Staro 16.03.2006., 19:37   #1
Postovi: 7,568
Thumbs up EPoX EP-9U1697 GLi.....overclocker za sitne pare
Anandtech je recenziral ovu (po meni) odličnu EPoX-ovu ploču, baziranu na ULi-evom 1697 chipsetu, koja po performansama drži korak (a u nekim slučajevima) i nadjačava bolje/skuplje ploče mnogo renomiranijih prozvođača.
Evo par dojmova Anandtech-ovih recenzenata:
The EPoX EP-9U1697 GLi offers excellent performance at a bargain price. The performance of the board in the majority of the benchmarks was extremely competitive with the ATI and NVIDIA chipset offerings. The stability of the board was superb at stock settings and very good at overclocked settings. We find it refreshing that a board with this performance is being offered for a retail price around US $85. While the ASRock 939SLI32-eSATA2 offers a greater feature set for the same price, the EPoX board offers significantly better performance in the overclocking area.
The board utilizes a manual jumper system to switch from single x16 PCI-E operation to dual x8 PCI-E operation. The performance of the board under SLI testing matched that of our nForce4 boards and offered full SLI compatibility with the ULi PowerExpress Engine Enabling driver. The board also fully supported our ATI X1900XTX and EVGA 7900GTX video cards.
The board offers RAID 0, 1, 0+1, 5 capability, NCQ, Hot Plug, and 3Gb/s support along with dual channel ATA133 Ultra DMA capability. The board also offers eight ULi USB 2.0 ports when utilizing the two USB 2.0 headers. The performances of the ULi SATA and IDE controllers were excellent and easily exceeded the nForce4 solutions.
The stability of the board was excellent during testing and general usage. The board's performance was consistently competitive with other ATI, ULi, and NVIDIA chipset offerings in the majority of benchmarks and applications.
Naravno nitko nije savršen:
However, we feel that EPoX made the following errors in the design and execution of the board. The location of the floppy drive connector at the bottom of the board, the location of the 24-pin ATX power connector right above the CPU socket, and the use of active cooling on the ULi M1697 chipset could be improved. EPoX will be offering the 9U1697 GLi-J board with PCI-E Gigabit via the Marvell 88E8053 controller, but it will only be upgrading the audio to the 8-channel capable ALC-850 AC97 codec.
The BIOS issue that we encountered, which caused random lockups after exiting Windows XP, was disconcerting, although we did not notice any stability or performance issues within Windows or during testing. EPoX has provided us with an updated BIOS for testing.
Kad stigne u prodaju, ploča bi trebala koštati oko 85$ (cca 500 kn) i manje (ovisno od dućanu, tj. retaileru).
Review
Staro 16.03.2006., 21:30   #2
domy_os
domy_os's Avatar
Postovi: 18,874
Performanse i layout su dosta loši kao na svakoj Epoxici...
RAM: 2 x 16 GB DDR4-3200
WLAN: Intel Wi-Fi 6 AX201
LCD monitor: AOC AG493UCX
SB: Mackie Onyx Producer 2x2
Speakers: 2 x JBL LSR305
MFP: Canon Pixma MP240
Staro 16.03.2006., 21:37   #3
Vuco
Vuco's Avatar
Lokacija: Zagreb, Tresnjevka
Postovi: 9,505
Oko layouta se slazem, al mislim da se varas oko performansi...ako ce cijena i biti 500kn, performanse su super
Samo, kad ce doc ta prokleta ploca u nas??
Staro 16.03.2006., 22:15   #4
Router
Hejter
Postovi: 6,521
meni se chipset ovaj jako svidja . a bar je bolje uli i epox , nego uli i asrock
Staro 17.03.2006., 00:33   #5
joolka
music freak
joolka's Avatar
Lokacija: Sibenik
Postovi: 3,316
Autor Router
...ja se ne bih slozio,a prednost epoxa je u vecim voltazama tim je moguc veci overclock
LENOVO LEGION 5 Pro Gaming Laptop (AMD Ryzen 7 7745HX,RTX 4060,32gb DDR5,2tb SSD)
joolka je online   Reply With Quote
Staro 17.03.2006., 00:40   #6
Vuco
Vuco's Avatar
Postovi: 9,505
Joj, kad bi barem ploca dosla u nas u par narednih dana. Cijenu od 500kn bih platio bez problema...
