Staro 25.06.2009., 10:53   #1
Jelc
Super Moderators
Datum registracije: May 2002
Postovi: 17,485
Matrox announces two new M-Series graphics cards
Still survinin', Matrox has stepped up to reveal its latest creations - the M9138 and M9148 DisplayPort graphics cards. The two low profile cards feature a PCI-Express x16 interface, 1GB of onboard memory, have OpenGL 2.0 support and can handle triple- (M9138) and quad-monitor (M9148) setups, delivering a maximum resolution of 2560x1600 for each display.
"The first generation of Matrox DisplayPort graphics cards bring a tremendous amount of flexibility to today's DisplayPort users," says Samuel Recine, Director of Business Development, Matrox Graphics. "Not only can users choose any combination of pivoted, independent, or stretched displays, but also have the opportunity to combine two M9148 cards in a single system to drive up to eight DisplayPort or DVI monitors
http://www.tcmagazine.com/comments.p...ghlight=matrox
I još malo na temu:
Matrox reveals DisplayPort-supporting DualHead2Go and TripleHead2Go
Matrox is showing DisplayPort some more love as it has developed the DualHead2Go DP Edition and TripleHead2Go DP Edition Graphics eXpansion Modules (GXMs) to enable people to use DP two and three displays, respectively.
The new GXMs both feature one DisplayPort input, have a reduced size and lower power consumption compared to the Analog and Digital models, and are packaged in an environmentally friendly, recyclable box. The DualHead2Go DP is able to deliver up to two 1920 x 1200 outputs, while the TripleHead2Go DP offers 3 x 1680 x 1050 (or also dual 1920 x 1200).
"Matrox is pleased to offer its first external multi-display upgrades to DisplayPort adopters seeking maximum display performance across multiple displays," says Samuel Recine, Director of Business Development, Matrox Graphics. "For example, with the new TripleHead2Go DP Edition, the DisplayPort interface allows users to easily connect three displays to a single notebook to generate a purely digital connection from system to monitors, while enabling resolution support of up to an impressive 1680x1050 per external display."
The DisplayPort Edition Matrox DualHead2Go and TripleHead2Go are said to arrive by the end of this quarter (less that one week to go for that).
Staro 25.06.2009., 11:25   #2
Bambusha
Bambusha's Avatar
Lokacija: Čepin
Postovi: 297
Samo da cijena nebude k'o sa Phareliama u ono doba, i da grafičke čak i rade i bit će dobro.
Sviđa mi se ovo triple i quad monitor setup. (Zbog toga su ih i napravili valjda)
Intel G1610; ASUS B75M-LX Plus; 4096 MB; Intel HD; Hitachi 7K1000.C 500 GB; LG GH24NS95; Silverstone Strider Essential 400 W; Logitech K200; Logitech B110; Logitech X-240 2.1; Philips 200V4LAB 20" DVI; Windows 7 64-bit Professional
Bambusha je offline   Reply With Quote
Staro 25.06.2009., 16:25   #3
Visage
8-bit Gen.
Visage's Avatar
Lokacija: Giethoorn - ZG
Postovi: 3,132
Matrox Epizoda: Fantomsko Svjetlucanje u ulici Brijestova
Autor Jelc Pregled postova
... staro vec 2 tjedna i tocno tjedan dana mi stoji otvorena tema u TAB-u da je spomenem na forumu. Ne sjecam se kad sam zadnji put imao ovakvu hardversku nemoc u realizaciji kontakta!
Jos jedan u nizu novih proizvoda. Samo sve ce biti jako upitno. Vec 2-3 mjeseca ni EU ni sama centrala ne dize telefone. Nakon velebne podrske (gdje su nestali postovi ispod mene?) pa ukidanja najboljeg support foruma na svijetu. Pa do uzasne kretenske web podrske preko 10 forumulara dok se dokopas neke zive osobe
Ima 2-3 mjeseca kako svako malo nazovem EU ili centralu i nonstop ista poruka. Identicna poruka CA/EU/US; identicni zenski glas koji je bio samo u Kanadiji i nigdje drugdje. Upisem blesavi product ID pa cekam na dva kontinenta i jednostavno nakon silnih robota, centrala jednostavno odfuka u mrak tisine. Da stvar bude gora, Matrox je privatna kompanije i nije duzna javno iznostiti podatke o poslovanju. Pa je tako jos zatvorenija u ovakvim fantomskim epizodama.
Veliki ili privatni zakukuljeni sektori poput ovog, postaju nepodnosljivi za izravnu komunikaciju. Posebno kad pocinju prikrivati bananu. Ni portira dobiti ne mogu. Hladno sterilno preko robota/telefona i ne vodi nigdje. Na mail tocno 3 mjeseca ne respondiraju a nikad nije proslo vise od 2 dana (odkad nema foruma) da se glavni George iz podrske nije odazvao. Uz ovo ljigavo ponasanje, posebno je sr#~!e kad uredno nastavljaju svim reganim korisnicima slati dojave o novim (?) proizvodima! Na Net-u nigdje ni jednog foruma koji uopce ima neko pracenja Matroxa. K. takodjer sve pretrazio i nista mi nije znao reci vise od ovoga sto i sam znam = koma. Naci nekoga i zamoliti da fizicki ode do tih nesretnika.
Jedno pitanje i molba kad je vec otvorena nova Matrox tema
1) Koji je najveci IT test izvor na webu za testiranje kartica? Mislim iskljucivo u smislu velicine, ugleda i broju sponzora koji ga pokrivaju? Dakle koji je trenutno The Site za sve gamere i opcenito prvi izvor za testiranje kartica? Mislim da ce mi biti od koristi, jer kladim se da uopce i ne znaju za ovu trenutnu Matrox ingoranciju.
