Staro 04.11.2009., 18:53   #1
kill
Datum registracije: Jun 2003
Postovi: 533
USB networking kabel ilitiga bridged USB
za spajanje dva PCa, gdje nabaviti kod nas?
kill je offline   Reply With Quote
Staro 06.11.2009., 23:09   #2
ali_dzi
Lokacija: x
Postovi: 57
Sta ce ti to?
Ja sam nekad davno nabavio (jos u doba Win98) jedan, cini mi se Maxxtro, i to nije lose radilo (brzina prijenosa je bila ok u ono vrijeme, na nivou 10MB lan-a) ali je imalo tako bezvezan file manager program da sam uskoro odustao od koristenja istog. A na zalost (ne znam zasto), samo taj FM se mogao koristiti pri radu - dok ne pokrenes program, dzaba si gurao kabel u PC-e.
USB je (simpaticno) nuzno zlo, pogotovo za transfer podataka. Barem pod Win.
ali_dzi je offline   Reply With Quote
Staro 07.11.2009., 22:00   #3
kill
Postovi: 533
pc-laptop
hm, mogao bih i preko bluetootha složit
Staro 08.11.2009., 00:36   #4
Mortal
Rambus 3xtr1m
Mortal's Avatar
Postovi: 2,694
A nebi preko običnog mrežnog kabla?
Ryzen 7 2700X
Sonic Tower rev.1 (polirani) + 12cm Chieftec
2x 8gb Crucial
B450 Aurus Elite
Segate 500GB Server edition
Silwerstone Strider 560W +12@11.97-11.94V
GTX 1060
Samsung p2770, Hanns G 22' landscape
Samsung pleomax& Microsoft Sidewinder
Kensington Duo Wawe Pad
1. 2xP3 933, Intel OR840 Server, PCI MX440, 4x128Mb Rambus, 80gb segate, SmartBox 400W
2. P4 2.0 wille, Intel i850, 4x128 Rambus, GF2 GTS PRO, 80gb segate, MS 480w
3. P4 1.6 willie@2.0 - Abit th7 II, 4x128Mb Rambus@ 1078mhz, 9000pro, 80gb segate, silwerstone 400w
3 x Prestigio 710, 3 x Microsoft Optical desktop v2.0
i5 530
640gb
1x4gb, 1x2gb ddr3
GT330M
16' wide - white body
Harman Kardon
MX revolution
Online with nokia E70
Battery grip
Beercan: 35-70, 28-85, 35-105, 70-210
Minolta: 28-80, 35-70, 28-100, 35-80, 28-105xi, 75-300
Sigma: 35-70, 28-135, 18-200, 70-300
Sony: 18-70, 55-200
m42: Zenit 135mm, Crestar 135mm, Helios 44m
Mortal je offline   Reply With Quote
Staro 08.11.2009., 01:42   #5
kill
Postovi: 533
nebi koristim ethernet port...i ne, nemam ruter/switch tu.
Staro 08.11.2009., 09:47   #6
Xan
networking wannabe guru
Xan's Avatar
Datum registracije: Sep 2002
Postovi: 1,001
pa jeftinije ti je neki switch kupit za 100 kn, ili čak polovni router nego tražit taj raritet
Quotation from the Bhagavad Gita famously quoted by J. Robert Oppenheimer upon witnessing the detonation of the first atomic bomb.
Also quoted numerous times by overly melodramatic players of Unreal Tournament upon detonation of the Redeemer weapon.
"Now I have become death, the destroyer of worlds who has come to annihilate everyone."
Xan je offline   Reply With Quote
Staro 08.11.2009., 20:10   #7
ali_dzi
Lokacija: x
Postovi: 57
Autor kill Pregled postova
Nisam skuzio, koristis ili ne koristis ethernet port?
Ako imas ethernet port, ne treba ti ni ruter ni switch. Napravi obicni crossover lan kabel (na jednoj strani A, na drugoj B raspored zica) i to uglavnom radi do 15-tak metara duzine s obicnim lan karticama na svakoj masini. Staticke IP adrese na oba PC-a i za razmjenu spremni!
BTW, a firewire ili ti IEEE1394? Bluetooth je poprilicno spor za vece kolicine podataka.
Zna biti na laptopima, a garantiranih 400Mbps nije za baciti, zar ne?
Moram to probati prvom prilikom, tek sad mi je palo na pamet!
Zadnje izmijenjeno od: ali_dzi. 08.11.2009. u 20:37.
Staro 08.11.2009., 21:13   #8
ali_dzi
Lokacija: x
Postovi: 57
Iako je ovo malo off topic, bio sam nestrpljiv da probam tu FireWire vezu i zaista radi. Jaako stari Sony Vaio notebook (Duron@800) sa PCI FireWire karticom u desktopu. Taman mi FireWire kabel stima na oba PC-a (6-4) i za nevjerovat (za Microsoft) sve radi k'o po loju. Staticke IP adrese na oba PC-a i to je to - istog trenutka masine se vide.
Najbolje od ove konekcije mi je to sto svaki FireWire adapter (barem koje sam ja vidio) automatski bude prepoznat od strane XP-a, a sve radi kao i svaka mrezna kartica, dakle TCP/IP. Task manager vidi vezu kao 400mbps, a ja sam kopirao podatke brzinom od cca 6000-6500 kbytes/sec, sto je bilo negdje oko 12-15% od tih 400mbps. U isto vrijeme, LAN 100 mi ide oko 80-90%, sto znaci da je LAN u mom slucaju nesto brzi.
Vrlo lako da su uzrok tome standardizirani, a neoptimizirani M$ driveri, ali sto je tu je - radi bez greske!
Problem je, naravno, ne bas jeftin kabel (nemoguca je samogradnja kao LAN), a i cini mi se da je duzina ogranicena, slicno kao USB.
Staro 09.11.2009., 11:43   #9
kill
Postovi: 533
Hm, istina, imam routera/switcheva viška, pa ću preko njega rješit.
