Staro 22.03.2009., 20:51   #1
dj_dannijel
love is back
dj_dannijel's Avatar
Postovi: 270
Webcam Logi3500E + MSN problem
Naime ljudi...
Ovako... problem je velike prirode... neznam dal je softwerski ili hardverski pa sam ga stavio u hardverski:-D(oprostite)
naime...
Kamera radi, offline, 2 put reinstairani driveri jer sam mislil da je u njima greška..
Čim se pokrene videopoziv u najnovijoj msn aplikaciji(stare nisam probal) osoba koju pozovem izbaci iz msn jer joj zašteka msn, kod međusobnog povezivanja(znači i drugi ima kameru) me baca van i njega također...
greška se počela pojavljivat nakon što mi je prijatelj u Comand Promptu isključil ISC jer je to trebalo napravit po njemu da radi internet na mobitelu preko bluetootha, i nije radilo:-D napravil je ovaj tutorijal;-)
Code:
    Setup instructions
  1. Disable ICS if you have enabled it for some reasons. You won't be able to enable it until you deactivate this sharing method.
  2. Open a command prompt and issue netsh routing ip nat install If you get an error here, do not proceed until you resolve it.
  3. Issue the following command: netsh routing ip show interface In the result, look for two lines:
    1. Look for the connection which is your connection towards the Internet. Note the exact name. In my case this is "Local Area Connection".
    2. Look for the connection named 'Internal' in the language of your windows. Note the exact name. In my case this is "Internal".
  4. Issue netsh routing ip nat add interface EXTERNAL full Substitute the name you got in point 3.1 instead of EXTERNAL. Add the " if there are spaces. So in my case this will sound: netsh routing ip nat add interface " Local Area Connection" full
  5. Issue netsh routing ip nat add interface INTERNAL private Substitute the name you got in point 3.2 instead of INTERNAL. Add the " if there are spaces. So in my case this will sound: netsh routing ip nat add interface " Internal " private In case of an english windows, this will sound: netsh routing ip nat add interface Internal private
  6. You are probably okay now if the above commands worked without error.
  7. It might be necessary to set the DNS addresses manually in the phone. If the connection does not work and you get 'Error No DNS server specified' in NetFront, 'no gateway reply!' in the internal Web app, or 'Could not locate remote server' error in Opera
e sad... sad kako ovovratit na početne postavke... neki reset il neki šrot...
btw možda nije do toga...
Naime možda treba msn imat otvoren port ili tak neke???:-D
EDIT: e i da... naime kad imam full upload znači 40kb/sec download mi je 0, 00 i neče više zbog tog mi vjerojatno ne radi web poziv, ili ako je download full onda mi ne radi upload:-S
Zbog čega bi to bilo
Ovo je sad full softwerski problem pa bi bio zahvalan da se tema premjesti ...
pomozite molim vas;-)
HVALA
ukoliko nešto nije razumnjivo postajte dolje pa ču ja objasnit ukoliko budem znao...
a admini i moderi mošte premjestit ovu temu ak ju smatrate softwerskom;-)
amen i hvala unaprijed
Bez reklama i linkova u sigu :-)
dj_dannijel je offline   Reply With Quote
Staro 24.03.2009., 20:51   #2
thopok
Lokacija: Splity
Postovi: 3,003
Staro 24.03.2009., 20:55   #3
dj_dannijel
love is back
Postovi: 270
a da malo objasniš:-D ajd čitat ču....
EDIT: da to je problem
kak da uključim taj UPnP na NATu??
EDIT:
SLOŽENOOOOOOOOO
hvala thopok
Dalje sam Googlal i našo kak uključit UPnP i Nat i sve radi...
HVALA...
EDIT:
e ljudi i dalje neradi... uključil sam to UPnP i ništa:-S
btw kak uključit UPnP???(da vidim dal sam na dobar način;-))
Zadnje izmijenjeno od: domy_os. 29.03.2009. u 17:04.
Staro 26.03.2009., 12:53   #4
Hrvoje xyz
lepi
Postovi: 923
ja imam slicnih problema sa slicnom webcamerom , mislim da je 3000 naziv modela . Na msnu radi vrlo bugovito kad su s obje strane ukljucene kamere dakle klasnicni video call.
rjesenje?
bez zeza ali this works
mozes cackat po opcijama dva dana , a NHF kolko vidim nisi nesto bas ni vican tome da bi nesto i nasao , tak da ti je ovo optimalno rjesenje.
Hrvoje xyz je offline   Reply With Quote
Staro 26.03.2009., 13:54   #5
dj_dannijel
love is back
Postovi: 270
Autor Hrvoje xyz Pregled postova
rjesenje?
imam to i ne radi... probo več 10 istih programa i svi na isti način;-) radi 5 sec i onda moja strana zacvika ostalo vidim;-) BTW radilo je perfektno;-) i sad poslije ovog icsa neradi;-)
Staro 26.03.2009., 14:51   #6
thopok
Lokacija: Splity
Postovi: 3,003
Staro 29.03.2009., 17:05   #7
domy_os
domy_os's Avatar
Postovi: 18,857
A da obojica probate NetMeeting? Start > Run > conf > OK, pratite upute na ekranu i povežite se direktno preko IP adrese pa javite kako radi u tom programu.
RAM: 2 x 16 GB DDR4-3200
WLAN: Intel Wi-Fi 6 AX201
LCD monitor: AOC AG493UCX
SB: Mackie Onyx Producer 2x2
Speakers: 2 x JBL LSR305
MFP: Canon Pixma MP240
