Staro 23.05.2009., 00:26   #1
estugarda
"Samo vodu ne!"
estugarda's Avatar
Lokacija: ZG istok > Legrad
Postovi: 1,741
Gdje kupiti produžni VGA kabel?
Trebam 2 produžna VGA kabela dužine min. 5m. Jedino što sam pronašao je u Vemilu 5m za 11kn/kom, ali nije raspoloživo. Našao sam još samo u Chipoteci, ali tamo ista stvar košta 90kn/kom, čini mi se. Ne želim tolerirati 9X razlike u cijeni, pa me zanima; zna li netko gdje se još može kupiti!?
Hvala...
It just works. Except when it doesn't.
CPU: AMD Ryzen9 7950X3D @ stock + AC Liquid Freezer II 360
MBO: Asus ProArt X670E-Creator WiFi
RAM: 4x32GB DDR5 G.Skill Trident Z5 Neo 6000
GPU1: NVIDIA GeForce RTX 4090 MSI Suprim Liquid X
GPU2: NVIDIA RTX A4000 custom cooled
SSD1: Samsung 990 PRO 2TB m.2 NVMe
SSD2: Samsung 970 EVO 4TB
PSU: Seasonic Prime GX-1300
CASE: Fractal Design Meshify 2 XL
Display: Asus Proart PA329CRV + 2x Dell 2715h
Audio: Asus Xonar U7 MK2 + Logitech X-530 5.1
Input: Ducky One 3 Classic RGB + Logitech MX Master 3
OS: Windows 11 Pro x64
HP Zbook 17 G6
CPU: i7-9850H @ 2.60GHz
RAM: 4x16GB DDR4 2400
GPU: NVIDIA Quadro RTX 4000
SSD: 512GB NVME SSD
Audio: Fiio Q1 DAC + AudioTechnica M50x
OS: Windows 10 Pro x64
CPU: AMD Ryzen Threadripper 2950X @ stock + Noctua NH-U12S
MBO: Gigabyte X399 Aorus Pro
RAM: 4x16GB DDR4 Corsair Vengance LPX 3200
GPU: NVIDIA GeForce RTX 1080 Ti 11GB
SSD: Samsung Evo Plus 500 m.2 NVMe
HDD: Toshiba 3TB
PSU: Corsair CX650M
CASE: Fractal Design Meshify C
Display: LG IPS231P
Audio: OnBoard + display speakers
Input: Microsoft Natural Keyboard + Logitech G602
CPU: AMD Ryzen 4350G @2.8GHz + AMD stock cooler
MBO: ASrock B550m Phantom Gaming
RAM: GSkill 2x8GB DDR4 3600MHz
GPU: AMD Vega 6
SSD: Samsung Evo Plus M.2 NVME 250GB
PSU: Seasonic 620W
CASE: Fractal Core 2300
Display: 32" LCD TV + BENQ W1070 DLP projector
Sound: Yamaha RX481 + ELAC Cinema 5.1
Input: Logitech vulgaris
CPU: AMD Athlon X2 5050e @0.8-2.6GHz + AC Freezer 64 Pro PWM
MBO: Gigabyte GA-M720-US3
RAM: Kingmax 2x2GB DDR2 800MHz
GPU: Gigabyte GeForce 8600 GTS SP
HDD: Seagate 7200.10 250GB single platter (Speedy Gonzales)
PSU: Chieftec 400W
CASE: Frontier generic
Display: 22" LCD AOC 2230Hf + ACER X1160 DLP projector
Sound: Logitech S-220 2.1
OS: Windows 8.1 PRO x64
2017: FX-8370E, ASRock 990FX Extreme3, nVidia GTX970, Windows 10 x64
2016: FX-8320E, Asus M5A97 PRO, nVidia GTX970, Windows 10 x64
2015: i7 6700k, Asus Z170-A, nVidia 750Ti 4GB, Windows 7 x64
2014: FX-8350, ASRock 990FX Extreme3, nVidia GTX660, Windows 8.1 x64
2012: i7 3610QM, Asus N76VZ, nVidia GT650M, Windows 7 x64
2011: AMD Athlon II X4 640, Gigabyte MA770-UD3, nVidia 9600GS, Windows 7 x64
2010: AMD Phenom II X6 1090T, Thuban, ASrock 880G Extreme3, nVidia GTX260, Windows 7 x64
