Staro 18.04.2010., 16:14   #1
Razer
Razer's Avatar
Postovi: 11,642
Nvidia ForceWare 197.45 WHQL driveri
This is a WHQL-certified driver for GeForce 6, 7, 8, 9, 100, 200, and 300-series desktop GPUs and ION desktop GPUs.
New in Version 197.45
* Recommended for the best performance with the new GPU-accelerated features in Adobe CS5.
* Adds support for the new version of MotionDSP's video enhancement software, vReveal.
* Fixes a video playback issue in Media Player Classic.
Existing Support in Release 197 Drivers
* Supports Next Generation ION.
* Supports GeForce GT 320 , GeForce GT 330 , and GeForce GT 340 .
* Upgrades PhysX System Software to version 9.10.0129.
* Upgrades HD Audio driver to version 1.0.9.1 (for supported GPUs).
* Increases performance in several PC games from v196.21 WHQL. The following are examples of measured improvements. Results will vary depending on your GPU and system configuration:
o Up to 13% performance increase in Crysis: Warhead with a single GPU
o Up to 30% performance increase in Crysis: Warhead with SLI technology
o Up to 13% performance increase in H.A.W.X with single GPU
o Up to 15% performance increase in H.A.W.X with SLI technology
o Up to 30% performance increase in Left 4 Dead with single GPU
o Up to 28% performance increase in Left 4 Dead with SLI technology
* Adds SLI and multi-GPU support for top new gaming titles including Assassin Creed II, Battlefield: Bad Company 2, Command and Conquer 4: Tiberium Twilight, Grand Theft Auto IV: Episodes from Liberty City, Mass Effect 2, Napoleon: Total War, and Zombie Driver.
* Enhanced SLI support for Metro 2033, Supreme Commander 2, Unigine, and World of Warcraft.
* Adds Ambient Occlusion support for Call of Juarez: Bound in Blood, Need for Speed: Shift, Resident Evil 5, RUSE, and Street Fighter IV.
* Adds override anti-aliasing support for Mass Effect 2.
* Includes numerous bug fixes. Refer to the release notes on the documentation tab for information about the key bug fixes in this release.
* Users without US English operating systems can select their language and download the International driver here .
Forceware 197.45 Windows 7 | Vista (64-bit) WHQL
Forceware 197.45 Windows 7 | Vista (32-bit) WHQL
Forceware 197.45 Windows XP (32-bit) WHQL
Znači ovi driveri su za sve Nvidijine kartice od 6 pa do 3xx serije. Za GTX4x0 seriju su namijenjeni 197.41 driveri, za koje je već otvorena tema.
Staro 18.04.2010., 16:45   #2
Baja 001
Baja 001's Avatar
Postovi: 7,504
Meni i dalje ne radi ni DXVA niti radi uredno playback.
Staro 19.04.2010., 23:29   #3
snorky_vk
snorky_vk's Avatar
Lokacija: u mraku
Postovi: 854
a meni se događa
i
prva slika je COD4 ,a druga je nakon što izađem iz igre i što god radio točkica koliko hoćeš... os je win7 64bit. nakon restarta sve je "kao" u normali....
Zadnje izmijenjeno od: snorky_vk. 20.04.2010. u 12:10. Razlog: Slike u thumb :-)
snorky_vk je offline   Reply With Quote
Staro 20.04.2010., 00:04   #4
Majo
Lokacija: Zagreb,Dubrava
Postovi: 2,281
Znaci kroz 20 revizija drivera smo trebali dobiti minimalno 200-600% performansi .
Najs .
Majo je offline   Reply With Quote
Staro 20.04.2010., 14:43   #5
mister lola
Postovi: 7
Autor snorky_vk Pregled postova
a meni se događa
i
Događa mi se potpuno ista stvar, s tim da mi se to još događa i na Left 4 Dead 2 i na Call of Duty 5.
mister lola je offline   Reply With Quote
Staro 25.04.2010., 01:06   #6
TheBEaST
TheBEaST's Avatar
Postovi: 666
Jel još netko isprobo ove drivere i kako radi playback u MPC?
