Staro 05.07.2006., 01:17   #1
Mailman
Mailman's Avatar
Postovi: 1,606
AMD dual core optimizer
AMD Dual-Core Optimizer - The AMD Dual-Core Optimizer can help improve some PC gaming video performance by compensating for those applications that bypass the Windows API for timing by directly using the RDTSC (Read Time Stamp Counter) instruction. Applications that rely on RDTSC do not benefit from the logic in the operating system to properly account for the affect of power management mechanisms on the rate at which a processor core's Time Stamp Counter (TSC) is incremented. The AMD Dual-Core Optimizer helps to correct the resulting video performance effects or other incorrect timing effects that these applications may experience on dual-core or multiple processor systems.
http://www.reghardware.co.uk/2006/07...re_tweak_tool/
http://www.amd.com/us-en/Processors/...1_9706,00.html
Mailman je offline   Reply With Quote
Staro 05.07.2006., 01:36   #2
PointDexter
PointDexter's Avatar
Lokacija: Éire
Postovi: 1,812
sta je to onaj reverse Hyper-threading ili... ???
PointDexter je offline   Reply With Quote
Staro 05.07.2006., 01:58   #3
Fleks
JDM
Fleks's Avatar
Datum registracije: Sep 2004
Postovi: 6,137
Ima kaj slicno za intel?
Staro 05.07.2006., 02:02   #4
Zvijerko
Pečurka
Zvijerko's Avatar
Lokacija: U blizini Osijeka
Postovi: 1,294
Nije anti-HT, ali je nešt što prethodi tome.
ECS Z77H2-A2X Deluxe
I5 3350P
G-Skill 16 GB DDR3 2133MHz
Gainward Phantom GTX760
250 GB Samsung Evo Basic SSD
XFX XTR 650W
Silencio 650
Zvijerko je offline   Reply With Quote
Staro 05.07.2006., 02:36   #5
PointDexter
Lokacija: Éire
Postovi: 1,812
a i taj anti-HT, sta ce biti samo softverski rijesen?
Staro 05.07.2006., 11:31   #6
nicko
Postovi: 4,190
Autor Fleks
LOOOOOOOOOL....skoro Fleks to ti je tak kad si na intelu i stalno se hvalis s njim
Autor PointDexter
pa da...ne treba tu nista fizicko...
nicko je offline   Reply With Quote
Staro 05.07.2006., 11:36   #7
Thoroughbred B
Thoroughbred B's Avatar
Datum registracije: Apr 2003
Lokacija: RI
Postovi: 4,918
Autor nicko_029
"fizicko" je vec tu,procesor
Staro 05.07.2006., 12:46   #8
ante2
ante2's Avatar
Postovi: 1,313
Talking ko je bio vidovit ko ko aaaa ?
a kada sam ja prije par mjeseci pitao jel mi trebaju driveri za proc ekipa mi se smijuljila : roller : aaaaaaaaa ko je sada u pravu aaaaaaaaaa!!!
ja jos nisam stigao isprobat doticni komad softwarea pa ako je ko nek javi kako radi ja cu veceras malo testirat pa se cujemo sutra sa rezultatima : cheers2
MSI Z77 MPower
Intel i5 3570K @4,2GHz, NOCTUA NH-U12S
Gigabyte GTX 1070
DDR3 16GB (4x4GB) 1600Hz Corsair Vengeance
Carbide Series Air 540, Corsair RM750i
CREATIVE LABS X-Fi Titanium-Kingston HyperX Cloud
DELL U2515H
Synology DS413
ante2 je offline   Reply With Quote
Staro 05.07.2006., 14:10   #9
Postovi: 7,568
AMD-ov Anti-HT je u fazi ispitivanja i ako je vjerovati onom kaj piše na raznim AMD-u namijenjenim portalima dual-core procesor na radnom taktu od 2.0GHz i s 1MB L2 cachea (po jezgri), nakon uključivanja Anti-HT-a postaje single-core procesor na radnom taktu od 3.0GHz i s 2MB L2 cachea. Navodno bi s Anti-HT-om performanse dual-core procesora porasle za kojih 60%. Intel ima sličnu foru pod nazivom CMT (Core-Multiplexing Techonology). CMT isključuje jednu jezgru dual-core procesora i stavlja na raspolaganje čitavi L2 cache jezgri koja je ostala u funkciji. Kaj bu od svega toga i dal je kaj od toga istina....to znaju samo inžinjeri AMD-a i Intela.
