EIZO 19" Flexscan Microsoft IntelliMouse Optical CoolerMaster Aerogate II CoolerMaster Cool Drive 3 CoolerMaster 2 x 80mm vent LED Blue Papst 120mm vent SkyStar 2 Case InWin X710 Black Zadnje izmijenjeno od: LuX.23. 26.03.2004. u 23:38. |
Billy lives forever
Datum registracije: Dec 2001
Lokacija: Hrvatska,Split
Postovi: 756
koliko krznenih? Dobro izgleda
FS Amilo M |
Lokacija: ZaGReB
Postovi: 406
Ma to još neće kod nas kolko mi se ćini!
Intel P4 1.8 Mhz ASUS P4S533-E SiS 645DX 2 x 256MB DDR333 Samsung HERCULES ATI Radeon 9800SE AIW 128 MB HDD Seagate Barracuda 60 & 80 GB NEC DVD RW+/-ND-2500 PSU Aopen 300W Monitor EIZO 19" Flexscan Microsoft IntelliMouse Optical CoolerMaster Aerogate II CoolerMaster Cool Drive 3 CoolerMaster 2 x 80mm vent LED Blue Papst 120mm vent SkyStar 2 Case InWin X710 Black |
Ex-Gastarbajter
Lokacija: Zagreb / Rijeka
Postovi: 5,463
Ej, kanta dobro zgleda, može se modat(iako je to grijeh ovome radit), možeš potrpat svu silu stvari unutra... ah... Kolko to para, alo vi sa PCX dajte nabavite jedno za review |
Lokacija: ZaGReB
Postovi: 406
Ma nemaš kaj tu rezati imaš samp staviti katodu možda ventova da diodicama i wire sleevs i to je to! Ma kućište je stvarno prejebeno! ![]()
PC maher
Datum registracije: Feb 2004
Lokacija: N.Gradiska
Postovi: 272
Kućište je stvarno prva liga, zaista bih poželio jedno za sebe, međutim moram vam reći da se uz malo truda može doći do krasnog kućišta. Ja sam nabavio polovno BigTower kućište (bez napajanja) stavio unutra 400W napajanje (već su bila unutra dva PAPST venta 80mm (nečujni), stvar ima ladicu za najveće matične koje možete kupiti (normalno sa ladicom idu skupa sve kartice koje su ubodene u matičnu) , tako da je probavanje i rastavljanje vrlo jednostavno i zahvalno, i naravno za kućište sam dao svega 100 kunića, 5 kom. 5,25" i 6 kom. 3,5" što je meni dovoljno (bar za sada). Naravno ovo Cooler Masterovo kućište je zaista koma i tko ga ne bi poželio. ![]() |
PC Ekspert
Datum registracije: Sep 2000
Lokacija: Zagreb, Hrvatska
Postovi: 1,214
Ne brinite se, bit ce test. Samo da stignu Stackeri ![]()
Nissan GT-R Black Edition |
Datum registracije: Oct 2001
Lokacija: Sesvete/Soblinec
Postovi: 773
Fala tetki da je netko napokon skužio da treba pometat 12cm ventove u kućište. Sam kaj bu cijena za ovu kantu opako opaka! |
Lokacija: ZaGReB
Postovi: 406
Pa u moju kantu ide 12 cm vent InWin
hmhm...zzz svima...
Lokacija: 21000 Split
Postovi: 1,070
odlično izgleda samo koja je lova u pitanju ![]()
moj zivot se mijenja... iz dana u dan ja kune neman pozzz svima koju me znaju, a i onima koj ne
Lokacija: ZaGReB
Postovi: 406
Pa sigurno neće biti ispod 1500 kunića
#15 | |
(°_°)
Postovi: 3,249
Toshiba m200 TabletPC + Samsung 205BW |
#16 |
hmhm...zzz svima...
Postovi: 1,070
ma daj moraju stavit napajanje nemože bez toga ![]()
#17 |
(°_°)
Postovi: 3,249
imas pravo, jednog 300W jnca bi trebali stavit ![]()
#18 |
hmhm...zzz svima...
Postovi: 1,070
uptavo tako netriba biti ništa posebnoe ![]()
#19 |
Lokacija: ZaGReB
Postovi: 406
Ma da 300 W ćist ok! Imam 300W Aopen što sam dobio sa kućištem i testirano na 360W i to stabilno! Miato misliš da neće biti napajanje tranu?
#20 | |
Ekspert iz sjene ...
Lokacija: New Eden
Postovi: 3,801
#21 |
hmhm...zzz svima...
Postovi: 1,070
ma daj sranje
#22 | |
(°_°)
Postovi: 3,249
#24 | |
Super Moderators
Datum registracije: May 2002
Postovi: 17,485
Ono kaj je vani 100$, kod nas je u pravilu soma krznatih. |
