Povratak   PC Ekspert Forum > PC Ekspert > Novosti
Staro 15.03.2004., 21:15   #1
tor
Administrator
tor's Avatar
Lokacija: Sesvete
Postovi: 15,963
Win XP SP2 - melem na ranu
Basically MS is setting things up for automatic updating of all the applications on your system. Not only that, but it'll only grab the updates that YOU need. MS also thinks this will deliver smaller and more reliable patches.
Jel to znači da svaki "sigurnosni" i "critical" update bude završio instaliran bez mojeg yes?! Ma fuck off!
Staro 15.03.2004., 21:23   #2
tor
Administrator
tor's Avatar
Lokacija: Sesvete
Postovi: 15,963
Vatrozid u akciji
Staro 15.03.2004., 21:27   #3
tor
Administrator
tor's Avatar
Lokacija: Sesvete
Postovi: 15,963
Pričam sam sa sobom, ali nema veze Ipak bude na izbor update
Service Pack 2 marks a change in Microsoft's strategy with regard to Windows Update. It is a tad more annoying now, and perhaps that is a good thing. For starters, the web interface (linked for size) has received a facelift for those using SP 2. There are now two options. Using the Express option, Windows Update searches for and installs critical updates. The Custom Installation allows for the installation of optional components as well as the critical updates. After making your selection, Windows Update will then download and install your selected updates.
Staro 15.03.2004., 22:43   #4
IceFisherman
Magister Mundi sum!
IceFisherman's Avatar
Datum registracije: Jun 2003
Lokacija: Zagorje
Postovi: 2,335
Ček , kaj u tom service packu dobiš firewall kjeg se neda ugasiti ili kaj ?
A to sa updejtanjem bez suglasnosti korisnika je glupost , uopče nem znal kaj mi se skida i samo bu mi odjenput komp riknul nakon nekog patcha , i onda bum moral windowze reinstalirati
Sapphire radeon x1650PRO
2x512mb 433mhz Kingmax
AOC 17", LCD, LM760
Win XP PRO SP2 & SUSE 10.1
www.crazywarriors.com
Staro 15.03.2004., 22:50   #5
horza
ono ispred konpjuktora
horza's Avatar
Datum registracije: Apr 2003
Postovi: 3,659
1) firewall se može isključiti, ali moraš stoput reći da si siguran da to želiš
2) da, automatic update critical patcheva će biti neophodan... ali mislim da ćeš recomended moći izabrati.
bubam napamet... nisam ništa 100% siguran iako sam ga vidio u akciji na više računala u različitim uvjetima.
Elven ?
Horza (death dwarf)
birthsign: rebel
character perks
major skills
greater powers
artifacts of choice
Staro 16.03.2004., 00:30   #6
Veky
Veky's Avatar
Datum registracije: Nov 2002
Postovi: 1,950
sve se moze iskljucit
Veky je offline   Reply With Quote
Staro 16.03.2004., 19:30   #7
tor
Administrator
tor's Avatar
Lokacija: Sesvete
Postovi: 15,963
DA, bude dosadniji nego ikad taj update, ali da se birati...
Staro 29.03.2004., 15:06   #8
Isus
Headbangig Grunf!
Isus's Avatar
Datum registracije: Aug 2003
Lokacija: headbanger's ball
Postovi: 4,373
Jos ce na konncu blokirat i rad programa tipa Ad aware tak da nemres maknuti AIDu.
Grunf je moj idol!
Moji Grunf type modovi
Alfisti site, Alfisti forum
Staro 29.03.2004., 15:59   #9
maky-st
hmhm...zzz svima...
maky-st's Avatar
Lokacija: 21000 Split
Postovi: 1,070
pa onda je li to šta valja ili ne
Staro 29.03.2004., 16:21   #10
miato
(°_°)
miato's Avatar
Postovi: 3,249
ja se jos uvijek drzim autopatchera... odlicna stvar, biras sto ces instalirat
Staro 29.03.2004., 21:25   #11
maky-st
hmhm...zzz svima...
maky-st's Avatar
Postovi: 1,070
jade moglo bi se reć da je tako
Staro 29.03.2004., 21:33   #12
LightForce1308
cmiiiiiiiiiiiiiiiiiii
LightForce1308's Avatar
Datum registracije: Jul 2003
Postovi: 452
Čovječe pa ja još nisam ni SP1 instaliro, a vi već brijete po SP2
LightForce1308 je offline   Reply With Quote
Staro 29.03.2004., 21:35   #13
horza
horza's Avatar
Postovi: 3,659
ja imam instaliran sp2 otkad je izašla RC1 i super mi je. osim dosadnog firewalla koji se nekim čudom naknadno sam uključio i onog shugavog update-a kojeg ne pustim kroz firewall sve je super. i ne vidi se nikakvo usporavanje rada kao pri prelasku na SP1. po meni je ovo za sada dobra zakrpa (ako takvo što može postojati)
Horza (death dwarf)
birthsign: rebel
character perks
major skills
greater powers
artifacts of choice
Staro 29.03.2004., 23:14   #14
IceFisherman
Magister Mundi sum!
Lokacija: Zagorje
Postovi: 2,335
Question Ok , now .....
A je došel celi service pack ili je još uvek beta , jer sam gledal po netu i sigde piše da je to beta verzija.
ak je došel celi , nek mi neko da link da si ga skinem
AOC 17", LCD, LM760
Staro 30.03.2004., 13:49   #15
maky-st
hmhm...zzz svima...
maky-st's Avatar
Postovi: 1,070
meni također triba link pozdrav
