Staro 05.07.2008., 18:29   #1
Kimi
Kimi's Avatar
Postovi: 652
kasda router mod problem
Pročitao sam sticky o tome kako namjestiti dva ili više kompa tako su neovisno spojeni na internet (mogu biti istovremeno spojeni s jednim usernameom i pw).Eh sad problem je kad je jedan komp na internetu,drugi stoji na onome da vertificira username i pw,te enakon 10sec kaže da se nemože spjiti na internet.Evo ss kako je podešena local area conection na jednom od kompova(tcp/ip)http://img512.imageshack.us/my.php?i...ak6.jpg.Please help
Problem riješen,naime u stickyu ne piše
Autor Nikky Pregled postova
U Postavi IP Linkača na 192.168.1.2, kompovima fiksni IP u nizu.
Gateway je IP od Linkača, također unesi DNS - ove u router i kompove.
Samo spajanje napravi tako da Linkača (WAN) spojiš na LAN1 starog routera.
Ili nije;naime jednini način da budu isodobno na internetu jest:dok je A komp na netu,na B kompu promjenim zadnju znamenku ip adrese i tada mogu s B na net.meka druga riješenja,tj. koje ip i sl. upisati.thx
Zadnje izmijenjeno od: Kimi. 05.07.2008. u 18:56.
Kimi je offline   Reply With Quote
Staro 06.07.2008., 18:14   #2
Kimi
Kimi's Avatar
Postovi: 652
Anyone???
Staro 06.07.2008., 18:48   #3
thopok
Lokacija: Splity
Postovi: 3,003
After routing settings are finished, if you want to enable DHCP service, then please set IP address of PC network card to obtain an IP address automatically. If you don’t want to enable DHCP service, then you need to assign an IP address for your PC network card and set DNS address to the address provided by operator (If operator doesn’t provide the DNS address, then the address is set to 192.168.1.1 that is the address of ROUTER).
A kad koristiš PPPoE konekciju kreiranu u Windows-ima za koju nema potrebe u routing mode-u.
1. Click Start, and then click Control Panel.
2. Click Network and Internet Connections.
3. Click Network Connections.
4. Right-click Local Area Connection, and then click Properties.
5. Click the General tab, click Internet Protocol (TCP/IP) in the This connection uses the following items list, and then click Properties.
6. In the Internet Protocol (TCP/IP) Properties dialog box, click Obtain an IP address automatically (if it is not already selected), and then click OK.
Zadnje izmijenjeno od: thopok. 06.07.2008. u 19:53.
Staro 06.07.2008., 19:58   #4
kasko
kasko's Avatar
Lokacija: Ivanić_Grad
Postovi: 2,013
ovako prvo unesi one postavke u router, moraš imati samo jedan redak u advanced setupu pod WAN moraš imati ovak jedan redak onda odi na Edit i tamo stišći next i samo upiši svoj username i password, na kraju reboot modema. kada je gotov reboot modema ( moraju svijetlit Lan1,Power,Dsl,Act ponekad traje i po par minuta dok se ne popale sve lampice ) ugasi ga na gumb i ne pali dok ne podesiš ovo na mrežnoj kartici.
Properties mrežne kartice na 1 kompu stavi ovako
IP: 192.168.1.3
Subnet: 255.255.255.0
Default Gateway: 192.168.1.1
DNS Primary: 192.168.1.1
Alternate DNS: prazno
Na 2 kompu isto tako samo
IP:192.168.1.3
nema potrebe za ikakvom konekcijom...
Staro 10.07.2008., 14:57   #5
Kimi
Kimi's Avatar
Postovi: 652
Meni je pod service pisalo ppp... a ne pppoe... i sad kad sam stavio iste ip adrese windowsi javljau error zbog toga i internet radi na samo 1 kompu
Prolem riješen jednostavnim upisivanjem alternate DNS na jedom kompu.Može lock
Zadnje izmijenjeno od: Kimi. 10.07.2008. u 15:28.
Staro 10.07.2008., 16:00   #6
thopok
Lokacija: Splity
Postovi: 3,003
IP address conflict
Each computer on the LAN must have a unique IP address. If more than one computer has the same IP address, an IP conflict occurs, and one of the network adapters turns off until the conflict is resolved. To resolve this conflict, configure the client computer to automatically obtain an IP address, or assign it a unique IP address.
IP: 192.168.1.3
IP:192.168.1.3
Staro 10.07.2008., 16:01   #7
Postovi: 23,585
Kolega se poviše zanio sa copy - paste. Ako je na 1. kompu IP:192.168.1.3 onda na 2. treba IP:192.168.1.4 (nesmiju biti isti).
U alternate DNS unesi DNS server svog ISP - a (vidi DNS by ISP, Adsl Bibliju).
Staro 10.07.2008., 16:56   #8
Kimi
Kimi's Avatar
Postovi: 652
Tako sam i stavio,taj zadnji broj različit,a alternate DNS sam stavio samo na jednom i sve radi tako da neću više dirati.Thx Nikky na helpu.
