Super Moderators
Datum registracije: May 2002
Postovi: 17,485
Catalyst 9.4
Tema o beti je slučajno završila u smeću, zato nova ![]() http://game.amd.com/us-en/drivers_catalyst.aspx ATI Catalyst™ 9.4 - New ATI OverDrive™ auto-tuning application* ATI Catalyst 9.4 includes a new ATI Overdrive™ auto-tune application to accurately determine the best over-clocked engine and memory values for ATI Overdrive supported ATI Radeon™ Graphics accelerators Designed for the ATI Radeon™ HD 4000 Series * AMD’s product warranty does not cover damages caused by over clocking, even when enabled via AMD OverDrive software Resolved Issues for the Windows Vista Operating System This section provides information on resolved issues in this release of the ATI Catalyst™ Software Suite for Windows Vista. These include: "World of Warcraft" or "World of Warcraft - Wrath of the Lich King": Flickering no longer occurs when Shadow is set to medium/high using CrossFire Google Sketchup no longer displays blank screen Resolutions above 10 x 7 will now full screen properly for specific HDMI displays Artifacts no longer visible while playing Age of Conan DX10 VC-1 progressive disc playback no longer exhibits block corruption Resolved Issues for the Windows XP Operating System This section provides information on resolved issues in this release of the ATI Catalyst™ Software Suite for Windows XP. These include: The Compute Abstraction Layer (CAL) driver now functions properly under Windows XP Overlay Theatre Mode display no longer corrupt after enabling 3D screen saver OS Display Settings no longer shows extra resolutions for Component Video Resolved Issues for the Windows 7 Operating System This section provides information on resolved issues in this release of the ATI Catalyst™ Software Suite for Windows 7. These include: City of Villains: Display now redraws correctly after changing graphics settings Catalyst Control Center: 1080i@30hz and 1080i@25hz Component Video modes can now be applied via Component Video - Advanced aspect Custom formats modes can now be applied properly and will be available under "List All Modes" Display profiles will now be restored when displays are swapped while the system sleeps WinDVD9 HD playback doesn't cause the desktop to jitter or flicker anymore Device Manager no longer displays error during express driver uninstall
Bill Gates
Lokacija: Vukovar
Postovi: 1,983
AAAAAaaaa. Bas sam prekjucer instalirao 9.3. ![]() Ima li kakvih vecih promjena ili ne? |
Flaccitra
Lokacija: Vinkovci
Postovi: 276
#10 | |
Postovi: 512
@BeroVK - nije "ko fol" nego ne podržava Imam istu kartušu, i zadnje kaj možeš trenutno stavit na nju su 9.3. Vjerojatno će izletit kakav modani driver baziran na 9.4, al treba se strpit.. 9.7 će opet podržavat X1xxx seriju.. pa opet jedan kvartal ništa, to je nova politikaCitiraj:
Intel Core 2 Duo E4400 @ 320x10 (3200MHz) w/ Scythe Ninja rev.B + 120mm fan | Gigabyte GA-P35-DS3R (Intel P35 + ICH9R) | 4x 1GB Kingmax MARS DDR2 800 CL5 | Sapphire ATi Radeon HD4890 | Seagate 7200.11 250GB+2x WD Black 640GB+Samsung F3 1TB; svi SATA/7200rpm | LG GH20NS15 SuperMulti, SATA | LG W2361V-PF 23", 1920x1080, DVI+HDMI | Aplus CS-188AF case w/ 250mm side fan | onboard 7.1, with Logitech X-540 5.1 speakers | Chieftec 450W /w 120mm fan | Windows 7 64bit Enterprise |
Postovi: 278
instalirao sam ih na Visti x64 i rade bez greške..Igre nisam isprobavao,ali sam pokrenuo 3D Mark SM2 test Firefly Forest i sa 9.3 sam imao 46.266fps a sa 9.4 46.759fps-a a valjda idu na bolje bumo rekli.... |
Postovi: 469
ja sam instalirao na Visti 32bit-a i driver je 8.600, sve radi ok s tim da sam setup za catalyst skinuo sa Techpowerup stranice, instalacija sa sluzbene ATI stranice mi je isto pokazivala 8.591 driver i cataliyst 9.3 s tim da sam skinuo 9.4 verziju, barem je tako bilo navedeno u nazivu setupa i na sluzbenoj stranici |
Lokacija: Petrinja
Postovi: 904
Dobio par fps-a u crysisu na dx10, vista 32 bit te nepada ispod 30 fps-a (sve very high osim object quality i shadows), u odnosu na 9.2 drivere. Nikakvih errora nije bilo kao ni inače, u ccc-u pokazuje da je verzija 8.60, te gpu-z potvrđuje da su 9.4 driveri. @Orgazmatron - probaj uključit vertycal syncronization iliti vsync.
