3.14zda ®
Lokacija: Orahovica
Postovi: 8,320
Celeron D341 256kB 2.93GHz pjeva i dalje...
Neki mozda znaju, a neki i ne pricu o tom cudnom svatu... http://forum.pcekspert.com/showthread.php?t=154848 |
Jack of all, master of none
Lokacija: Matulji - Rijeka
Postovi: 6,214
Joj, kad se tog epic poteza sjetim odmah u smijeh odvalim ![]()
![]() C L O W N I N G ![]() |
3.14zda ®
Lokacija: Orahovica
Postovi: 8,320
Evo danas mi se digao zivac i kao iz p**** ga odvalim na 170MHz FSB na P31-DS3L (multi je 22x sto dovodi do efektivne frekvencije od 3.74GHz) ![]() Rezultat? OCCT govno se ne rusi oko 45 minuta, temperatura pod CF800 ne prlazi 50°C, ja zadovoljan i masem repom, zasad ![]() Code:
Field Value CPU Properties CPU Type Intel Celeron D 341 CPU Alias Prescott-256 CPU Stepping E0 Engineering Sample No CPUID CPU Name Intel(R) Celeron(R) CPU 2.93GHz CPUID Revision 00000F41h CPU Speed CPU Clock 3740.0 MHz (original: 2933 MHz, overclock: 28%) CPU Multiplier 22x CPU FSB 170.0 MHz (original: 133 MHz, overclock: 28%) Memory Bus 340.0 MHz DRAM:FSB Ratio 8:4 CPU Cache L1 Trace Cache 12K Instructions L1 Data Cache 16 KB L2 Cache 256 KB (On-Die, ECC, ATC, Full-Speed) Motherboard Properties Motherboard ID 07/19/2007-P31-ICH7-6A79OG0WC-00 Motherboard Name Gigabyte GA-P31-DS3L (3 PCI, 3 PCI-E x1, 1 PCI-E x16, 4 DDR2 DIMM, Audio, Gigabit LAN) Chipset Properties Motherboard Chipset Intel Bearlake P31 Memory Timings 5-4-4-10 (CL-RCD-RP-RAS) Command Rate (CR) 2T DIMM2: OCZ Gold XTC OCZ2G8001G 1 GB DDR2-800 DDR2 SDRAM (5-5-5-15 @ 400 MHz) (4-5-5-13 @ 333 MHz) (3-4-4-10 @ 266 MHz) DIMM4: OCZ Gold XTC OCZ2G8001G 1 GB DDR2-800 DDR2 SDRAM (5-5-5-15 @ 400 MHz) (4-5-5-13 @ 333 MHz) (3-4-4-10 @ 266 MHz) BIOS Properties System BIOS Date 07/19/07 Video BIOS Date 05/02/08 Award BIOS Type Award Modular BIOS v6.00PG Award BIOS Message Intel P31 BIOS for P31-DS3L F1 DMI BIOS Version F1 Graphics Processor Properties Video Adapter nVIDIA GeForce 9600 GSO GPU Code Name G92GSO (PCI Express 1.0 x16 10DE / 0610, Rev A2) GPU Clock (Geometric Domain) 555 MHz (original: 600 MHz) GPU Clock (Shader Domain) 1350 MHz (original: 1500 MHz) Memory Clock 499 MHz (original: 800 MHz) |
#4 | |
Postovi: 6,214
3.14zda ®
Lokacija: Orahovica
Postovi: 8,320
Najvise mi muka skidati Nirvanu dolje i vaditi plocu van iz kucista jer ima ona 4 brezona usarafljena u plocicu ispod...blah. Mada i CF800 ima isti sistem montaze, lakse je pristupljiv jer nije tower hladnjak. Uglavnom, ja sam odusevljen OC ogucnostima na stock naponu za jedan Prescott based procesor. 800MHz kao iz sale, dobar malac. Sad jel to zbog moje "rucne modifikacije" ili ne, ne znam ![]() |
3.14zda ®
Lokacija: Orahovica
Postovi: 8,320
