Staro 01.10.2005., 13:26   #1
Brain32
Brain32's Avatar
Postovi: 498
Forceware v81.82beta
Puno novotarija o ovom izdanju
Lista fixeva:
"This driver fixes some issues found on Release 75 drivers on Black and White 2 including:
- Performance slowdown on GeForce 6 and 7 series GPUs
- Texture corruption on GeForce 6 series GPUs
- Adds SLI profile for the best out of box experience
In addition this new driver also adds many new features including:
- Increased performance for GeForce GPUs
- SLI Mixed vendor support
- Dynamic SLI with no reboot when using a single monitor
- PureVideo and HDTV enhancements "
A tu je i novi nVidia Control panel...
http://img329.imageshack.us/my.php?image=nvcpnew1qc.jpg
Download: http://downloads.rojakpot.com/details.php?file=128
To vam je 30MB , poslije ce valjda na guru3d bit znatno manja prepakirana verzija, pa onima koji su zainteresirani a kao i ja pate na 56k preporucujem da malo pricekaju...
Ja ih nisam probal pa ak nesto podje po zlu nemojte moju mamu spominjat u kontekstu s psima
Brain32 je offline   Reply With Quote
Staro 01.10.2005., 21:04   #2
joolka
music freak
joolka's Avatar
Lokacija: Sibenik
Postovi: 3,316
...pretpostavljam da ovo nema smisla stavljati na ista osim 6*** i 7*** serije kartica,je li proba ko na recimo fx5900 ?
LENOVO LEGION 5 Pro Gaming Laptop (AMD Ryzen 7 7745HX,RTX 4060,32gb DDR5,2tb SSD)
Staro 01.10.2005., 21:07   #3
buljo
Strichek Moderator
buljo's Avatar
Postovi: 9,344
Re: Forceware v81.82beta
dakle crosfire se više nemože hvalit s tim...
Staro 02.10.2005., 00:03   #4
Crash009
Crash009's Avatar
Lokacija: Orahovica
Postovi: 7,363
mislim da bi dobio samo lošije performase ako bi uopće radilo tako uzmi neki iz serije 5x.xx i igraj se koliko ide ...
probaj neke moddane sa guru3d
Staro 02.10.2005., 19:39   #5
Brain32
Brain32's Avatar
Postovi: 498
Je, neki lik s guru3d-a je probal i veli da su mu performanse OK, tj. evo ti citat:"so slightly slower for me but iq is better and it seems smoother in fear, other games play the same. gonnna keep em for now."
Inace ti driveri se nisu smijeli pojavit do utorka kada sluzbeno izlaze, a nekak ni ne vjerujem da bu sluzbenjaca manja.
Ja sam ih probal i jos jednom se pokazalo da sto je manji 3d mark score, to igre idu bolje
E da i ak neko "pere" NFSU2 cujem da se roka s ovim driverom, al se to moze rijesit tak da pobrisete njegov profil...
Skoro zaboravih, ovi driveri kao i svi 81.xx su multi-threaded tj. ekipa s dvije jezgre ili dva proca(mozda cak i HT) ce moc upogonit obje tijekom igre, no mi smrtnici sa "samo" jednim nis ne gubimo
Staro 02.10.2005., 20:03   #6
Kerber
Captain
Kerber's Avatar
Lokacija: Osijek-Bilje
Postovi: 282
Ja sam ih probao ali ne mogu reci da su nesto bolji, 3dmark score je isti
i5750@4000Mhz (200x20@1.4)--Gigabyte P55UD3R--Zalman CNPS10xEXTREME
2x2GB 1600Mhz GSKILL 7-7-7-24 --XFX GTX285 --Audigy2 ZS
Raid 0 2xWD BLACK 750GB SataII--DVD/RW Pioneer 111BK--CORSAIR 750W
Kerber je offline   Reply With Quote
Staro 02.10.2005., 20:26   #7
Brain32
Brain32's Avatar
Postovi: 498
Ma je*es 3dmark, kak ti igre idu? Mislim, nikad svi ne osjete neki pomak sa odredjenim driverima u svim aplikacijama, vjerojatno si pogodil kombinaciju...
Staro 02.10.2005., 22:22   #8
Lihto
The Dark Side of Moon
Lihto's Avatar
Postovi: 3,945
Meni se zacrni ekran na 15sec prije ulaska u windowse,al ostalo je ok
Macbook M1+ LG32UQ85R
iPad 5 White 32gb Wifi
iPhone XR 128gb
Lihto je offline   Reply With Quote
Staro 03.10.2005., 14:08   #9
Kerber
Captain
Kerber's Avatar
Postovi: 282
Ajd ti skuzi na 7800GT razliku od par frameova
