Staro 26.06.2012., 14:46   #1
_saiko
system kaiser
Postovi: 194
Ventilacija serverske sobice
Pozdrav,
Imam u potkrovlju malu sobicu svega 3m^2 sa nakosenim stropom.
Soba nema prozora niti neki konktakt prema van. Vrata sa izo staklom ju prakticno hermetski zatvaraju.
Unutra imam 2 PC-a u sluzbi servera i nešto mrežne opreme tako da je unutra po ljeti kao u svedskoj sauni
Razmisljao sam probiti na jednom zidu dvije cijevi, i na jednu staviti ventilator.
Alternativno jednu od rupa napraviti na stropu i probiti mali dimnjak.
Koji fi za rupe i kakav vent upotrijebiti, te kako sprijeciti da vlaga ulazi?
Ako netko ima iskustva ili savjet...
<FLEET>
MBO: Gigabyte GA-X58A-UD7 (rev. 2.0)
CPU: Intel Core i7-950 @ 3.2 GHz
Chipset: Intel X58
RAM: 6 x 4 GB DDR3-1600 (PC3-12800)
VGA: HD4850
HDD(OS): OCZ Vertex3 120GB
HDD(local storage): WD WD2002FAEX 2TB, 2x Seagate 500GB (RAID0@IRST/ICH10R)
ODD: Optiarc (?)
PSU: Silverstone SST-ST60F-P Corsair VX450
Display: Samsung Syncmaster 930BF @ 1280 x 1024
Display2: Panasonic TC-P55VT60 @ 1920x1080
Other: eSata dock
OS: Windows 7 Ultimate x64
Input:
Logitech MX1000 + Logitech UltraX cordless
Model: HP Z420
CPU: Intel Xeon E5-1650 6x core @ 3.2 GHz
Chipset: Intel Sandy Bridge-E
RAM: 4 x 16 GB DDR3-1600 (PC3-12800)
VGA: Nvidia
HDD(OS): Seagate ST500DM002 500GB
HDD(local storage): 2x WD WD5000AAKX (RAID1@C600 SAS/SATA ctrl)
Display: 2x HP LA2205wg 22" @ 1680 x 1050
OS: Windows 7 Enterprise x64
Model: HP Elitebook 8570
CPU: Intel i5 3360M
Chipset: Intel Ivy Bridge
RAM: 2 x 8 GB DDR3-800 (PC3-12800)
VGA: Intel HD4000
HDD: Samsung SSD 850Pro 512GB
ODD: DVD+/-RW
Display: 15.4" (1366 x 768)
Other: Fingerprint reader
Input:
Logitech V500 cordless
MBO: GA-P35-DS3P (rev. 2.0)
CPU: Intel C2Q Q6600 @ 2.4 GHz
RAM: 4 x 2 GB DDR2-800 @ 533 MHz
VGA: ATI Rage 3D @ PCI
HDD(OS): Seagate ST380815AS 80GB / Seagate ST3500418AS 500GB
HDD(storage01): 2x WD RE WD4000FYYZ 4TB (RAID10,f2@mdadm)
HDD(storage02): WDC WD20EARX-00P 2TB
HDD(storage_cctv): Seagate ST3250824AS 250GB
ODD: NEC DVD-RW ND-4551A
PSU: Corsair GS800
Display: -
LAN: Intel 82571EB @2x1Gbps LACP
Controllers: RS232 Oxford Semiconductor Ltd OXuPCI952
OS: Linux x64 (Ubuntu 14.04 LTS)
MBO: HP ProLiant DL120 G7
CPU: Intel Xeon E3-1220 @ 4x 3.10GHz
Chipset: Intel i875P-ICH5
RAM: 4 x 4096 MB DDR3-667 (PC3-10600)
HDD1: 2x MB2000EBUCF HUA723020ALA640 2TB 7200RPM (RAID1@P410)
Display: -
LAN: 82574L @ 1000Mbps FD
OS: Linux x86_64 (Ubuntu 14.04 LTS)
MBO: ASRock 4Core1333-FullHD
CPU: Intel Core 2 Duo E84000 @ 3.0 GHz
Chipset: ATI RS600+SB600
RAM: 1 x 512 MB DDR2-800
VGA: -
HDD: Seagate 500GB
ODD: DVD-RW
PSU: Corsair VX450(?)
Display: Panasonic TH-50PY800
LAN: @1Gbps FD
OS: Windows 8.1 Pro x64
Input:
Logitech Cordless DiNovo Edge
MBO: Intel D201GLY2 (ITX)
CPU: Intel Celeron 220 @ 1.2GHz
Chipset: SiS662
RAM: 1 x 512 MB DDR2-533
VGA: Intel
HDD: Sandisk 1GB CF @ CF2IDE
ODD: -
PSU: miniITX type(?)
