Staro 09.01.2009., 18:08   #1
panisher20
panisher20's Avatar
Postovi: 939
Nvidia Forceware 181.20
http://www.itx.ba/index.php?option=c...=8818&Itemid=1
Možete skinuti drajver i pogledati prilično dugu listu poboljšanja
http://www.nvidia.com/object/winxp_181.20_whql.html
panisher20 je offline   Reply With Quote
Staro 09.01.2009., 18:50   #2
kripton
Cars & Tunning
kripton's Avatar
Lokacija: Vukovar - Rijeka
Postovi: 536
ili jednostavno na nvidiinoj stranici.
NovA Squadron
kripton je offline   Reply With Quote
Staro 09.01.2009., 18:52   #3
DraŽ
DraŽ's Avatar
Lokacija: Petrinja
Postovi: 904
Ako tako nastave podizat performanse u igrama, sa 8500gt cu igrat crysis na high LOL
Zen5 PCIvy bridge Notebook
CPU: AMD Ryzen 7 9700x, CO per Core, CS -20 (Mid, High, Max)
COOLER: Arctic Cooling Liquid Freezer III 420 A-RGB
MBO: MSI Tomahawk X870
RAM: Corsair Vengeance DDR5 32GB, 6000MHz CL28
GPU: MSI SuprimX Nvidia GeForce RTX 3070
NVM1: Samsung Evo 970 2TB
HDD1: WD Red 4TB, WD40EFRX
HDD2: WD Blue 6TB, WD60EZRZ
HDD3: WD Blue 6TB, WD60EZRZ
PSU: Corsair RMx 850W, ATX3.1
CASE: Fractal Meshify 2 XL
VENTS: 4x Arctic Cooling P14 PWM PST A-RGB
OS: Win 11 Pro, 64-bit
MONITOR: AOC Q3279VWFD8 - 32", IPS, 2560x1440
TV: LG 7450
MOUSE: Logitech MX Master 3
KEYBOARD: Logitech MX Keys
GAMEPAD: XBOX One
HEADPHONES: Sennheiser HD560s
DELL Inspiron 15R, 5520
CPU: Intel Core i7 3632QM, 2.20Ghz, turbo 3.20GHz
RAM: DDR3, 6GB (4GB + 2GB), 1600Mhz CL11
GPU: AMD Radeon 7670, Intel HD4000
SSD: Samsung EVO 850, 250GB
SCREEN: 15,6 inch LCD, 1366x768
OS: Ubuntu 24.04, 64-bit
DraŽ je offline   Reply With Quote
Staro 09.01.2009., 20:51   #4
zeko750
zeko750's Avatar
Postovi: 56
driver ti je super...
žalim šta sa ga instalirao jer mi je poje(beep) cijeli komp, sve se srušilo tako da sam Vistu morao ponovo stavljati.
prvo u control panelu nije bilo niti jedne ikone, drivere nisam mogao deinstalirati nego jednostavno napraviti FORMAT C:
hvala na ničem
zeko750 je offline   Reply With Quote
Staro 09.01.2009., 20:57   #5
Blue_Fatal1ty
Blue_Fatal1ty's Avatar
Lokacija: Čazma
Postovi: 1,728
ja baš ne vidim razlog da skinem te drivere...
Staro 09.01.2009., 21:33   #6
bluefluid
bluefluid's Avatar
Lokacija: VG
Postovi: 1,760
kako ne? pa sta jos nemas gtx 285 il 295?
Exciting New Features:
Added support for GeForce GTX 295 and GeForce GTX 285
Enables NVIDIA SLI technology on SLI-certified Intel X58-based motherboards with all SLI-certified GPUs.
Enables NVIDIA PhysX acceleration on a dedicated GeForce graphics card. Use one card for graphics and dedicate a different card for PhysX processing for game-changing physical effects. Learn more here. (Note: GPU PhysX is supported on all GeForce 8-series, 9-series and 200-series GPUs with a minimum of 256MB dedicated graphics memory. This driver package automatically installs PhysX System Software version 8.10.13).
Supports GeForce Plus Power Pack #2. Download these free PhysX and CUDA applications now!
Added support for the new NVIDIA CUDA Video Encoder with H.264 optimization
Boosts performance in numerous 3D applications. The following are some examples of improvements measured with Release 180 drivers vs. Release 178 drivers (results will vary depending on your GPU, system configuration, and game settings):
Up to 10% performance increase in 3DMark Vantage (performance preset)
Up to 13% performance increase in Assassin's Creed
Up to 13% performance increase in BioShock
Up to 15% performance increase in Company of Heroes: Opposing Fronts
Up to 10% performance increase in Crysis Warhead
Up to 25% performance increase in Devil May Cry 4
Up to 38% performance increase in Far Cry 2
Up to 18% performance increase in Race Driver: GRID
Up to 80% performance increase in Lost Planet: Colonies
Up to 18% performance increase in World of Conflict
sve sto je bolje vrijedno je isprobavanja, sto ne?
odoh sad isprobati fc2 bash da vidim dal ce bit koji frejm vise
@zeko750, osobno sam ih install najnormalnije, ne znam zasto brijes covjeku zbog svojih problema?
