Staro 24.07.2008., 18:01   #1
Jurrasic
Lokacija: Zadrkovec
Postovi: 4
Nero problem
Windows XP 5.1
WinAspi: -
ahead WinASPI: File 'C:\Program Files\Nero\Nero 7\Core\Wnaspi32.dll': Ver=2.0.1.74, size=164112 bytes, created 2.11.2004 13:54:32
NT-SPTI used
Nero Version: 7.5.1.1
Internal Version: 7, 5, 1, 1
Recorder: <PHILIPS SPD2412T> Version: P1.5 - HA 1 TA 0 - 7.5.1.1
Adapter driver: <IDE> HA 1
Drive buffer : 2048kB
Bus Type : default (0) -> ATAPI, detected: ?
CD-ROM: <HL-DT-ST DVD-ROM GDR8161B>Version: 0042 - HA 1 TA 1 - 7.5.1.1
=== Scsi-Device-Map ===
DiskPeripheral : ST340016A atapi Port 0 ID 0 DMA: On
DiskPeripheral : WDC WD2500JB-00REA0 atapi Port 0 ID 1 DMA: On
CdRomPeripheral : PHILIPS SPD2412T atapi Port 1 ID 0 DMA: On
CdRomPeripheral : HL-DT-ST DVD-ROM GDR8161B atapi Port 1 ID 1 DMA: On
=== CDRom-Device-Map ===
PHILIPS SPD2412T E: CDRom0
HL-DT-ST DVD-ROM GDR8161B G: CDRom1
AutoRun : 1
Excluded drive IDs:
WriteBufferSize: 83886080 (0) Byte
BUFE : 0
Physical memory : 639MB (654836kB)
Free physical memory: 32MB (33276kB)
Memory in use : 94 %
Uncached PFiles: 0x0
Use Inquiry : 1
Global Bus Type: default (0)
Check supported media : Disabled (0)
24.7.2008
ISO compilation
17:35:00 #1 Text 0 File Isodoc.cpp, Line 6510
Iso document burn settings
Determine maximum speed : FALSE
Simulate : FALSE
Write : TRUE
Finalize CD : FALSE
Multisession : TRUE
Multisession type: : Start multisession
Burning mode : DAO
Mode : 1
ISO Level : 1 (Max. of 11 = 8 + 3 char)
Character set : ISO 9660
Joliet : FALSE
Allow pathdepth more than 8 directories : TRUE
Allow more than 255 characters in path : TRUE
Write ISO9660 ;1 file extensions : TRUE
17:35:00 #2 Text 0 File ThreadedTransfer.cpp, Line 540
ReadBuffer-Pipe got 81920KB of Memory
17:35:00 #3 Text 0 File Reader.cpp, Line 126
Reader running
17:35:00 #4 Text 0 File Writer.cpp, Line 123
Writer E: PHILIPS SPD2412T running
17:35:00 #5 ISO9660GEN -11 File Geniso.cpp, Line 3313
First writeable address = 0 (0x00000000)
17:35:00 #6 Text 0 File Burncd.cpp, Line 3443
Turn on Disc-At-Once, using DVD media
17:35:01 #7 Text 0 File DlgWaitCD.cpp, Line 300
Last possible write address on media: 2295103 (510:01.28, 4482MB)
Last address to be written: 1790591 (397:54.41, 3497MB)
17:35:01 #8 Text 0 File DlgWaitCD.cpp, Line 312
Write in overburning mode: NO (enabled: CD)
17:35:01 #9 Text 0 File DlgWaitCD.cpp, Line 2851
Recorder: PHILIPS SPD2412T, Media type: DVD+R
Disc Manufacturer ID: RITEK, Media Type ID: R03, Product revision number: 2
Disc Application Code: 0, Extended Information Indicators: 3
17:35:01 #10 Text 0 File DlgWaitCD.cpp, Line 484
>>> Protocol of DlgWaitCD activities: <<<
17:35:01 #11 Text 0 File ThreadedTransferInterface.cpp, Line 863
Setup items (after recorder preparation)
0: TRM_DATA_MODE1 ()
2 indices, index0 (150) not provided
original disc pos #0 + 1790592 (1790592) = #1790592/397:54.42
relocatable, disc pos for caching/writing not required/ required, no patch infos
-> TRM_DATA_MODE1, 2048, config 0, wanted index0 0 blocks, length 1790592 blocks [E: PHILIPS SPD2412T]
17:35:01 #12 Text 0 File ThreadedTransferInterface.cpp, Line 1079
Prepare recorder [E: PHILIPS SPD2412T] for write in CUE-sheet-DAO
DAO infos:
MCN: ""
TOCType: 0x00; Session Closed, disc not fixated
Tracks 1 to 1: Idx 0 Idx 1 Next Trk
1: TRM_DATA_MODE1, 2048/0x00, FilePos 0 0 3667132416, ISRC ""
DAO layout:
___Start_|____Track_|_Idx_|_CtrlAdr_|_____Size_|______NWA_|_RecDep__________
0 | lead-in | 0 | 0x41 | 0 | 0 | 0x00
0 | 1 | 0 | 0x41 | 1790592 | 0 | 0x00
0 | 1 | 1 | 0x41 | 1790592 | 0 | 0x00
1790592 | lead-out | 1 | 0x41 | 0 | 0 | 0x00
17:35:01 #13 Text 0 File SCSIPassThrough.cpp, Line 39
SPTILockVolume - completed successfully for FCTL_LOCK_VOLUME
17:35:01 #14 Phase 24 File dlgbrnst.cpp, Line 1730
Caching of files started
17:35:01 #15 Text 0 File Burncd.cpp, Line 4274
Cache writing successful.