Staro 17.03.2006., 00:44   #7
Postovi: 7,568
Dobro, layout ko layout (nekomu paše, nekomu ne....ali čovek se navikne), sve u svemu imam osjećaj da bi ta ploča (još kad EPoX malo sredi BIOS) mogla biti i više nego solidna......i po pitanju performansi, a bome i kaj se tiče overclockanja.
Staro 19.03.2006., 19:54   #8
Postovi: 7,568
Xtreme Systems
This board features a 24-Pin connector, vs ASRock's 20-Pin setup. This should provide much more stable power to the board and components, which should improve the board's overclockability. The board already does 325MHz HTT stable, which is more than most people would need. With a bit more voltage, and 2T it goes slightly higher.
EPoX EP-9U1697 GLi-J Review, SLi u akciji
Zadnje izmijenjeno od: McG. 19.03.2006. u 20:38.
Staro 19.03.2006., 22:27   #9
Vuco
Vuco's Avatar
Postovi: 9,505
Jel itko nagadja kad ce to cudo doc u Rvacku? i di ce se moc kupit...
Hitno mi je, sljedeci tjedan moram kupit maticnu, jer vise nemrem bez kompa...a bilo bi mi zao ako bih upecal npr, Asrocka sa ULi 1697 (koji takodjer nije losa maticna) a da mi dva dana kasnije dodje ta epoxica koja je u nekim stvarima jaca od asrocka....ne puno, al ako je cijena tu negdje, zasto ne
Makar mislim da ce me i asrock dobro sluzit.
P.S. Ima li netko tu Asrock 939SLI-eSATA2 maticnu? Ako ima nek mi posalje PM, da vidim koje su dobre a koje lose strane, kaj radi kak treba a kaj ne...
Staro 20.03.2006., 14:37   #10
Postovi: 7,568
Strpi se malo, sad bi ovaj mjesec trebala stići u prodaju. BTW ploča podržava i SLi i CrossFire uz pomoć predelanih drivera
Staro 20.03.2006., 16:53   #11
Vuco
Vuco's Avatar
Postovi: 9,505
Ma nemrem cekat, jednostavno mi je prijeko potreban komp za fax (3d crtanje).
Tako da mislim da ce ipak radi novaca doci u moj doma Asrokica Dual SATA...
A kasnije ko ce znat
Staro 21.03.2006., 14:09   #12
MadBoY
MadModerator
MadBoY's Avatar
Datum registracije: Sep 2002
Lokacija: N/A
Postovi: 5,195
Ako je u USA oko 500-520kn, kod nas ce bit min oko 700-800kn.
Staro 03.04.2006., 14:41   #13
SRV
SRV's Avatar
Lokacija: n/a
Postovi: 6,128
Zna li tko kada ce doc u Hr? Mislim da ce ipak bit jeftinija od 700kn.
Staro 03.04.2006., 14:53   #14
Router
Hejter
Postovi: 6,521
ko zna kad ce to .
Staro 03.04.2006., 15:46   #15
Codiac
bycod
Codiac's Avatar
Lokacija: Zagreb / Dubrava
Postovi: 6,699
Zanimljiva ploca za malo love
.i.
Razer Blade 15
Staro 03.04.2006., 16:35   #16
Postovi: 7,568
Kaj se tiče dobavljivosti ploče u Lijepoj Našoj, nažalost još je nema. Ja se nadam da bu stigla i to ubrzo.
Staro 03.04.2006., 18:06   #17
FERRYS
AutoCad & Allplan expert
FERRYS's Avatar
Postovi: 2,159
Chipset voltage adjust Yes, 2V +0.1V - +0.2V
DDR voltage adjust Yes, 2.5V – 3.2V
CPU Vcore Yes, 0.8V – 1.75V
HT bus voltage Yes ; 1.2V~1.6V
Clock adjust : 200 ~ 400MHz, CPU Multiplier 5x~25x
PCI-E speed range 100MHz – 200MHz
sviđa mi se ovo, mogao bi ja to ubost kad stigne....
none
Staro 03.04.2006., 18:20   #18
SRV
SRV's Avatar
Lokacija: n/a
Postovi: 6,128
Jedino sto mi se ne svidja je sto nema SLI bridge konektora, to sto ne valja polozaj 24-pinskog konektora je normalno za epoxice