Staro 06.07.2006., 01:45   #10
Ozy
Spužva Bob Skockani.. :XD
Ozy's Avatar
Postovi: 1,685
Sve je to lijepo McG,ali nije bash da kužim...jer ako jezgra radi po na recimo 2Ghz,pa ako se sa Anti-HT-om jedan core zagasi,kako sa te (fizički odvojene jezgre) prebaciti 1MB tog drugog l2 cache-a na prvu jezgru...? A kako tek onda napraviti da ta prva jezgra radi odjednom na 3Ghz,tek mi to nije jasno... :confused: : stoopid
Ili se ta druga jezgra u biti "ne zagasi"...? :confused:
Athlon64 X2 5400BE Brisbane @3000Mhz + KATANA 2 + AirTunel@2x Xilence 120mm
Gigabyte GA-MA78G-DS3H @F4
Mushkin Redline @1000Mhz 5-5-5
XFX 9600GSO @680/1700 || 2000Mhz
Seagate Gonzales 250GB & 320GB && Spinpoint F1 500GB
Coolermaster Elite Power RS460; Sharkoon Silvation; LG GH22NP20/LG GH20NS10/Pioneer DVR107D/Pioneer 216DBK/ Samsung SH-S223F; Logitech MX518; Philips 190P7ES 19" LCD
Ozy je offline   Reply With Quote
Staro 06.07.2006., 02:38   #11
Zvijerko
Pečurka
Zvijerko's Avatar
Postovi: 1,294
Kod AMD-a se ništa ne gasi, već taj anti-HT driver dijeli posao na dvije jezgre. Nešto slično SLI-u. A za ovu intelovu foru nisam siguran pa neć ništ reć
I5 3350P
XFX XTR 650W
Silencio 650
Staro 06.07.2006., 02:53   #12
Ozy
Ozy's Avatar
Postovi: 1,685
Jel ti to kužiš josh manje od mene ili...?
Pa eto mene konkretno zanima kako onda ova jedna jezgra "ide" u tom slučaju na 3Ghz...
Staro 06.07.2006., 03:19   #13
Vuco
Vuco's Avatar
Lokacija: Zagreb, Tresnjevka
Postovi: 9,505
Mene više zanima kako se ponaša taj anti-HT kad je jedan X2 OC-an na nekih 2.6-2.8Ghz ...
Samo, kaj to donosi poboljšanja samo u igrama ili?
Staro 06.07.2006., 04:56   #14
Postovi: 7,568
Autor Ozy
It is like doubling the pipelinening of a single CPU upon both CPUs, which would than on theory enable for doubling the performance but again it is like any other thing - although a normal program can profit a lot more often from this as an usual proram can profit from a dual core - it still needs to be somewhat optimized.
Na koju foru točno postižu viši radni takt...ne znam. Možda je neka fora ko ove Tritium konfiguracije, pa se automatski clocka....ma ko bi ih znal. Navodno da i Intelov CMT podiže radni takt jezgre koja ostane u funkciji, prilikom uključivanja spomenute tehnologije. Kak sam i napomenul u ranijem postu....pitanje je kaj je od svega toga istina i dal budu krajnji korisnici imali prilike koristiti/isprobati AMD-ovu i Intelovu tehnologiju.
Zadnje izmijenjeno od: McG. 06.07.2006. u 05:06.
Staro 06.07.2006., 10:34   #15
nicko
Postovi: 4,190
Autor Ozy
Intel ima shared L2 cache izmedju jezgara...tako da jednostavno se iskljuci jedna jezgra a druga okupira cijeli L2
ali ko zna kaj ce od toga bit...
Staro 06.07.2006., 11:51   #16
FERRYS
AutoCad & Allplan expert
FERRYS's Avatar
Postovi: 2,159
kak sam ja skuzil kad je taj anti-ht ukljucen kao da imas jednu jezgru na 3.0, nis se ne gasi neg kao funkcionira kao kaj je neko napisal poput sli-ja
none
Zadnje izmijenjeno od: FERRYS. 06.07.2006. u 12:50.
Staro 06.07.2006., 11:58   #17
Zvijerko
Pečurka
Zvijerko's Avatar
Postovi: 1,294
O kakvom OC vi ljudi trabunjate pobogu? Nitko ništa ne OC-a. To tamo je značilo da radi ekvivalentno jednom single-core procu koji radi na 3GHz i ima 2MB cachea, a ne da netko nešt OC-a
I5 3350P
XFX XTR 650W
Silencio 650
Staro 06.07.2006., 12:22   #18
tOta
Lokacija: ...
Postovi: 685
Mozda je i AMD shvatio kako im se dobro OC-aju procesori pa kad se jedna jezgra "izgasi" druga ode gore
tOta je offline   Reply With Quote
Staro 06.07.2006., 12:31   #19
nicko
Postovi: 4,190
Autor FERRYS
kak sam ja skuzil kad je taj anti-ht ukljucen kado da imas jednu jezgru na 3.0, nis se ne gasi neg kao funkcionira kao kaj je neko napisal poput sli-ja
ja govorim o intelu!!!
