Staro 12.01.2007., 16:35   #1
Mr.Ex.President
Torrent freek
Mr.Ex.President's Avatar
Postovi: 3,948
Problem s BeSweet-om
Evo san iša poslat jednom liku koji mi rješava ''audio/video probleme'' al nema ga Pa evo ovdje. Neman vrimena lektorirat, al ako kome nije jasno poslje editiram.
Prika…sranje,
Ka šta san u prošlom PM reka sve san sredija i sve je ok. Ne javlja errore, nema problema, ali….
.wav. zvuk mi je ok. Prebacin ga u ac3 i onda krči :cry: Onako ka kad na radiju starom 20 godina pustiš muziku i pojačaš ''do daske'' E pa takav zvuk.
U prethodnom PM su ti opcije koje san postavija ( Slika 1 ). Al opcije i nisu tolko bitne jer san proba sve živo. Nešto je sa Besweetom 100% il nećin drugin, ti ćeš možda znat
Evo šta kaže Gspot za taj fajl - http://i89.photobucket.com/albums/k2...e313/Gspot.jpg
A evo ti i LOG:
BeSweet v1.5b31 by DSPguru.
Using AC3enc.dll v1.20 (Feb 18 2004) by Fabrice Bellard (http://ffmpeg.org).
Logging start : 01/11/07 , 21:57:28.
BeSweet.exe -core( -input D:\My Documents\Beethoven\Virtual dub - beethoven.wav -output D:\My Documents\Beethoven\Virtual dub - beethoven-new.ac3 -logfile D:\My Documents\Beethoven\Virtual dub - beethoven.log ) -ota( -hybridgain ) -ac3enc( -b 384 )
[00:00:00:000] +------- BeSweet -----
[00:00:00:000] | Input : D:\My Documents\Beethoven\Virtual dub - beethoven.wav
[00:00:00:000] | Output: D:\My Documents\Beethoven\Virtual dub - beethoven.ac3
[00:00:00:000] | Floating-Point Process: No
[00:00:00:000] | Source Sample-Rate: 48.0KHz
[00:00:00:000] +------- AC3ENC ------
[00:00:00:000] | Bitrate method : CBR
[00:00:00:000] | AC3 bitrate : 384
[00:00:00:000] | Channels Mode : 2.0
[00:00:00:000] | Error Protection: Yes
[00:00:00:000] +---------------------
[01:22:51:640] Conversion Completed !
[01:22:51:640] Actual Avg. Bitrate : 383kbps
[00:03:07:000] <-- Transcoding Duration
Logging ends : 01/11/07 , 22:00:35.
Ne pitajte zašto Beethoven
U čemu bi moga bit problem ? I da, znan da se to može radit i preko samog GUI-a od Besweeta, ali meni je dosta lakše i jednostavnije preko BeLight-a. Da ne govorin koliko je program više user-frendly.
Verzija Besweta je BeSweet 1.5b31 ( 1.4 mi uopće neće radi )
Verzija BeLighta je BeLight 0.22-beta 6
eto...
MBO: MSI B450 Gaming Plus
PSU: Corsair RM550X 550W
Periferija
LCD: HP ZR24w
Mouse: Logitech G400
Sound: Genius SP-HF1201A
Printer: HP LaserJet 1020
Scanner: HP ScanJet 4300
Headphones: Philips SHC 2000
MBO: Gigabyte GA-F2A85XM-HD3
HDD: WD Green 2TB [WD20EZRX]
PSU: Antec SU380
TV: Samsung 43E450 @HDMI
LINK
Staro 12.01.2007., 16:45   #2
Costa
Costa's Avatar
Datum registracije: Aug 2003
Postovi: 3,193
Probaj poslušat taj file bez upotrebe ffdshowa. Jednom davno sam se opekao s njim tako da ga nikad ne koristim za zvuk. AC3 filter ti je dovoljan.
Staro 12.01.2007., 16:48   #3
Mr.Ex.President
Torrent freek
Postovi: 3,948
Autor Costa Pregled postova
Kolko ja znan treba mi za video ?
Kako ga maknit sa kompa, tj. kako maknit njegov ''zvučni dio'', a da ostane ''video dio''
Ako se kužimo
Periferija
LCD: HP ZR24w
PSU: Antec SU380
LINK
Staro 12.01.2007., 17:02   #4
Costa
Costa's Avatar
Postovi: 3,193
Kod instalacije se može izabrati da ga ne želiš za audio ali da se to srediti i dok je već instaliran. Pokreni mu config za audio (npr. preko start menija ili direktno kroz neki media program - za MPC je play > filters > ffdshow audio decoder).
Zatim u Codecs izborniku izaberi disabled za AC3 (i sve ostale formate za koje ga ne želiš.. meni je ovo samo za potrebe screenshota, inače ga nemam ).
Staro 12.01.2007., 17:03   #5
Mr.Ex.President
Torrent freek
Postovi: 3,948
Zanemari ovo gore...
EDIT: Brz si Fala, naša san tu opciju. Stavija disable i ništa. Pa san ga deinstalira i opet ništa, tj. problem ostaje.