#16 |
Postovi: 139
Ukljucen je... Ali sada mi catalyst ne radi,kada ga pokrenem nista se ne desava... Framework sam nanovo stavio i isto... (xp,sada je 3.5 gore) --- edit: stavio xtreme-g 9.2 i vojla,pes PES ne steka,CCC radi! ovo je smijesno... Zadnje izmijenjeno od: Orgazmatron. 10.04.2009. u 14:31. |
#17 | |
Lokacija: Petrinja
Postovi: 904
Nikad nisam mislio da ću imat "problema" zbog viška fps-a!
#20 |
Lokacija: Petrinja
Postovi: 904
#21 |
Postovi: 565
jesam i niš nije pomoglo očito je do win7(Build 7000) grrr ![]() p.s do sada nikad nisam imo problema sad win7 čak su radili i 64bit wista driveri niš budem pogledal jel funkcionira na visti64 Zadnje izmijenjeno od: Minox. 10.04.2009. u 19:28. |
#22 | |
Lokacija: Petrinja
Postovi: 904
A šta ti očekuješ od beta OS-a? Skini build 7105 ili kak već..
#23 |
Postovi: 512
Ovak, za one na Win7, a možda je slično i na Visti 64bit Ak vam instalacija prođe, a i dalje piše da su stari Catalyst-i u CCC, onda fino ovak: - raspakirajte drivere u neki folder - odite na device manager, kliknite na karticu, desni klik, update driver - pokažite mu na folder sa raspakiranim driverima - on izinstalira, restart (za svaki slučaj) - trebalo bi sad pokazivat i radit ispravno.. Ima neki bug, više ljudi na techpowerup i guru3d je spominjalo da im u Win7 "preskoči" instalaciju. Kao prođe, ali prebrzo, i driver ostane stari. Probajte, javite!
#24 | |
Lokacija: Petrinja
Postovi: 904
Uglavnom sve piše successful, ali kod display drivera piše error. Probao sam samo display drivere instalirat i nije htjelo.
#25 |
Postovi: 2,883
9.4 u Warhammeru DOW2 malo malo inicira VPU recovery a 9.3 u mjesec dana koliko igram niti jednom
#26 |
Datum registracije: Aug 2008
Lokacija: karlovac
Postovi: 111
Ja bi zamolio netkoga tko ima Catalyst 9.3 drivere za windows 7 za ati 3870 da mi ih stavi na rapid jer ne mogu nikako dobiti Catalyst 9.4 da mi rade uopće ne mogu upaliti ccc niti u samom screen resolution dobiti extendet desktop iako mi pod vistim i xp radi ovdje odaberem extended stavim apply i vrati mi na show on 1. display. Evo link koji potvrđuje probleme sa friško instaliranim Catalyst 9.4 http://forums.amd.com/game/messagevi...&enterthread=y ja uopće ne mogu otvoriti ccc. Hvala unaprijed. |
#27 | |
Flaccitra
Lokacija: Vinkovci
Postovi: 276
izvolte http://downloads.guru3d.com/Videocar...%7C64_c31.html
#28 | |
Lokacija: karlovac
Postovi: 111
#29 |
Lokacija: 50km od Zg
Postovi: 87
Evo instalirao 9.4 na vistu x64 i neće otvorit CCC.. |
