Staro 14.03.2005., 18:58   #1
BrunoZG
Junior Member
BrunoZG's Avatar
Datum registracije: May 2003
Postovi: 3,205
Unreal Tournamenrt i Ice fisherman
Ice , zahvaljujuci izvanrednom searchu na forumu, nemrem najti tvoj toic za forama na UT..
Aj postaj link ak ti usopijes najti ili prepisi
AMD 3800+x2@2500, 1,375V
MB-ASROCK DUAL SATA(bios 2.2) 2+ENERMAX485W
2x512 Supertalent CL2
HDD-Hitachi 160GB, WD 800JB
ELSA 7600GT
Leadtek-2000XP expert
DVDROM-LITEON-167T ,DVDRW BENQ 1650,DVDRW NEC ND2500A@2510_fw205C
Monitor: Samsung 997MB (19')
Terratec Sky 5.1,EPSON-C42
BrunoZG je offline   Reply With Quote
Staro 14.03.2005., 19:36   #2
IceFisherman
Magister Mundi sum!
IceFisherman's Avatar
Datum registracije: Jun 2003
Lokacija: Zagorje
Postovi: 2,335
misilš na ovo
http://forum.pcekspert.com/showthrea...threadid=18381
samo kaj nije meni bil cilj nabrajati trikove i slicno nego da mi neko veli kakav kaj ja sam jos neznam
Sapphire radeon x1650PRO
2x512mb 433mhz Kingmax
AOC 17", LCD, LM760
Win XP PRO SP2 & SUSE 10.1
www.crazywarriors.com
Staro 14.03.2005., 19:58   #3
BrunoZG
Junior Member
BrunoZG's Avatar
Postovi: 3,205
to iCE, mogel bi malo i dopunit
ELSA 7600GT
Staro 14.03.2005., 20:01   #4
IceFisherman
Magister Mundi sum!
Lokacija: Zagorje
Postovi: 2,335
nebi mogel , jedino ak neko drgi nadopuni kaj zna ono kaj ja neznam , morem jedino napisati gde je redimer na kojoj stazi i slicno , samo kaj mi se neda jer imas negde na netu sve to na engleskome
AOC 17", LCD, LM760
Staro 14.03.2005., 20:10   #5
tor
Administrator
tor's Avatar
Lokacija: Sesvete
Postovi: 15,963
In SinglePlayer and during gameplay press and enter iamtheone to activate cheat mode. Now enter any of the following "Codes":
Code Effect
god God Mode
loaded All Weapons
allammo All Ammo
ghost No Clipping
fly Fly Mode
walk Walk Mode
killall class Kills all Enemies of a class
playersonly Freezes Time Again to UnFreeze
behindview 0 or 1 Normal View or Behind View
open mapname Jump to mapname
summon unreali.item name Spawn item name
summon unreali.opponent name Spawn opponent name
addbots Add of Bots
say message Broadcast message to Others
Možda nešto od ovoga?
Staro 14.03.2005., 20:11   #6
tor
Administrator
tor's Avatar
Lokacija: Sesvete
Postovi: 15,963
I još...
Item Names
cannon
eightball
flakcannon
nali
skaarjwarrior
quad shot
warheadlauncher
enforcer
doubleenforcer
minigun2
pulsegun
shockrifle
sniperrifle
utbiorifle
uteightball
utflackcannon
chainsaw
rifle
razorjack
gesbiorifle
minigun
flakcannon
dispersionpistol
stinger
automag
asmd
clip
rifleround
flakshellammo
defaultammo
Opponent Names
warlord
titan
stone titan
squid
slith
skaarj
skaarjwarrior
skaarjscout
skaarjlord
skaarjberserker
skaarjassassin
iceskaarj
skaarjtrooper
skaarjsniper
skaarjofficer
skaarjinfantry
skaarjgunner
queen
pupae
nali
nalipriest
mercenary
mercenaryelite
manta
giantmanta
cavemanta
krall
lesserkrall
krallelite
gasbag
giantgasbag
fly
devilfish
cow
babycow
tentacle
brute
lesserbrute
behemoth
bots
skaarjplayerbot
humanbot
malebot
maletwobot
malethreebot
maleonebot
femalebot
femaletwobot
femaleonebot
nalirabit
horsefly
blobelt
biterfish
bird1
parentblob
horseflyswarm
deadbodyswarm
biterfishschool
Boss Skin
First make a backup copy of the file user.ini which is located in System in the game directory. Then open up the original with any text editor and add these lines:
Botpack.Ladder
HasBeatenGameTrue
Staro 14.03.2005., 20:15   #7
IceFisherman
Magister Mundi sum!
Lokacija: Zagorje
Postovi: 2,335
ma neeee too , ja ne varam , radije idem nekaj drugo delati nego igrati igricu sa šiframa , mene baš zanima trikovi slični onome kaj sam ja navel
AOC 17", LCD, LM760
Staro 14.03.2005., 20:18   #8
tor
Administrator
tor's Avatar
Lokacija: Sesvete
Postovi: 15,963
A možda ovo:
There are a range of special moves which can be performed by your character under certain circumstances. Some require that you have 100 Adrenalin. Others, like the Dodging moves require that you have the Dodge setting ticked (See In-game Settings section). You can get Adrenalin points through various methods:
* Adrenalin pill: 3 points
* A Kill: 2 points
* Headshots: 5 points
* First Blood: 12 points
* Killing sprees: 12 points
Once your Adrenalin reaches 100 points, you will be allowed to perform one of the following special moves, the effects of which will only last for a while. The following key combinations need to be pressed in rapid succession to activate the Adrenalin effect:
* Speed: Forward, Forward, Forward, Forward
* Regeneration: Back, Back, Back, Back
* Invisibility: Right, Right, Left, Left
* Berserk: Forward, Forward, Back, Back
Special Moves
Special moves require that you activate the dodging in the settings. Most of these moves need a lot of practice to be able to perform them at any time.
* Double Jump: Jump and then press jump again in the arc of the jump.
* Dodge: Tap Left, Right, Forward or Back twice quickly.
* Dodge Jump: Perform a Dodge, and jump just before you lose your air.
* Wall Jump: Run alongside a wall, Dodge (double tap) into it and as you're about to hit it, quickly Dodge away from it.
* Goo Jump: Shoot some goo from the Biorifle, get a shield up using the Shield Gun, jump just when goo explodes (You can also use the shield gun to bounce energy weapons, break your fall and of course block normal weapons.)
* Lift Jump: Jump while on a lift to get an extra boost.
* Death from Above: If you jump from a great height and land on someone you'll cause them damage.
Staro 14.03.2005., 20:20   #9
tor
Administrator
tor's Avatar
Lokacija: Sesvete
Postovi: 15,963
Ma ne, nije sve varanje. Imaš skinove od bosa i slične stvari.
Ono iznad je za 2004 ali dosta toga radi i na UT...
Staro 14.03.2005., 20:24   #10
IceFisherman
Magister Mundi sum!
Lokacija: Zagorje
Postovi: 2,335
hmm .. ovo gore kaj si navel je za novi ut , ja sam mislil na onaj stari, prvi ut ali dobromi je sad i ovo doslo
AOC 17", LCD, LM760
Staro 14.03.2005., 21:19   #11
Renesis
Ex-Gastarbajter
Renesis's Avatar
Lokacija: Zagreb / Rijeka
Postovi: 5,463
death from above mi se čini malo teže za izvest
Abit IS7-E + TR NB-1
Homemade vodeno part1
Homemade vodeno part2