2) Svi koji ovo citaju, zamolio bih da kliknu ovdje i samo pastiraju ovaj tekst :
Respected Matrox,
It is most intriguing how you present your latest M9138 and M9148 products, while for months you offer not even a glimpse of product support to any of your products? Tried and true with both EU and Canadian support office. Perhaps both support and those new products of yours are being offered in some parallel dimension? If so, could you please point us how to obtain proper communication with such sphere? If by any chance, some living entity, preferably humanoid still resides within Matrox headquarters... could you kindly communicate such abilities to your handful of loyal customers who are still crazy to entertain the very idea of purchasing your latest M range - while served with zero respect/support at the same time!
Sincerely yours (in misery) in Matrox,
Jack T. Colton
Volio bih da prime sa sto vise adresa ovo pitanje. Bez brige, Matrox ne salje Spam a ionako mozete ostaviti neku beznacajnu adresu koja vam nije glavna. Hvala
____________________________
>>> PCE kolegijalna molba <<<
>>>> PCE kante 2012 <<
>>>>>>>>> PCE & ostalo <<<<<
>>>>>>> Što sam Slušao? <<<<<<
>>>>> Gimnastika za Okulare & LCD Addendum<<<<
>>>>> P o s t ... M j e s e c a <<<<
______________________________
Zadnje izmijenjeno od: Visage. 25.06.2009. u 16:50. Razlog: besan ka ris
Staro 26.06.2009., 18:03   #4
newalss
Raindrops keep fallin'...
newalss's Avatar
Lokacija: Đakovo
Postovi: 826
Autor Visage Pregled postova
Respected Matrox,
Jack T. Colton
Kako te nije stid ovako blatiti ljude, još i ja ispadnem kriv, a sve zbog tvog nepoznavanja zemljopisa. Kako se Irske nisi sjetio? Svašta...
Evo uredno odgovaraju...
Dear Mr. Pavenso or are you Mr. Balic or Mr. Garic?
wow, you must either have a very big family or many different email addresses! This is the third time I receive exactly the same email! Please find my earlier anserws below.
Strange enough to receive exactly the same request twice. So please take a look at the email I wrote to you or your twin before.
Dear Mr. Balic,
Thanks for your email but I have checked my archive and apparently the German office has never received any info from you.
However, Matrox is an Canadian Company with subsidiaries for sales in UK, Germany, Asia and America. Logistics is settled in Ireland. Technical Support is exclusively provided by Headquarter (graph_TS@matrox.com) We always try to offer the best service possible to our customers in each territory.
So if you need any information on our products (no Tech Support) please feel free to contact me and I shall be happy to help you. For Tech Support issues, please contact above mentioned email.
Hope this helps.
Kind regards,
Kerstin Paulus
Pepel u ruke i udri s posipanjem.
"I told my parents that when I grew up I wanted to be a musician.They said it had to be one or the other"
newalss je offline   Reply With Quote
Staro 26.06.2009., 20:15   #5
Visage
8-bit Gen.
Visage's Avatar
Postovi: 3,132
Autor newalss Pregled postova
Hehehe
Kao prvo hvala ti sto si bio dobre volje baciti svoj pozdrav Matroxu Newalss. Razumljivo da si tako dozivio te refleksne EU poruke jer nisi u toku sto sam sve preduzimao. Sto po mailu sto po pozivima, ovaj forumski dio je taman dosao kao biser na kraju jer sam nekoliko sati po postanju, vec uspio dobiti glavonju iz centrale. Nakon 20 minuta pomoci medjunarodne sluzbe pa onda listanja njihovih brojeva... uspio sam na malu prevaru doci konacno do zivih ljudi. Ova prica koju svima salju na mail (sokirani i zacudjeni) je samo refleksija onoga sto je pokrenuto nakon tog razgovora, ali i hrpe poruka sto od mene sto od drugih njihovim glavnim akterima. Ipak su ih pokrenule ove poruke pa su prvo digli EU i inu ekipu na budjenje. No oni su nazalost tek repetirori same centrale. A sama centrala je vec 3 mjeseca do daske bila mrtva komunikacijom. Jucer mi je glavna žena Matrox UK-a (nakon razgovora sa centralom) priznala da nije imala pojma koliko je ljudi otislo iz podrske nakon sto je na moje inzistiranje provjerila nekoliko imena, ukljucujuci Georga koji je bio jedan zadnjih "starih" meštrova. EU ekipa je mahom u igri za distribuciju i promo stvari. A nama su trebale same glavonje.
Kao sto vidis na dnu svog maila (Managing Director) prepoznajes vrlo HR prezime, zar ne? Upravo prezime jednog od glavnog osnivaca Matroxa. On se sigurno ne bavi beznacajnim mailovima. Nitko ne voli losu reklamu i gomila poruka je ipak doprla do glava u centrali. To mi je bila i namjera. Kao bonus, dobio sam usmeno obecanje da cu od sad dobiti uvijek direktan odgovor direktno na mail i bez glupih probijanja kroz web formulare.
Nekoliko glasova ipak moze pokrenuti promjene. Izuzetno mi je drago da to mogu posvjedociti u ovoj Matrox epizodi. Jos da ih se samo nekako ponovo nagovori na stari forum Zahvaljujem svima koji su bili ljubazni pomoci i vise nije potrebno dalje slati.
Hvala
>>>> PCE kante 2012 <<
>>>>>>>>> PCE & ostalo <<<<<
Zadnje izmijenjeno od: Visage. 26.06.2009. u 20:35. Razlog: ... covjece pazi da ne ides malen ispod...
