Povratak   PC Ekspert Forum > Računala > Software > Web dizajn, programiranje i ostalo
Staro 28.02.2006., 10:19   #1
MSA
MSA's Avatar
Postovi: 115
Question VISUAL STUDIO 2005 problem
...evo baš sam instalirao visual studio 2005...uglavnom napravim jednostavnu win32 console aplikaciju...ucitam je kao empty project i preko solution managera dodam new item s .cpp ekstenzijom, tj. napišem novi source....kad sam sve to napravio odem na build...build prođe bez greške i tada idem na start without debugging i onda mi javlja missing MSVCR80D.dll....na netu sam našao da to ime nekakve veze s manifestima al ne znam kaj da točno napravim da riješim taj problem....
MSA je offline   Reply With Quote
Staro 28.02.2006., 10:39   #2
Andeo
Andeo's Avatar
Postovi: 455
Ne znam, nisam imao takvih problema, ovo je ono šta Microsoft kaže.
Microsoft:
"Please use Start - Search - for files and folders to see where MSVCR80D.DLL is on your system. You should only have one of them on your system at:
C:\windows\winsxs\x86_Microsoft.VC80.DebugCRT_1fc8b3b9a1e18e3b_8.0.50727.42_x-ww_f75eb16c
Delete any others (and the folders they are contained in). Do the same for MSVCR80.DLL. As well as MSVCP80(d).DLL and MSVCM80(d).DLL "
RABBITS CLAN
Andeo je offline   Reply With Quote
Staro 28.02.2006., 10:53   #3
MSA
MSA's Avatar
Postovi: 115
...ne pomaže to....to su napisali u slučaju da vs javlja "The procedure entry point _encode_pointer could not be located in the dynamic link library MSVCR80D.dll." al meni prilikom samog pokretanja aplikacije javlja
"The application has failed to start because MSVCR80D.dll was not found. Re-installing the application may fix this problem"
Staro 28.02.2006., 10:58   #4
atha
atha's Avatar
Postovi: 9,067
Code:
This means several things.
a) your console application does not have manifest.
Either embedded inside or external.
To check this, do the following:
1. Check for <appname>.exe. manifest next to exe.
If it is not there, it may be embedded. Go to step 2.
2. Open appname.exe in VS. See if it has RT_MANIFEST.
Save it as a file and see if it has this line in it:
<assemblyIdentity type="win32" name="Microsoft.VC80.DebugCRT" version="8.0.50215.4652" processorArchitecture="amd64" publicKeyToken="1fc8b3b9a1e18e3b"></assemblyIdentity>
If no RT_MANIFEST resource is present in the binary, go to step 3. If it is there, then go to step 4.
3. You are building with /manifest:no. Don't do this, it is not supported scenario. Remove this linker switch and it all should work.
4. msvcr80d.dll is not on the system. We need to know what version of VS is installed,
what OS, what parts of VC++ have you selected during installations.
Go ahead and file a bug on this on lab.msdn.microsoft.com.
___________
Just atha
x
Staro 28.02.2006., 11:02   #5
atha
atha's Avatar
Postovi: 9,067
a ako ne pomogne niti to, prouchi malo link.
___________
Just atha
x
Staro 28.02.2006., 21:21   #6
nicko
Postovi: 4,190
instaliraj visual studio 6.0...puno je bolji od 2005 (jednostavniji) za ono sto ti treba....
preptpostavljam da si ferovac pa ga mozes besplatno skinut sa msdnaa sitea...
nicko je offline   Reply With Quote
Staro 28.02.2006., 23:20   #7
MSA
MSA's Avatar
Postovi: 115
....dobro pretpostavljaš: goood : ...ma skužio sam i ovdje u čemu je finta...uglavnom nikakav problem ne stvara otvaranje novog projekta kao CLR-a, ali win32 console ga muči i tu moram isključit embbed manifest i onda radi.....
Staro 28.02.2006., 23:42   #8
nicko
Postovi: 4,190
ajde, drago mi je da si sredio...
