Staro 18.03.2004., 21:11   #1
Master Neo
Stane
Master Neo's Avatar
Datum registracije: Jul 2003
Lokacija: Nasice
Postovi: 657
CD-RW Firmware HELP!
da li se nekako moze izbrisati/presnimiti postojeci Firmware npr. noviji 1.13 i snimiti stariji 1.09! napravio sam zajeb, snimo sam pogresni Firmware, i sada zajebava! Help
Master Neo je offline   Reply With Quote
Staro 18.03.2004., 21:25   #2
Veky
Veky's Avatar
Datum registracije: Nov 2002
Postovi: 1,950
mozes ga silovat
prosvrljaj tu http://forum.rpc1.org/portal.php
Veky je offline   Reply With Quote
Staro 19.03.2004., 00:41   #3
Master Neo
Stane
Master Neo's Avatar
Lokacija: Nasice
Postovi: 657
ok, nasao sam Firmware!
>>ALI NAPRAVIO SAM Sranje! SAada mi u windowzima uopce nece prepoznati ni przilicu ni dvd!
Sjebao sam ga sa Firmware ! Kak npraviti da mi prepozna , UPOCE NE MOGU UPAJDIRATI NOVE Firmware, KADA GA NE PREPOZNA (u Divice manegeru je nasao DVD i przu), ali ne mogu uopce upajdirati!
Help LJUDI, HHHHHEEEEEEEEELLLLLLLLLPPPPPPPPP!!!!
Staro 19.03.2004., 01:31   #4
Master Neo
Stane
Master Neo's Avatar
Lokacija: Nasice
Postovi: 657
uspio sam narediti DVD, a jos samo przu, ali kako!
Evo vam da ubuduce znate :
>>Reconnect the jumper line on the rear panel of the Drive to SL(slave) position, and reposition other IDE device to Master.
All the devices shall be connected on the same cable.
If you have a CD-RW drive or a DVD-ROM drive besides Primary IDE HDD at Slave position, please re-connect the above drives to Master and connect the DVD-R/RW Drive on the same cable line.
Some HDD require jumper setting change when a drive is connected to the Slave position.
Please consult with the manual or check the relevant web site for the infomation.<<
Staro 19.03.2004., 01:44   #5
RAK
Feldwebel
RAK's Avatar
Datum registracije: Feb 2002
Lokacija: bolnica
Postovi: 3,739
Baš ti to hdjedoh reći. Dobro da si sam našao.
Lakže (li jedino moguće) ti je oživljavati CD-ove sa startupice. Dakle, nabavi program za flashanje iz DOS-a.
Tih kao mačka
Brz kao gepard
Jak kao lav
Elegantan kao leopard
Nisam to ja, to je moj komp.
Staro 19.03.2004., 01:53   #6
Master Neo
Stane
Master Neo's Avatar
Lokacija: Nasice
Postovi: 657
de mi reci kak da si sad sredim svoj teac 52x24x52x ? nigdje na netu ne mogu naci Firmware Update Failure for Teac, cak ni na njihovoj stranici?
koji programi se korise za Firmware Update iz dosa?