17:35:01 #16 Phase 25 File dlgbrnst.cpp, Line 1730
Caching of files completed
17:35:01 #17 Phase 36 File dlgbrnst.cpp, Line 1730
Burn process started at 6x (8.310 KB/s)
17:35:01 #18 Text 0 File ThreadedTransferInterface.cpp, Line 2746
Verifying disc position of item 0 (relocatable, disc pos, no patch infos, orig at #0): write at #0
17:35:01 #19 Text 0 File Cdrdrv.cpp, Line 9215
---- DVD Structure: Physical Format Information (00h) ----
Media Type: 0, Layer: 0, Address: 0 (0 h), AGID: 0; Length: 2050
Book Type: DVD+R (10), Part Version: 1.0x (1)
Disc Size: 120 mm, Maximum Rate: <not specified> (F h)
Number of Layers: 1, Track Path: Parallel Track Path (PTP), Layer Type: recordable
Linear Density: 0,267 um/bit, Track Density: 0,74 um/track
Starting Physical Sector Number of Data Area: 30000 h (DVD-ROM, DVD-R/-RW, DVD+R/+RW)
End Physical Sector Number of Data Area: 26053F h
End Sector Number in Layer 0: 0 h (LBN: FFFD0000 h, 4193920 MB)
Data in Burst Cutting Area (BCA) does not exist
Disc Application Code: 0 / 0 h
Extended Information indicators: 3 h
Disc Manufacturer ID: RITEK...
Media type ID: R03
Number of Physical format information bytes in use in ADIP up to byte 63: 56
Media Specific [16..63]:
00 00 03 52 49 54 45 4B - 00 00 00 52 30 33 02 38 ...RITEK...R03.8
23 54 00 00 00 00 00 00 - 00 00 00 00 00 00 00 00 #T..............
00 00 00 00 00 00 00 00 - 00 00 00 00 00 00 00 00 ................
