Staro 04.10.2004., 21:41   #1
Jelc
Super Moderators
Datum registracije: May 2002
Postovi: 17,485
FFDShow MPEG-4 Video Decoder 20041003
Changes from FFDShow 20040828 to FFDShow 20041003 :
- updated libavcodec, somewhat smaller libavcodec_dec.dll
- updated x264
- added (and disabled) encrypted dvd video support
- use extradata provided by nero splitter for mp4v
- very incomplete support for subtitles in AVI
- very crude support for matroska UTF-8 subtitles
- attempt to support ogm subtitles
- updated DPLII coefficients
- Y800 colorformat support
- working on ogm subtitles
- fixed crash with vobsub subtitles not containng all subtitle streams
- installer autodetects dscaler folder
- don't unregister ffdshow before installing - looses merit information
See full list of changes here!
Changes from FFDSHOW 01-07-2004 SSE2 to FFDSHOW 09-07-2004 SSE2 :
- Luma Offset/Gain fixed
- clear input buffer when decoding audio using libavcodec
- better keyboard handling in codecs and keys pages
- fixed aac decoding
- imported faad2 library
- working on liba52 integration
- better ac3 support
- working on audio part 2
- multithreaded encoding using libavcodec
- split long subtitle lines
* Only for CPUs with support for SSE2 (Streaming SIMD Extensions 2) instructions.
http://www.free-codecs.com/download_soft.php?d=46&s=50
Staro 05.10.2004., 20:31   #2
tor
Administrator
tor's Avatar
Lokacija: Sesvete
Postovi: 15,963
Da baš ga isprobao jučer. Dosta toga su sredili ali kao i uvijek ima problema s određenim verzijama Xvid codeca. AC3 i dalje nije sređen kako treba (svako tko je probao pustit AC3 zvuk kroz FF zna o čem pričam (iritantno krčanje i ubrzan zvuk). MP3 zvuk s druge strane isto tako zna zasrat pa mu ručno moraš naštimati frekvencije i ostala sranja da bi to radilo kako treba. Što se mene tiče nek se okanu filtera za zvuk i nek rađe bace malo truda na video jer im to ide. Oni problem s Xvidom javljaju se samo kod nekih beta relissa tak da nije bad. S filmovima kodiranim Divixom radi savršeno, ima finih opcija za postprocesing, Nic`s metodu za " izglađivanje" loše kodiranih filmova (koja btw radi odlično, razlika je uočljiva JAAAAAKO). Overlay je isto tako jača strana.
Staro 05.10.2004., 22:50   #3
Costa
Costa's Avatar
Datum registracije: Aug 2003
Postovi: 3,193
Prvo sto napravim nakon instalacije je da disableam podrsku za zvuk jer fakat je usrana. Cak mi se znao i srusiti player kod premotavanja. Al video je prva liga.
BTW posebno mi se svidja opcija "Add tray icon menu to player's stream/languages menu". Super za brzo ukljucivanje/iskljucivanje filtera.
Staro 06.10.2004., 18:29   #4
tor
Administrator
tor's Avatar
Lokacija: Sesvete
Postovi: 15,963
Je, zgodni opšn.
