Staro 04.08.2012., 15:33   #1
walbandon
Lokacija: Valbandon-blizu Pule
Postovi: 974
Problem s otvaranjem nekih stranica
Ne mogu skuziti zasto, ali neke stranice ne mogu vec neko vrijeme (prije radile) otvoriti/pingati/trejsati na kompu (win xp home )
konkretno :
ipress.hr
uniline.hr
dok druge otvara normalno
win firewall je iskljucen odavno ( probao sam i disejblati avast) , a drugi komp u mrezi sasvim normlano otvara/pinga iste stranice ...
ima netko ideju sta probati, se netko susreo s time?
thnx
C I C E.... TRGOVAC 1 , 2 ,
walbandon je offline   Reply With Quote
Staro 04.08.2012., 16:56   #2
Postovi: 23,617
Koji operater i koji router ?
Za probu postavi fiksne mrežne postavke na kompu uključujući i DNS Servere.
Vidi Sticky DNS by ISP
Staro 04.08.2012., 17:05   #3
domy_os
domy_os's Avatar
Postovi: 18,943
Kako ti izgleda hosts file? Probaj promijeniti DNS servere u OpenDNS ili Google, kako kaže Nikky.
RAM: 2 x 16 GB DDR4-3200
WLAN: Intel Wi-Fi 6 AX201
LCD monitor: AOC AG493UCX
SB: Mackie Onyx Producer 2x2
Speakers: 2 x JBL LSR305
MFP: Canon Pixma MP240
Staro 05.08.2012., 10:59   #4
walbandon
Postovi: 974
@Nikky
adrese su fiksne na sva 3 kompa,
svi kompovi su xp home (original) , firewall off, i avast av ... na 2 mi ne pinga, a na jednom da
hosts fileovi su original i isti :
# Copyright (c) 1993-1999 Microsoft Corp.
# This is a sample HOSTS file used by Microsoft TCP/IP for Windows.
# This file contains the mappings of IP addresses to host names. Each
# entry should be kept on an individual line. The IP address should
# be placed in the first column followed by the corresponding host name.
# The IP address and the host name should be separated by at least one
# space.
# Additionally, comments (such as these) may be inserted on individual
# lines or following the machine name denoted by a '#' symbol.
# For example:
# 102.54.94.97 rhino.acme.com # source server
# 38.25.63.10 x.acme.com # x client host
127.0.0.1 localhost
net ide preko wirelessa jedne lokalne firme, a oni idu van preko metroneta ... mada sam probao promjeniti i gateway na 1, tj na tcommodem koji mi stoji kao backup, i isto nije pingalo ...
e, da... da ne zaboravim, a preko proxya mi otvara... wtf ??
Zadnje izmijenjeno od: walbandon. 05.08.2012. u 12:30.
Staro 05.08.2012., 12:35   #5
nitrooxid
Datum registracije: Jun 2012
Postovi: 133
Probaj omogućiti NetBios putem TCP/IP-a ,jer ako imaš statične IP on ti zna riješiti probleme s povezivanjem!
Zadnje izmijenjeno od: nitrooxid. 05.08.2012. u 12:38. Razlog: ispravak
nitrooxid je offline   Reply With Quote
Staro 05.08.2012., 13:49   #6
Postovi: 23,617
Autor walbandon Pregled postova
Možda u toj firmi imaju dignut kakav firewall / filter, vidiš da ide kroz proxy.
U prevodu nisi ti "kriv".
Staro 07.08.2012., 21:42   #7
walbandon
Postovi: 974
ma, gle, oni su provideri neta, tako da ne vj da je do njih, jer , kao sto sam napisao, na jednom kompu radi, na drugom ne ...da je u njima problem, ne bi radilo ni na jednom komp, zar ne?