Deinstalira san ffdshow i opet isto - krči. U čemu bi još moga bit problem
Periferija
LCD: HP ZR24w
PSU: Antec SU380
LINK
Staro 12.01.2007., 17:18   #6
Costa
Costa's Avatar
Postovi: 3,193
Pogledaj da li se ista stvar događa s nekim drugim wav-om? Možeš i isprobati HeadAC3he program:
http://mitglied.lycos.de/darkav/svcdguide/svcd.html
Staro 12.01.2007., 17:20   #7
Mr.Ex.President
Torrent freek
Postovi: 3,948
Da
***emu prije reinstala Windowsa je radilo. Sad se više ne sjećam šta je tada toćno bilo i kako, al radilo je...
Mogu isprobat. Iden baš vidit
EDIT: Ne sviđa mi se baš A i u startu mi je javija 303 errora
Periferija
LCD: HP ZR24w
PSU: Antec SU380
LINK
Staro 12.01.2007., 18:49   #8
Mr.Ex.President
Torrent freek
Postovi: 3,948
Može li mala pomoć za ovaj program ?
***ate nema ni pola MB. zato šta ništa ne dolazi u njemu već sve triba tražit naokolo. Da prostite na izrazu sere mi se od takvih programa...
Drugo ja uopće ne vidin opciju da od Wav - ac3. Vidin obrnuto, al ne ovo...
EDIT: Vratija san se Besweetu + BeLight. Nove verzije skinija, najnovije. Ista stvar. Pari mi da je neki problem u nekakvin driverima ili codecima. Samo neznan di i kad ni kako
Periferija
LCD: HP ZR24w
PSU: Antec SU380
LINK
Zadnje izmijenjeno od: Mr.Ex.President. 12.01.2007. u 19:18.
Staro 12.01.2007., 19:19   #9
Costa
Costa's Avatar
Postovi: 3,193
Izgleda da program ipak ne može to... ide samo obrnuto.
Evo ti ovdje uputstva za tri različita programa:
http://club.cdfreaks.com/showthread.php?t=78614
EDIT: Jesi probao neki drugi file pretvoriti BeSweetom?
Staro 12.01.2007., 19:21   #10
Mr.Ex.President
Torrent freek
Postovi: 3,948
Pogle edit. Mislim da nije problem u programu
Periferija
LCD: HP ZR24w
PSU: Antec SU380
LINK
Staro 12.01.2007., 19:23   #11
Costa
Costa's Avatar
Postovi: 3,193
Skini Media Player Classic i u njemu poslušaj taj krčeći ac3.
Staro 12.01.2007., 19:24   #12
Mr.Ex.President
Torrent freek
Postovi: 3,948
U njemu ga i slušam
Periferija
LCD: HP ZR24w
PSU: Antec SU380
LINK
Staro 12.01.2007., 19:29   #13
Costa
Costa's Avatar
Postovi: 3,193
Stavi zadnji AC3Filter i postavi mu postavke na defaultne.
http://ac3filter.net/
Staro 12.01.2007., 19:32   #14
Mr.Ex.President
Torrent freek
Postovi: 3,948
Evo baš to radin ***emu u zadnja 2,3 posta nan se poklapaju razmišljanja
Tribat će restart posli
EDIT - Ništa, krči
Periferija
LCD: HP ZR24w
PSU: Antec SU380
LINK
Zadnje izmijenjeno od: Mr.Ex.President. 12.01.2007. u 19:48.
Staro 12.01.2007., 19:36   #15
Costa
Costa's Avatar
Postovi: 3,193
Ne pada mi ništa drugo na pamet osim da još eventualno isprobaš slušati s nekim drugim programom tipa foobar (treba plugin), winamp i sl.
BTW sad idem van pa neću više stić odgovarati
Staro 12.01.2007., 19:40   #16
Mr.Ex.President
Torrent freek
Postovi: 3,948
Ma nije problwem u slušanju Problem je šta kod konvektiranja wav-a u ac3 nastanu šumovi i krčenje. Dakle wav je ok, a ac3 koji nastane konvektiranjem wav-a nevalja?
Uglavnon meni nije bitno za komp, ja ovo pržim na DVD i dajem nekome ko će to gledat na DVD-u, al je za*** da ako to meni krči na kompu, da će njemu krčat i na tv-u
Lipo se provedi
Periferija
LCD: HP ZR24w
PSU: Antec SU380
LINK
Staro 12.01.2007., 20:17   #17
Mr.Ex.President
Torrent freek
Postovi: 3,948
Sad san doša do spoznaje da .ac3 koje san prije ima dok je sve radilo.
I sad rade.
Dakle nije problem u playeru ili AC3 filtru ili ....
Problem je u programu ili nekom driveru koji očito radi neki sitan error ili neku grešku. Ko mi rješi ovo ima piće
Periferija
LCD: HP ZR24w
PSU: Antec SU380
LINK
Staro 13.01.2007., 03:10   #18
Costa
Costa's Avatar
Postovi: 3,193
Evo mene
Kao što sam prije već rekao probaj jednim od ovih načina konvertirat:
http://club.cdfreaks.com/showthread.php?t=786144
Nekako mora proraditi.
Staro 13.01.2007., 03:12   #19
domy_os
domy_os's Avatar
Postovi: 18,891
Boost AC3 volume?
RAM: 2 x 16 GB DDR4-3200
WLAN: Intel Wi-Fi 6 AX201
LCD monitor: AOC AG493UCX
SB: Mackie Onyx Producer 2x2
Speakers: 2 x JBL LSR305
MFP: Canon Pixma MP240
Staro 13.01.2007., 19:23   #20
Mr.Ex.President
Torrent freek
Postovi: 3,948
Evo mene
Boli li glava: lol2 :
Nego da, nakon šta san proba sve moguće odusta san od BeLihgta i instalira ffMPEG. Mnogo siromašniji opcija, al u biti ima sve šta mi triba. I RADI
Zašto ovo ne radi ? - Neman pojma, vjerovatno će proradit kad stavin nove Windowse
Fala svima
Periferija
LCD: HP ZR24w
PSU: Antec SU380
LINK