2010: AMD Phenom II X4 Deneb 945, Gigabyte 790X-DS4, nVidia 8800GTS Ultra 320bit, Windows 7 x64
2009: Intel C2Q Q6600, GIGABYTE EP31, nVidia 8600GS, Windows 7 x64
2008: AMD Athlon X2 Winsdor 5600+ AM2, MSI K9N Neo V3, Gigabyte 790x, nVidia 8600GS, Windows Vista x64
2008: Intel Core2Duo T7200, Toshiba A100-847, nVidia 7600 Go, Windows Vista x64
2007: AMD Athlon X2 4600+ Manchester S939, ASUS A8n32-SLI Deluxe, nVidia 7600GT, Windows Vista x64
2005: AMD Athlon 64 3200+ Venice S939, Asus A8V Deluxe, ATI Radeon X700 PRO, Windows XP x64
2003: AMD Athlon XP 2400+ Thoroughbred, Matsonic MS8137C, Matrox G450, Windows XP
2003: Intel Pentium III Mobile 1000 Tualatin, Compaq Evo N110, ATI RAGE LT Pro, Windows 2000
2002: AMD Duron 1200, Matsonic MS8127C, Matrox G450, Windows XP
2001: AMD Duron 750, Matsonic MS8127C, Matrox G400 DH, SB PCI 128, Windows98,
1998: Intel Pentium II 300 Klamath, Matrox G200, SB AWE64, Windows98
1996: Intel Pentium 120, Matrox Millenium, SB AWE32, Windows95
1993: Intel i386SXSA 40MHz(turbo)
1991: Intel 286 @20Mhz
estugarda je offline   Reply With Quote
Staro 23.05.2009., 00:33   #2
pipe
Bill Gates
pipe's Avatar
Lokacija: Vukovar
Postovi: 1,983
Autor estugarda Pregled postova
Hvala...
Hm, nabava mi ne izbacuje nista ispod 80 kn. Mozes eventualno spojiti dva od 3m i to je to.
I ja imam na ploci.
Staro 23.05.2009., 00:46   #3
estugarda
"Samo vodu ne!"
estugarda's Avatar
Postovi: 1,741
Sad sam malo googlao "DVI kabel". Na kraju Chipoteka ispada najjeftinija s obzirom da ovih u vemilu nema.
A jel ima kakav negativan efekt to serijsko spajanje kablova?
HP Zbook 17 G6
SSD: 512GB NVME SSD
HDD: Toshiba 3TB
PSU: Corsair CX650M
Display: LG IPS231P
GPU: AMD Vega 6
PSU: Seasonic 620W
PSU: Chieftec 400W
Staro 23.05.2009., 01:42   #4
Old Iggy
Old Iggy's Avatar
Postovi: 4,888
Hvala...
Ima po IT trgovinama, no samo digresija... 90 kn je jeftino, 11 kn je teska greska.
Igor Batinic
Staro 23.05.2009., 08:49   #5
Visage
8-bit Gen.
Visage's Avatar
Lokacija: Giethoorn - ZG
Postovi: 3,138
Trebam 2 produžna VGA kabela dužine min. 5m. Jedino što sam pronašao je u Vemilu 5m za 11kn/kom, ali nije raspoloživo. Našao sam još samo u Chipoteci, ali tamo ista stvar košta 90kn/kom, čini mi se. Ne želim tolerirati 9X razlike u cijeni, pa me zanima; zna li netko gdje se još može kupiti!? Hvala...
Ima ih Verica i stvarno su 11 k. Samo imaj na umu da takvi nisu dorasli nekom kvalitetnijem radu. Meni taj kabel sluzi za udaljiti mali LCD prilicno daleko od m0n0walla. Za crno-bijeli prikaz adekvatno. Ali za neki bolji prikaz (boje) fokusa, ostrine = za plakati. Provjeri kakva je kvaliteta kabla u Chipoteci no nisam siguran da ce i taj briljirati.