17:35:01 #20 SPTI -1065 File SCSIPassThrough.cpp, Line 291
E: CdRom0: SCSIStatus(x02) WinError(0) NeroError(-1065)
Sense Key: 0x05 (KEY_ILLEGAL_REQUEST)
Sense Code: 0x20
Sense Qual: 0x00
CDB Data: 0xDF 00 0F 00 00 01 00 00 00 00 00 00
Sense Area: 0x70 00 05 00 00 00 00 0A 00 00 00 00 20
Buffer x06350600: Len x80
17:35:01 #21 SPTI -1065 File SCSIPassThrough.cpp, Line 291
Sense Code: 0x20
Sense Qual: 0x00
17:35:01 #22 Text 0 File DVDPlusRW.cpp, Line 662
Start write address at LBA 0
DVD high compatibility mode: No
17:35:33 #23 SPTI -1106 File SCSIPassThrough.cpp, Line 291
E: CdRom0: SCSIStatus(x02) WinError(0) NeroError(-1106)
Sense Key: 0x03 (KEY_MEDIUM_ERROR)
Sense Code: 0x73
Sense Qual: 0x03
CDB Data: 0x2A 00 00 00 00 00 00 00 20 00 00 00
Sense Area: 0x71 00 03 00 00 00 00 0A 00 00 00 00 73 03
Buffer x0c8c0000: Len x10000
0x00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
17:35:33 #24 CDR -1106 File Writer.cpp, Line 312
Power calibration error
E: PHILIPS SPD2412T
17:35:33 #25 Text 0 File ThreadedTransfer.cpp, Line 229
all writers idle, stopping conversion
17:35:33 #26 Text 0 File ThreadedTransfer.cpp, Line 223
conversion idle, stopping reader
17:35:34 #27 SPTI -1046 File SCSIPassThrough.cpp, Line 291
E: CdRom0: SCSIStatus(x02) WinError(0) NeroError(-1046)
Sense Code: 0x30
Sense Qual: 0x06
CDB Data: 0x5B 01 02 00 00 00 00 00 00 00 00 00
Sense Area: 0x70 00 05 00 00 00 00 0A 00 00 00 00 30 06
17:35:34 #28 SPTI -1065 File SCSIPassThrough.cpp, Line 291
Sense Code: 0x20
Sense Qual: 0x00
17:35:34 #29 SPTI -1065 File SCSIPassThrough.cpp, Line 291
Sense Code: 0x20
Sense Qual: 0x00
17:35:34 #30 CDR -1046 File WriterStatus.cpp, Line 167
Illegal disc
E: PHILIPS SPD2412T
17:35:34 #31 TRANSFER -24 File WriterStatus.cpp, Line 167
Could not perform end of Disc-at-once
17:35:34 #32 Phase 38 File dlgbrnst.cpp, Line 1730
Burn process failed at 6x (8.310 KB/s)
Existing drivers:
File 'Drivers\CDRALW2K.SYS': Ver=8.0.0.212 , size=2560 bytes, created 19.5.2006 23:16:24
File 'Drivers\PXHELP20.SYS': Ver=3.00.56a, size=43528 bytes, created 21.2.2008 04:05:38 (Prassi/Veritas driver for win 2K)
Registry Keys:
HKLM\Software\Microsoft\Windows NT\CurrentVersion\WinLogon\AllocateCDROMs : 0 (Security Option)
Unaprijed hvala
Zdravo
Da nebi bio odgovor koristi opciju "traži" u obranu moram reči da sam pokušal već puno opcija ali jednostavno ne radi.
Pržilica ( PHILIPS SPD2412T) mi neće pržit DVD (Traxdata ValuePack +R - oni zeleni, pokušao sam i sa drugima).
Firmware sam updejtal na 1.5 i mijenjal brzine (8x, 6x, 4x) ali ne pomaže
Uglavnom, evo:
Windows XP 5.1
WinAspi: -
NT-SPTI used
AutoRun : 1
Excluded drive IDs:
BUFE : 0
Use Inquiry : 1
24.7.2008
ISO compilation
Simulate : FALSE
Write : TRUE
Finalize CD : FALSE
Multisession : TRUE
Burning mode : DAO
Mode : 1
Joliet : FALSE
Reader running
DAO infos:
MCN: ""
DAO layout:
Media type ID: R03
Sense Code: 0x20
Sense Qual: 0x00
Sense Code: 0x20
Sense Qual: 0x00
Sense Code: 0x73
Sense Qual: 0x03
E: PHILIPS SPD2412T
Sense Code: 0x30
Sense Qual: 0x06
Sense Code: 0x20
Sense Qual: 0x00
Sense Code: 0x20
Sense Qual: 0x00
Illegal disc
E: PHILIPS SPD2412T
Existing drivers:
Registry Keys:
Unaprijed hvala
Jurrasic je offline   Reply With Quote
Staro 24.07.2008., 19:21   #2
yedwy
Beskorisna bitanga...
yedwy's Avatar
Lokacija: Sesvete (Zg)
Postovi: 6,956
Probao neke druge medije?
Have a nice day...
Staro 24.07.2008., 20:25   #3
Joke
N00B
Joke's Avatar
Postovi: 3,886
@Jurrasic je li ti imas isto problem sa illegal disc?Vidim da si postao i u toj temi to se obicno javlja ako prza ne moze prepoznati medij ili kad je pri kraju..
IE6
Linux is Not Windows
Staro 25.07.2008., 10:06   #4
Jurrasic
Lokacija: Zadrkovec
Postovi: 4
Budem danas kupil malo više različitih DVD-a pa bumo vidli jel bude kojeg prepoznal.
Pod kaj misliš "kad je pri kraju", na pržilicu?
Prza je relativno nova, ni godinu dana stara.