Staro 09.01.2009., 21:45   #7
demetrius
demetrius's Avatar
Lokacija: rijeka
Postovi: 3,875
Autor DraŽ Pregled postova
,to piše i na mojima 177.92 znači do 181.20 je prošlo par serija drivera,znači imaš 50% više fps-a u igrama,nego zašto meni baci baca plavi ekran kad hoću stavit ne ove nego 180.48??recimo da ne deinstaliram stare nego ih samo gazim novima što sam i inače radio an bivšoj agp kartici,pci drugačije funkcionira.
Staro 09.01.2009., 22:17   #8
ante2
ante2's Avatar
Postovi: 1,313
Autor demetrius Pregled postova
molim te reci mi da se zezas kad kazes da ne napravis unintal drivera (za grafu) prije nego stavis nove
ps-makni i drivere za fiziku prije dizanj anovih drivera jer se znaju doticni isto potuc
MSI Z77 MPower
Intel i5 3570K @4,2GHz, NOCTUA NH-U12S
Gigabyte GTX 1070
DDR3 16GB (4x4GB) 1600Hz Corsair Vengeance
Carbide Series Air 540, Corsair RM750i
CREATIVE LABS X-Fi Titanium-Kingston HyperX Cloud
DELL U2515H
Synology DS413
ante2 je offline   Reply With Quote
Staro 09.01.2009., 22:21   #9
ante2
ante2's Avatar
Postovi: 1,313
bas bi bio stos da se zeznu pa da greskom ospsobe divere da rade SLI na starijim intel chipsete koji kao podrzavaju samo ATI crossfire
u je bi skocila porodaj maticnih sa doticnim chipsetima
MSI Z77 MPower
Gigabyte GTX 1070
DELL U2515H
Synology DS413
Staro 09.01.2009., 23:09   #10
MAXx
Čupavac
MAXx's Avatar
Postovi: 261
Joj, a baš sam jučer instalirao 180.48 na svježu Vistu
Science cannot be stopped. Man will gather knowledge no matter what the consequences – and we cannot predict what they will be. - Linus Pauling
MAXx je offline   Reply With Quote
Staro 10.01.2009., 00:19   #11
panisher20
panisher20's Avatar
Postovi: 939
Autor zeko750 Pregled postova
hvala na ničem
cuj ti lika, ja sam stavio drivere ak neko oce skinuti nek si skine, ima dosta poboljšanja u igrama, nova tehnlogija CUDA sve ti gore lijepo pise ne vidim u cemu je problem
Staro 10.01.2009., 01:14   #12
panisher20
panisher20's Avatar
Postovi: 939
evo ja ih instaliro sve super radi, pokrenuo FR2 i dobio 4-5FPS-a vise
Staro 10.01.2009., 02:14   #13
DraŽ
DraŽ's Avatar
Lokacija: Petrinja
Postovi: 904
E da 180.48 nepodrzava 8500gt, ali ovi 180.21 podrzavaju.
TV: LG 7450
GAMEPAD: XBOX One
Staro 10.01.2009., 13:58   #14
Pizz
Registered Abuser
Pizz's Avatar
Lokacija: Velika Gorica \ ZG
Postovi: 747
nemadu ambient occlusion, heh
Pizz je offline   Reply With Quote
Staro 10.01.2009., 14:20   #15
Thoroughbred B
Thoroughbred B's Avatar
Datum registracije: Apr 2003
Lokacija: RI
Postovi: 4,918
hvala na ničem
da nisi ti uspio instalirat driver za xp na vistu
i btw...nije to njegov driver.
Meni radi super,Vista x64
Staro 10.01.2009., 17:48   #16
glama
Lokacija: bih
Postovi: 32
Instalirani i sve ok nikakvih problema nema malo poboljšanja ima u FC2
glama je offline   Reply With Quote
Staro 10.01.2009., 17:48   #17
panisher20
panisher20's Avatar
Postovi: 939
Autor Thoroughbred B Pregled postova
i to sta kazes 100% je instaliro drivere xp na vistu heheheheh
Staro 10.01.2009., 17:50   #18
Blue_Fatal1ty
Lokacija: Čazma
Postovi: 1,728
Evo i ja sam inst te drivere i sve radi oke...
Staro 10.01.2009., 18:28   #19
ALiEN17
ALiEN17's Avatar
Lokacija: Histria
Postovi: 1,260
Šta je ovo? Neki dan izašli i ja instalirao 185.* drajvere, a sada izađu 181.* Šta je to?
Staro 11.01.2009., 02:45   #20
danc00
Why so serious
danc00's Avatar
Postovi: 3,415
JEl ima kakvih poboljšanja kaj se GTA 4 tiče? Možda koji FPS više, niš ne piše... da ne stavljam bezveze
danc00 je offline   Reply With Quote
