Staro 19.09.2008., 15:16   #1
sasuke_the_king
sasuke_the_king's Avatar
Lokacija: istra
Postovi: 1,016
partition magic - status BAD
danas sam trebao reparticionirati jedan od diskova, i instaliram partition magic na server, i izbaci mi ovu sliku na jednom od diskova:
disk radi potpuno normalno, mogu pristupit svim podacima gore, ništa mu ne fali.
mi netko zna reć zašto piše da je BAD i zašto ne vidi popunjenost diska i particije na njemu? inače disk je pun oko 90%.
ostalim diskovima ništa ne fali.
smart ne izbacuje nikakav error.
sasuke_the_king je offline   Reply With Quote
Staro 20.09.2008., 18:32   #2
DjedMraz
Chile
DjedMraz's Avatar
Datum registracije: Apr 2008
Lokacija: Destination Unknown
Postovi: 370
pa uradi test na hdd za bad sectors.. a jesi probao reparticionirati unatoc tome? mozda je samo neki bug..
DjedMraz je offline   Reply With Quote
Staro 20.09.2008., 20:24   #3
sasuke_the_king
Lokacija: istra
Postovi: 1,016
tom disku ne mogu ništa. samo mi format nudi.
evo šta mi partitioninfo kaže:
Code:
Disk Geometry Information for Disk 3:    30401 Cylinders,  255 Heads,  63 Sectors/Track
System              PartSect  # Boot BCyl Head Sect  FS    ECyl Head Sect    StartSect     NumSects
                           0  0  00     0    1    1  07    1023  254   63           63  156,312,387
Info: End C,H,S values were large drive placeholders.
  Actual values are:
        0  0  00      0    1    1  07   9729  254   63        63 156312387
                           0  1  00  1023   47   31  07    1023  254   63  156,299,376  332,092,689
Info: Begin C,H,S values were large drive placeholders.
  Actual values are:
        0  1  00   9729   47   31  07  30400  254   63 156299376 332092689
Error #105: Partition didn't begin on head boundary.
  ucBeginHead expected to be 0 or 1, not 47.
Error #106: Partition didn't begin on head boundary.
  ucBeginSector expected to be 1, not 31.
Staro 20.09.2008., 20:37   #4
thopok
Lokacija: Splity
Postovi: 3,003
How do I handle errors 100-199?
If PartitionMagic does not automatically fix these errors, a sure way to resolve these errors it to do the following:
1 Back up all the data that is in the defective partitions.
2 Delete the defective partitions.
3 Create new partitions.
4 Restore all your data to the new partitions.
PartitionMagic 8.0 FAQ
To je "server"?
Staro 20.09.2008., 22:14   #5
sasuke_the_king
Lokacija: istra
Postovi: 1,016
delete partitions, hahahaha, isti drek kao format da ne bih slučajno.
i da, to je server moj kućni server, kojem pristupaju svi kompjuteri doma i ftp server za ekipu sa faksa. uostalom ne mora "server" bit server da bi ga netko tako zvao.
Staro 20.09.2008., 22:57   #6
thopok
Lokacija: Splity
Postovi: 3,003
Ako bi i bio, onda zbog Does PartitionMagic support servers? u gornjem FAQ-u…
Staro 20.09.2008., 23:31   #7
DjedMraz
Chile
DjedMraz's Avatar
Postovi: 370
A zasto onda te podatke sa diska ne prebacis negdje pa disk fino formatiras pa onda vidi hoce li opet jevljati isti problem?
Staro 20.09.2008., 23:35   #8
sasuke_the_king
Lokacija: istra
Postovi: 1,016
screw that. ovo su čisti win xp sa sheranim diskovima.
u svakom slučaju tnx za ono objašnjenje o errorima, ali disk će se načekat neko vrijeme da ga formatiram.
edit: @djedmraz - zato šta bi mi pod a: trebalo 250 gb slobodnog prostora kojeg nemam, pod b) transfer 500gb preko mreže bi trajao između 18-20 sati.
Staro 20.09.2008., 23:40   #9
DjedMraz
Chile
DjedMraz's Avatar
Postovi: 370
hm.. onda brisi partition magic! dok njega nisi istalirao sve je bilo ured