Display: -
LAN1-Uplink: @1000Mbps FD
LAN2: @100Mbps FD
OS: Mikrotik OS 6.28
Model: Mikrotik RB2011UAS-2HnD
</FLEET>
cat.7 - where crosstalk is not an issue anymore.
_saiko je offline   Reply With Quote
Staro 26.06.2012., 15:03   #2
Postovi: 23,634
A malo građevine i termodinamike, . . .
- da dvije cijevi / otvora, jedan usis a drugi ispuh, na obje nekakve klapne da možeš zatvoriti po potrebi
- na taj način teško ćeš spriječiti ulaz / stvaranje vlage
- možda neka jeftinjak klima ?
Links:
http://www.radovi.net/index.php?opti...rov&Itemid=279
http://www.samsvojmajstor.com/portal...a-u-potkrovlju
Zadnje izmijenjeno od: Nikky. 26.06.2012. u 15:10.
Staro 26.06.2012., 15:19   #3
_saiko
system kaiser
Postovi: 194
Odmah i jesam rekao dvije cijevi zbog usisa i ispuha... Ali vent i cijev mi je jasno da je problem vlaga, jedino pretpostavljam da postoji neko rješenje i za to. Ovako laicki bi rekao nekakav filter koji bi se u cijev stavio?
Klimu bih volio izbjeci obzirom da to neusporedivo vise trosi...
<FLEET>
Chipset: Intel X58
VGA: HD4850
ODD: Optiarc (?)
Other: eSata dock
Input:
Model: HP Z420
VGA: Nvidia
CPU: Intel i5 3360M
VGA: Intel HD4000
ODD: DVD+/-RW
Input:
PSU: Corsair GS800
Display: -
Display: -
VGA: -
HDD: Seagate 500GB
ODD: DVD-RW
LAN: @1Gbps FD
Input:
Chipset: SiS662
VGA: Intel
ODD: -
Display: -
LAN2: @100Mbps FD
</FLEET>
Staro 26.06.2012., 15:28   #4
nitrooxid
Datum registracije: Jun 2012
Postovi: 133
ne znam baš da bi trebao imati vlage u potkrovlju,nije to podrum.Opcija usis i ispuh je dobra samo ventilator neki sporo što vrti i sve pet!
nitrooxid je offline   Reply With Quote
Staro 26.06.2012., 15:35   #5
Swarm dude
Premium moderator
Swarm dude's Avatar
Postovi: 4,600
Baš, vlaga će biti kao i atmosferska. Uostalom, izostanku kondenzacije pogoduje upravo viša temperatura
Po zimi možeš staviti onaj Henkelov Ceresit odvlaživač zraka, ako će se temperatura spuštati dosta nisko. Nikakav filter neće pomoći za vlagu, jedino odvlaživač. Iako, ako računala rade stalno (a rade jel), to ne bi trebao biti problem.
MBO: MSI 760GM-E51 FX
VGA: Nvidia Quadro K600
SSD: Crucial BX500 1TB
Staro 26.06.2012., 15:45   #6
_saiko
system kaiser
Postovi: 194
I dalje ostaje pitanje gdje staviti cijevi, da li je bolje radi strujanja zraka jednu staviti na strop (tek je onda kisa problem...) a drugu na zid ili obje na zid...
I naravno koji fi...
<FLEET>
Chipset: Intel X58
VGA: HD4850
ODD: Optiarc (?)
Other: eSata dock
Input:
Model: HP Z420
VGA: Nvidia
CPU: Intel i5 3360M
VGA: Intel HD4000
ODD: DVD+/-RW
Input:
PSU: Corsair GS800
Display: -
Display: -
VGA: -
HDD: Seagate 500GB
ODD: DVD-RW
LAN: @1Gbps FD
Input:
Chipset: SiS662
VGA: Intel
ODD: -
Display: -
LAN2: @100Mbps FD
</FLEET>
Staro 26.06.2012., 15:55   #7
nitrooxid
Postovi: 133
najbolje je jednu na strop,jer ti topli zrak ide u visinu a hladni pada dolje na pod zbog težine.Ne trebaš skidati crijep nego ga samo malo podići jer ti sami nagib ne da da ti kiša pada unutra,a filter se malo raspitaj ja mislim da ti ne treba jer ti ta dva kompa ubiše svu vlagu u zraku svojim grijanjem prostorije!