Autor tOta
ajde molim te ne baljezgaj
Staro 06.07.2006., 13:23   #20
mrtvi
mrtvi's Avatar
Postovi: 183
znači današnje aplikacije imaju tolike zahtjeve za dual-core procesorima da je AMD odlučio pomoći svojim korisnicima da ih pretvore u jednojezgrene ?
mrtvi je offline   Reply With Quote
Staro 06.07.2006., 13:34   #21
Zvijerko
Pečurka
Zvijerko's Avatar
Postovi: 1,294
Točno to. Nema puno aplikacija/igara koje su optimizirane za multicore pa je ovako nešt jako jako dobro. Samo da dođe više
I5 3350P
XFX XTR 650W
Silencio 650
Staro 06.07.2006., 13:37   #22
Crais
Crais's Avatar
Datum registracije: May 2005
Lokacija: Zgb - shpaolin
Postovi: 641
Meni je tu najlogičnije da taj driver napravi da proc SIMULIRA jednu jezgru na 3 ghz, a u biti obe rade normalno, samo ne mogu napraviti da se taktovi jezgri zbrajaju (što je i normalno..). Čisto sumnjam da se jedna jezgra samo tako zgasi, nema mi tu logike.
Crais je offline   Reply With Quote
Staro 06.07.2006., 14:38   #23
ante2
ante2's Avatar
Postovi: 1,313
evo ovakva su moja iskustva nakon stavljanja optimizer-a
1 nisam primjetio da iskljucuju 1 jezdru tj rade obe
2 definitivno igre rade bolje tj nema stucanja koje se zna javit kod npr NFS MW sada sve radi tecno i ljepo: cheers2
3 3dmark score je isti ko i prije tako da tu nema nekog napredka (steta)
4 kod rada sa koverzijom videa npr iz divx-a u dvd, imam osjecaj da ima napretka ali kolikog ne mogu jos tocno rec nisam stigo usporedit stara vremena sa novim (ali budem) plus nisam stigo ripnit dvd u divx
da zakljucim izgleda da ima poboljsanja na bolje, ali treba jos malo pricekat tj jos malo radit ili se igrat da mogu sa vecom sigurnoscu rec je sam li u pravu ili ne
MSI Z77 MPower
Gigabyte GTX 1070
DELL U2515H
Synology DS413
Staro 06.07.2006., 14:56   #24
Zvijerko
Pečurka
Zvijerko's Avatar
Postovi: 1,294
Sam da podsjetim (da ne bi bilo zabune), ovaj optimizer nema veze s anti-HT koji bi trebao kasnije doći. Kao što je netko već napisao, ovo je samo AMD-ova verzija dualcore fixa.
I5 3350P
XFX XTR 650W
Silencio 650
Staro 06.07.2006., 15:05   #25
Helix
Helix's Avatar
Postovi: 244
Autor Vucko
e uzeo si mi rijeci iz usta....
Helix je offline   Reply With Quote
Staro 06.07.2006., 15:07   #26
hrvojezg00
Lokacija: ZAGREB
Postovi: 376
hm, znaci to je prakticki korak prije nego se SMP pocne razvijat vise u svim segmentima inf.da li to znaci dobitak na brzini recimo renderiranja, jer dok recimo stavim nesto u maxu da se renda u vrayu 4 jezgre, svaka obavlja svoj posao sa 1.8 ghz, sa optimizerom bi se to prikazalo kao 2 jezgre od koje svaka radi na oko 3ghz?
cm stacker 830
tyan thunder s2895 k8we
2x265 opterons
gefoce gtx 275
4x1gb ecc reg samsung
74gb wd raptor
300gb seagate
samsung 242mp 24*
hrvojezg00 je offline   Reply With Quote
Staro 06.07.2006., 15:33   #27
Ozy
Ozy's Avatar
Postovi: 1,685
Ako ti recimo taj 3D Max upošljava sve 4 jezgre,onda ćesh veći posao napravit tako nego kad su dvije jezgre na po ta 3Ghz...jer ako su ti sve 4 jezgre u pogonu neće ono biti ništa brže...
Staro 06.07.2006., 15:45   #28
Zvijerko
Pečurka
Zvijerko's Avatar
Postovi: 1,294
Kad taj driver(anti-HT) prepozna aplikaciju koja može iskoristiti sve jezgre, neće se koristiti anti-HT, u suprotnom hoće
I5 3350P
XFX XTR 650W
Silencio 650
Staro 06.07.2006., 15:58   #29
Vuco
Vuco's Avatar
Postovi: 9,505
Ja opet napominjem, mene zanima koja će biti "ekvivalentna" brzina kad je neki X2 OC-an na 2.6-2.8Ghz.
Jer tu se spominje da će jedan X2 3800+ na taktu od 1.8Ghz u jednojezgrenim aplikacijama imati sličnu "brzinu" kao proc na 3Ghz i 2MB L2 cache-a.
Kolko je onda ta brzina kad je proc OC-an na npr. 2.8Ghz?
Staro 06.07.2006., 16:11   #30
Postovi: 7,568
Autor Vucko
5.0GHz? A kad stigne quad-core....kaj pa bu onda na stvari?
