Staro 05.01.2004., 11:57   #1
termic
Lokacija: Sveta Marija
Postovi: 21
IIS ?? Problem...
Od kad sam s FAT32 presao na NTFS ima problema s upisivanjem ili promjenom podataka u bazi...
kad upisujem na ovaj na cin:
CS.Execute(iSQL)
javlja mi ovu gresku:
Error Type:
Microsoft JET Database Engine (0x80004005)
Operation must use an updateable query.
a kod ovakvog:
strSQL = "SELECT tbl.* FROM tbl;"
RS.CursorType = 2
RS.LockType = 3
RS.Open strSQL, strCon
RS("x") = RS("xx") + 1
RS.Update
RS.Requery
RS.Close
ovu:
Error Type:
Microsoft OLE DB Provider for ODBC Drivers (0x80004005)
[Microsoft][ODBC Microsoft Access Driver] Cannot
[b]update. Database or object is read-only.
pomozite,,,
termic je offline   Reply With Quote
Staro 05.01.2004., 12:04   #2
LorD ClockaN
od LemilicE
LorD ClockaN's Avatar
Lokacija: Veli Lošinj
Postovi: 4,712
Imaš na Windows Updateu neki patch za Microsoft Jet DataBase, pa ga probaj skinut. Možda pomogne
Nemam više lema!!!
Staro 05.01.2004., 14:46   #3
termic
Postovi: 21
ne pomaze...
Staro 05.01.2004., 19:01   #4
sbp
PC Ekspert
Datum registracije: Sep 2000
Postovi: 377
Ajmo opet, po 100-ti put, www.google.com... (Upisi: NTFS Operation must use an updateable query)
Probaj s ovim dolje. Odnosi se na XP, Access, preformatiran disk s fat-a na ntfs
quote:
as then having same problem on XP Pro and I have solved the problem after searching a LOT. Okay, here is the solution: - open the Explorer - click on Tools and then Folder Options - goto View tab - scroll down all the way and the last item (i think) will say "Use simple file sharing" - uncheck it if it is checked - now, goto appropriate .mdb file and right click - click on properties - goto Security tab - select Everyone from User - check "Write" checkbox under Everyone as a user VOILA.......You have done it!!!!!! This should work now. It worked for me and now I can run SQL command from frontend to update my Access database.
I jos jednom, ljudi, sve vam je pred nosom, sam treba otic na google
sbp je offline   Reply With Quote
Staro 05.01.2004., 22:29   #5
termic
Postovi: 21
to sam 1. probal... ne radi...
Staro 06.01.2004., 11:22   #6
dpajur
PC Ekspert
dpajur's Avatar
Lokacija: Luksemburg
Postovi: 694
Znaci dal si IIS useru (IUSR_imestroja) full access na .mdb file i nije pomoglo?
Onda ti ostaje jos jedna stvar, naime Access napravi lock file kad netko pristupa bazi (.ldb), a IIS mozda ima samo read-access na direktorij u kojem je baza, i nemre napravit lock.
Stoga istim postupkom promijeni permissione na direktoriju u kojem je baza i daj IUSR_xxx full access.
Intel Xeon X5550
Asus Rampage II Extreme
6GB Corsair Dominator GT
PowerColor Radeon PCS+ 5870
Samsung PM800 256GB SSD
Samsung F3 EcoDrive 2TB
Seasonic X750
Silverstone TJ-07
Dell U2311H
Cooling:
Thermochill 140.3
Fractal Design 140x3
EK Supreme HF
EK 5870FC v2
Laing DDC 3.25 + EK DDC Top v2
EK Multioption 250
mCubed T-Balancer XL
Build Log
dpajur je offline   Reply With Quote
Staro 06.01.2004., 11:23   #7
dpajur
PC Ekspert
dpajur's Avatar
Postovi: 694
E da, jos jedna stvar.. vrlo glupa, al Microsoft je takav..
Pogledaj file attibutes na .mdb fajlu, mozda je postaljen kao read-only.
Intel Xeon X5550
Seasonic X750
Silverstone TJ-07
Dell U2311H
Cooling:
Thermochill 140.3
EK Supreme HF
EK 5870FC v2
EK Multioption 250
Build Log
Staro 06.01.2004., 11:37   #8
termic
Postovi: 21
nije...
OK proradilo... na direktoriju gdje je baza je bilo Read-only i nisam ga mogao maknuti...
Hvala svima...
Pozdrav...
