Staro 30.09.2006., 10:42   #1
Mailman
Mailman's Avatar
Postovi: 1,606
ATI Tray Tools 1.2.6.940
[F] Fixed bug when manual fan control can not be applied[*] Updated some translation files
[F] Fixed Old I2C Method to be compatible with X1xxx boards in memory voltage control procedure
[+] Added ability to change how ATT will react on "ATI HotKey poller" service. (in General options)[*] Updated Overdrive control procedure. Now you can set any available clocks for OverDrive even beyond the Catalyst limits!
And change GPU Voltage too.
[+] Added option to apply OverDrive settings on startup
[+] Added Portuguese (Brazilian) and Belorussian translations
http://downloads.guru3d.com/download.php?det=733
News about next release
At this moment I'm finishing adding new method of overclocking for R5xx boards. This method will be called "Driver Level".
What will do this method:
1. Overclocking will be done by Catalyst itself like Overdrive
2. Voltage will be applied by driver for GPU and by ATT for memory
3. ATT will emulate Overdrive job, but will allow to set clocks when you want it instead of when you run full screen 3D application.
4. This should work even if you didn't disable ATI HotKey poller! And clocks will not resets by that service in 3D games
5. With this method clocks will not resets when you play any video files (checked on my 1800XT, no more resets)
6. More stable overclocking. Catalyst know HOW to do overclock job better that any other utils
Mailman je offline   Reply With Quote
Staro 30.09.2006., 11:27   #2
Jelc
Super Moderators
Datum registracije: May 2002
Postovi: 17,485
A, imam ga već dva dana instaliranog-radi ok.
Staro 01.10.2006., 18:44   #3
damir1
Ancient
damir1's Avatar
Lokacija: Đakovo
Postovi: 893
Za Saber_tooth-a ništa Ti nisi promijenio s tim neboj se.To je samo kako želiš gledati izraženu brzinu memorije(kako se lakše snalaziš-jasnije ti je na koliko radi u ddr ili kao sdr pa sam pomnožiš)
Asus Z97-A-i5 4690K-xfx 470 -Kingston DDR3 1866 SDRAM 2x4GB -dvd ladice-asus 450W-sve to u chenbro gaming bomb, jedinici + Dell U2412HM
damir1 je offline   Reply With Quote
Staro 01.10.2006., 20:00   #4
Matth€w
Matth€w's Avatar
Lokacija: NaN
Postovi: 3,438
Matth€w je offline   Reply With Quote
Staro 01.10.2006., 20:08   #5
Mailman
Mailman's Avatar
Postovi: 1,606
Autor Matth€w Pregled postova
ma forum je ponovo "pojeo" neke postove....
Staro 08.10.2006., 01:33   #6
mrtvi
mrtvi's Avatar
Postovi: 183
jel sa ovima rade titlovi na TV-u
mrtvi je offline   Reply With Quote
Staro 08.10.2006., 11:02   #7
domy_os
domy_os's Avatar
Postovi: 18,796
Za to ti treba ffdshow ili VobSub filter...
RAM: 2 x 16 GB DDR4-3200
WLAN: Intel Wi-Fi 6 AX201
LCD monitor: AOC AG493UCX
SB: Mackie Onyx Producer 2x2
Speakers: 2 x JBL LSR305
MFP: Canon Pixma MP240
Staro 08.10.2006., 15:50   #8
mrtvi
mrtvi's Avatar
Postovi: 183
imam Vobsub i radili su titlovi i onda su samo nestali
to se odnosi na tray tools kad stavim u extended desktop ili u clone mode da bude theater; znači ne mogu pustit film na telki i radit nešto drugo na monitoru; rade kad stavim na primary ali to mogu i windowsi za to mi ne treba tray tool
Staro 08.10.2006., 23:10   #9
domy_os
domy_os's Avatar
Postovi: 18,796
Uključi clone opciju s overlayem.
Staro 09.10.2006., 00:36   #10
Dexxy
nije mi jasno kako jos na nema drivera za x1950,samo neki beta koji nisu nest....a i att ne radi...nemoze se voltaza dizat
Staro 09.10.2006., 01:07   #11
mrtvi
mrtvi's Avatar
Postovi: 183
da ni meni
@domy di uključim taj overlay nije valjda ovo pod video & color to mi ne radi mislim nemrem mijenjat
Staro 09.10.2006., 02:08   #12
Jelc
Super Moderators
Postovi: 17,485
Autor Dexxy Pregled postova
Strpite se malo-tek je izašao novi hardware-biti će podrška u drugoj reviziji.
Mislim da ATI Overclocker radi sa tom grafom.
Staro 09.10.2006., 17:13   #13
domy_os
domy_os's Avatar
Postovi: 18,796
Autor mrtvi Pregled postova
da ni meni
Ti bi htio nešt radit na glavnom monitoru dok se na drugom monitoru/TV-u vrti film u fullscreenu, je li tako? Ako je, uključi taj drugi monitor/TV, ali ne da se proširi desktop na njega (extend) nego da imaš istu sliku na oba. Zatim prebaci u Theater Mode/Same as source video/4:3 (Standard TV) i to je to.
Staro 09.10.2006., 17:59   #14
mrtvi
mrtvi's Avatar
Postovi: 183
iz nekog glupog razloga više ne rade titlovi u theater modu : giljotin