>>>> PCE kante 2012 <<
>>>>>>>>> PCE & ostalo <<<<<
>>>>>>> Što sam Slušao? <<<<<<
>>>>> Gimnastika za Okulare & LCD Addendum<<<<
>>>>> P o s t ... M j e s e c a <<<<
______________________________
Zadnje izmijenjeno od: Visage. 23.05.2009. u 09:09. Razlog: ... odoliti zubu vremena moze samo....
Staro 23.05.2009., 09:13   #6
estugarda
"Samo vodu ne!"
estugarda's Avatar
Postovi: 1,741
Autor Visage Pregled postova
...Ali za neki bolji prikaz (boje) fokusa, ostrine = za plakati...
Stvarno!?
Meni produzni treba za LCD projektore. Dakle dobra slika mi je važna. Nisam nikada imao loš VGA kabel. Ovi koji su dolazili sa monitorima uvijek su zadovoljavali. I nisam nikada primjetio razliku. A koji su to dobri VGA kablovi?
HP Zbook 17 G6
SSD: 512GB NVME SSD
HDD: Toshiba 3TB
PSU: Corsair CX650M
Display: LG IPS231P
GPU: AMD Vega 6
PSU: Seasonic 620W
PSU: Chieftec 400W
Staro 23.05.2009., 09:38   #7
Visage
8-bit Gen.
Visage's Avatar
Postovi: 3,138
Stvarno!? Meni produzni treba za LCD projektore. Dakle dobra slika mi je važna. Nisam nikada imao loš VGA kabel. Ovi koji su dolazili sa monitorima uvijek su zadovoljavali. I nisam nikada primjetio razliku. A koji su to dobri VGA kablovi?
Nisam vidio kako izgleda taj u Chipoteci, ali ovaj od Verice je neoklopljena sirotinja. Taj kabel vise slici nekom mreznom ili u najboljem slucaju USB kablichu. Kvaliteta ozicenja je dodatni upitnik. Od ovih igraca sam uzimao zadnja 2 BNC seta, jer su pravi BNC a ne laznjaci koji signalno izlaze na 20 cm.
Oni imaju kvalitetne produzne sa kojima sigurno neces imati manjkavosti.
Staro 23.05.2009., 09:47   #8
Burko
Osobni opis - pitaj me
Burko's Avatar
Postovi: 2,317
ja sam napravio produzni koji radi 5/5. uzeo sa jednog monitora kabel, srezao ga, i nalemio ostatak od nekog drugog gdje je bio muski kraj.
uglavnom, radi savrseno na CRT-u.
Staro 23.05.2009., 09:53   #9
estugarda
"Samo vodu ne!"
estugarda's Avatar
Postovi: 1,741
Hvala.
HP Zbook 17 G6
SSD: 512GB NVME SSD
HDD: Toshiba 3TB
PSU: Corsair CX650M
Display: LG IPS231P
GPU: AMD Vega 6
PSU: Seasonic 620W
PSU: Chieftec 400W
Staro 23.05.2009., 10:01   #10
Visage
8-bit Gen.
Visage's Avatar
Postovi: 3,138
Autor Burko Pregled postova
ja sam napravio produzni koji radi 5/5. uzeo sa jednog monitora kabel, srezao ga, i nalemio ostatak od nekog drugog gdje je bio muski kraj. uglavnom, radi savrseno na CRT-u.