Većini ljudi i dalje trza.
Meni se to jedino događa kod avi fajlova, dok sa slider-om premotavam na neko određeno vrijeme. Ako se na output stavi na EVR onda nema problema uopće. Ali zato nema subtitlova onda.
TheBEaST je offline   Reply With Quote
Staro 28.04.2010., 16:18   #7
Pantera-N
Pantera-N's Avatar
Lokacija: In front of the monitor
Postovi: 1,593
Jel ima tko ove drivere? Kak rade?
Pantera-N je offline   Reply With Quote
Staro 29.04.2010., 21:27   #8
CyCl0p$
Autor TheBEaST Pregled postova
znaci nisam jedini koga ovo muci, vec sam pobenavio od drkanja po codecima
Staro 29.04.2010., 22:06   #9
Baja 001
Baja 001's Avatar
Postovi: 7,504
Autor CyCl0p$ Pregled postova
Reinstalirao danas Winse, stavio ove drivere EVR ne radi. Player se cili zdrka.
Niti jedna kombinacija mi ne radi dobro
Stavio VLC dok oni ne poprave to sranje od drivera
Staro 29.04.2010., 22:41   #10
Ivo_Strojnica
PRO
Ivo_Strojnica's Avatar
Postovi: 4,882
Nevjerojatno kako se raspada nVidia. Loši driveri za nove grafičke, loši driveri za stare grafičke.
Staro 29.04.2010., 23:00   #11
Rain Man
Lokacija: x
Postovi: 1,447
Pisalo je negdje da mozda iskljucivanje v-synca pomaze (pritisnuti "V" u MPC-u). Meni daje mjesane rezultate (citaj: ne pomaze). Ako nist drugo, ne smije se koristiti EVR custom za AVi fileove, ili svaki put kad se namjerava prevrtit video, treba pauzirat ili ako pocne zastajkivat onda pauzirat jednom ili 2 put da pocne normalno ici.
Rain Man je offline   Reply With Quote
Staro 30.04.2010., 00:17   #12
Mihael
Mihael's Avatar
Lokacija: Home
Postovi: 2,186
o ljudi dragi, instalirajte si the kmplayer i uživajte.
evo vam i tut za enejblat da vam cuda vrti hd filmove
http://imouto.my/configuring-kmplaye...itecture-cuda/
inace vam ne trebaju nikakvi codeci, the kmplayer ima sve u sebi
Staro 23.05.2010., 11:48   #13
Lewis
Freelancer
Lewis's Avatar
Lokacija: Bilje (Osijek)
Postovi: 5,336
Meni jucer ovi driveri pregrijali GTX260 do te mjere da je ugasila komp . Nisam pratio temperaturu nego sam normalno nesto radio (inace mi je temp u radu nekih 53-54°C) kad odjednom puff ugasi se komp i nesto zasmrdi. Brzo pocupam naponski kabel i otvorim kuciste ka dono graficku nemos dotaknuti koliko je vruca, Nakon 5 minuta sam je uspio izvaditi i ostavio jo pola sata da se ohladi. Sve radi OK ali brijem da ocito jos nisu popravitli problem sa paljenjem/gasnjem ventilatora . Sreca pa ima neku zastitu da se ugasi prije nego se flambira .
Ima li neki nacin da natjeram vent da uvijek radi a ne da ga reguliraju driveri (u normalnom radu mi je na 40%)?
Staro 23.05.2010., 12:44   #14
T0mB1ll
420
T0mB1ll's Avatar
Lokacija: Le Molve
Postovi: 1,577
kod mene na staroj grafi rade normalno.. nikakvih problema...
još je OC na 600/800
T0mB1ll je offline   Reply With Quote
Staro 23.05.2010., 13:02   #15
Lewis
Freelancer
Lewis's Avatar
Postovi: 5,336
Autor T0mB1ll Pregled postova
i kod mene su radili dva tjedna normalno i onda odjednom puff .
