Staro 23.01.2004., 09:23   #1
Costa
Costa's Avatar
Datum registracije: Aug 2003
Postovi: 3,193
Lightbulb Spyware Blaster
SpywareBlaster doesn't scan and clean for spyware - it prevents it from ever being installed.
By setting a "kill bit" for spyware ActiveX controls, SpywareBlaster can prevent the installation of any spyware ActiveX controls from a webpage. It does this while not interfering with "friendly" ActiveX controls - so your browser can work correctly and you can have peace of mind!
You won't get any more annoying "Yes/No" boxes popped up, asking you to install a spyware ActiveX control (which can increasingly be found in pop-up ads!). In fact, Internet Explorer will never even download or run the spyware ActiveX control!
In addition, SpywareBlaster can prevent many of these spyware ActiveX controls from running, even if they are already installed on your system.
Link
Staro 23.01.2004., 19:54   #2
widowmaker
m e m b e r
widowmaker's Avatar
Lokacija: Zagreb, Črnomerec
Postovi: 446
super programčić, imaš
widowmaker je offline   Reply With Quote
Staro 24.01.2004., 02:50   #3
tin.
tin.'s Avatar
Datum registracije: Dec 2003
Postovi: 823
Re: Spyware Blaster
Originally posted by Costa
[I]SpywareBlaster doesn't scan and clean for spyware - it prevents it from ever being installed.
Ma to !! BRAVO !! Pošto baratam japanskim,evo prijevoda na Japanskom; "Koreoke o no yomajano "Spyware Blaster" watakshi akadui fudjimoto mitsuadas.Tokodonei "kill bit"
manoa,akadui Active X mada mada Spyware blaster gara hazmeo otonyi oyshi dezne Active X korenna kodasai.Mada,mada Active X dezne - atamoro oshtee imass.Tu tsu gatai tai sun ga "Yes/No" dinneo midjikotowa.Dezne Active X (tosuzende sigga kinkishhadai sedes!).Watchidawa Internet Explorer akadui gyotsu noadi daikosho Active X dezne!
Etendes ! Taff Spyware blaster tabe te mada mass ne.Igiri su dezne Active X konoko hakko,kasidasi tasidasi korenna kodasaii !
tin. je offline   Reply With Quote
Staro 24.01.2004., 15:18   #4
Paske
Ekspert iz sjene ...
Paske's Avatar
Lokacija: New Eden
Postovi: 3,801
Ma krasan kurac .....
Prvo nakon instalacije mi je hijackao web browser na neku tam lijevu stranicu kao home. - ako promijeniš sruši se IE/Opera i ponovo ostaje isto.
Ako probaš skinuti Ad aware ili nešto slično - sruši se IE/Opera
Ako probaš na Yahoo/Google potražiti Adaware isl - sruši IE/Operu
Ekipa - nemojte to stavljat, jerbo je to mene koštalo reinstala win-a
Staro 24.01.2004., 15:23   #5
BrunoZG
Junior Member
BrunoZG's Avatar
Datum registracije: May 2003
Postovi: 3,205
kaj te briga, barem imas najfriskije windoze na forumu
AMD 3800+x2@2500, 1,375V
MB-ASROCK DUAL SATA(bios 2.2) 2+ENERMAX485W
2x512 Supertalent CL2
HDD-Hitachi 160GB, WD 800JB
ELSA 7600GT
Leadtek-2000XP expert
DVDROM-LITEON-167T ,DVDRW BENQ 1650,DVDRW NEC ND2500A@2510_fw205C
Monitor: Samsung 997MB (19')
Terratec Sky 5.1,EPSON-C42
Zadnje izmijenjeno od: BrunoZG. 24.01.2004. u 17:15.
BrunoZG je offline   Reply With Quote
Staro 24.01.2004., 16:26   #6
LuX.23
LuX.23's Avatar
Lokacija: ZaGReB
Postovi: 406
Paske pa kaj je to tebi reinstall?
Intel P4 1.8 Mhz
ASUS P4S533-E SiS 645DX
2 x 256MB DDR333 Samsung
HERCULES ATI Radeon 9800SE AIW 128 MB
HDD Seagate Barracuda 60 & 80 GB
NEC DVD RW+/-ND-2500
PSU Aopen 300W
Monitor EIZO 19" Flexscan
Microsoft IntelliMouse Optical
CoolerMaster Aerogate II
CoolerMaster Cool Drive 3
CoolerMaster 2 x 80mm vent LED Blue
Papst 120mm vent
SkyStar 2
Case InWin X710 Black
LuX.23 je offline   Reply With Quote
Staro 24.01.2004., 19:06   #7
Paske
Paske's Avatar
Lokacija: New Eden
Postovi: 3,801
To ti je meni poslijepodnevna zabava
Staro 24.01.2004., 19:47   #8
Elven
Elven's Avatar
Datum registracije: Sep 2002
Postovi: 2,721
Tak sam si i mislio, htio sam to skidati, ali sam se onda sjetio da bi takav program bio ipak poznatiji i da je to najvjerojatnije neki trojanac. Ponekad je prelijepo da bude istinito, jednostavno prelijepo da bude istinito.
BTW Mislim da si samo trebao skinuti sa drugog kompa Hijackthis, a ako to ne bi pomoglo, onda CWShreder
Staro 24.01.2004., 20:07   #9
evilstoy
evilstoy's Avatar
Datum registracije: Oct 2001
Lokacija: Enterprise bridge
Postovi: 285
Ne znam kaj se vama dogodilo, ali Spywareblaster je genijalan program i ja ga koristim vec par godina bez ikakvih problema:clap:
Ubuntu 8.10
cpu Intel Q6600 @3GHz (333x9) w/Scythe MINE Rev.B - 29C idle
mbo Gigabyte P35-DS3 ram 8GB Kingston DDR2 667MHz
gpu Asus EN9600GT hdd 2xWD3200AAKS - RAID1
case Chieftec BX-03B-B-B psu Fortron BS 400W
evilstoy je offline   Reply With Quote
Staro 24.01.2004., 20:14   #10
LuX.23
LuX.23's Avatar
Lokacija: ZaGReB
Postovi: 406
Pa objasni narodu onda kako se upravlja!
Intel P4 1.8 Mhz
PSU Aopen 300W
Papst 120mm vent
SkyStar 2
Staro 24.01.2004., 20:43   #11
widowmaker
m e m b e r
widowmaker's Avatar
Postovi: 446
meni dela super
Staro 24.01.2004., 20:53   #12
IceFisherman
Magister Mundi sum!
IceFisherman's Avatar
Datum registracije: Jun 2003
Lokacija: Zagorje
Postovi: 2,335
Kod mene isto dela normalno , nič se ne ruši ( a moji windowzi se voliju rušiti ) , home page mi je ista ostala , i sve dela normalno , a niti zone alarm nič ne prijavljuje da bi taj program dlelal nekaj treeče mjesto ovoga čemu je namjenjen
Sapphire radeon x1650PRO
2x512mb 433mhz Kingmax
AOC 17", LCD, LM760
Win XP PRO SP2 & SUSE 10.1
www.crazywarriors.com
Staro 24.01.2004., 21:40   #13
Costa
Costa's Avatar
Postovi: 3,193
Radije lijeci ovisnost kupnje hardwarea necim drugim, recimo pifom, a ne surfanjem pornografskim stranicama
Program sprecava one activex controle koje mu se nalaze u bazi, a pri tom ne mora ni raditi. Pokrenes, on banna ono kaj mu pase i to je to. OK ga je tu i tamo updateat. BTW viruse saljem samo potpunim neznancima