Ha dobro. To moze proc jer vecina boljih VGA kablova su dostatne kvalitete. No prave razlike se pocinju uocavati na velikim rezama. Onda vidis koji je zbilja dobar a koji je tek prolazan. Uzeo sam 4 kvalitetna kabla i gledao (VGA ulaz) 1920x1200 i 2304x1440 na Sony-u. 2 su bila odlicna, dok je 3 i 4-ti pokazao neke sitne manjkavosti. Isti kablovi su bili odlicni na 19/21" monitorima ali cim reza ide gore, prokaze se razlika
Druga stvar, Estugarda je poznat u kvartu kao veliki esteta i sumjam da ce mu uz nove Pop Art tapete pasati kablovi sa velikom grbom
Staro 23.05.2009., 11:21   #11
estugarda
"Samo vodu ne!"
estugarda's Avatar
Postovi: 1,741
Upravo sam zvao Vemil. Nemaju, kao sto i pise na webu. Pokusat cu sa Chipotekom...
Kod mene Pop Art, a kod Visage-a:
...zapravo kao s avatara, samo iz drugog kuta fotkano...
HP Zbook 17 G6
SSD: 512GB NVME SSD
HDD: Toshiba 3TB
PSU: Corsair CX650M
Display: LG IPS231P
GPU: AMD Vega 6
PSU: Seasonic 620W
PSU: Chieftec 400W
Staro 23.05.2009., 15:30   #12
Burko
Burko's Avatar
Postovi: 2,317
a ok za vece reze, tu nisam pokusavao jer nisam imao potrebe. meni je jednostavno trebao produzni za 17" crt. i nakon sto sam potrosio neko vrijeme da ulovim kabel, rekoh, idem ga probat napravit. vec duze vrijeme radi bez ikakvog problema .
mene to ne dira, cak i sa uzitkom volim napraviti nesto sto barem jednako radi kao "original".
Staro 03.06.2009., 14:16   #13
babac
Postovi: 65
dakle, preporuka vga-vga kabel duzine 3 metra.
trebam oba muška da spojim laptop i lcd tv.
gdje i koji a da je kvalitetan? hvala
babac je offline   Reply With Quote
Staro 03.06.2009., 20:00   #14
Visage
8-bit Gen.
Visage's Avatar
Postovi: 3,138
Upravo sam zvao Vemil. Nemaju, kao sto i pise na webu. Pokusat cu sa Chipotekom... Kod mene Pop Art, a kod Visage-a: ...zapravo kao s avatara, samo iz drugog kuta fotkano...
Ajme, zaboravio sam na ovo odgovoriti. Nije lose
Samo maknuti onu groznu dekadno promasenu vitrinu + naturu sa stola i moze proci pod populi-kitsch pred kraj 50-ih.
Staro 25.06.2009., 00:13   #15
Visage
8-bit Gen.
Visage's Avatar
Postovi: 3,138
Sjetih se da sam neki dan uzeo bas iz Chipoteke dva takva
VGA kablicha i da se cine vise nego pristojni :
Staro 01.07.2009., 14:32   #16
Mr. Nice
Mr. Nice's Avatar
Datum registracije: Sep 2004
Postovi: 357
M+S
OK
Tamo sam kupio preko nekoliko VGA kabela od 10 m za projektore i svi rade OK. Kablovi su s feritom. Nisam uspoređivao posebno cijene s drugim dučanima za kabel, ali dosta toga što sam kupovao kod njih je bilo jeftinije od drugih dučana, a imaju kvalitetne stvari. Dučan na prvi pogled ne uljeva povjerenje, ali to nije bitno.
Mr. Nice je offline   Reply With Quote
Staro 02.07.2009., 17:47   #17
yedwy
Beskorisna bitanga...
yedwy's Avatar
Lokacija: Sesvete (Zg)
Postovi: 6,956
U m+s u sam i ja kupovao nekoliko puta, dobra iskustva imam s robom od tamo...
Have a nice day...
Staro 02.09.2015., 08:24   #18
darkydark
N0teb00k n00b
darkydark's Avatar
Lokacija: Zagreb/Koprivnica
Postovi: 2,102
Intel widi ili neki slican derivat wireless screen sharinga. Ja koriatim belkin screen cast sa intel widi aplikacijom na win7. Ono kratko kaj sam win 10 imao koristio sam built in pidrsku za spajanje na wireless display.
1TB A2000, 2TB KC3000
Linđa
Truenas Scale
